8
7
4
5
6
1
2
3
REVISIONS
14.83±0.10 .584±.004
F
1.96±0.10 .077±.004
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
2406
08/01/2011
GC
B
2477
12/08/2011
LH
C
2604
INITIAL RELEASE
UPDATE 3 VIEWS, TOLERANCES TABLE AND
SCHEMATIC TD- 2 (WAS RD- 2)
UPDATE NOTE 1 SHELL MATERIAL BRASS C2680H
(WAS STAINLESS STEEL)
05/31/2012
LH
F
1.40±0.10 .055±.004
13.70±0.15 .539±.006
+0.10
+.004
1.65
.065
0.00
- .000
3.30±0.20 .130±.008
NOTES:
1. MATERIAL:
Plastic Housing:
RJ Housing: PBT, UL94V-0, Black
Transformer Housing: Phenolic, UL94V-0, Black
Terminals:
RJ Contacts: 0.25mm Thickness, Phosphor Bronze C5191H
Shields:
Shell: 0.2mm Thickness, Brass C2680H
PCB: FR-4 Two layer PCB
2. PLATING:
RJ Contact: .000050" min. Nickel Underplate,
.000006" Selective Gold.
Shield Grounding Legs: Pre-soldering
3. RoHS Compliance per EU Directive 2002/95/EC
4. Transmitter & Receiver Filter:
DETAIL A
DETAIL A
E
16.00±0.50 .630±.020
3.20±0.50 .126±.020
4.55±0.30 .179±.012
3.00±0.10 .118±.004
18.35±0.50 .722±.020
D
Insertion Loss
(dB Max)
PRE-SOLDER
1.50±0.10 .059±.004
5.
6.
7.
8.
9.
0.46±0.10 .018±.004
C
Return Loss at 100:
(dB Max)
1~30MHz
30~60MHz
60~80MHz
-1.0
-18
-16
-12
Common Mode Rejection @ 1~100 MHz: -30dB MIN
Cross Talk @ 1~100 MHz: -35dB MIN
Inductance @ 100KHz/ 0.1V,8mA DC BIAS: 350mH MIN
HiPot Test: 1500Vrms, 60sec
Operating Temperature Range: 0 C TO +70 C
14.63 .576
11.43 .450
CABLE SIDE
1CT : 1
3.05 [.120]
2 X Ø3.20 [.126]
1 TX+
2 X Ø2.10 [.083]
8.89 [.349]
PCB SIDE
TD- 2
7
2 TX-
B
TCT 3
RD+ 4
3 RX+
1CT : 1
4
RD- 5
5
RCT 6
6 RX-
RECOMMENDED P.C.B LAYOUT
TOLERANCE:±0.05[.002]
DRAWN
4x75 :
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN MM[INCHES]
Pb
A
PIN 8
2KV 1000pF
7
TOLERANCES:
ANGULAR:
RoHS COMPLIANT
6
2
B
7 X 1.27=8.89 [.349]
8
PIN 7
1
8
8 X Ø0.90 [.035]
7
8
C
16.00 [.629]
SCHEMATIC:
TD+ 1
D
1~100MHz
3.20±0.50 .126±.020
2.00±0.20 .079±.008
E
5
4
DECIMALS:
.X= .4 [.016]
.XX= .25 [.010]
.XXX= .130 [.0051]
DATE
NAME
08/01/2011
GC
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
SIZE
C
3
A
VERTICAL RJ45 10/100 BASE-T
CAGE CODE
54453
SMJ100-T88I-DS-11
DWG. NO.
REV
C
11819
SCALE: 2:1
SHEET 1 OF 1
2
1
FILE NAME: Z:\ECO PENDING\2604, TAIWAN PARTS RECEIVED ORDER\11819, SMJ100-T88I-DS-11 PRINT: 6/28/2012
很抱歉,暂时无法提供与“SMJ100-T88I-DS-11”相匹配的价格&库存,您可以联系我们找货
