FN393-2.5-05-11
FN393-2.5-05-11
    SCHAFFNER(夏弗纳)
    PWR ENT MOD RCPT IEC320-C14 PNL
FN393-2.5-05-11 数据手册
DATA SHEET Power Entry Module with EMC- Filter FN390 Versatile Filtered Power Entry Module Rated currents up to 10 A Approvals & Compliances For one or two fuses Fuses Ø6.3 x 32 mm or Ø5 x 20 mm 2-pole rocker switch Voltage selector Optional earth line choke (E type) Performance indicators The FN 390 power entry module combines an IEC inlet, mains filter with single or dual-fuse holder, voltage selector and 2-pole rocker switch. Choosing FN 390 product line brings you the rapid availability of a standard filter associated with the necessary safety acceptances. Standard IEC connector filters are a practical solution helping you to pass EMI system approval in a short time. Multiple options designed to offer you the desired solution. Features and Benefits High conducted attenuation performance, based on chokes with high saturation resistance and excellent thermal behavior Rear or front mounting Single or dual-fuse holder USA Ø6.3 x 32 mm or EU Ø5 x 20 mm fuses 2-pole rocker switch Technical Specifications Voltage selector 110-120 V/220-240 V Custom-specific versions are available on request Maximum continuous operating voltage 250 VAC, 50/60 Hz Operating frequency DC to 400 Hz Rated currents 1 to 10 A @ 40°C max. High potential test voltage P –> PE 2000 VAC for 2 sec P –> N 760 VAC for 2 sec Protection category IP 40 according to IEC 60529 Temperature range (operation and storage) -25°C to +85°C (25/85/21) Design corresponding to Single-phase power supplies, switch-mode power supplies UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 Test and measurement equipment Flammability corresponding to UL 94V-2 or better MTBF @ 40°C/230 V (Mil-HB-217F) 2,200,000 hours Voltage selector description Function Series/parallel Voltage marking Series 110-120 V Parallel 220-240 V Rocker switch description Fuse holder 1 or 2 fuses (Ø5 x 20 mm) (certified to IEC 60127-6), power acceptance 1.6W @ Ta 23°C per pole for 2 fuses. 2.5W, if only 1 pole is used. Function 2-pole, dark not illuminated Marking I - 0 Electrical specifications Inrush current 51 A 6,000 on-off operations according to UL 1054, TV 5 10,000 on-off operations according to ENEC Mechanical life 50,000 cycles Switch ratings * USA (UL) and Canada (C-UL) 10 A, 125 VAC; 10 A, 250 VAC; 1/3 HP Europe (ENEC) 10 A (4 A), 250 VAC* Value in () relates to the inductive current charge: cos φ=0.65 Typical Applications Portable electrical and electronic equipment Consumer goods EDP and office equipment Typical electrical schematic 2 Power Entry Module with EMC- Filter Schaffner Group DATA SHEET 24. Nov 2022 Filter Selection Table Filter Rated current Leakage current* Inductance Capacitance @ 40°C (25°C) @ 230 VAC/50 Hz L1 L2 Cx Cx1 Cy [mH] [nF] [nF] Resistance Output R connections Fuses** Weight [A] [μA] [mH] [nF] [kΩ] [Qty] [g] FN 393-1-05-11 1 (1.2) 560 7.5 220 3.3 1000 05-11 1 200 FN 393-2.5-05-11 2.5 (3) 560 2 220 3.3 1000 05-11 1 200 FN 393-6-05-11 6 (7.2) 560 0.45 220 3.3 1000 05-11 1 200 FN 394-1-05-11 1 (1.2) 560 7.5 220 3.3 1000 05-11 2 200 FN 394-2.5-05-11 2.5 (3) 560 2 220 3.3 1000 05-11 2 200 FN 394-6-05-11 6 (7.2) 560 0.45 220 3.3 1000 05-11 2 200 FN 393 E-1-05-11 1 (1.2) 560 7.5 0.4 220 3.3 1000 05-11 1 205 FN 393 E-2.5-05-11 2.5 (3) 560 2 0.4 220 3.3 1000 05-11 1 205 FN 393 E-6-05-11 6 (7.2) 560 0.45 0.4 220 3.3 1000 05-11 1 205 FN 394 E-1-05-11 1 (1.2) 560 7.5 0.4 220 3.3 1000 05-11 2 205 FN 394 E-2.5-05-11 2.5 (3) 560 2 0.4 220 3.3 1000 05-11 2 205 FN 394 E-6-05-11 6 (7.2) 560 0.45 0.4 220 3.3 1000 05-11 2 205 FN 1393-1-05-11 1 (1.2) 797 16 220 100 4.7 470 05-11 1 210 FN 1393-2.5-05-11 2.5 (3) 797 8 220 100 4.7 470 05-11 1 210 FN 1393-6-05-11 6 (7.2) 797 2.5 220 100 4.7 470 05-11 1 210 797 0.6 220 100 4.7 470 05-11 1 210 797 16 220 