DATA SHEET
Power Entry Module with EMC- Filter FN9280
Ultra Compact and Versatile Filtered Power Entry Module
Single stage filter
Approvals & Compliances
Ultra compact design
Rated currents up to 10 A
dual-fuse holder
Fuses Ø5x20 mm
2-pole rocker switch
Good attenuation performance
Faston or spring cage terminals
Performance indicators
(CQC except HI-types; Patent US 20110227692/US
8766761; CN ZL201080069589.0)
Choosing FN 9280/90 product line brings you the
rapid availability of a standard filter associated with
the necessary safety acceptances and a high
attenuation performance. For higher attenuation
performance the FN 9290 family with a dual stage
filter and identical panel cut-out can be used.
Standard IEC connector filters are a practical
solution to pass EMI system approval in a short
time. A wide selection of amperage ratings,
mounting possibilities and also filters for medical
applications are designed to offer you the best
solution.
Features and Benefits
Good conducted attenuation performance, based
on chokes with high saturation resistance and
excellent thermal behavior
Deep-drawn iron-sheet housing for best possible
shielding against magnetic fields
Technical Specifications
Rear/front flange mounting or snap-in versions
Maximum continuous operating voltage
250 VAC, 50/60 Hz
Rated currents
1 to 10 A @ 40°C max
Operating frequency
DC to 400 Hz
Leakage current
Standard: PE 2500 VAC for 2 sec (B types)
P –> N 760 VAC for 2 sec
Design corresponding to
UL 1283, CSA 22.2 No. 8 1986, EN 60939, EN 60950, EN
60601-1, UL 544, EN 60320
Flammability corresponding to
UL 94 V-2 or better
Temperature range (operation and storage)
– 25°C to +85°C (25/85/21)
Protection category
IP 40 according to IEC 60529 (front side)
MTBF @ 40°C/230 V (Mil-HB-217F)
>1,000,000 hours
Switch ratings
Rocker switch
2-pole, non-illuminated, Marking I - 0
USA (UL) and Canada (C-UL)
10 A, 125 VAC; 10 A, 250 VAC; 1/3 HP
Europe (ENEC)
10 A (4 A), 250 VAC*
Mechanical life
50,000 cycles
Electrical specifications
Inrush current 82 A
6,000 on-off operations according to UL 1054
10,000 on-off operations according to ENEC
Fuse holder
2 fuses (Ø5 x 20 mm) max. 250 V (certified to IEC
60127-6), power acceptance 1.6W @ Ta 23°C per pole
Value in () relates to the inductive current charge: cos γ = 0.65
Dual and additional spare fuse holder
FN 928X B versions comply with the
requirements of 1MOP acc. to IEC/EN 60601-1
All versions according IEC/EN 62368-1
Typical Applications
Portable electrical and electronic equipment
Consumer goods
EDP and office equipment
Single-phase and switch-mode power supplies
Test and measurement equipment
Medical electrical devices (MD) and InVitro-Diagnostics (IVD) equipment
Audio/Video, information and communication
technologies
Typical electrical schematic
2
Schaffner Group
DATA SHEET
24. Nov
2022
Filter Selection Table
Filter*
Rated current
@ 40°C
Leakage current**
@ 250 VAC /50 Hz
Inductance
Capacitance
Resistance
Output
connections
L1
L2
Cx
Cy
R
Weight
(@ 120 VAC /60 Hz)
[A]
[mA]
[mH]
[mH]
[nF]
[nF]
[kOhm]
[g]
FN 9280-1-..
1
0.31 (0.18)
10.9
2.2
1000
-06
-100
101
FN 9280-2-..
2
0.31 (0.18)
4.4
2.2
1000
-06
-100
102
FN 9280-4-..
4
0.31 (0.18)
1.7
2.2
1000
-06
-100
105
FN 9280-6-..
6
0.31 (0.18)
0.78
2.2
1000
-06
-100
104
FN 9280-10-..
10
0.31 (0.18)
0.32
2.2
1000
-06
-100
106
FN 9280 B-1-..
