1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cat6a Straight-Through Modular Shielded In-Line
Snap-In Coupler with 90-Degree Down-Angled
Port (RJ45 F/F), TAA
MODEL NUMBER: N235-001-SH-6AD
Highlights
90° down-angled RJ45 port for
easy installation in tight spaces
Protective shielded housing
reduces EMI/RFI interference
50-µinch gold-plated contacts on
RJ45 jacks
Keystone design for use with
standard data wallplate
Backward compatible with Cat6,
Cat5e and Cat5 LANs
Package Includes
Fully shielded coupler with 90° angled port connects two Cat6a cables to provide feed-through patching
with standard data wallplates. Ideal for premise wiring, telecommunications, data networking and Ethernet
connections.
Description
Strengthen your high-speed network with Tripp Lite’s N235-001-SH-6AD Cat6a Straight-Through Modular
Shielded In-Line Snap-In Coupler (F/F). It connects two Cat6a patch cords to create one longer cable. Its
keystone design is perfect for convenient feed-through patching when used with a standard data wallplate
(such as Tripp Lite’s N042-001-WH). One RJ45 port is angled down at a 90-degree angle for easy
installation in hard-to-reach spaces. Built for ultra-fast performance, this is an ideal coupler when setting
up premise wiring, telecommunications, data networking and Ethernet connections.
Compatible with all Cat6a cables, the N235-001-SH-6AD’s protective metal housing is fully shielded to
reduce EMI/RFI interference that can damage or degrade data. This coupler features straight-through
wiring and 50-µinch gold-plated contacts designed to resist corrosion. The N235-001-SH-6AD is UL-listed
and meets all requirements for EIA/TIA Category 6A compliance. It’s also backward compatible with Cat6,
Cat5e and Cat5 LANs.
Features
Strengthens Your High-Speed Network
● Ideal for premise wiring, telecommunications, data networking and Ethernet connections
Connects 2 Cat6a patch cables for a longer cable run
Keystone design for easy snap-in installation in standard data wallplates (such as Tripp Lite’s N042001-WH)
Backward compatible with Cat6, Cat5e and Cat5 LANs
Superior Construction for Superior Performance
● 90° down-angled RJ45 port for easy installation in hard-to-reach spaces
Fully shielded metal housing cuts down on EMI/RFI interference that can damage or degrade data
50-µinch gold-plated contacts resist corrosion and improve conduction
Features straight-through wiring
1/3
Coupler (RJ45 F/F)
Cleveland, OH 44122
United States
UL-listed
Meets all EIA/TIA Category 6A requirements
TAA-Compliant
● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332197191
Technology
Cat5/5e; Cat6; Cat6a
PHYSICAL
Color
Silver
Shipping Dimensions (hwd / in.)
5.00 x 4.00 x 0.50
Shipping Dimensions (hwd / cm)
12.70 x 10.16 x 1.27
Shipping Weight (lbs.)
0.04
Shipping Weight (kg)
0.02
ENVIRONMENTAL
Operating Temperature Range
14 TO 140 F (-10 TO 60 C)
Storage Temperature Range
-40 TO 154.4 F (-40 TO 68 C)
Relative Humidity
10 TO 90% RH, NON-CONDENSING
CONNECTIONS
Side A - Connector 1
RJ45 (FEMALE)
Side B - Connector 1
RJ45 (FEMALE)
STANDARDS & COMPLIANCE
Product Compliance
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
2/3
Cleveland, OH 44122
United States
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N235-001-SH-6AD”相匹配的价格&库存,您可以联系我们找货
