N235-001-SH-D
N235-001-SH-D
    TRIPPLITE
    N235-001-SH-D
N235-001-SH-D 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6 Straight-Through Modular Shielded In-Line Snap-In Coupler with 90-Degree Down-Angled Port (RJ45 F/F) MODEL NUMBER: N235-001-SH-D Highlights ● 90° down-angled RJ45 port for easy installation in tight spaces ● Protective shielded housing reduces EMI/RFI interference ● 50-µinch gold-plated contacts on RJ45 jacks ● Keystone design for use with standard data wallplate ● Backward compatible with Cat5e and Cat5 LANs Package Includes ● Fully shielded coupler with 90° angled port connects two Cat6 cables to provide feed-through patching with standard data wallplates. Ideal for premise wiring, telecommunications, data networking and Ethernet connections. Description Strengthen your high-speed network with Tripp Lite’s N235-001-SH-D Cat6 Straight-Through Modular Shielded In-Line Snap-In Coupler (F/F). It connects two Cat6 patch cords to create one longer cable. Its keystone design is perfect for convenient feed-through patching when used with a standard data wallplate (such as Tripp Lite’s N042-001-WH). One RJ45 port is angled down at a 90-degree angle for easy installation in hard-to-reach spaces. Built for ultra-fast performance, this is an ideal coupler when setting up premise wiring, telecommunications, data networking and Ethernet connections. Compatible with all Cat6 cables, the N235-001-SH-D’s protective metal housing is fully shielded to reduce EMI/RFI interference that can damage or degrade data. This coupler features straight-through wiring and 50-µinch gold-plated contacts designed to resist corrosion. The N235-001-SH-D is UL-listed and meets all requirements for EIA/TIA Category 6 compliance. It’s also backward compatible with Cat5e and Cat5 LANs. Features Strengthens Your High-Speed Network ● Ideal for premise wiring, telecommunications, data networking and Ethernet connections ● Connects 2 Cat6 patch cables for a longer cable run ● Keystone design for easy snap-in installation in standard data wallplates (such as Tripp Lite’s N042001-WH) ● Compatible with all Cat6 cables ● Backward compatible with Cat5e and Cat5 LANs Superior Construction for Superior Performance ● 90° down-angled RJ45 port for easy installation in hard-to-reach spaces ● Fully shielded metal housing cuts down on EMI/RFI interference that can damage or degrade data ● 50-µinch gold-plated contacts resist corrosion and improve conduction ● Features straight-through wiring 1/2 N235-001-SH-D Cat6 StraightThrough Modular Shielded InLine Snap-In Coupler (RJ45 F/F) 1000 Eaton Boulevard Cleveland, OH 44122 United States ● UL-listed ● Meets all EIA/TIA Category 6 requirements TAA-Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332197207 Technology Cat5/5e; Cat6 PHYSICAL Color Silver Housing Color Black Shipping Dimensions (hwd / in.) 5.00 x 4.00 x 0.50 Shipping Dimensions (hwd / cm) 12.70 x 10.16 x 1.27 Shipping Weight (lbs.) 0.04 Shipping Weight (kg) 0.02 CONNECTIONS Side A - Connector 1 RJ45 (FEMALE) Side B - Connector 1 RJ45 (FEMALE) STANDARDS & COMPLIANCE Product Compliance Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
N235-001-SH-D 价格&库存
很抱歉,暂时无法提供与“N235-001-SH-D”相匹配的价格&库存,您可以联系我们找货