1
0.00
10.9
-06
-100
101
FN 9280 B-2-..
2
0.00
4.4
-06
-100
102
FN 9280 B-4-..
4
0.00
1.7
-06
-100
105
FN 9280 B-6-..
6
0.00
0.78
-06
-100
104
FN 9280 B-10-..
10
0.00
0.32
-06
-100
106
FN 9289-1-..
1
0.31 (0.18)
10.9
2.2
1000
-06
-100
101
FN 9289-2-..
2
0.31 (0.18)
4.4
2.2
1000
-06
-100
102
FN 9289-4-..
4
0.31 (0.18)
1.7
2.2
1000
-06
-100
105
FN 9289-6-..
6
0.31 (0.18)
0.78
2.2
1000
-06
-100
104
FN 9289-10-..
10
0.31 (0.18)
0.32
2.2
1000
-06
-100
106
FN 9289 B-1-..
1
0.00
10.9
-06
-100
101
FN 9289 B-2-..
2
0.00
4.4
-06
-100
102
FN 9289 B-4-..
4
0.00
1.7
-06
-100
105
FN 9289 B-6-..
6
0.00
0.78
-06
-100
104
FN 9289 B-10-..
10
0.00
0.32
-06
-100
106
FN 9280 E-1-..
1
0.31 (0.18)
10.9
0.4
220
2.2
1000
-06
-100
135
FN 9280 E-2-..
2
0.31 (0.18)
4.4
0.4
220
2.2
1000
-06
-100
136
FN 9280 E-4-..
4
0.31 (0.18)
1.66
0.4
220
2.2
1000
-06
-100
137
FN 9280 E-6-..
6
0.31 (0.18)
0.78
0.4
220
2.2
1000
-06
-100
138
FN 9280 E-10-..
10
0.31 (0.18)
0.32
0.4
220
2.2
1000
-06
-100
139
FN 9280 EB-1-..
1
0.00
10.9
0.4
220
-06
-100
135
FN 9280 EB-2-..
2
0.00
4.4
0.4
220
-06
-100
136
FN 9280 EB-4-..
4
0.00
1.66
0.4
220
-06
-100
137
FN 9280 EB-6-..
6
0.00
0.78
0.4
220
-06
-100
138
FN 9280 EB-10-..
10
0.00
0.32
0.4
220
-06
-100
139
FN 9289 E-1-..
1
0.31 (0.18)
10.9
0.4
220
2.2
1000
-06
-100
135
FN 9289 E-2-..
2
0.31 (0.18)
4.4
0.4
220
2.2
1000
-06
-100
136
FN 9289 E-4-..
4
0.31 (0.18)
1.66
0.4
220
2.2
1000
-06
-100
137
FN 9289 E-6-..
6
0.31 (0.18)
0.78
0.4
220
2.2
1000
-06
-100
138
FN 9289 E-10-..
10
0.31 (0.18)
0.32
0.4
220
2.2
1000
-06
-100
139
FN 9289 EB-1-..
1
0.00
10.9
0.4
220
-06
-100
135
FN 9289 EB-2-..
2
0.00
4.4
0.4
220
-06
-100
136
FN 9289 EB-4-..
4
0.00
1.66
0.4
220
-06
-100
137
FN 9289 EB-6-..
6
0.00
0.78
0.4
220
-06
-100
138
FN 9289 EB-10-..
10
0.00
0.32
0.4
220
-06
-100
139
* To compile a complete part number, please replace the -.. with the required output connection style (e.g. FN 9289-1-06, FN 9282-4-100)
** Maximum leakage current under normal conditions (according to IEC60939-3)
3
Schaffner Group
DATA SHEET
24. Nov
2022
Product selector
All FN 9280/FN 9290 are equipped with a dual fuse holder with a spare fuse holder.
Note: All FN 9280/FN 9280 B/FN 9289/FN 9289 B/FN 9290/FN 9290 B/FN 9299/FN 9299 B are stock types from our distribution partners.
