FN9264B-10-06
FN9264B-10-06
    SCHAFFNER(夏弗纳)
    Power Entry Connector Receptacle, Male Blades - Module IEC 320-C14 Panel Mount, Flange
FN9264B-10-06 数据手册
DATA SHEET Power Entry Module with EMC- Filter FN9264 General Purpose Power Entry Module with Switch Rated currents up to 10 A Approvals & Compliances High quality 2-pole rocker switch Optional reduced leakage current versions (A/B type) Complies with IEC/EN 60601-1 Snap-in versions (S type) Good attenuation performance Features and Benefits Excellent conducted attenuation performance, based on chokes with high saturation resistance and good thermal behavior High quality 2-pole rocker switch for all-pole disconnection Performance indicators Faston terminals for easy assembly FN 9264 B versions comply with the requirements of 1MOP acc. to IEC/EN 60601-1 for creepage and clearance, leakage current and high potential testing As flange mount and snap-in types available Typical Applications Portable electrical and electronic equipment EDP and office equipment Single-phase power supplies Switch-mode power supplies Test and measurement equipment Technical Specifications Medical electrical devices (MD) and In-Vitro Diagnostic (IVD) medical devices Maximum continuous operating voltage 250 VAC, 50/60 Hz Operating frequency DC to 400 Hz Rated currents 1 to 10 A @ 40°C max. High potential test voltage P –> PE 2000 VAC for 2 sec (Standard) P –> PE 2500 VAC for 2 sec (B-types) P –> N 760 VAC for 2 sec Protection category IP 40 according to IEC 60529 Protection category IP 40 according to IEC 60529 Temperature range (operation and storage) -25°C to +85°C (25/85/21) -25°C to +85°C (25/85/21) Design corresponding to UL 60939-3, CSA Std C22.2 No. 8, IEC/EN 60939-3, GB/ T15287, GB/T15288 Flammability corresponding to UL 94 V-2 or better MTBF @ 40°C/230 V (Mil-HB-217F) ≥ 616,000 hours Function 2-pole, dark not illuminated Marking I – 0 Electrical specifications Inrush current 100 A 50,000 on-off operations for 10 A according to EN 610581-1 Switch ratings * Europe (ENEC) 10 A (4 A), 250 VAC* 5E4 USA (UL) 20 A, 125 VAC 1 HP; 250 VAC 2 HP; Value in () relates to the inductive current charge: cosφ = 0.65 Typical electrical schematic 2 Power Entry Module with EMC- Filter Schaffner Group DATA SHEET 06. Jul 2022 Filter Selection Table Filter Rated current @ 40°C (25°C) Leakage current* Inductance** Capacitance** @ 250 VAC/50 Hz L Cx Resistance** Output Cy R connections Weight (@120 VAC/60Hz) [A] [mA] [mH] [μF] [nF] [kΩ] FN 9264xx-1-06-y 1 (1.2) 0.31 (0.18) 5.15 0.1 2.2 1000 -06 55 FN 9264xx-2-06-y 2 (2.3) 0.31 (0.18) 2.7 0.1 2.2 1000 -06 55 FN 9264xx-3-06-y 3 (3.6) 0.31 (0.18) 2 2.2 1000 -06 55 FN 9264xx-4-06-y 4 (4.6) 0.31 (0.18) 1 0.1 2.2 1000 -06 55 FN 9264xx-6-06-y 6 (6.9) 0.31 (0.18) 0.3 0.1 2.2 1000 -06 55 10 (11.5) 0.31 (0.18) 0.21 0.1 2.2 1000 -06 55 FN 9264xx-10-06-y [g] * Leakage current under normal operating conditions (acc. to IEC60939-3). Note: if the neutral line is interrupted, worst case leakage could reach twice this level. ** Tolerances apply: Inductance: -30/+50%, Capacitance: ±20%, Resistance: ±10% Product selector For example: FN 9264-1-06, FN 9264 B-6-06, FN 9264 SB-4-06-30 3 Power Entry Module with EMC- Filter Schaffner Group DATA SHEET 06. Jul 2022 Typical Filter Attenuation Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym 1 A Standard types 2 A Standard types 3 A Standard types 4 A types dB dB dB dB 90 90 90 90 80 80 A 70 60 50 A 70 70 60 60 B 50 B 80 80 A 60 B 50 40 40 40 30 30 30 30 20 20 20 20 10 10 10 10 100k 1M 10M 100M 0 10k 100k 1M 6 A Standard types 10 A Standard types dB dB 90 90 100M 100k 1M 10M 100M 0 10k 100k 80 80 70 70 A 60 60 50 50 40 30 20 20 10 10 100k 1M 10M A 40 B 30 0 10k 10M 0 10k B 50 40 0 10k A 70 100M 0 10k B 100k 1M 1 A B-types 10 A Standard types 6 A B-types 10 A B-types 10M 100M 3 A B-types 4 B types 1M 10M 100M 4 Power Entry Module with EMC- Filter Schaffner Group DATA SHEET 06. Jul 2022 Mechanical Data FN 9264 Panel cut out* **Recommended torque for