EHRJ45P6
EHRJ45P6
    SWITCHCRAFT
    EHRJ45P6
EHRJ45P6 数据手册
8 7 F 6 CAT5e ADAPTER UNSHIELDED 5 CAT5e ADAPTER SHIELDED RJ45 MOUNTING PLATE EHRJ45P6 CAT6A ADAPTER SHIELDED EHRJ45P6S EHRJ45P6AS EHRJ45P6A SHIELDED F RJ45 MOUNTING PLATE RJ45 MOUNTING PLATE SHIELDED UNSHIELDED 0.58 14.6 0.58 14.6 0.58 14.6 1 CAT6A ADAPTER UNSHIELDED RJ45 MOUNTING PLATE UNSHIELDED SHIELDED 2 CAT6 ADAPTER SHIELDED RJ45 MOUNTING PLATE EHRJ45P5ES UNSHIELDED 3 CAT6 ADAPTER UNSHIELDED RJ45 MOUNTING PLATE EHRJ45P5E 4 E E B 1.19 30.1 0.083 2.11 REF 1.18 29.8 1.18 29.8 0.083 2.11 REF D 0.083 2.11 REF 0.138 [3.51] THRU 0.230 [5.84] X 82 (2) PLACES REF 1.22 31.0 1.22 31.0 0.63 16.1 C D 0.138 [3.51] THRU 0.230 [5.84] X 82 (2) PLACES REF 0.138 [3.51] THRU 0.230 [5.84] X 82 (2) PLACES REF 1.22 31.0 0.64 16.2 0.64 16.2 C 1.02 26.0 1.02 26.0 1.02 26.0 EHRJ45P5E - UNSHIELDED EHRJ45P5ES - SHIELDED (SHOWN) EHRJ45P6 - UNSHIELDED (SHOWN) EHRJ45P6S - SHIELDED EHRJ45P6A - UNSHIELDED (SHOWN) EHRJ45P6AS - SHIELDED D 0.748 19.00 PART NUMBER 0.945 24.00 B 0.945 24.00 NOTES: CAT5e UNSHIELDED EHRJ45P5ES CAT5e SHIELDED EHRJ45P6 CAT6 UNSHIELDED EHRJ45P6S CAT6 SHIELDED D EHRJ45P6A CAT6A UNSHIELDED D EHRJ45P6AS CAT6A SHIELDED B CUSTOMER DRAWING THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. 2. MATERIALS: RJ45 MOUNTING PLATE - THERMOPLASTIC, BLACK RJ45 HOUSING - THERMOPLASTIC, BLACK RJ45 SHIELD - COPPER ALLOY, NICKEL PLATED UNLESS OTHERWISE SPECIFIED 4. WHEN MOUNTING ASSEMBLY, USE A SCREW TORQUE OF 10 INCH-LBS MAXIMUM. 5. THIS PRODUCT IS RoHS COMPLIANT. D 27721 6-21-16 TO TJK - TWO PLACE DECIMALS 0.02 C 27585 10/08/15 PC TJK - THREE PLACE DECIMALS 0.005 [0.13] B 27247 1/24/14 JGK A 26387 5/15/09 RS REV ECO NUMBER DATE REVISIONS 7 6 5 4 BY SIZE WIDTH SPEC No. FIRST USED ON [0.5] TJK BY TJK 7/7/08 JGK DO NOT SCALE DRAWING SolidWorks CAD File C TEMPER A SPEC No. SCALE * NAME LBS/M MATERIAL DATE DRAWN APVD MULT FINISH 1. ALL DIMENSIONS IN INCHES [mm] 3. FOR SCREWS TO BE SHIPPED WITH ASSEMBLY, ADD SUFFIX -PKG TO PART NUMBER. 8 EHRJ45P5E RECOMMENDED PANEL CUT-OUT 1. ADAPTER MEETS: CAT5e: TIA/EIA-568-B.2 STANDARD CAT6: TIA/EIA-568-B.2-1 STANDARD D CAT6A: TIA/ANSI-568-C.2 STANDARD A 0.138 3.51 (2) PLACES RJ45 ADAPTER 1.5:1 CHKD RS 7/28/09 APVD TJK 10/24/09 EH SERIES RJ45 ADAPTER, RoHS SHEET PART No. 1 OF EHRJ45P SERIES 1 REV D
EHRJ45P6 价格&库存
很抱歉,暂时无法提供与“EHRJ45P6”相匹配的价格&库存,您可以联系我们找货
EHRJ45P6
  • 1+251.186261+32.59940
  • 10+213.4997910+27.70838
  • 25+200.1354125+25.97393
  • 50+190.5848350+24.73444
  • 100+181.49419100+23.55464
  • 250+170.14392250+22.08158
  • 500+162.03392500+21.02905
库存:591
