CXB300EZBK
CXB300EZBK
    WINCHESTER(温彻斯特)
    CONN BOOT FOR CAT6 EZ RJ45 PLUGS
CXB300EZBK 数据手册
Modular Plugs A complete variety of UL Recognized modular plugs are available. All plugs have 15 micro inches* of gold plating on the contacts which meet all standard applications for voice and data. Flat satin stranded, round stranded, and round solid cables are accommodated. Keyed, MMJ, DEC types, shielded and category 5 versions are available. Flat modular cable types accept 24-28 AWG, stranded. Round cable types accept 24-26 AWG, stranded or solid. Part No. 300062 300064 300066 300068 300164 300166 300168 300168K 300160 300264 300266 300268 300066D 300068K 300068S 300568 300566EZ 300568EZ 300568L 300568S 300668EZ Description Ty 4P4C Handset Plug For Flat Satin, Stranded 6P4C Plug For Flat Satin, Stranded 6P6C Plug For Flat Satin, Stranded 8P8C Plug For Flat Satin, Stranded 6P4C Plug For Round Twisted Pair, Solid 6P6C Plug For Round Twisted Pair, Solid 8P8C Plug For Round Twisted Pair, Solid 8P8C Keyed Plug For Round Twisted Pair, Solid DISCONTINUED 6P4C Plug For Round Twisted Pair, Stranded 6P6C Plug For Round Twisted Pair, Stranded 8P8C Plug For Round Twisted Pair, Stranded 6P6C DEC Offset Plug For Flat Satin 8P8C Keyed Plug For Round Twisted Pair, Stranded 8P8C Shielded Plug For Round Twisted Pair, Solid DISCONTINUED 8P8C Category 5 Plug For Round Twisted Pair, Solid 6P6C EZ-RJ12 Plug (see below) 8P8C EZ-RJ45 Category 5 Plug (see below) 8P8C Category 5 Liner Plug For Round Twisted Pair, Solid 8P8C Shielded Category 5 Liner Plug For Round, Solid 8P8C EZ-RJ45 Category 6 Plug — RJ11 RJ12 RJ45 RJ11 RJ12 RJ45 RJ45 RJ50 RJ11 RJ12 RJ45 MMJ RJ45 RJ45 RJ45 RJ12 RJ45 RJ45 RJ45 RJ45 Category 6 Boot with Strain Relief RJ45 Boot NEW (see below) 8P8C EZ-RJ45 Shielded Category 6 Plug NEW (see below) 300668SEZ CXB300EZ s s s s EZ RJ45 Modular Plugs The new patented EZ-RJ45™ connector simplifies installation by allowing the pairs to be inserted through the connector. There is no difficult to handle liner or wire bar to deal with. Inspection of the correct conductor order is done before crimping so no connector is wasted because if incorrect wiring. The conductors are able to be pulled forward so the pairs are very close to the contacts. This method allows the integrity of the pairs to maintain Category Five, and even enhanced Category 5 and Category 6 capabilities. (50 u in. gold) The EZ-RJ12™ and both EZ-RJ45™ can be crimped with most any standard tool, then trimmed with a cutter or small utility knife. However, the new BD45000 crimp tool crimps and trims the exposed conductors in one operation. The vertical action of the tool makes a uniform and positive crimp. PartNo. Description 300566EZ 300568EZ 300668EZ 300668SEZ BD45000 BD45000BL CXB300EZ CXB500EZ CXB600EZ 6P6C EZ-RJ12 Plug 8P8C EZ-RJ45 Category 5 Plug (solid or stranded) RJ12 RJ45 RJ45 NEW (solid or stranded) 8P8C EZ-RJ45 Shielded Category 