N034-001
N034-001
    TRIPPLITE
    CONNMODCOUPLER8P8CTO8P8C
N034-001 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cisco Serial Console Rollover RJ45 M/F Adapter Highlights ● RJ45 Male to RJ45 Female Rollover Adapter ● Use with Cisco RJ45 Serial ports ● Allows standard Ethernet patch cables to become Cisco Rollover cables MODEL NUMBER: N034-001 System Requirements ● Cisco or other network hardware utilizing RJ45 serial ports that require rolled cables Package Includes ● Description Tripp Lite's Cisco Rollover Adapter can be used to convert any standard Ethernet cable into a serial Rollover cable. The Rollover Adapter eliminates the need for carrying extra cables. Plugs into a RJ45 serial console port on switches and routers, and internally "rolls" the pins so that a straight through Cat5e or Cat6 patch cable can be used. Features ● RJ45 Male to Female Rollover adapter ● Pinning: 1-8, 2-7, 3-6, 4-5, 5-4, 6-3, 7-2, 8-1 ● Allows readily available Cat5e/Cat6 patch cables to be used Specifications OVERVIEW UPC Code 037332185464 Technology Cat5/5e PHYSICAL Color Blue Shipping Dimensions (hwd / in.) 6.00 x 4.50 x 0.50 Shipping Dimensions (hwd / cm) 15.24 x 11.43 x 1.27 Shipping Weight (lbs.) 0.03 Shipping Weight (kg) 0.01 1/2 Cisco Serial Console Rollover RJ45 M/F Adapter 1000 Eaton Boulevard Cleveland, OH 44122 United States CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
N034-001 价格&库存
很抱歉,暂时无法提供与“N034-001”相匹配的价格&库存,您可以联系我们找货