Order Examples:
FN 9280 B-6-100: Medical version of single stage, dual fuse EMC/EMI filter, flange set for vertical/horizontal/front/rear mounting, 6 A, spring cage terminals,
from stock available.
FN 9298-6-06-30: Dual stage, dual fuse EMC/EMI filter, snap-in version, snappers for snap-in panel thickness range >2.5 to 3.5 mm, snapper on vertical side, 6 A,
fast-on terminals, non-stock order type
Accessories: The 4D flanges can be ordered separately. The order number is 427532. Please note that the minimum order quantity is one box of 50 pieces. One
item includes both type of flanges (vertical and horizontal).
Standard type filters*
B-type filters* (without Cy)
E-type filters* (with earth line choke)
EB-type filters* (with earth line choke and without Cy)
* Fuses are not included
4
Schaffner Group
DATA SHEET
24. Nov
2022
Typical Filter Attenuation
FN 9280 Series | Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym
1 A types
2 A types
4 – 6 A types
10 A types
4 – 6 A types
10 A types
4 – 6 A types
10 A types
4 – 6 A types
10 A types
FN 9280 B Series | Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym
1 A types
2 A types
FN 9280 E Series | Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym
1 A types
2 A types
FN 9280 EB Series | Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym
1 A types
2 A types
5
Schaffner Group
DATA SHEET
24. Nov
2022
Mechanical Data
FN 9280-x-06/FN 9280 B-x-06
FN 9280-X-100/FN 9280 B-X-100
FN 9289-x-06/FN 9289 B-x-06
FN 9289-X-100/FN 9289 B-X-100
6
Schaffner Group
DATA SHEET
24. Nov
2022
Mechanical Data
FN 9280 E-x-06/FN 9280 EB-x-06
FN 9280 E-x-100/FN 9280 EB-x-100
FN 9289 E-x-06/FN 9289 EB-x-06
FN 9289E-x-100 / FN 9289EB-x-100
7
Schaffner Group
DATA SHEET
24. Nov
2022
Assembly Instructions
Terminal -100
clamping range, solid wire / flex wire
0,20 mm² –1,5 mm², AWG24 –AWG16
operating force of slider
recommended stripped length
Removal Of The Combined Switch / Fuse Holder
Unit
max. 40 N
Push the knob above
the terminal to insert
the wire.
8 mm
An additional fuse mark on the switch indicates the fuses holders behind
the switch. The red frame shows the outline of the removable unit.
With a simple tool like a Swiss Army knife or a screwdriver No 1 or smaller
the unit (1) can be removed from the filter. On the topside (2) behind the
switch there are two fuse holders for each live connection. On the bottom
side (3) is a clip to carry an additional spare fuse.
Please visit www.schaffner.com to find more details on filter connectors.
8
Schaffner Group
DATA SHEET
24. Nov
2022
Accessories
Power Cor
Cord
d with angled LLock
ocking
ing Syst
System
em C13
Protects appliances that are vulnerable to
vibration
Connector cannot be accidentally pulled or
vibrated out of the inlet
Space availability/constraints
Different angles for ease of access
Space saving
Release locking mechanism
Prevents accidental disconnection
Technical Data Sheet >
IL 13P IEC C13 R
Re
ewir
wireable
eable Angled Connec
Connecttors with LLock
ocking
ing Syst
System
em
vibration
Space saving
IL 13P IEC C13 R
Re
ewir
wireable
eable Connec
ocking
ing Syst
System
em
The locking system has a tensile force of typical
300N. It is recommended to use it with flange
mount filters. For details refer to our Application
Note "Using IEC Lock Power Cords with IEC Inlets
and Filters".
