RP34-8P-3SC(71)
RP34-8P-3SC(71)
    HRS(广濑)
    Power Entry Connector Plug, Female Sockets RP34 Free Hanging (In-Line), Right Angle
RP34-8P-3SC(71) 数据手册
Small I/O connectors for AC adapters RP34 Series Features 1. Superior mating operability A snap-and-lock style allows easy mating/ unmating. 2. Cable direction is variable The three-position, right-angled plug makes it possible to arrange the cable to the left or right, offering flexible wiring options depending on your requirement. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3. Sequential contact mating Designed with sequential contact mating, one pin makes contact with its counterpart sooner than the others and establishes a securely grounded connection. 4. Easy plug assembly A snap-together case eliminates the need for screws to fasten the case and helps provide for a quick plug assembly. 5. Variations Items Number of contacts 3 or, 4 Plug : Straight, right angle Connector type Receptacle : Right angle Plug termination version Crimp Receptacle termination version PCB dip Receptacle mounting method PCB dip Product Specifications Rated current Rated voltage Ratings Items 1. Contact resistance 2. Insulation resistance 3. Withstanding voltage 4. Vibration resistance 3A AC30V, DC42V Operating temperature range Storage temperature range Specifications Conditions 30mø max Measured at DC 1A 1,000Mø min Measured at DC 100V No flashover or dielectric breakdown. AC 150V for 1 minute No electrical discontinuity for 10µs or longer. 5. Shock resistance No electrical discontinuity for 10µs or longer. 6. Mating Cycles Contact resistance : 60mø max. 7. Temperature cycle Insulation resistance : 100Mø min. 8. Moisture resistance -10 to +60℃ -10 to +60℃ Insulation resistance: 10Mø min (at high humidities). 100Mø min (when dry). 10 to 55Hz/cycle, amplitude : 0.75mm, 3 axis directions, 2 hours each Acceleration : 490m/s2, duration : 11ms, 3 axis directions, 3 cycles each 3 contacts : 5,000 times, 4 contacts : 1,000 times -55ç : 30 minutes ➝ Normal temperature : 10 to 15 minutes ➝ 85ç : 30 minutes➝ Normal Temperature : 10 to 15 minutes, left for 5 cycles Temperature : 40ç, relative humidity : 90 to 95%, left for 96 hours Materials / Finish Plug Receptacle Crimped female contact Items Exterior, insulator Clamp Bushing Male contact Material Polycarbonate resin Brass Vinyl chloride resin PBT resin Steel Brass Finish ―――― ―――― ―――― ―――― Tin plating Silver plating Remarks UL94V-0 ―――― ―――― UL94V-0 ―――― ―――― Female contact Phosphor bronze Silver plating ―――― Exterior, insulator In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2018.11③ 1 RP34 Series●Small plastic connectors for AC adapters Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. Connector RP34 - 8 SP - 3 S C (71) Model name : RP34 Series Shell size : The shell size is the outer diameter of the mating end of the plug. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Shell type SP : Straight plug P : Right-angled plug R : Receptacle Number of contacts : Contact form P : Male contact S : Female contact Contact termination method : C : Crimp contact termination DL : Right-angled dip method Other specifications : A two-digit character is added to indicate other specifications. Crimp contact RP34 - SC - 2 1 2 Model name : RP34 Series Contact type : SC = Crimped female contact Contact packaging types : 1 : Loose piece contacts 2 : Reel contacts Applicable wire : 1 : For 18 to 22 AWG 2 : For 24 to 28 AWG Identification of plating : 2 : Silver plating 2 RP34 Series●Small plastic connectors for AC adapters Straight plug 37.5 10 Ø4.4 30.5 7.5 A 3 1 2 RP34-8SP-3SC(71) HRS No. 113-5049-1 71 RP34-8SP-3SCD(71) 113-5061-7 71 RP34-8SP-4SC(71) 113-5097-4 71 No. of contacts A 3 9.6 4 11 Remarks ―――― Mating key dependent type ―――― Note : Cable clamping force, cable rotation force, and other aspects may differ depending on the cable construction. We reccomend that you verify the suitability of the cable assembly before use or production. Right-angled plug 25 7.5 2 18 Ø4.4 18 10 RP34-8P-3SC(71) 10 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. RP34-8SP-3SC(71) (This figure is a representative example.) 