DATA SHEET
IEC Inlet Filters FN9244E
Excellent Performance EMC/EMI Filter with Earth Line Choke
Rated currents up to 15 A
Approvals & Compliances
Superior attenuation performance
Integrated earth line choke
Complies with IEC/EN 60601-1
Snap-in versions (S and S1 type)
Hot inlet versions (HI type)
(CQC except HI-types)
Performance indicators
The FN 9244 E IEC inlet filter combines an IEC inlet
and mains filter with superior filter attenuation in a
small form factor. The FN 9244 E high performance
power entry module offers additional EMI
suppression on the earth line. Choosing the FN
9244 E product line brings you the rapid availability
of a standard filter associated with the necessary
safety acceptances. Standard IEC connector filters
are a practical solution helping you to pass EMI
system approval in a short time. A wide selection
on amperage ratings, output connections,
mounting possibilities and filters for medical
applications are designed to offer you the desired
solution. For types without additional earth line
choke please consult the FN 9244 data sheet.
Features and Benefits
Technical Specifications
Superior conducted attenuation performance,
based on chokes with high saturation resistance
and excellent thermal behavior
Maximum continuous operating voltage
250 VAC, 50/60 Hz
Operating frequency
DC to 400 Hz
Rated currents
Without earth line choke see FN 9244 data sheet
1 to 15 A @ 50°C
Approvals by rated current
1 to 10 A (ENEC, CQC)
1 to 15 A (UL, CSA)
High potential test voltage
P –> PE 2000 VAC for 2 sec (standard types)
P –> PE 2500 VAC for 2 sec (B types)
P –> N 1000 VAC for 2 sec
FN 9244 B versions comply with the
requirements of 1MOP acc. to IEC/EN 60601-1 for
creepage and clearance, leakage current and
high potential testing
Rear/front or snap-in mounting
Wide mounting flanges available
Custom-specific versions are available on request
Protection category
IP 40 according to IEC 60529
Temperature range (operation and storage)
-25°C to +85°C (25/85/21)
Design corresponding to
UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939
Flammability corresponding to
UL 94 V-2 or better
Electrical and electronic equipment
MTBF @ 40°C/230 V (Mil-HB-217F)
2,230,000 hours
Small to medium-sized machines and household
equipment
Typical Applications
Single-phase power supplies, switch-mode power
supplies
Test and measurement equipment
Medical devices (MDD)
In-vitro diagnostic medical devices (IVDD)
Rack mounting equipment
Typical electrical schematic
2
IEC Inlet Filters
Schaffner Group
DATA SHEET
21. Jun 2022
Filter Selection Table
Filter
Rated current
@ 50°C (25°C)
Leakage current*
Inductance
Capacitance
Resistance
@ 250 VAC/50 Hz
L1
L2
Cx
Cy
R
[kΩ]
Output connections
Weight
(@ 120 VAC/60 Hz)
[A]
[mA]
[mH]
[mH]
[μF]
[nF]
[g]
FN9244Ex-1-06
1 (1.2)
0.31 (0.18)
59.53
0.4
0.1
2.2
-06
46
FN9244Ex-3-06
3 (3.5)
0.31 (0.18)
13.45
0.4
0.1
2.2
-06
46
FN9244Ex-6-06
6 (7.2)
0.31 (0.18)
4.1
0.4
0.1
2.2
-06
46
FN9244Ex-8-06
8 (10.6)
0.31 (0.18)
2.3
0.4
0.1
2.2
-06
46
FN9244Ex-10-06
10 (11.6)
0.31 (0.18)
1.02
0.4
0.1
2.2
-06
46
FN9244Ex-12-06
12 (12)
0.31 (0.18)
0.58
0.1
0.1
2.2
-06
46
FN9244Ex-15-06
15 (15)
0.31 (0.18)
0.4
0.1
0.1
2.2
-06
46
FN9244Ex-12-06HI
12 (12)
0.31 (0.18)
0.58
0.1
0.1
2.2
-06
46
FN9244Ex-15-06HI
15 (15)
0.31 (0.18)
0.4
0.1
0.1
2.2
-06
46
FN9244ExR-1-06
1 (1.2)
0.31 (0.18)
59.53
0.4
0.1
2.2
1000
-06
46
FN9244ExR-3-06
3 (3.5)
0.31 (0.18)
13.45
0.4
0.1
2.2
1000
-06
46
FN9244ExR-6-06
6 (7.2)
0.31 (0.18)
4.1
0.4
0.1
2.2
1000
-06
