TM23P-8-BT(02)
TM23P-8-BT(02)
    HRS(广濑)
    CONN BOOT HOODED FOR TM23 PLUG
TM23P-8-BT(02) 数据手册
CAT 6 Data Wiring System Connectors ■Features Permanent Link PSACR 1. High-Speed Data Transfer Conforms to the TIA/EIA-568B.2-1 data Wiring standard, thereby clears CAT 6 transfer performance requirements. As such, these products easily support Gigabit Ethernet (1000BASE-T/1000BASE-TX), which is the next generation of high-speed applications. 2. A Product Lineup Focused on Building of a Complete System In addition to modular plugs, Hirose Electric offers box type outlets, patch panels, and wall outlets. Systems built using all components from the same manufacturer will assure stable data transfer. 100 90 Attenuation/PSNEXT (dB) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. TM23 Series 80 70 Measured value 60 50 CAT 6 PSNEXT standard value 40 30 20 CAT 6 Attenuation standard value 10 Measured value 0 1 10 100 1000 Frequency (MHz) 3. Support of a Wide Variety of Manufacturers' CAT 6 Cable To assure high performance of the system we test and monitor data transfer using CAT 6 cables manufactured by different suppliers. 2008.4w 1 TM23 Series●CAT 6 Data Wiring System Connectors ■Plugs, Boots ■Specifications Rating Current rating 1A Voltage rating 125V AC Item Operating temperature range -25ç to +60ç (Note) Specification Conditions 100 V DC Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1. Insulation resistance 100 M ohms min. 2. Withstanding voltage No flashover or insulation breakdown. (between adjacent contacts) 3. Contact resistance 230 m ohms max. No electrical discontinuity of 5μs min. 4. Vibration Contact resistance : 250m ohms max. No electrical discontinuity of 5μs. min. 5. Shock Contact resistance : 250m ohms max. 6. Durability Contact resistance : 250m ohms max. (mating/un-mating) 500 V AC / one minute 100mA Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 1 octave/min. conduct, 10 cycles to each 3 directions. Acceleration of 490 m/s2, 11 ms duration, sine half-wave waveform, 3 cycles in each of the 6 axes. 200 cycles Temperature : -55±3ç ➝ +15ç to +35ç ➝ +85±2ç ➝ +15ç to +35ç Duration (Minutes): 30+50 ➝ 2 to 3 ➝ 30+50 ➝ 2 to 3 5 cycles Contact resistance : 250 m ohms max. Insulation resistance : 100 M ohms min. 7. Temperature cycle Contact resistance: 250 m ohms max. Insulation resistance: 1 M ohms min. (High humidity) Insulation resistance: 100 M ohms min. (Dry state) Contact resistance: 250 m ohms max. 9. Salt Spray Note: Includes temperature rise caused by current flow. 500 hours at temperature of 40ç and humidity of 90% to 95%. 8. Humidity 5% salt water/48 hours. ■Materials and Finishes Plugs Component Material Finish Remarks Insulator Polycarbonate Color: Clear UL94V-0 Contacts Phosphor bronze Contact area: Gold plated ------------------- Strain relief clamp Brass Nickel plated ------------------- Component Material Boots Insulator EPTR Finish Remarks White (Standard color) UL94V-0 Black, red, blue, yellow, green, orange, gray, light blue ------------------- ■Ordering Information ● Plugs 1 Series name TM23 - P - 8 8P 1 2 3 4 ● Boots 2 Connector type P : Plug 3 Size 8 : 8 contacts 4 Inserted contacts 8P : 8 contacts 1 Series name TM23 - P - 8 BT 1 2 3 4 ● Jacks P : Plug 3 Size 8 : 8 contacts : Boot 1 Series name TM23 R - 5A 8 8 2 : TM23 2 Connector type 4 BT 1 : TM23 2 3 4 5 2 Connector type : TM23 R : Jack 3 Mounting style/termination type 5A : Right-angle/through hole 4 Jack opening code 8 : For 8 contacts 5 Number of inserted contacts 8 : 8 contacts TM23 Series●CAT 6 Data Wiring System Connectors ■Plugs BOverview . Contact configured for CAT 6 performance. . 