3 1 2 (This figure is a representative example.) Part No. RP34-8P-3SC(71) HRS No. 113-5041-0 71 Note : Cable clamping force, cable rotation force, and other aspects may differ depending on the cable construction. We recommend that you verify the suitability of the cable assembly before use or production. 3 RP34 Series●Small plastic connectors for AC adapters Receptacle 11.3 A 10 1 3 3 2 B RP34-8R-3PDL Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. (This figure is a representative example.) HRS No. No. of contacts RP34-8R-3PDL 113-5042-2 RP34-8R-3PDLD 113-5066-0 RP34-8R-4PDL 113-5098-7 A B 3 10 11 4 11 12 Remarks ―――― Mating key dependent type ―――― Contact (female contact) Part No. HRS No. B A_A RP34-SC-212 113-5043-5 1.6 Applicable wire size 2.1 18 to 22 AWG B RP34-SC-112 113-5076-4 1.6 2.1 18 to 22 AWG RP34-SC-222 113-5100-7 1.2 1.35 24 to 28 AWG RP34-SC-122 113-5102-2 1.2 1.35 24 to 28 AWG 1.48 C A A C Remarks Reel contacts Loose piece contacts Reel contacts Loose piece contacts Note : Loose piece contacts are packaged 100 pcs/pack and reel contacts are available on 10,000 piece reel. Please order in full quantity packs or reels. 8.7 Dip post arrangement for PCB layout 5.25 5.9 2 2.1 .1 +0 0 .5 Ø1 1 .7 3 0.8 0.8 1. Ø1 4- 1 +0 .1 +0 0 1.9 0 .1 4 4Ø +0 0 .1 1.7 4-Ø 1.9 5.25 10.5 0 4 position 2.1 5 +0.1 Ø1. 7.4 1 +0. 0 1.1 3-Ø Positioning hole (1 location) 4.25 4.75 2.75 4.75 Positioning hole (1 location) 10.5 3 position 2.4 2.4 Remarks 1. The applicable PCB thickness is between 0.8 and 1.6mm. 2. A machining tolerance of ±0.05 is recommended for the PCB layout. 3. The above figure shows the PCB side of the rack into which contact dip posts will be inserted. "▼" mark indicates the plug interface mating side. 4 RP34 Series●Small plastic connectors for AC adapters Termination procedure Straight plug Operation procedure̶straight plug 1. First, pass the prepared cable through the bushing, and then crimp and terminate the contacts. 2. Assemble the crimped and terminated contacts into the contact holes of the S-insulation P case. At this time, please make sure that the crimped contacts are securely engaged onto the contact holes of the S-insulation P case by lightly pulling on the cable. 3. Crimp and fix the metal fitting for clamping with the applicable tool (RP34-TC-01). 4. Assemble the S-insulation P case, metal fitting for clamping, and bushing onto the cord tube (A). The S-insulation P case can be assembled in two ways, at 180° opposing angles. Please make sure to select the orientation that is suitable for your purpose. 5. Finally, assemble the remaining cord tube (B). The assembly has been completed. Metal fitting for clamping 20 Cord tube (A) or (B) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2 0 S-insulation P case +0.5 2mm or more Bushing 1.3 Cable Rightangle plug Operation procedure̶right-angled plug 1. The right-angled plugs can be assembled in the same manner as the straight plugs, and the S-insulation P case can be assembled to the cord tube in one of two positions. 