46
FN9244ExR-8-06
8 (10.6)
0.31 (0.18)
2.3
0.4
0.1
2.2
1000
-06
46
FN9244ExR-10-06
10 (11.6)
0.31 (0.18)
1.02
0.4
0.1
2.2
1000
-06
46
FN9244ExR-12-06
12 (12)
0.31 (0.18)
0.58
0.1
0.1
2.2
1000
-06
46
FN9244ExR-15-06
15 (15)
0.31 (0.18)
0.4
0.1
0.1
2.2
1000
-06
46
FN9244ExR-12-06HI
12 (12)
0.31 (0.18)
0.58
0.1
0.1
2.2
1000
-06
46
FN9244ExR-15-06HI
15 (15)
0.31 (0.18)
0.4
0.1
0.1
2.2
1000
-06
46
FN9244ExB-1-06
1 (1.2)
0.00
59.53
0.4
0.1
1000
-06
46
FN9244ExB-3-06
3 (3.5)
0.00
13.45
0.4
0.1
1000
-06
46
FN9244ExB-6-06
6 (7.2)
0.00
4.1
0.4
0.1
1000
-06
46
FN9244ExB-8-06
8 (10.6)
0.00
2.3
0.4
0.1
1000
-06
46
FN9244ExB-10-06
10 (11.6)
0.00
1.02
0.4
0.1
1000
-06
46
FN9244ExB-12-06
12 (12)
0.00
0.58
0.1
0.1
1000
-06
46
FN9244ExB-15-06
15 (15)
0.00
0.4
0.1
0.1
1000
-06
46
FN9244ExB-12-06HI
12 (12)
0.00
0.58
0.1
0.1
1000
-06
46
FN9244ExB-15-06HI
15 (15)
0.00
0.4
0.1
0.1
1000
-06
46
* Maximum leakage under normal operating conditions (acc. to IEC60939-3). Note: if the neutral line is interrupted, worst case leakage could reach twice this
level.
Distributor Inventory
Check stock levels at global distributors at
https://products.schaffner.com/stock
(Also available via the QR code)
Stock level per types 1 - 15 A
Standard housing types
Housing with wider mounting flanges (U)
Snap-in housing types (S&S1)
Medical versions (B)
Bleed resistor types (R)
Link
3
IEC Inlet Filters
Schaffner Group
Product selector
For example: FN 9244 E-15-06, FN 9244 ES1B-10-06-20, FN 9244 ER-12-06HI, FN 9244 EUB-8-06
Typical Filter Attenuation
Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym; C=0.1 Ω/100 Ω sym; D=100 Ω/0.1 Ω sym
1 and 3 A types
6 to 10 A types
12 and 15 A types
DATA SHEET
21. Jun 2022
4
IEC Inlet Filters
Schaffner Group
Mechanical Data
FN 9244 E
FN 9244 E-HI
FN 9244 ES
FN 9244 ES1
FN 9244EU
Panel cut out
Installation
DATA SHEET
21. Jun 2022
5
IEC Inlet Filters
Schaffner Group
DATA SHEET
21. Jun 2022
Dimensions
FN 9244 E
FN 9244 EU
FN 9244 ES
FN 9244 ES1
FN 9244 E-HI
A
48
48
29.9
29.9
48
B
22.4
25
22.4
22.4
22.4
C
40
40
D
47.1
47.1
47.1
47.1
47.1
E
27.8
27.7
27.8
27.8
27.8
40
F
5.7
5.7
5.7
5.7
5.7
G
20.1
20.1
20.1
20.1
20.1
H
Ø3.3
Ø3.3
Ø3.3
I
14
14
14
14
14
J
13.3
13.3
13.3
13.3
13.3
M
R ≤3
R ≤3
R ≤1.5
R ≤1.5
R ≤3
N
21.5
21.5
20.8
21.9
21.5
P
28.5
28.5
29.4
28.5
28.5
R*
M3
M3
S
90°
90°
M3
90°
T**
0.7 - 1.5
0.7 - 1.5
T**
1.5 - 2.2
1.5 - 2.2
**Recommended torque for M3 (90° countersunk flat head) is 0.5 Nm
** For selecting the panel thickness, please refer to the filter selector table.
All dimensions in mm; 1 inch = 25.4 mm
Tolerances according: ISO 2768-m/EN 22768-m
Please visit www.schaffner.com to find more details on filter connectors.
Tol.
±0.2
+0.6/-0
+0.6/-0
6
IEC Inlet Filters
Schaffner Group
Accessories
Power Cor
Cord
d with angled LLock
ocking
ing Syst
System
em C13
Protects appliances that are vulnerable to
vibration
Connector cannot be accidentally pulled or
vibrated out of the inlet
Space availability/constraints
Different angles for ease of access
Space saving
Release locking mechanism
Prevents accidental disconnection
Technical Data Sheet >
IL 13P IEC C13 R
Re
ewir
wireable
eable Angled Connec
Connecttors with LLock
ocking
ing Syst
System
em
vibration
Space saving
IL 13P IEC C13 R
Re
ewir
wireable
eable Connec
ocking
ing Syst
System
em
The locking system has a tensile force of typical
300N. It is recommended to use it with flange
mount filters. For details refer to our Application
Note "Using IEC Lock Power Cords with IEC Inlets
and Filters".
