N235-001-WH-6AD
N235-001-WH-6AD
    TRIPPLITE
    N235-001-WH-6AD
N235-001-WH-6AD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6a Straight-Through Modular In-Line Snap-In Coupler with 90-Degree Down-Angled Port, White (RJ45 F/F) MODEL NUMBER: N235-001-WH-6AD Highlights ● 90° down-angled RJ45 port for easy installation in tight spaces ● 50-µinch gold-plated contacts on RJ45 jacks ● Keystone design for use with standard data wallplate ● Compatible with all Cat6a cables ● Backward compatible with Cat6, Cat5e and Cat5 LANs Package Includes ● White coupler with 90° angled port connects 2 Cat6a cables to provide feed-through patching with standard data wallplates. Ideal for premise wiring, telecommunications, data networking and Ethernet connections. Description Strengthen your high-speed network with Tripp Lite’s N235-001-WH-6AD Cat6a Straight-Through Modular In-Line Snap-In Coupler (F/F). This white coupler connects two Cat6a patch cords to create one longer cable. Its keystone design is perfect for convenient feed-through patching when used with a standard data wallplate (such as Tripp Lite’s N042-001-WH). One RJ45 port is angled down at a 90-degree angle for easy installation in hard-to-reach spaces. Built for ultra-fast performance, this is an ideal coupler when setting up premise wiring, telecommunications, data networking and Ethernet connections. Compatible with all Cat6a cables, the N235-001-WH-6AD’s durable scratch-resistant polycarbonate housing is colored white to blend into any color scheme. This coupler features straight-through wiring and 50-µinch gold-plated contacts designed to resist corrosion. The N235-001-WH-6AD is UL-listed and meets all requirements for EIA/TIA Category 6A compliance. It’s also backward compatible with Cat6, Cat5e and Cat5 LANs. Features Strengthens Your High-Speed Network ● Ideal for premise wiring, telecommunications, data networking and Ethernet connections ● Connects 2 Cat6a patch cables for a longer cable run ● Keystone design for easy snap-in installation in standard data wallplates (such as Tripp Lite’s N042001-WH) ● Compatible with all Cat6a cables ● Backward compatible with Cat6, Cat5e and Cat5 LANs Superior Construction for Superior Performance ● 90° down-angled RJ45 port for easy installation in hard-to-reach spaces ● 50-µinch gold-plated contacts resist corrosion and improve conduction ● Features straight-through wiring ● Durable scratch-resistant polycarbonate housing 1/3 N235-001-WH-6AD Cat6a Straight-Through Modular InLine Snap-In Coupler, White (RJ45 F/F) 1000 Eaton Boulevard Cleveland, OH 44122 United States ● White coloring blends into any color scheme ● UL-listed ● Meets all EIA/TIA Category 6A requirements TAA-Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332197184 Technology Cat5/5e; Cat6; Cat6a PHYSICAL Color White Cable Length (ft.) 0 Cable Length (m) 0.00 Housing Color White Shipping Dimensions (hwd / in.) 5.00 x 4.00 x 0.50 Shipping Dimensions (hwd / cm) 12.70 x 10.16 x 1.27 Shipping Weight (lbs.) 0.02 Shipping Weight (kg) 0.01 ENVIRONMENTAL Operating Temperature Range 14 TO 140 F (-10 TO 60 C) Storage Temperature Range -40 TO 154.4 F (-40 TO 68 C) Relative Humidity 10 TO 90% RH, NON-CONDENSING CONNECTIONS Side A - Connector 1 RJ45 (FEMALE) Side B - Connector 1 RJ45 (FEMALE) STANDARDS & COMPLIANCE Product Compliance Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N235-001-WH-6AD 价格&库存
很抱歉,暂时无法提供与“N235-001-WH-6AD”相匹配的价格&库存,您可以联系我们找货