6 Plug NEW (solid or stranded) RJ45 8P8C EZ-RJ45 Category 6 Plug - Crimp and Trim Tool for EZ RJ12, EZ RJ45 Cat 5 & 6 Replacement Blades ( 2 per Pkg ) for BD45000 Tool Cable Boot with Strain Relief ( Required for Cat 6 ) - Cable Boot SNAGLESS Cat 5 (color: clear) NEW ------------- Cable Boot SNAGLESS Cat 6 (color: clear) NEW ---- BD45000 Crimp & Trim Tool Video Demo EZ-RJ45 Cat 6 Shielded with SNAGLESS Boot CXB500/600 Snagless Boot Back to Index FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX973-347-2111 Category Five Liner Plugs Category 5 Liner Plugs are supplied with an insertable liner for the conductors. This is also known as a “Wire Bar” style. The separated conductors are inserted into the liner, cut off squarely at bottom, inserted into the RJ45 plug, then perfectly crimped. (Use CBX300 series boots for a proper Category 5 assembly. Part No. 300568L 8P8C Category 5 Liner Plug For Round Twisted Pair, Solid RJ45 300568S 8P8C Shielded Category 5 Liner Plug For Round, Solid RJ45 Description Wall Jacks Plastic wall jacks are furnished with mounting hardware for easy installation. The Non-UL types are very economical and are to be used where UL is not required. 15 micro inches of gold plate on the contacts is standard on all jacks. Rounded configuration, rear wiring terminals allow these wall plates to fit all standard receptacle boxes. Part Number 300004IV 300004WH 300006IV 300008IV 300014IV 300014WH 300016IV 300018IV 300090 300094IV 300094WH 300095 300104 301004WH 301006WH 301008WH 301014WH 301016WH 301018WH 301094WH Description 4C Ivory Flush Mount Single Jack, Non-UL 4C White Flush Mount Single Jack, Non-UL 6C Ivory Flush Mount Single Jack, Non-UL 8C Ivory Flush Mount Single Jack, Non-UL 4C Ivory Flush Mount Dual Jack, Non-UL 4C White Flush Mount Dual Jack, Non-UL 6C Ivory Flush Mount Dual Jack, Non-UL 8C Ivory Flush Mount Dual Jack, Non-UL 4C Ivory Wall-Phone, 3 Jacks, Non-UL 4C Ivory Wall-Phone Jack, Non-UL 4C White Wall-Phone Jack, Non-UL 4C Steel Wall-Phone Jack, Non-UL 4C Ivory Telephone/TV Jack, Non-UL 4C Ivory Flush Mount Single Jack, UL 6C Ivory Flush Mount Single Jack, UL 8C Ivory Flush Mount Single Jack, UL 4C White Flush Mount Dual Jack, UL 6C White Flush Mount Dual Jack, UL 8C White Flush Mount Dual Jack, UL 4C White Wall-Phone Jack, UL FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX973-347-2111 Back to Index 21 Hit Counter
CXB300EZBK
1. 物料型号:文档列出了多种型号的模块化插头,包括4P4C、6P4C、6P6C、8P8C等,适用于不同类型的电缆,如扁平缎带电缆、圆形双绞线和圆形实心电缆。
2. 器件简介:所有插头的接触点都镀有15微英寸的金,适用于语音和数据的标准应用。
3. 引脚分配:文档中提到了不同型号的插头,如300062、300064、300066等,它们适用于不同数量的引脚。
4. 参数特性:提到了插头的镀金厚度,以及EZ-RJ45™连接器的简化安装过程,允许通过连接器插入线对,无需处理复杂的衬里或线缆条。
5. 功能详解:EZ-RJ45™连接器在压接前检查正确的导线顺序,以避免因错误布线而浪费连接器。导线可以向前拉,使线对非常接近接触点,保持五类甚至增强五类和六类的性能。
6. 应用信息:文档提到了EZ-RJ12™和EZ-RJ45™可以使用大多数标准工具压接,然后使用切割器或小工具刀修剪。
7. 封装信息:提到了CXB300系列靴子,用于适当的五类性能,以及新的BD45000压接工具,可以一次性压接和修剪暴露的导线。
CXB300EZBK 价格&库存
很抱歉,暂时无法提供与“CXB300EZBK”相匹配的价格&库存,您可以联系我们找货