180° opposite each other. Please make sure to select the orientation that is suitable for your purpose. Cover S-insulation P case Cord tube Applicable tools Type Machine crimping Items Part No. HRS No. Applicable contact Applicable wire size Automatic crimping press CM-105C 901-0001-0 ―――― ―――― AP105-RP34-1 901-2025-2 RP34-SC-212 18 to 22 AWG AP105-RP34-2 901-2034-3 RP34-SC-222 24 to 28 AWG Applicator Cable crimping tool RP34-TC-01 150-0074-1 ―――― ―――― Extraction tool RP34-SC-TP 150-0072-6 ―――― ―――― Cable crimping tool (RP34-TC-01) (The handle shape shown above is a representative example.) Automatic crimping press (Type CM-105C) 5 RP34L Series●Small plastic connectors for AC adapters Type RP34L Product Specifications Ratings Rated current 5A (when using 18 AWG) Operating temperature range −25℃ to +85℃ Rated voltage AC30V, DC42V Storage temperature range −10℃ to +60℃ Items Specifications Conditions 1. Contact resistance 30mø max. 2. Insulation 1,000Mø min. resistance 3. Withstanding No flashover or dielectric breakdown. voltage Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4. Vibration proof No electrical discontinuity 10µs or longer. 5. Temperature cycle Insulation resistance : 100Mø min 6. Corrosion resistance 7. Mating Cycles Measured at DC 1A Measured at DC 100V AC 150V for 1 minute 10 to 55Hz, half amplitude : 0.75mm, 3 axis directions, 2 hours each -55ç : 30 minutes ➝ Normal temperature : 10 to 15 minutes ➝ +85ç : 30 minutes ➝ Normal Temperature : 10 to 15 minutes, 5 cycles No corrosion that affects performance. Left in 5% salt water solution for 48 hours Contact resistance : 60mø max 5,000 times Materials / Finish Items Receptacle̶ (2position) Plug̶ (2 position) Receptacle̶ (3 position) Metal fitting Material Phosphor bronze Insulator Polyamide resin Black UL94HB Contact Brass Palladium plating ―――― Exterior Vinyl chloride resin Insulator Polyamide resin Black UL94V-0 UL94HB Contact Phosphor bronze Silver plating ―――― Phosphor bronze Solder plating ―――― Insulator PPS resin Black UL94V-0 Brass Palladium plating ―――― Black UL94V-0 Palladium plating ―――― Exterior Polycarbonate resin Vinyl chloride resin Insulator PPS resin Contact Phosphor bronze ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. RP34L - 5 PA - 2 SC (****) Series name : RP34L Shell : Indicates the shell form. Type Receptacle : R Straight plug : PA Right-angled plug : LP Number of contacts : Shows the number. 2 or 3 contacts. 6 Remarks ―――― Metal fitting Contact Plug̶ (3 position) Finish Solder plating Contact type PD : Male contact (dip) SC : Female contact (crimped) Cable length : (****) may vary depending on the cable. RP34L Series●Small plastic connectors for AC adapters Receptacle 2 position 3 position 2 position 7 9.1 7 2.5 2.5 6.1 5 7.4 RP34L-5R-2PD(71) Recommended panel opening dimensions (reference) 7.5 +0.1 0 Recommended panel opening dimensions (reference) 0 -0.1 1.3 7.4 +0.1 0 3− Ø1 + .1 0 . 0 1 1.35±0.05 1.35±0.05 3 4±0.05 0 4− Ø1 .1 2.35±0.05 +0 0 .1 4±0.05 .1 2− Ø1.5 +0 0 3 2− Ø1.5 +0.1 RP34L-5R-3PD(71) 113-5157-4 71 4.3±0.05 2.35±0.05 4.5±0.05 4.3±0.05 3.45±0.05 (Mating interface side) (Mating interface side) 1.15±0.05 PCB layout mounting dimensions PCB layout dimension 3.45±0.05 (1.2) PCB Plug Panel 0.2±0.05 Part No. HRS No. RP34L-5R-2PD(71) 113-5154-6 71 1.3 -0.1 3.9 6.2 (1.2) RP34L-5R-3PD(71) 0 +0.1 0 PCB Plug 1857 A 22.4 4.8 5.5 2.5 7.6 A Bushing Single-contact shielded cable (Center conductor wires: 18 AWG, shielded cable: 18AWG or equivalent) Ø9 6 A_A 21.5 Board-in crimping contact 1.5 9.7 7 6.1 1800 Ø3.5 7.8 R3 6 RP34L-5PA-2SC(1857)(71) 29.7 23.1 6.2 10.45 7.2 4.8 Ø4.4 7.8 3.7 (External shell) RP34L-5PA-3SC(71) Ø4.4 RP34L-5LP-3SC(71) 11.625 4.8 7.2 10.9 11.85 2.65 6.2 5.925 11.4 17.6 11 7.8 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. +0.1 0 Panel 2.12±0.05 3 position 3.7 Part No. HRS No. RP34L-5PA-2SC(1857)(71) 113-5153-3 71 RP34L-5PA-3SC(71) 113-5178-4 71 RP34L-5LP-3SC(71) 113-5161-1 71 7 RP34L