M3 (90° countersunk flat head) is 0.5 Nm FN 9264 S Installation Panel cut out 5 Power Entry Module with EMC- Filter Schaffner Group Accessories Power Cor Cord d with angled LLock ocking ing Syst System em C13 Protects appliances that are vulnerable to vibration Connector cannot be accidentally pulled or vibrated out of the inlet Space availability/constraints Different angles for ease of access Space saving Release locking mechanism Prevents accidental disconnection Technical Data Sheet > IL 13P IEC C13 R Re ewir wireable eable Angled Connec Connecttors with LLock ocking ing Syst System em Protects appliances that are vulnerable to vibration Connector cannot be accidentally pulled or vibrated out of the inlet Space availability/constraints Different angles for ease of access Space saving Release locking mechanism Prevents accidental disconnection Technical Data Sheet > IL 13P IEC C13 R Re ewir wireable eable Connec Connecttors with LLock ocking ing Syst System em The locking system has a tensile force of typical 300N. It is recommended to use it with flange mount filters. For details refer to our Application Note "Using IEC Lock Power Cords with IEC Inlets and Filters". Schaffner power connector with IEC lock guard against accidental disconnection of all electrical appliances with an IEC inlet. No exchange or modification of the IEC inlet or IEC inlet filter system is needed. Easy retrofit .for all electronic equipments and devices Technical Data Sheet > DATA SHEET 06. Jul 2022 6 Power Entry Module with EMC- Filter Headquarters, Global Innovation and Development Switzerland Schaffner Holding AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 info@schaffner.com Schaffner Group China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road, Pudong district 201201 Shanghai +86 2138139500 cschina@schaffner.com Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid +34 917 912 900 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 8500 Lohja +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstrorg 1 114 42 Stockholm +46 8 5050 2425 swedensales@schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons +33 1 34 34 30 60 francesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 switzerlandsales@schaffner.com India Schaffner India Pvt. Ltd Regus World Trade Centre WTC, 22nd Floor Unit No 2238, Brigade Gateway Campus, 26/1, Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore +91 8067935355 indiasales@schaffner.com © 2022 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifica-tions are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloa-ded from the Schaffner website. All trademarks recognized. 06. Jul 2022 Sales and Application Centers Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe +49 721 56910 germanysales@schaffner.com To find your local partner within Schaffner‘s global network schaffner.com DATA SHEET Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. ISM Sangenjaya 7F 1-32-12 Kamiuma, Setagaya-ku 154-0011 Tokyo +81 3 5712 3650 japansales@schaffner.com Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1, #05-09, Kampong Ubi Industrial Estate 408705 Singapore +65 63773283 singaporesales@schaffner.com Taiwan Schaffner EMV Ltd. U-Town 20 Floor-2, No 97, Section 1, XinTai 5th Road, XiZhi District 22175 New Taipei City +886 226975500 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Sathorn Square Tower Room 3780, 37FL, 98 North-Sathorn Rd, Silom, Bangrak 10500 Bangkok +66 621056397 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 1, Oakmede Place Terrace Road RG42 4JF Binfield +44 118 9770070 uksales@schaffner.com United States Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey +1 732 225 9533 usasales@schaffner.com
FN9264B-10-06 价格&库存
很抱歉,暂时无法提供与“FN9264B-10-06”相匹配的价格&库存,您可以联系我们找货
FN9264B-10-06
  • 1+257.243471+29.84974
  • 10+198.5175510+23.03537
  • 25+179.8535025+20.86965
  • 60+164.1305360+19.04520
  • 120+152.99914120+17.75355
  • 300+139.88705300+16.23207
  • 540+132.34758540+15.35721
库存:71