100 4.7 470 05-11 2 210 797 8 220 100 4.7 470 05-11 2 210 FN 1393-10-05-11 FN 1394-1-05-11 FN 1394-2.5-05-11 10 (12) 1 (1.2) 2.5 (3) FN 1394-6-05-11 6 (7.2) 797 2.5 220 100 4.7 470 05-11 2 210 FN 1394-10-05-11 10 (12) 797 0.6 220 100 4.7 470 05-11 2 210 * Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level. ** Filters are delivered without fuse. Note: for medical versions please contact your local partner within Schaffner‘s global network. Product selector For example: FN 393-1-05-11, FN 394 E-2.5-05-11, FN 1394-10-05-11 3 Power Entry Module with EMC- Filter Schaffner Group DATA SHEET 24. Nov 2022 Typical Filter Attenuation Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym; C=0.1 Ω/100 Ω sym; D=100 Ω/0.1 Ω sym FN 39x: 1 A types FN 39x: 2.5 A types FN 39x: 6 A types FN 139x: 1 A types FN 139x: 2.5 A types FN 139x: 6 and 10 A types Mechanical Data 1 to 10 A types Panel cut out 4 Power Entry Module with EMC- Filter Schaffner Group DATA SHEET 24. Nov 2022 Dimensions 1 to 10 A Tolerances A 50 ±0.3 B 65 ±0.3 C 40 ±0.1 D 70 ±0.5 E 28.5 ±0.3 F 5.5 ±0.3 G 59.8 ±0.2 H Ø 3.3 I 13.5 J 7.5 ±0.5 M R ≤ 2.5 N 60 +0.5/-0 P 29 +0.5/-0 R M3 S 90° U 15 All dimensions in mm; 1 inch=25.4 mm Tolerances according: ISO 2768-m/EN 22768-m Please visit www.schaffner.com to find more details on filter connections. ±0.3 5 Power Entry Module with EMC- Filter Schaffner Group DATA SHEET 24. Nov 2022 Headquarters, Global Innovation and Development Switzerland Schaffner Group Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 info@schaffner.com Sales and Application Centers China Schaffner EMC Ltd. Shanghai T20-3 C No 565 Chuangye Road Pudong district 201201 Shanghai +86 2138139500 cschina@schaffner.com Spain Schaffner EMC España Calle Caléndula 93 Miniparc III Edificio E El Soto de Moraleja Alcobendas 28109 Madrid +34 917 912 900 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 8500 Lohja +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstrorg 1 114 42 Stockholm +46 8 5050 2425 swedensales@schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons +33 1 34 34 30 60 francesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 switzerlandsales@schaffner.com Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe +49 721 56910 germanysales@schaffner.com India Schaffner India Pvt. Ltd Regus World Trade Centre WTC 22nd Floor Unit No 2238 Brigade Gateway Campus 26/1 Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore +91 8067935355 indiasales@schaffner.com To find your local partner within Schaffner‘s global network schaffner.com © 2022 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifica-tionsw are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloa-ded from the Schaffner website. All trademarks recognized. Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. ISM Sangenjaya 7F 1-32-12 Kamiuma Setagaya-ku 154-0011 Tokyo +81 3 5712 3650 japansales@schaffner.com Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1 #05-09 Kampong Ubi Industrial Estate 408705 Singapore +65 63773283 singaporesales@schaffner.com Taiwan Schaffner EMV Ltd. U-Town 20 Floor-2 No 97 Section 1 XinTai 5th Road XiZhi District 22175 New Taipei City +886 226975500 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Sathorn Square Tower Room 3780 37FL 98 North-Sathorn Rd Silom Bangrak 10500 Bangkok +66 621056397 thailandsales@schaffner.com United Kingdom Schaffner Ltd. Suite 1 Oakmede Place Terrace Road RG42 4JF Binfield +44 118 9770070 uksales@schaffner.com United States Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey +1 732 225 9533 usasales@schaffner.com
FN393-2.5-05-11 价格&库存
很抱歉,暂时无法提供与“FN393-2.5-05-11”相匹配的价格&库存,您可以联系我们找货
FN393-2.5-05-11
  • 1+452.257691+58.50644
  • 20+366.0324920+47.35189
  • 40+348.5728440+45.09322
  • 60+338.7509260+43.82261
  • 100+326.77016100+42.27271
  • 260+305.49771260+39.52080
库存:27
