CAT 6 Data Wiring System Connectors
■Features
Permanent Link PSACR
1. High-Speed Data Transfer
Conforms to the TIA/EIA-568B.2-1 data Wiring standard,
thereby clears CAT 6 transfer performance requirements.
As such, these products easily support Gigabit Ethernet
(1000BASE-T/1000BASE-TX), which is the next
generation of high-speed applications.
2. A Product Lineup Focused on Building of a
Complete System
In addition to modular plugs, Hirose Electric offers box
type outlets, patch panels, and wall outlets. Systems built
using all components from the same manufacturer will
assure stable data transfer.
100
90
Attenuation/PSNEXT (dB)
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
TM23 Series
80
70
Measured value
60
50
CAT 6 PSNEXT standard value
40
30
CAT 6 Attenuation standard value
10
Measured value
10
100
1000
Frequency (MHz)
3. Support of a Wide Variety of Manufacturers'
CAT 6 Cable
To assure high performance of the system we test and
monitor data transfer using CAT 6 cables manufactured
by different suppliers.
2008.4w
1
TM23 Series●CAT 6 Data Wiring System Connectors
■Plugs, Boots
■Specifications
Rating
Current rating
1A
Voltage rating
125V AC
Item
Operating temperature range -25ç to +60ç (Note)
Specification
Conditions
100 V DC
1. Insulation resistance 100 M ohms min.
2. Withstanding voltage
No flashover or insulation breakdown.
(between adjacent contacts)
3. Contact resistance
230 m ohms max.
No electrical discontinuity of 5μs min.
4. Vibration
Contact resistance
: 250m ohms max.
No electrical discontinuity of 5μs. min.
5. Shock
Contact resistance
: 250m ohms max.
6. Durability
Contact resistance
: 250m ohms max.
(mating/un-mating)
500 V AC / one minute
100mA
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm,
1 octave/min. conduct, 10 cycles to each 3 directions.
Acceleration of 490 m/s2, 11 ms duration, sine half-wave
waveform, 3 cycles in each of the 6 axes.
200 cycles
Temperature : -55±3ç ➝ +15ç to +35ç ➝ +85±2ç ➝ +15ç to +35ç
Duration (Minutes): 30+50 ➝ 2 to 3 ➝ 30+50 ➝ 2 to 3
5 cycles
Contact resistance
: 250 m ohms max.
Insulation resistance : 100 M ohms min.
7. Temperature cycle
Contact resistance: 250 m ohms max.
Insulation resistance: 1 M ohms min. (High humidity)
Insulation resistance: 100 M ohms min. (Dry state)
9. Salt Spray
Note: Includes temperature rise caused by current flow.
500 hours at temperature of 40ç and humidity of 90% to 95%.
8. Humidity
5% salt water/48 hours.
■Materials and Finishes
Plugs
Component
Material
Finish
Remarks
Insulator
Polycarbonate
Color: Clear
UL94V-0
Contacts
Phosphor bronze
Contact area: Gold plated
Strain relief clamp
Brass
Nickel plated
Component
Material
Boots
Insulator
EPTR
Finish
Remarks
White (Standard color)
UL94V-0
Black, red, blue, yellow, green, orange, gray, light blue
■Ordering Information
● Plugs
1 Series name
TM23 - P - 8 8P
1
2
3
4
● Boots
2 Connector type
P
: Plug
3 Size
8
: 8 contacts
4 Inserted contacts
8P : 8 contacts
1 Series name
TM23 - P - 8 BT
1
2
3
4
● Jacks
P
: Plug
3 Size
8
: 8 contacts
: Boot
1 Series name
TM23 R - 5A 8 8
2
: TM23
2 Connector type
4 BT
1
: TM23
2
3
4
5
2 Connector type
: TM23
R
: Jack
3 Mounting style/termination type 5A : Right-angle/through hole
4 Jack opening code
8
: For 8 contacts
5 Number of inserted contacts
8
: 8 contacts
■Plugs
BOverview
. Contact configured for CAT 6 performance.
. 0.5 mm dia. solid wire or AWG #24 stranded wire.
. Use with cables having external diameters of 5.4 mm to 6.8mm.
Plug body
Connector guide insert *
(25)
5.4
10.05
4.75
1
11.7
6.09
24
C6
(17.5)
6.6
(12.9)
Strain relief clamp *
8.9
Connecter guide insert
(Shown inserted)
Contact No. 1
Contact No. 8
17
10.05
6
5.05
. Strain relief clamp protects the contact/conductor
termination areas.
TM23P-88P
Part No.
CL No.
RoHS
TM23P-88P
222-2916-6
YES
BMated with corresponding receptacle
(Shown for reference only)
(15.45)
* Supplied separately(1bag contains 1pcs.)
3
■Boots
BOverview
. Dedicated boots for the TM23P-88P.
. 9 color variations.
. Halogen-free.
. Protects the plug’s lock/release lever.
13.4
(6.5)
8.8
10.8
12
25.3
(12)
1
(17.2)
TM23P-8-BT
Part Number
CL No.
Color
TM23P-8-BT(01)
222-2917-9-02
White
TM23P-8-BT(01)
222-2917-9-01
Black
TM23P-8-BT(02)
222-2917-9-02
Red
TM23P-8-BT(03)
222-2917-9-03
Blue
TM23P-8-BT(04)
222-2917-9-04
Yellow
TM23P-8-BT(05)
222-2917-9-05
Green
TM23P-8-BT(06)
222-2917-9-06
Orange
TM23P-8-BT(07)
222-2917-9-07
Gray
TM23P-8-BT(08)
222-2917-9-08
Light Blue
BBoot installed
Protected lock/release lever
Ø6.8MAX
(40)
TM23P-88P
4
(16.9)
10.8
Ø6
.8
(4)
RoHS
YES
■Manual Termination Tool
HRS marking side
(For contact/conductor termination)
A
Reverse side
(For cable strain relief clamp crimping)
Part No.