Schaffner power connector with IEC lock guard
against accidental disconnection of all electrical
appliances with an IEC inlet. No exchange or
modification of the IEC inlet or IEC inlet filter system
is needed. Easy retrofit .for all electronic
equipments and devices
DATA SHEET
21. Jun 2022
7
IEC Inlet Filters
Headquarters, Global
Innovation and
Development
Switzerland
Schaffner Holding AG
Industrie Nord
Nordstrasse 11e
4542
Luterbach
+41 32 681 66 26
info@schaffner.com
Schaffner Group
China
Schaffner EMC Ltd. Shanghai
T20-3 C, No 565 Chuangye Road,Pudong
district
201201
Shanghai
+86 2138139500
cschina@schaffner.com
Spain
Schaffner EMC España
Calle Caléndula 93, Miniparc III, Edificio E El
Soto de Moraleja, Alcobendas
28109
Madrid
+34 917 912 900
spainsales@schaffner.com
Finland
Schaffner Oy
Sauvonrinne 19 H
8500
Lohja
+358 50 468 7284
finlandsales@schaffner.com
Sweden
Schaffner EMC AB
Östermalmstrorg 1
114 42
Stockholm
+46 8 5050 2425
swedensales@schaffner.com
France
Schaffner EMC S.A.S.
16-20 Rue Louis Rameau
95875
Bezons
+33 1 34 34 30 60
francesales@schaffner.com
Switzerland
Schaffner EMV AG
Industrie Nord
Nordstrasse 11e
4542
Luterbach
+41 32 681 66 26
switzerlandsales@schaffner.com
India
Schaffner India Pvt. Ltd
Regus World Trade Centre
WTC, 22nd Floor Unit No 2238, Brigade
Gateway Campus, 26/1, Dr. Rajkumar Road
Malleshwaram (W)
560055
Bangalore
+91 8067935355
indiasales@schaffner.com
© 2022 Schaffner Group
The content of this document has been
carefully
checked
and
understood.
However, neither Schaffner nor its
subsidiaries
assume
any
liability
whatsoever for any errors or inaccuracies
of this document and the consequences
thereof. Published specifica-tions are
subject to change without notice. Product
suitability for any area of application must
ultimately
be
determined
by
the
customer. In all cases, products must
never be operated outside their published
specifications.
Schaffner
does
not
guarantee the availability of all published
products. This disclaimer shall be
governed by substantive Swiss law and
resulting disputes shall be settled by the
courts at the place of business of Schaffner
Holding AG. Latest publications and a
complete disclaimer can be downloa-ded
from the Schaffner website. All trademarks
recognized.
21. Jun 2022
Sales and Application
Centers
Germany
Schaffner Deutschland GmbH
Schoemperlenstrasse 12B
76185
Karlsruhe
+49 721 56910
germanysales@schaffner.com
To find your local partner within
Schaffner‘s global network schaffner.com
DATA SHEET
Italy
Schaffner EMC S.r.l.
Via Ticino, 30
20900
Monza (MB)
+39 039 21 41 070
italysales@schaffner.com
Japan
Schaffner EMC K.K.
ISM Sangenjaya 7F
1-32-12 Kamiuma, Setagaya-ku
154-0011
Tokyo
+81 3 5712 3650
japansales@schaffner.com
Singapore
Schaffner EMC Pte Ltd.
Blk 3015A Ubi Road 1, #05-09, Kampong Ubi
Industrial Estate
408705
Singapore
+65 63773283
singaporesales@schaffner.com
Taiwan
Schaffner EMV Ltd.
U-Town
20 Floor-2, No 97, Section 1, XinTai 5th Road,
XiZhi District
22175
New Taipei City
+886 226975500
taiwansales@schaffner.com
Thailand
Schaffner EMC Co. Ltd.
Sathorn Square Tower
Room 3780, 37FL, 98 North-Sathorn Rd,
Silom, Bangrak
10500
Bangkok
+66 621056397
thailandsales@schaffner.com
United Kingdom
Schaffner Ltd.
1, Oakmede Place
Terrace Road
RG42 4JF
Binfield
+44 118 9770070
uksales@schaffner.com
United States
Schaffner EMC Inc.
52 Mayfield Avenue
Edison, New Jersey
+1 732 225 9533
usasales@schaffner.com
很抱歉,暂时无法提供与“FN9244E-10-06”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 120+76.67945120+9.91966
