MPP-1100-05-DS-4GR(S1402)
    SULLINS
    CONN TRANSIST TO-220/TO-247 5POS
MPP-1100-05-DS-4GR(S1402) 数据手册
8 7 5 6 4 REVISIONS PART NUMBER CODING MPP-_100-05-DS-4GR(S1402) REV. ECO. NO B 2094 C 2834 D 4368 INSULATOR MATERIAL F 1 2 3 1 = BROWN PPS OPERATING TEMP: -65°C TO +200°C PROCESSING TEMP: 260°C FOR 20 SECS MAX 8= NATURAL BROWN PEEK OPERATING TEMP: -65°C TO +250°C PROCESSING TEMP: 260°C FOR 20 SECS MAX DESCRIPTION DATE CORRECTED DIM. (.430 WAS .420) & ADDED FOOT PRINT LAYOUT 12/28/2009 RECOMMENDED ( .045 WAS .043) ADD '8' MATERIAL OPTION BY TT 8/30/2013 JH UPDATE OPERATING TEMP TO 250C FOR MTL CODE  '8' (WAS 200C), NOTE 8 (WAS 3A), ADD TOL TO 1ST  12/8/2021 RA BEND, REF TO RAB ROW SPACING JH F .420 10.67 2X .095 2.41 .420±.008 10.67±0.20 E 2X .115 2.92 E 10X .045 1.14 THRU MIN .156 3.96 .330 8.38 FOOT PRINT LAYOUT RECOMMENDED 2X .115 2.92 D D 2X .095 2.41 .610±.015 15.49±0.38 A .345 8.76 INSERTION DEPTH .431 10.95 C C .050±.010 1.27±0.25 .028 0.71 .156 3.96 A B .125±.025 3.18±0.64 .315 8.00 NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SPINODAL SECTION A-A 3. PLATING: .000050" MIN NICKEL UNDERPLATE CONTACT SURFACE: .000030" GOLD TERMINATION: .000010" GOLD 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING (CONSULT FACTORY FOR SPECIAL SOLDERING REQUIREMENT) 6. UL FLAMMABILITY RATING: 94V-0 7. OPERATING VOLTAGE: 700 VAC 8. CURRENT RATING: 6 AMP PER CONTACT PAIR UNLESS OTHERWISE SPECIFIED: DRAWN DIMENSIONS ARE IN INCHES [MM] 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX TOLERANCES: 10. INSULATION RESISTANCE: 5000 MEGA OHMS 11. DURABILITY: 500 CYCLES MIN ANGULAR: 1 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE DECIMALS 13. MODIFICATION: SHORTING CONTACTS ALL POSITIONS. RIGHT ANGLE BEND, .156" ROW SPACING, .XX= .02 [.5] .XXX= .005 [.13] .125" TAIL LENGTH FROM SIDE OF BODY AFTER BEND. CONTACT CENTERS .095"/.115", .XXXX= .0005 [.013] RoHS COMPLIANT .345" INSERTION DEPTH B CUSTOMER COPY A Pb 8 7 6 5 4 DATE NAME 8/30/13 JH THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. 3 TITLE A TO-220 & TO-247 SOCKET PART NUMBER MPP-_100-05-DS-4GR(S1402) SIZE C CAGE CODE 54453 SCALE: 4:1 2 DWG. NO. C11412 REV D SHEET 1 OF 1 1 FILE NAME: C11412, MPP-_100-05-DS-4GR(S1402)
MPP-1100-05-DS-4GR(S1402) 价格&库存
很抱歉,暂时无法提供与“MPP-1100-05-DS-4GR(S1402)”相匹配的价格&库存,您可以联系我们找货