0.5 mm dia. solid wire or AWG #24 stranded wire. . Use with cables having external diameters of 5.4 mm to 6.8mm. Plug body Connector guide insert * (25) 5.4 10.05 4.75 1 11.7 6.09 24 C6 (17.5) 6.6 (12.9) Strain relief clamp * 8.9 Connecter guide insert (Shown inserted) Contact No. 1 Contact No. 8 17 10.05 6 5.05 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. . Strain relief clamp protects the contact/conductor termination areas. TM23P-88P Part No. CL No. RoHS TM23P-88P 222-2916-6 YES BMated with corresponding receptacle (Shown for reference only) (15.45) * Supplied separately(1bag contains 1pcs.) 3 TM23 Series●CAT 6 Data Wiring System Connectors ■Boots BOverview Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. . Dedicated boots for the TM23P-88P. . 9 color variations. . Halogen-free. . Protects the plug’s lock/release lever. 13.4 (6.5) 8.8 10.8 12 25.3 (12) 1 (17.2) TM23P-8-BT Part Number CL No. Color TM23P-8-BT(01) 222-2917-9-02 White TM23P-8-BT(01) 222-2917-9-01 Black TM23P-8-BT(02) 222-2917-9-02 Red TM23P-8-BT(03) 222-2917-9-03 Blue TM23P-8-BT(04) 222-2917-9-04 Yellow TM23P-8-BT(05) 222-2917-9-05 Green TM23P-8-BT(06) 222-2917-9-06 Orange TM23P-8-BT(07) 222-2917-9-07 Gray TM23P-8-BT(08) 222-2917-9-08 Light Blue BBoot installed Protected lock/release lever Ø6.8MAX (40) TM23P-88P 4 (16.9) 10.8 Ø6 .8 (4) RoHS YES TM23 Series●CAT 6 Data Wiring System Connectors ■Manual Termination Tool HRS marking side (For contact/conductor termination) A Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Reverse side (For cable strain relief clamp crimping) Part No. CL No. HT601-TM23/22P-88P 902-2128-1 * Changing the “A” Assembly parts to TM22 dedicated clamp parts will allow wiring of Hirose’s TM22P-88P plugs supporting CAT 5e. ● Automatic Contact Termination Machine Item Part Number CL No. Body CM-105 AP105-TM23P-88P CL901-0005-4 CL901-2588-5 Applicator ● Cable Strain Relief Clamp Crimping Jig (Manual operated) Part Number CL No. TM23P-88P/CK-MP(01) CL902-2130-3(01) ■Recommended Cable Specification Solid copper conductor: Jacket Filler Conductor Conductor 0.5mm dia. Stranded copper conductor: AWG#24 Individual conductor insulation dia. Insulation Overall jacket dia. (0.95mm to 1.05mm) (5.4mm to 6.8mm) Note: To achieve CAT 6 performance, refer to TM23P-88P Cable Termination Procedure Manual(ETAD-E2415). 5 TM23 Series●CAT 6 Data Wiring System Connectors ■Jacks BOverview . Unique contact structure designed for crosstalk reduction. . (Through hole : 3 rows) . Temporary retention to board with integral flexible posts. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BPCB mounting pattern 15 15 13 7.112 5.08 8-Ø0.8 3.048 14.5 2.54 1.016 4 7 3 15 6 6 Contact No. 1 3 Recommended board thickness: 1.6mm 2.54 4 6 Part Number CL No. Color RoHS TM23R-5A-88(50) 222-2918-1-50 Black YES Note: The jack by itself does not clear CAT 6 performance requirements. Compensation on the board is required to secure CAT 6 performance. 