DATA SHEET
Power Entry Module with EMC- Filter FN9260/
FN261
General Purpose Power Entry Module with Fuses
Rated currents up to 10 A
Approvals & Compliances
Integrated single/dual fuse holder
Optional reduced leakage current versions
(A/B type)
Complies with IEC/EN 60601-1
Snap-in versions (S type)
Good attenuation performance
NEW: Wire leads option
Performance indicators
The FN9260 power entry module combines an IEC
inlet, mains filter with excellent filter attenuation
and fuses in a small form factor. Choosing FN9260
product line brings you rapid availability of a
standard filter associated with the necessary safety
acceptances. Standard IEC connector filters are a
practical solution helping you to pass EMI system
approval in a short time. A wide selection on
amperage ratings, output connections, mounting
possibilities and filters for medical applications are
designed to offer you the desired solution.
Features and Benefits
Exceptional conducted attenuation performance,
based on chokes with high saturation resistance
and excellent thermal behavior
FN9260 B versions comply with the requirements
of 1MOP acc. to IEC/EN 60601-1 for creepage and
clearance, leakage current and high potential
testing
Versions up to 10 A are available with fuse holder
for one or two fuses
Technical Specifications
Custom-specific versions are available on request
Maximum continuous operating voltage
250 VAC, 50/60 Hz
Operating frequency
DC to 400 Hz
Rated currents
1 to 10 A @ 40°C max
Portable electrical and electronic equipment
High potential test voltage
P –> PE 2000 VAC for 2 sec (standard types)
P –> PE 2500 VAC for 2 sec (B types)
P –> N 760 VAC for 2 sec
Medical equipment
Protection category
IP 40 according to IEC 60529
Temperature range (operation and storage)
-25°C to +85°C (25/85/21)
Single-phase power supplies, switch-mode power
supplies
Design corresponding to
UL 60939-3, CSA Std C22.2 No. 8-13, IEC/EN 60939-3,
GB/T15287, GB/T15288
Test and measurement equipment
Flammability corresponding to
Inlet plastic: UL 94 V-0
Fuseholder plastic: UL 94 V-0
Typical electrical schematic
MTBF @ 40°C/230 V (Mil-HB-217F)
2,200,000 hours
Fuse holder
1 or 2 fuses (Ø5 x 20 mm) (certified to IEC 60127-6),
power acceptance 1.6W @ Ta 23°C per pole for 2 fuses.
2.5W, if only 1 pole is used.
Typical Applications
Small to medium-sized machines and household
equipment
2
Schaffner Group
DATA SHEET
24. Nov
2022
Filter Selection Table
Filter
Buy
Rated current
Leakage current*
Inductance**
Capacitance**
Resistance**
@ 40°C (25°C)
@ 250 VAC/50 Hz
L
Cx
Cy
R
Output
connections
Fuses***
Weight
[Qty]
[g]
(@ 120 VAC/60 Hz)
[A]
[mA]
[mH]
[μF]
[nF]
[kΩ]
FN9260v-1-yy-zz
1 (1.2)
0.31 (0.18)
5.3
0.1
2.2
1000
-06
-07
2
55
FN9260v-2-yy-zz
2 (2.3)
0.31 (0.18)
2.7
0.1
2.2
1000
-06
-07
2
55
FN9260v-4-yy-zz
4 (4.6)
0.31 (0.18)
1.0
0.1
2.2
1000
-06
-07
2
55
FN9260v-6-yy-zz
6 (6.9)
0.31 (0.18)
0.3
0.1
2.2
1000
-06
-07
2
55
10 (11.5)
0.31 (0.18)
0.2
0.1
2.2
1000
-06
-07
2
55
FN9260vA1-1-yy-zz
1 (1.2)
0.03 (0.02)
5.3
0.1
0.22
1000
-06
-07
2
55
FN9260vA-2-yy-zz
2 (2.3)
0.07 (0.04)
2.7
0.1
0.47
1000
-06
-07
2
55
FN9260vA-4-yy-zz
4 (4.6)
0.07 (0.04)
1.0
0.1
0.47
1000
-06
-07
2
55
FN9260v-10-yy-zz
FN9260vA-6-yy-zz
6 (6.9)
0.07 (0.04)
0.3
0.1
0.47
1000
-06
-07
2
55
10 (11.5)
0.07 (0.04)
0.2
0.1
0.47
1000
-06
-07
2
55
FN9260vB-1-yy-zz
1 (1.2)
0.00
5.3
0.1
1000
-06
-07
2
55
FN9260vB-2-yy-zz
2 (2.3)
0.00
2.7
0.1
1000
-06
-07
2
55
FN9260vB-4-yy-zz
4 (4.6)
0.00
1.0
0.1
1000
-06
-07
2
55
FN9260vB-6-yy-zz
6 (6.9)
0.00
0.3
0.1
1000
-06
-07
2
55
10 (11.5)
0.00
0.2
0.1
1000
-06
-07
2
55
FN261v-1-06-zz
1 (1.2)
0.31 (0.18)
5.3
0.1
2.2
1000
-06
1
55
FN261v-2-06-zz
2 (2.3)
0.31 (0.18)
2.7
0.1
2.2
1000
-06
1
55
FN261v-4-06-zz
4 (4.6)
0.31 (0.18)
1.0
0.1
2.2
1000
-06
1
55
FN261v-6-06-zz
6 (6.9)
0.31 (0.18)
0.3
0.1
2.2
1000
-06
1
55
10 (11.5)
0.31 (0.18)
0.2
0.1
2.2
1000
-06
1
55
FN9260vA-10-yy-zz
FN9260vB-10-yy-zz
FN261v-10-06-zz
* Leakage current under normal operating conditions (acc. to IEC60939-3). Note: if the neutral line is interrupted, worst case leakage could reach twice this
level.