Schaffner power connector with IEC lock guard
against accidental disconnection of all electrical
appliances with an IEC inlet. No exchange or
modification of the IEC inlet or IEC inlet filter system
is needed. Easy retrofit .for all electronic
equipments and devices
9
Schaffner Group
DATA SHEET
24. Nov
2022
Headquarters, Global
Innovation and
Development
Switzerland
Schaffner Group
Industrie Nord
Nordstrasse 11e
4542
Luterbach
+41 32 681 66 26
info@schaffner.com
Sales and Application
Centers
China
Schaffner EMC Ltd. Shanghai
T20-3 C No 565 Chuangye Road Pudong
district
201201
Shanghai
+86 2138139500
cschina@schaffner.com
Spain
Schaffner EMC España
Calle Caléndula 93 Miniparc III Edificio E El
Soto de Moraleja Alcobendas
28109
Madrid
+34 917 912 900
spainsales@schaffner.com
Finland
Schaffner Oy
Sauvonrinne 19 H
8500
Lohja
+358 50 468 7284
finlandsales@schaffner.com
Sweden
Schaffner EMC AB
Östermalmstrorg 1
114 42
Stockholm
+46 8 5050 2425
swedensales@schaffner.com
France
Schaffner EMC S.A.S.
16-20 Rue Louis Rameau
95875
Bezons
+33 1 34 34 30 60
francesales@schaffner.com
Switzerland
Schaffner EMV AG
Industrie Nord
Nordstrasse 11e
4542
Luterbach
+41 32 681 66 26
switzerlandsales@schaffner.com
Germany
Schaffner Deutschland GmbH
Schoemperlenstrasse 12B
76185
Karlsruhe
+49 721 56910
germanysales@schaffner.com
India
Schaffner India Pvt. Ltd
Regus World Trade Centre
WTC 22nd Floor Unit No 2238 Brigade
Gateway Campus 26/1 Dr. Rajkumar Road
Malleshwaram (W)
560055
Bangalore
+91 8067935355
indiasales@schaffner.com
To find your local partner within
Schaffner‘s global network schaffner.com
© 2022 Schaffner Group
The content of this document has been
carefully
checked
and
understood.
However, neither Schaffner nor its
subsidiaries
assume
any
liability
whatsoever for any errors or inaccuracies
of this document and the consequences
thereof. Published specifica-tionsw are
subject to change without notice. Product
suitability for any area of application must
ultimately
be
determined
by
the
customer. In all cases, products must
never be operated outside their published
specifications.
Schaffner
does
not
guarantee the availability of all published
products. This disclaimer shall be
governed by substantive Swiss law and
resulting disputes shall be settled by the
courts at the place of business of Schaffner
Holding AG. Latest publications and a
complete disclaimer can be downloa-ded
from the Schaffner website. All trademarks
recognized.
Italy
Schaffner EMC S.r.l.
Via Ticino, 30
20900
Monza (MB)
+39 039 21 41 070
italysales@schaffner.com
Japan
Schaffner EMC K.K.
ISM Sangenjaya 7F
1-32-12 Kamiuma Setagaya-ku
154-0011
Tokyo
+81 3 5712 3650
japansales@schaffner.com
Singapore
Schaffner EMC Pte Ltd.
Blk 3015A Ubi Road 1 #05-09 Kampong Ubi
Industrial Estate
408705
Singapore
+65 63773283
singaporesales@schaffner.com
Taiwan
Schaffner EMV Ltd.
U-Town
20 Floor-2 No 97 Section 1 XinTai 5th Road
XiZhi District
22175
New Taipei City
+886 226975500
taiwansales@schaffner.com
Thailand
Schaffner EMC Co. Ltd.
Sathorn Square Tower
Room 3780 37FL 98 North-Sathorn Rd Silom
Bangrak
10500
Bangkok
+66 621056397
thailandsales@schaffner.com
United Kingdom
Schaffner Ltd.
Suite 1 Oakmede Place
Terrace Road
RG42 4JF
Binfield
+44 118 9770070
uksales@schaffner.com
United States
Schaffner EMC Inc.
52 Mayfield Avenue
Edison, New Jersey
+1 732 225 9533
usasales@schaffner.com
很抱歉,暂时无法提供与“FN9289-10-100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+384.200671+49.68760
- 10+326.5711010+42.23453
- 40+296.1475340+38.29993
- 80+282.0256480+36.47359
- 120+274.07918120+35.44589
- 280+258.19550280+33.39170