6 2 Connector front edge 1.3 Contact No. 8 0.35 2.1 Flexible post 0.43 1 5 4 8 1.3 2-Ø2.4 TM23 Series●CAT 6 Data Wiring System Connectors ■ Precautions in System Construction The TM23 Series connector and components were designed for CAT 6 data transfer. However, it is highly recommended that the entire connected system be checked for this performance level. ● Cable termination procedures Cable termination procedure manual No. Part Number ETAD-E2415 TM23P-88P Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● Recommended Cable Manufacturers Hirose Electric closely examines the transfer performance of these connectors with the CAT 6 cable that is manufactured and sold by the various cable manufacturers. Please use the cable from among those indicated in Table 1 for system construction with the TM23 Series. Table1 Recommended Cable Manufacturers Manufacturer's Name Web Site Hitachi Cable, Ltd. http://www.hitachi-cable.co.jp/index_e.html Tonichi Kyosan Cable, Ltd. http://www.tonichi-kyosan.co.jp/ NipponSeisen Co. Ltd. http://www.nscable.co.jp/ Okano Electric Wire Co., Ltd. http://www.okano-cable.co.jp/english/index.html Tsushin Kogyo K.K. http://www.tsuko.co.jp/ Showa Electric Wire & Cable Co., Ltd. http://www.swcc.co.jp/eng/index.html Fuji Electric Cable Co, Ltd. http://www.tokyo-fuji.co.jp/index_f.htm Note: Please see the web sites of the various manufacturers for cable specifications. Contact HRS for recommendations when using cables from other suppliers. ● Use of Different Manufacturers' Components Use of different manufacturers' components in one system could cause the deterioration of transfer performance. ● Check of the System Performance Verification All measures have been taken to assure the transfer performance of the TM23 series. However, it is highly recommended to verify transfer performance of complete system using commercially available measuring instruments. Hirose Electric does not build wiring systems. Please contact Hirose Electric sales representative for system construction contractor information. 7 TM23 Series●CAT 6 Data Wiring System Connectors ■ Technical Documentation ● CAT 6 Transmission Characteristics Data This is representative transfer performance for the TM23 Series. A high margin is used for CAT 6 standard values. . Permanent Links Permanent Link PSACR 100 Horizontal cable 90 m 90 Attenuation/PSNEXT (dB) TM23R-MPP24 TM23R-T01 Permanent link adapter (PM06) DSP4300 Main unit Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 80 70 Measured value 60 50 CAT 6 PSNEXT standard value 40 30 20 CAT 6 Attenuation standard value 10 DSP4300 Remote unit Measured value 0 1 10 100 1000 Frequency (MHz) . Channel Links Horizontal cable 90 m Channel Link PSACR 100 90 Patch cable 2m Attenuation/PSNEXT (dB) TM23R-MPP24 TM23R-T01 Patch cable Stranded 5m wire 3 m ( :TM23P-88P) Channel link adapter 80 70 Measured value 60 50 CAT 6 PSNEXT standard value 40 30 20 Measured value CAT 6 Attenuation standard value 10 0 1 DSP4300 Main unit DSP4300 Remote unit . Patch Cable 10 1000 Patch Cable 2 m DSP4300 Main unit Channel link adapter DSP4300 Remote unit Patch Cable 2 m NEXT Patch Cable 2 m RL 120 60 100 50 Measured value Measured value 80 40 RL(dB) NEXT(dB) 100 Frequency (MHz) 60 CAT 6 NEXT standard value 30 40 20 20 10 CAT 6 RL standard value 0 0 1 10 100 Frequency (MHz) ® 8 1000 1 10 100 1000 Frequency (MHz) 5-23,OSAKI 5-CHOME,SHINAGAWA-KU,TOKYO 141-8587,JAPAN PHONE: 81-3-3491-9741, FAX: 81-3-3493-2933 http://www.hirose.com http://www.hirose-connectors.com The contents of this catalog are current as of date of publication. Contents are subject to change without notice for the purpose of improvements.
TM23P-8-BT(02) 价格&库存
很抱歉,暂时无法提供与“TM23P-8-BT(02)”相匹配的价格&库存,您可以联系我们找货