** Tolerances apply: Inductance: -30/+50%, Capacitance: ±20%, Resistance: ±10%
*** Fuses are not included in the filter and need to be selected according to application
Product selector
FN9260vw- xx-yy-zz
Snap -in range for S version only
10:
Snap -in range 0.6 to 1.5mm
20:
Snap -in range 1.6 to 2.5mm
30:
Snap -in range 2.6 to 3.5mm
06:
07:
Fast-on 6.3 x 0.8mm (spade/soldering)
Wire leads
1 to 10: Rated current
Blank:
A:
B:
Standard version
Safety version
Medical version (without Y-capacitor)
Blank:
S:
Standard housing with mounting flanges
Snap -in version, snapper on vertical side
For example: FN9260-1-06-10, FN9260SB-10-06-20, FN261S-6-06-30
3
Schaffner Group
DATA SHEET
24. Nov
2022
Typical Filter Attenuation
Per CISPR 17; DM (differential mode)=50 Ω/50 Ω sym; CM (common mode)=50 Ω/50 Ω asym
FN261/ FN9260: 1 A type
FN261/ FN9260: 2 A type
FN261/ FN9260: 4 A type
FN261/ FN9260: 6 and 10 A types
Mechanical Data
FN9260w-xx-06-zz / FN261
FN9260Sw-xx-06-zz / FN261S
FN9260w-xx-07-zz
FN9260Sw-xx-07-zz
B
B
IEC PLUG TYPE C14
IEC PLUG TYPE C14
H
S
BU
BU
J
AC J
GNYE
E
Z
G
Panel cut out
F
D
A
J
J
E
GNYE
BN
Z
BN
G
I
F
D
I
Installation
For selecting the panel thickness, please refer to the filter selector table
4
Schaffner Group
DATA SHEET
24. Nov
2022
Dimensions
FN9260vw-xx-06-zz
FN261
Fast-On
FN9260vw-xx-07-zz
FN9260Sw-xx-07-zz
Wire leads**
FN9260Sw-xx-06-zz
FN261
Fast-On
A
46
Wire leads**
Tolerances
46
34
34
B
±0.3
35
35
35
35
±0.3
C
36
36
D
41
50
41
50
E
27.8
27.8
27.8
27.8
F
5.5
5.5
5.5
5.5
±0.3
G
32
32
32
32
+0.3/-0
H
±0.3
Ø3.2
Ø3.2
I
14±0.5
160±5**
14±0.5
160±5**
J
12.5
7.8
12.5
7.8
±0.1
M
R ≤3.5
R ≤3.5
R ≤3.5
R ≤3.5
N
33 +0.3/-0
33 +0.3/-0
33 +0.2/-0
33 +0.2/-0
P
29 ±0.3
29 ±0.3
29.5 ±0.2
29.5 ±0.2
R*
M3
M3
S
90°
90°
Z
6
*Recommended torque for M3 (90° countersunk flat head) is 0.5 Nm
** 1 A - 6 A - AWG18; 10 A - AWG16
All dimensions in mm; 1 inch = 25.4 mm / Tolerances according: ISO 2768-m/EN 22768-m
Please visit www.schaffner.com to find more details on filter connections.
+0.3/-0
6
5
Schaffner Group
DATA SHEET
24. Nov
2022
Accessories
IL 13P IEC C13 R
Re
ewir
wireable
eable Connec
Connecttors with LLock
ocking
ing Syst
System
em
The locking system has a tensile force of typical
300N. It is recommended to use it with flange
mount filters. For details refer to our Application
Note "Using IEC Lock Power Cords with IEC Inlets
and Filters".