CL No.
HT601-TM23/22P-88P
902-2128-1
* Changing the “A” Assembly parts to TM22 dedicated clamp parts will
allow wiring of Hirose’s TM22P-88P plugs supporting CAT 5e.
● Automatic Contact Termination Machine
Item
Part Number
CL No.
Body
CM-105
AP105-TM23P-88P
CL901-0005-4
CL901-2588-5
Applicator
● Cable Strain Relief Clamp Crimping Jig (Manual operated)
Part Number
CL No.
TM23P-88P/CK-MP(01)
CL902-2130-3(01)
■Recommended Cable Specification
Solid copper conductor:
Jacket
Filler
Conductor
Conductor
0.5mm dia.
Stranded copper conductor:
AWG#24
Individual conductor
insulation dia.
Insulation
Overall jacket dia.
(0.95mm to 1.05mm)
(5.4mm to 6.8mm)
Note: To achieve CAT 6 performance, refer to
TM23P-88P Cable Termination Procedure Manual(ETAD-E2415).
5
■Jacks
BOverview
. Unique contact structure designed for crosstalk reduction.
. (Through hole : 3 rows)
. Temporary retention to board with integral flexible posts.
BPCB mounting pattern
15
15
13
7.112
5.08
8-Ø0.8
3.048
14.5
2.54
1.016
4
7
3
15
6
6
Contact No. 1
3
Recommended board thickness: 1.6mm
2.54
4
6
Part Number
CL No.
Color
RoHS
TM23R-5A-88(50)
222-2918-1-50
Black
YES
Note: The jack by itself does not clear CAT 6 performance requirements. Compensation on the
board is required to secure CAT 6 performance.
6
2
Connector front edge
1.3
Contact No. 8
0.35
2.1
Flexible post
0.43
1
5
4
8
1.3
2-Ø2.4
■ Precautions in System Construction
The TM23 Series connector and components were designed for CAT 6 data transfer. However, it is highly
recommended that the entire connected system be checked for this performance level.
● Cable termination procedures
Cable termination procedure manual No.
Part Number
ETAD-E2415
TM23P-88P
● Recommended Cable Manufacturers
Hirose Electric closely examines the transfer performance of these connectors with the CAT 6 cable that is
manufactured and sold by the various cable manufacturers. Please use the cable from among those indicated in
Table 1 for system construction with the TM23 Series.
Table1 Recommended Cable Manufacturers
Manufacturer's Name
Web Site
Hitachi Cable, Ltd.
http://www.hitachi-cable.co.jp/index_e.html
Tonichi Kyosan Cable, Ltd.
http://www.tonichi-kyosan.co.jp/
NipponSeisen Co. Ltd.
http://www.nscable.co.jp/
Okano Electric Wire Co., Ltd.
http://www.okano-cable.co.jp/english/index.html
Tsushin Kogyo K.K.
http://www.tsuko.co.jp/
Showa Electric Wire & Cable Co., Ltd.
http://www.swcc.co.jp/eng/index.html
Fuji Electric Cable Co, Ltd.
http://www.tokyo-fuji.co.jp/index_f.htm
Note: Please see the web sites of the various manufacturers for cable specifications.
Contact HRS for recommendations when using cables from other suppliers.
● Use of Different Manufacturers' Components
Use of different manufacturers' components in one system could cause the deterioration of transfer performance.
● Check of the System Performance Verification
All measures have been taken to assure the transfer performance of the TM23 series. However, it is highly
recommended to verify transfer performance of complete system using commercially available measuring
instruments.
Hirose Electric does not build wiring systems. Please contact Hirose Electric sales representative for system
construction contractor information.
7
■ Technical Documentation
● CAT 6 Transmission Characteristics Data
This is representative transfer performance for the TM23 Series. A high margin is used for CAT 6 standard values.
. Permanent Links
100
Horizontal cable 90 m
90
TM23R-MPP24
TM23R-T01
Permanent link adapter (PM06)
DSP4300
Main unit
80
70
Measured value
60
50
40
30
10
DSP4300
Remote unit
Measured value
10
100
1000
Frequency (MHz)
. Channel Links
Channel Link PSACR
100
90
Patch cable
2m
TM23R-MPP24 TM23R-T01
Patch cable
Stranded
5m
wire 3 m
( :TM23P-88P)
Channel link
adapter
80
70
Measured value
60
50
40
30
Measured value
10
DSP4300
Main unit
DSP4300
Remote unit
. Patch Cable
10
1000
Patch Cable 2 m
DSP4300
Main unit
Channel link adapter
DSP4300
Remote unit
Patch Cable 2 m NEXT
Patch Cable 2 m RL
120
60
100
50
Measured value
Measured value
80
40
RL(dB)
NEXT(dB)
100
Frequency (MHz)
60
CAT 6 NEXT standard value
30
40
CAT 6 RL standard value
10
100
Frequency (MHz)
8
1000
1
10
100
1000
Frequency (MHz)
5-23,OSAKI 5-CHOME,SHINAGAWA-KU,TOKYO 141-8587,JAPAN
PHONE: 81-3-3491-9741, FAX: 81-3-3493-2933
http://www.hirose.com
http://www.hirose-connectors.com
The contents of this catalog are current as of date of publication. Contents are subject to change without notice for the purpose of improvements.
很抱歉,暂时无法提供与“TM23P-8-BT”相匹配的价格&库存,您可以联系我们找货
