Series: SBU, DBU
Low Profile Machined Female Header
v
v
v
v
v
v
Insertion depth, 2.4 mm min. - 3.9 mm max.
Insertion diameter, 0.40 mm min. - 0.56 mm max.
Six finger clip with funnel design entry
Side and end stackable
Single row 1 - 64 positions
Dual row 4 - 64 positions
Ordering examples:
DBU - 64 0 Z
5.08
SBU - 32 0 Z
3.6
3
4.1
7.4
3.45
3
3.86
7.4
3.6
N - 1 x 2.54
3
4.1
7.4
2.54
N - 1 x 2.54
PCB
Ø 0.53
2.54
Ø 0.53
5.08
SBU - 32 0 Z - R
3.7
2.54
2.54
O 0.46
N - 1 x 2.54
5.08
3.2
contact point
1.4 - 2.0
3.2
O 0.7 - 0.9
5.6
2.4
1.27
N - 1 x 2.54
1.27
1.4 - 2.0
3.7
2.4
contact point
DBU - 64 0 Z - R
O 0.7 - 0.9
5.60
2.54
2.54
O 0.46
On-Shore Technology v1917 W. Third St.Tempe, AZ 85281 vTelephone: 602-921-3000 vFax: 602-968-4444
Specifications
Machined Pin Female Header Series:
SBU
DBU
SBL
DBL
Ratings:
Current for SBU, DBU
Current for SBL, DBL
Voltage
Dielectric strength
Contact resistance
Insulation resistance
Air and creepage distance
PCB thickness
PCB hole size
1A max.
3A max.
10 mV - 60 V
> 1000 V (RMS)
≤ 7 mΩ
12
> 10 Ω
> 0.6 mm
1.6 mm - 2.0 mm
.7 mm - .9 mm
Material:
Plastic
Color
Sleeve
Clip
Temperature range
Mechanical life
PBT, Glass-filled, UL94V-0
Black
Turned brass, Flash copper plated, Nickel 2-3µm, Tin 5µm
Beryllium-copper, Nickel 2-3µm, Gold 0.25µm
-55°C / +125°C, 260°C for 5 sec. (solder bath resistant)
100 cycles
ORDERING PROCEDURE
1
2
3
4
5
1) Series
2) Number of Positions (see series page for available positions)
3) Contact style:
O = Solder tail
4) Plating:
Z = Gold clip/Tin sleeve
G = Gold clip/Gold sleeve
5) Series options:
R = Right angle
Please refer to following pages for ordering examples.
On-Shore Technology v1917 W. Third St. Tempe, AZ 85281 vTelephone: 602-921-3000 vFax: 602-968-4444
很抱歉,暂时无法提供与“SBU130Z”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 200+3.98718200+0.51512