Schaffner power connector with IEC lock guard
against accidental disconnection of all electrical
appliances with an IEC inlet. No exchange or
modification of the IEC inlet or IEC inlet filter system
is needed. Easy retrofit .for all electronic
equipments and devices
Technical Data Sheet >
IL 13P IEC C13 R
Re
ewir
wireable
eable Angled Connec
ocking
ing Syst
System
em
Protects appliances that are vulnerable to
vibration
Connector cannot be accidentally pulled or
vibrated out of the inlet
Space availability/constraints
Different angles for ease of access
Space saving
Release locking mechanism
Prevents accidental disconnection
Power Cor
Cord
d with angled LLock
ocking
ing Syst
System
em C13
vibration
Space saving
6
Schaffner Group
DATA SHEET
24. Nov
2022
Headquarters, Global
Innovation and
Development
Switzerland
Schaffner Group
Industrie Nord
Nordstrasse 11e
4542
Luterbach
+41 32 681 66 26
info@schaffner.com
Sales and Application
Centers
China
Schaffner EMC Ltd. Shanghai
T20-3 C No 565 Chuangye Road Pudong
district
201201
Shanghai
+86 2138139500
cschina@schaffner.com
Spain
Schaffner EMC España
Calle Caléndula 93 Miniparc III Edificio E El
Soto de Moraleja Alcobendas
28109
Madrid
+34 917 912 900
spainsales@schaffner.com
Finland
Schaffner Oy
Sauvonrinne 19 H
8500
Lohja
+358 50 468 7284
finlandsales@schaffner.com
Sweden
Schaffner EMC AB
Östermalmstrorg 1
114 42
Stockholm
+46 8 5050 2425
swedensales@schaffner.com
France
Schaffner EMC S.A.S.
16-20 Rue Louis Rameau
95875
Bezons
+33 1 34 34 30 60
francesales@schaffner.com
Switzerland
Schaffner EMV AG
Industrie Nord
Nordstrasse 11e
4542
Luterbach
+41 32 681 66 26
switzerlandsales@schaffner.com
Germany
Schaffner Deutschland GmbH
Schoemperlenstrasse 12B
76185
Karlsruhe
+49 721 56910
germanysales@schaffner.com
India
Schaffner India Pvt. Ltd
Regus World Trade Centre
WTC 22nd Floor Unit No 2238 Brigade
Gateway Campus 26/1 Dr. Rajkumar Road
Malleshwaram (W)
560055
Bangalore
+91 8067935355
indiasales@schaffner.com
To find your local partner within
Schaffner‘s global network schaffner.com
© 2022 Schaffner Group
The content of this document has been
carefully
checked
and
understood.
However, neither Schaffner nor its
subsidiaries
assume
any
liability
whatsoever for any errors or inaccuracies
of this document and the consequences
thereof. Published specifica-tionsw are
subject to change without notice. Product
suitability for any area of application must
ultimately
be
determined
by
the
customer. In all cases, products must
never be operated outside their published
specifications.
Schaffner
does
not
guarantee the availability of all published
products. This disclaimer shall be
governed by substantive Swiss law and
resulting disputes shall be settled by the
courts at the place of business of Schaffner
Holding AG. Latest publications and a
complete disclaimer can be downloa-ded
from the Schaffner website. All trademarks
recognized.
Italy
Schaffner EMC S.r.l.
Via Ticino, 30
20900
Monza (MB)
+39 039 21 41 070
italysales@schaffner.com
Japan
Schaffner EMC K.K.
ISM Sangenjaya 7F
1-32-12 Kamiuma Setagaya-ku
154-0011
Tokyo
+81 3 5712 3650
japansales@schaffner.com
Singapore
Schaffner EMC Pte Ltd.
Blk 3015A Ubi Road 1 #05-09 Kampong Ubi
Industrial Estate
408705
Singapore
+65 63773283
singaporesales@schaffner.com
Taiwan
Schaffner EMV Ltd.
U-Town
20 Floor-2 No 97 Section 1 XinTai 5th Road
XiZhi District
22175
New Taipei City
+886 226975500
taiwansales@schaffner.com
Thailand
Schaffner EMC Co. Ltd.
Sathorn Square Tower
Room 3780 37FL 98 North-Sathorn Rd Silom
Bangrak
10500
Bangkok
+66 621056397
thailandsales@schaffner.com
United Kingdom
Schaffner Ltd.
Suite 1 Oakmede Place
Terrace Road
RG42 4JF
Binfield
+44 118 9770070
uksales@schaffner.com
United States
Schaffner EMC Inc.
52 Mayfield Avenue
Edison, New Jersey
+1 732 225 9533
usasales@schaffner.com
很抱歉,暂时无法提供与“FN9260A1-1-06”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+157.779501+20.41119
- 10+134.1184710+17.35027
- 25+125.7178325+16.26352
- 60+118.1874160+15.28935
- 120+112.54910120+14.55995
- 300+105.50935300+13.64925
- 540+101.22839540+13.09544
- 国内价格
- 1+170.91250
- 5+150.40300
- 10+143.56650
