FN1394-10-05-11-QN-0
    SCHAFFNER(夏弗纳)
    PWR ENT MOD RCPT IEC320-C14 PNL
FN1394-10-05-11-QN-0 数据手册
IEC Inlet Filters FN 390 Versatile Filtered Power Entry Module n n n n n n Rated currents up to 10A For one or two fuses Fuses Ø6.3 x 32mm or Ø5 x 20mm 2-pole rocker switch Voltage selector Optional earth line choke (E type) Technical specifications Maximum continuous operating voltage: Operating frequency: Rated currents: High potential test voltage: Protection category: Temperature range (operation and storage): Design corresponding to: Flammability corresponding to: MTBF @ 40°C/230V (Mil-HB-217F): Typical electrical schematic 250VAC, 50/60Hz 50 to 400Hz 1 to 10A @ 40°C max. P –> PE 2000VAC for 2 sec P –> N 760VAC for 2 sec IP40 according to IEC 60529 -25°C to +85°C (25/85/21) UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 UL 94V-2 or better 2,200,000 hours Voltage selector description: Function: Series/parallel Voltage marking: Series: 110-120V Parallel: 220-240V Rocker switch description: Function: 2-pole, dark not illuminated Marking I - 0 Electrical specifications: Inrush current 51A 6,000 on-off operations according to UL 1054, TV 5 10,000 on-off operations according to ENEC Mechanical life: 50,000 cycles Switch ratings: USA (UL) and Canada (C-UL): 10A, 125VAC; 10A, 250VAC; 1/3HP Europe (ENEC): 10A (4A), 250VAC* * Approvals Standard types Cx R 2xL1 Cx1 2xCy N PE P Line Load E types Cx R 2xL1 Cx1 2xCy N PE P Line Load L2 Value in () relates to the inductive current charge: cos g = 0.65 Features and benefits Typical applications The FN 390 power entry module combines n n an IEC inlet, mains filter with single or based on chokes with high saturation equipment dual-fuse holder, voltage selector and 2-pole resistance and excellent thermal behavior. n Consumer goods rocker switch. Choosing FN 390 product n Rear or front mounting. n EDP and office equipment line brings you the rapid availability of a n Single or dual-fuse holder. n Single-phase power supplies, switch-mode standard filter associated with the necessary n USA safety acceptances. Standard IEC connector n 2-pole rocker switch. filters are a practical solution helping you n Voltage selector 110-120V / 220-240V. to pass EMI system approval in a short time. n Custom-specific versions are available on Multiple options designed to offer you the request. desired solution. High conducted attenuation performance, Ø6.3 x 32mm or EU Ø5 x 20mm fuses. Portable electrical and electronic power supplies n Test and measurement equipment > Components > FN 390 Filter selection table Filter Rated current Leakage current* @ 40°C (25°C) @ 230VAC/50Hz Inductance L1 L2 Cx Capacitance Resistance Output Cx1 Cy R connections FN 393-1-05-11 FN 393-2.5-05-11 FN 393-6-05-11 FN 394-1-05-11 FN 394-2.5-05-11 FN 394-6-05-11 [A] 1 (1.2) 2.5 (3) 6 (7.2) 1 (1.2) 2.5 (3) 6 (7.2) [μA] [mH] [mH] [nF] [nF] [nF] 560 7.5 220 3.3 560 2 220 3.3 560 0.45 220 3.3 560 7.5 220 3.3 560 2 220 3.3 560 0.45 220 3.3 [kΩ] 1000 05-11 1000 05-11 1000 05-11 1000 05-11 1000 05-11 1000 05-11 FN FN FN FN FN FN 393E-1-05-11 393E-2.5-05-11 393E-6-05-11 394E-1-05-11 394E-2.5-05-11 394E-6-05-11 1 (1.2) 2.5 (3) 6 (7.2) 1 (1.2) 2.5 (3) 6 (7.2) 560 560 560 560 560 560 FN FN FN FN FN FN FN FN 1393-1-05-11 1393-2.5-05-11 1393-6-05-11 1393-10-05-11 1394-1-05-11 1394-2.5-05-11 1394-6-05-11 1394-10-05-11 1 (1.2) 2.5 (3) 6 (7.2) 10 (12) 1 (1.2) 2.5 (3) 6 (7.2) 10 (12) 797 797 797 797 797 797 797 797 7.5 2 0.45 7.5 2 0.45 0.4 0.4 0.4 0.4 0.4 0.4 16 8 2.5 0.6 16 8 2.5 0.6 Weight [Qty] 1 1 1 2 2 2 [g] 200 200 200 200 200 200 220 220 220 220 220 220 3.3 3.3 3.3 3.3 3.3 3.3 1000 1000 1000 1000 1000 1000 05-11 05-11 05-11 05-11 05-11 05-11 1 1 1 2 2 2 205 205 205 205 205 205 220 220 220 220 220 220 220 220 4.7 4.7 4.7 4.7 4.7 4.7 4.7 4.7 470 470 470 470 470 470 470 470 05-11 05-11 05-11 05-11 05-11 05-11 05-11 05-11 1 1 1 1 2 2 2 2 210 210 210 210 210 210 210 210 100 100 100 100 100 100 100 100 * Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level. ** Filters are delivered without fuse. Note: for medical versions please contact your local partner within Schaffner‘s global network. Product selector FN (1)39xx-y-zz 