1938
1938
    ADAFRUIT
1938 数据手册
WS2812 Intelligent control LED integrated light source Features and Benefits l l l l l l l l l Control circuit and RGB chip are integrated in a package of 5050 components, form a complete control of pixel point. Built-in signal reshaping circuit, after wave reshaping to the next driver, ensure wave-form distortion not accumulate. Built-in electric reset circuit and power lost reset circuit. Each pixel of the three primary color can achieve 256 brightness display, completed 16777216 color full color display, and scan frequency not less than 400Hz/s. Cascading port transmission signal by single line. Any two point the distance more than 5m transmission signal without any increase circuit. When the refresh rate is 30fps, low speed model cascade number are not less than 512 points, high speed mode not less than1024 points. Send data at speeds of 800Kbps. The color of the light were highly consistent, cost-effective.. Applications l l Full-color module, Full color soft lights a lamp strip. LED decorative lighting, Indoor/outdoor LED video irregular screen. General description WS2812 is a intelligent control LED light source that the control circuit and RGB chip are integrated in a package of 5050 components. It internal include intelligent digital port data latch and signal reshaping amplif ication drive circuit. Also include a precision internal oscillator and a 12V voltage programmable constant curre -nt control part, effectively ensuring the pixel point light color height consistent. The data transfer protocol use single NZR communication mode. After the pixel power-on reset, the DIN port receive data from controller, the first pixel collect initial 24bit data then sent to the internal data latch, the other data which reshaping by the internal signal reshaping amplification circuit sent to the next cascade pixel through the DO port. After transmission for each pixel,the signal to reduce 24bit. pixel adopt auto resha -ping transmit technology, making the pixel cascade number is not limited the signal transmission, only depend on the speed of signal transmission. LED with low driving voltage, environmental protection and energy saving, high brightness, scattering angl e is large, good consistency, low power, long life and other advantages. The control chip integrated in LED above becoming more simple circuit, small volume, convenient installation. http://www.world-semi.com WS2812 Intelligent control LED integrated light source Mechanical Dimensions PIN configuration PIN function NO. Symbol 1 DOUT Control data signal output 2 DIN Control data signal input 3 VCC Power supply control circuit 4 NC 5 VDD Power supply LED 6 VSS Ground Absolute Maximum Ratings http://www.world-semi.com Function description WS2812 Intelligent control LED integrated light source Prameter Symbol Ratings Unit Power supply voltage VCC +6.0~+7.0 V Power supply voltage VDD +6.0~+7.0 V Input voltage VI -0.5~VDD+0.5 V Operation junction temperature Topt -25~+80 ℃ Storage temperature range Tstg -55~+150 ℃ Electrical Characteristics(TA=-20~+70℃,VDD=4.5~5.5V,VSS=0V,unless otherwise specified) Prameter Smybol conditions Min Tpy Max Unit Low voltage output current IOL ROUT —— 18.5 —— mA Idout Vo=0.4V,DOUT 10 —— —— mA Input current II VI=VDD/VSS —— —— ±1 µA VIH DIN,SET 0.7VDD —— —— V VIL DIN,SET —— —— 0.3 VDD V VH DIN,SET —— 0.35 —— V Input voltage level Hysteresis voltage Switching characteristics(TA=-20~+70℃,VDD=4.5~5.5V,VSS=0V,unless otherwise specified) Prameter Symbol Condition Min Tpy Max Unit Operation frequency Fosc2 —— —— 800 —— KHz Transmission delay time tPLZ CL=15pF,DIN→ DOUT,RL=10KΩ —— —— 300 ns Fall time tTHZ CL=300pF,OUTR/OU TG/OUTB —— —— 120 µs Data transmission rate FMAX Duty ratio50% 400 —— —— Kbps Input capcity CI —— —— —— 15 pF http://www.world-semi.com WS2812 Intelligent control LED integrated light source LED characteristic parameter Emitting color Wavelength(nm) Luminous intensity(mcd) Current(mA) Voltage(V) Red 620-630 550-700 20 1.8-2.2 Green 515-530 1100-1400 20 3.0-3.2 Blue 465-475 200-400 20 3.2-3.4 Data transfer time( TH+TL=1.25µs±600ns) T0H 0 code ,high voltage time 0.35us ±150ns T1H 1 code ,high voltage time 0.7us ±150ns T0L 0 code , low voltage time 0.8us ±150ns T1L 1 code ,low voltage time 0.6us ±150ns RES low voltage time Above 50µs Sequence chart: T0L 0 code T0 H T1L 1 co de T1H Treset RET co de Cascade method: D1 DIN DO PIX1 D2 DIN DO D3 PIX2 http://www.world-semi.com D4 DIN DO PIX3 WS2812 Intelligent control LED integrated light source Data transmission method: reset code >=50us Data refresh cycle 1 first 2 4 b it D1 Data refresh cycle 2 seco n d 2 4 b it th ird 2 4 b it seco n d 2 4 b it D2 reset code first 2 4 b it th ird 2 4 b it seco n d 2 4 b it th ird 2 4 b it seco n d 2 4 b it th ird 2 4 b it th ird 2 4 b it D3 th ird 2 4 b it D4 Note: The data of D1 is send by MCU,and D2, D3, D4 through pixel internal reshaping amplification to transmit. Composition of 24bit data: G7 G6 G5 G4 G3 G2 G1 G0 R7 R6 R5 R4 R3 R2 R1 R0 Note: Follow the order of GRB to sent data and the high bit sent at first. Typical application circuit: http://www.world-semi.com B7 B6 B5 B4 B3 B2 B1 B0
很抱歉,暂时无法提供与“1938”相匹配的价格&库存,您可以联系我们找货