Series●Small plastic connectors for AC adapters Crimp contact 1.6 0.3 2.2 A A 12.7 Section A_A RP34L-SC1-212(01) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. RP34L-SC1-212(01) HRS No. 113-5151-8 01 Applicable tools Type Manual crimping tools Automatic Machine crimping press crimping Applicator Part No. HT-102/RP34L-SC1-212 HRS No. 150-0210-8 Applicable contact RP34L-SC1-112(01) Applicable cables 18 to 22 AWG CM-105C 901-0001-0 -------------- -------------- AP105-RP34L-SC1-212 901-2043-4 RP34L-SC1-212(01) 18 to 22 AWG Cable crimping tool RP34-TC-01 150-0074-1 -------------- Ø4 Extraction tool RP6-SC-TP 150-0039-0 -------------- -------------- Assembly procedure (3 position plug) Straight plug Cable Bushing 2 1 Metal fitting for clamping 8 2 +0.5 0 5.3 (Mating section) (Round hole) Cord tube (A) Cord tube (B) Cord tube (A) (Tab) S-insulation P case Cord tube (B) Right angle 1. Right-angled plugs can be assembled in the same manner as the straight plugs. 13.7 2 +0.5 0 S-insulation P case Metal fitting for clamping 2 11 2 Bushing Cable Metal fitting for clamping S-insulation P case 8 1 1. First pass the prepared cable through the bushing, and then crimp and terminate the contacts. 2. Assemble the crimped and terminated contacts into the contact holes of the S-insulation P case. At this time, please make sure that the crimped contacts are securely engaged onto the contact holes of the S-insulation P case by lightly pulling the cable. If you find an erroneous wiring, insert the extractor (RP6-SC-TP) from the mating side to pull out the contact from the termination side, and then reassemble. 3. Crimp the metal fitting for clamping with the applicable tool (RP34TC-01). 4. Align and assemble the protrusion of the S-insulation P case to the round hole of the cord tube (B). 5. Attach the mating section of the metal fitting for clamping to the recess of the cord tube (B), and then assemble the bushing and metal fitting for clamping onto the cord tube (B). 6. Assemble the cord tube (A) onto the cord tube (B). At this time, please make sure that the four tabs of the cord tube (B) rest on the angled hole of the cord tube (A). Cord tube RP34L Series●Small plastic connectors for AC adapters Precautions 1. To prevent damage to the connector after mounting, make sure that it is supported with a panel or another substrate. This will prevent any type of excessive load or force on the connector. For 2 position type, please support the external shell of the receptacle. For 3 position type, please support the external shell of the plug.  See page 3 for details on recommended panel dimensions. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Receptacle Panel (External shell) Receptacle Plug Panel 2. When mated together, do not apply a load of 30 N or more on the cable in the direction indicated by the arrows. Please note that an excessive tensile stress may break the connectors. 3. This product series uses silver plated contacts. Silver reacts easily to exposure to sulfur gas so the below conditions may cause tarnishing.  ・Dusty environments  ・Area with a high concentration area of gases such as sulfur dioxide gas, hydrogen sulfide gas, nitrogen dioxide gas and so on. Example; In close proximity to factory exhaust, automotive emissions, etc.  ・Close to heaters, or in other areas marked by extreme temperature differences or high humidity.  ・Close to rubber products includes rubber adhesives. The Electrical connection is not affected by tarnishing on a silver surface due to the wiping effect of the contact pins. Storage Packing state; Packed in original packing or equivalent container Temperature -10 to +60ç Humidity 85% Max (It is recommended that the product be stored in an area of normal level of temperature and humidity, and free of any temperature fluctuation) Please use this products within 6 months of delivery. (After 6 month, please check the solderbility before use) “Storage” means long-term storage of the unused products in sealed packaging, prior to assembly to PCB. 9 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. RP34 Series●Small plastic connectors for AC adapters MEMO : 10 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. RP34 Series●Small plastic connectors for AC adapters MEMO : 11 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. RP34 Series●Small plastic connectors for AC adapters USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE 2300 Warrenville Road, Suite 150, Downers Grove, IL 60515 Phone : +1-630-282-6700 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 2841 Junction Ave, Suite 200 San Jose, CA. 95134 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 17197 N. Laurel Park Drive, Suite 253, Livonia, MI 48152 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE 300 Brickstone Square Suite 201, Andover, MA 01810 Phone : +1-978-662-5255 THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Schoenbergstr. 20, 73760 ostfildern Phone : +49-711-456002-1 Fax : +49-711-456002-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE Neumeyerstrasse 22-26, 90411 Nurnberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE Bayernstr. 3, Haus C 30855 Langenhagen, Germany Phone : +49-511 97 82 61 30 Fax : +49-511 97 82 61 35 http://www.hirose.com/eu/ FRANCE: HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE 130 Avenue Joseph Kessel, Bat E, 78960 Voisins le Bretonneux, France Phone : +33-1-85764886 Fax : +33-1-85764823 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. (SHANGHAI, HEADQUARTERS) 18, Enterprise Center Tower 2, 209# Gong He Road, Jing’an District, Shanghai, CHINA 200070 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. SHENZHEN BRANCH Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7355 http://www.hirose.com/tw/ KOREA: HIROSE KOREA CO.,LTD. 143, Gongdan 1-daero, Siheung-si, Gyeonggi-do, 15084, Korea Phone : +82-31-496-7000 Fax : +82-31-496-7100 http://www.hirose.co.kr/ SINGAPORE: INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE HIROSE ELECTRIC SINGAPORE PTE. LTD. 03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C, Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India Singapore 079909 Phone : +91-12-660-8018 Phone : +65-6324-6113 Fax : +91-120-4804949 Fax : +65-6324-6123 http://www.hirose.com/sg/ http://www.hirose.com/sg/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma Gandhi (MG) Road, Bangalore 560 001, Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ MALAYSIA: THAILAND: PENANG REPRESENTATIVE OFFICE BANGKOK OFFICE (REPRESENTATIVE OFFICE) 73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn Road, Yannawa, Sathorn, Bangkok 10120 Thailand Lepas Penang, 11950, Malaysia Phone : +66-2-686-1255 Phone : +604-648-5536 Fax : +66-2-686-3433 http://www.hirose.com/sg/ http://www.hirose.com/sg/ ® 12 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 11/2018. Contents are subject to change without notice for the purpose of improvements.
RP34-8P-3SC(71)
物料型号:HIROSE ELECTRIC CO., LTD. 提供的RP34系列小型I/O连接器,适用于交流适配器。
器件简介: - 特点包括优越的配对操作性、可变的电缆方向、顺序接触配对、简易的插头组装,以及多种变化选项。 - 提供直插头和直角插头,接触件数量可选3或4个。
引脚分配: - 接触件类型包括公接触件和母接触件,接触终止方式包括压接。
参数特性: - 额定电流为3A,适用于-10至+60°C环境。 - 额定电压为交流30V或直流42V。 - 接触电阻最大30毫欧,绝缘电阻最小1000兆欧,耐电压测试为交流150V持续1分钟无击穿或闪络。
功能详解: - 顺序接触配对设计,确保接地连接的安全性。 - 提供了抗振、抗冲击、耐温、耐湿等性能测试结果。
应用信息: - 适用于需要高可靠性的应用场景,如汽车领域。
封装信息: - 材料包括聚碳酸酯树脂、PBT树脂、黄铜、钢(镀锡)、磷青铜(镀银)等。 - 完成品的封装方式包括散装和卷装。
RP34-8P-3SC(71) 价格&库存
很抱歉,暂时无法提供与“RP34-8P-3SC(71)”相匹配的价格&库存,您可以联系我们找货