05-11: Faston 6.3 x 0.8mm 1 to 10: Rated current Blank: Standard version E: Optional earth line choke 3: 1 fuse (Ø5 x 20mm or Ø6.3 x 32mm) 4: 2 fuses (Ø5 x 20mm or Ø6.3 x 32mm) Blank: Standard version 1: Additional Cx1 capacitor and higher inductivity For example: FN 393-1-05-11, FN 394E-2.5-05-11, FN 1394-10-05-11 Fuses** > Components > FN 390 Typical filter attenuation Per CISPR 17; A = 50Ω/50Ω sym; B = 50Ω/50Ω asym; C = 0.1Ω/100Ω sym; D = 100Ω/0.1Ω sym FN 39x: 1A types FN 39x: 2.5A types FN 39x: 6A types FN 139x: 1A types FN 139x: 2.5A types FN 139x: 6 and 10A types Mechanical data 1 to 10A types Panel cut out A C E 6.3 x 0.8 IEC plug type C14 R M N B G S U H P C J F J D I J Dimensions 1 to 10A A 50 B 65 C 40 D 69.5 E 28 F 5.5 G 59.6 H Ø3.3 I 15 J 7.5 M R ≤ 2.5 N 60.03 P 29.03 R M3 S 90° U 15 Tolerances ±0.3 ±0.3 ±0.1 ±0.3 ±0.3 ±0.2 ±0.2 All dimensions in mm; 1 inch = 25.4mm Tolerances according: ISO 2768-m / EN 22768-m Your local partner: To find your local partner within Schaffner’s global network, please go to www.schaffner.com May 2011 Headquarters and global innovation and development center Schaffner Group Nordstrasse 11 4542 Luterbach Switzerland T +41 32 681 66 26 F +41 32 681 66 30 info@schaffner.ch www.schaffner.com Sales and application centers China Schaffner EMC Ltd. Shanghai Building 11, Lane 1365 East Kangqiao Road Shanghai 201319 T +86 21 6813 9855 F +86 21 6813 9811 cschina@schaffner.com www.schaffner.com Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe T +49 721 56910 F +49 721 569110 germanysales@schaffner.com Finland Schaffner Oy Tynninkuja 7 08700 Lohja T +358 19 35 72 71 F +358 19 32 66 10 finlandsales@schaffner.com France Schaffner EMC S.A.S. 112, Quai de Bezons 95103 Argenteuil T +33 1 34 34 30 60 F +33 1 39 47 02 28 francesales@schaffner.com Italy Schaffner EMC S.r.l. Via Galileo Galilei, 47 20092 Cinisello Balsamo (MI) T +39 02 66 04 30 45/47 F +39 02 61 23 943 italysales@schaffner.com Japan Schaffner EMC K.K. Mitsui-Seimei Sangenjaya Bldg. 7F 1-32-12, Kamiuma, Setagaya-ku Tokyo 154-0011 T +81 3 5712 3650 F +81 3 5712 3651 japansales@schaffner.com www.schaffner.jp Sweden Schaffner EMC AB Turebergstorg 1, 6 19147 Sollentuna T +46 8 5792 1121 / 22 F +46 8 92 96 90 swedensales@schaffner.com Switzerland Schaffner EMV AG Nordstrasse 11 4542 Luterbach T +41 32 681 66 26 F +41 32 681 66 41 sales@schaffner.ch To find your local partner within Schaffner‘s global network, please go to Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1 05-09 Kampong Ubi Industrial Estate T +65 6377 3283 F +65 6377 3281 singaporesales@schaffner.com © 2011 Schaffner EMC. Specifications subject to change without notice. All trademarks recognized. Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de la Moraleja, Alcobendas 28109 Madrid T +34 618 176 133 spainsales@schaffner.com Taiwan Schaffner EMV Ltd. 6th Floor, No 413 Rui Guang Road Neihu District Taipei City 114 T +886 2 87525050 F+886 2 87518086 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Northern Region Industrial Estate 67 Moo 4 Tambon Ban Klang Amphur Muang P.O. Box 14 Lamphun 51000 T +66 53 58 11 04 F +66 53 58 10 19 thailandsales@schaffner.com UK Schaffner Ltd. 5 Ashville Way Molly Millars Lane Wokingham Berkshire RG41 2PL T +44 118 9770070 F +44 118 9792969 uksales@schaffner.com www.schaffner.uk.com USA Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey 08837 T +1 732 225 9533 F +1 732 225 4789 usasales@schaffner.com www.schaffner.com/us www.schaffner.com May 2011 Schaffner is an ISO-registered company. Its products are designed and manufactured under the strict quality and environmental requirements of the ISO 9001 and ISO 14001 standards. This document has been carefully checked. However, Schaffner does not assume any liability for errors or inaccuracies. Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Schaffner: FN1393-1-05-14 FN1394-10-05-11-QN-0 FN393-1-05-14 FN1394-1-05-11
FN1394-10-05-11-QN-0 价格&库存
很抱歉,暂时无法提供与“FN1394-10-05-11-QN-0”相匹配的价格&库存,您可以联系我们找货
  • 1+491.107301+63.56872
  • 20+397.5190320+51.45470
  • 40+378.5558640+49.00011
  • 60+367.8901660+47.61955
  • 100+354.88107100+45.93566
  • 260+331.77853260+42.94528
库存:344
