DATA SHEET
Power Entry Module with EMC- Filter FN370
Versatile Filtered Power Entry Module
Rated currents up to 6 A
Approvals & Compliances
Single or dual-fuse holder
Fuses Ø6.3 x 32 mm or Ø5 x 20 mm
Voltage selector 100/120/230/240 V
General purpose application
Optional medical versions (B type)
Performance indicators
The FN 370 power entry module combines an IEC
inlet, a mains filter with a single or dual- fuse
holder and a voltage selector. Choosing FN 370
product line brings you the rapid availability of a
standard filter associated with the necessary safety
acceptances. Standard IEC connector filters are a
practical solution helping you to pass EMI system
approval in a short time. A wide selection on
amperage ratings, fuse options, mounting
possibilities and filters for medical applications are
designed to offer you the desired solution.
Features and Benefits
Good conducted attenuation performance, based
on chokes with high saturation resistance and
excellent thermal behavior
Rear/front or snap-in mounting
USA Ø6.3 x 32 mm or EU Ø5 x 20 mm fuses
Technical Specifications
Two attenuation performance ranges
Maximum continuous operating voltage
250 VOLT, 50/60 Hz
Operating frequency
DC to 400 Hz
Rated currents
2 to 6 A @ 40°C max.
High potential test voltage
P –> PE 2000 VAC for 2 sec (standard types)
P –> PE 2500 VAC for 2 sec (B types)
P –> N 760 VAC for 2 sec
Typical Applications
Portable electrical and electronic equipment
Consumer goods
EDP and office equipment
Protection category
IP 40 according to IEC 60529
Temperature range (operation and storage)
-25°C to +85°C (25/85/21)
Design corresponding to
Single-phase power supplies, switch-mode power
supplies
UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939
Flammability corresponding to
Test and measurement equipment
UL 94 V-2 or better
Medical equipment
MTBF @ 40°C/230 V (Mil-HB-217F)
550,000 hours
Voltage selector description
VOL-SE 4SP-4
Function
Series/parallel
Voltage marking
1st
100
2nd
120
3rd
230
4st
240
Closed internal contact corresponding to
Custom-specific versions are available on request
1st
a, c, e
2st
b, c, e
3st
3st a, d
4st
b, d
Other selected voltage marking on request.
Typical electrical schematic
2
Schaffner Group
DATA SHEET
04. Jul 2022
Filter Selection Table
Filter*
Rated current
Leakage current**
Inductance
Capacitance
Resistance
Output
Fuses***
Weight
@ 40°C (25°C)
@ 230 VAC/50 Hz
L
Cx
[A]
[μA]
[mH]
[nF]
Cy
R
connections
[nF]
[kΩ]
FN 370-2-2 z
2 (2.4)
373
0.70
47
2.2
13
[Qty]
[g]
1
55
FN 370-4-2 z
4 (4.8)
373
0.30
47
2.2
FN 370-6-2 z
6 (7.2)
373
0.18
47
2.2
13
1
55
13
1
55
FN 372-2-2 z
2 (2.4)
373
0.70
47
FN 372-4-2 z
4 (4.8)
373
0.30
47
2.2
13
2
55
2.2
13
2
55
FN 372-6-2 z
6 (7.2)
373
0.18
47
2.2
13
2
55
FN 378-2-2 z
2 (2.4)
373
0.70
47
2.2
13
2
60
FN 378-4-2 z
4 (4.8)
FN 378-6-2 z
6 (7.2)
373
0.30
47
2.2
13
2
60
373
0.18
47
2.2
13
2
60
FN 379-2-2 z
FN 379-4-2 z
2 (2.4)
373
2.00
47
2.2
13
2
70
4 (4.8)
373
0.80
47
2.2
13
2
70
FN 379-6-2 z
6 (7.2)
373
0.50
47
2.2
13
2
70
FN 379 B-2-2 z
2 (2.4)
2
2.00
47
1000
13
2
70
FN 379 B-4-2 z
4 (4.8)
2
0.80
47
1000
13
2
70
FN 379 B-6-2 z
6 (7.2)
2
0.50
47
1000
13
2
70
* Select the requested fuse holder for fuse EUR-1 or USA-1 (z).
** Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level.
*** Filters are delivered without fuse.
Product selector
For example: FN 370-6-21, FN 378-4-22, FN 379 B-2-22
3
Schaffner Group
Typical Filter Attenuation
Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym; C=0.1 Ω/100 Ω sym; D=100 Ω/0.1 Ω sym
FN 370/FN 372/FN 378
FN 379
Mechanical Data
FN 370/FN 372
Connection designation
FN 378/FN 379
Panel cut out
DATA SHEET
04. Jul 2022
4
Schaffner Group
DATA SHEET
Dimensions
FN 370
FN 372
FN 378
FN 379
Tolerances
A
32
32
50
50
±0.3
B
58
58
58
58
±0.3
40
40
±0.1
D
54
54
54
64.5
F
5.5
5.5
5.5
5.5
Ø3.3
Ø3.3
C
H
J
12.5
12.5
12.5
12.5
M
R ≤2
R ≤2
R ≤2
R ≤2
±0.1
N
55.9*/56.2**
55.9*/56.2**
55.9*/56.2**
55.9*/56.2**
+0.2/-0
P
28.5
28.5
28.5
28.5
+0.2/-0
R
M3
M3
S
90°
90°
9
9
U
9
9
* For a panel thickness between 0.8 and 3 mm
** For a back panel thickness between 2.1 and 3.2 mm
All dimensions in mm; 1 inch = 25.4 mm
Tolerances according: ISO 2768-m/EN 22768-m
Please visit www.schaffner.com to find more details on filter connectors.
04. Jul 2022
5
Headquarters, Global
Innovation and
Development
Switzerland
Schaffner Holding AG
Industrie Nord
Nordstrasse 11e
4542
Luterbach
+41 32 681 66 26
info@schaffner.com
Schaffner Group
China
Schaffner EMC Ltd. Shanghai
T20-3 C, No 565 Chuangye Road, Pudong
district
201201
Shanghai
+86 2138139500
cschina@schaffner.com
Spain
Schaffner EMC España
Calle Caléndula 93, Miniparc III, Edificio E El
Soto de Moraleja, Alcobendas
28109
Madrid
+34 917 912 900
spainsales@schaffner.com
Finland
Schaffner Oy
Sauvonrinne 19 H
8500
Lohja
+358 50 468 7284
finlandsales@schaffner.com
Sweden
Schaffner EMC AB
Östermalmstrorg 1
114 42
Stockholm
+46 8 5050 2425
swedensales@schaffner.com
France
Schaffner EMC S.A.S.
16-20 Rue Louis Rameau
95875
Bezons
+33 1 34 34 30 60
francesales@schaffner.com
Switzerland
Schaffner EMV AG
Industrie Nord
Nordstrasse 11e
4542
Luterbach
+41 32 681 66 26
switzerlandsales@schaffner.com
India
Schaffner India Pvt. Ltd
Regus World Trade Centre
WTC, 22nd Floor Unit No 2238, Brigade
Gateway Campus, 26/1, Dr. Rajkumar Road
Malleshwaram (W)
560055
Bangalore
+91 8067935355
indiasales@schaffner.com
© 2022 Schaffner Group
The content of this document has been
carefully
checked
and
understood.
However, neither Schaffner nor its
subsidiaries
assume
any
liability
whatsoever for any errors or inaccuracies
of this document and the consequences
thereof. Published specifica-tions are
subject to change without notice. Product
suitability for any area of application must
ultimately
be
determined
by
the
customer. In all cases, products must
never be operated outside their published
specifications.
Schaffner
does
not
guarantee the availability of all published
products. This disclaimer shall be
governed by substantive Swiss law and
resulting disputes shall be settled by the
courts at the place of business of Schaffner
Holding AG. Latest publications and a
complete disclaimer can be downloa-ded
from the Schaffner website. All trademarks
recognized.
04. Jul 2022
Sales and Application
Centers
Germany
Schaffner Deutschland GmbH
Schoemperlenstrasse 12B
76185
Karlsruhe
+49 721 56910
germanysales@schaffner.com
To find your local partner within
Schaffner‘s global network schaffner.com
DATA SHEET
Italy
Schaffner EMC S.r.l.
Via Ticino, 30
20900
Monza (MB)
+39 039 21 41 070
italysales@schaffner.com
Japan
Schaffner EMC K.K.
ISM Sangenjaya 7F
1-32-12 Kamiuma, Setagaya-ku
154-0011
Tokyo
+81 3 5712 3650
japansales@schaffner.com
Singapore
Schaffner EMC Pte Ltd.
Blk 3015A Ubi Road 1, #05-09, Kampong Ubi
Industrial Estate
408705
Singapore
+65 63773283
singaporesales@schaffner.com
Taiwan
Schaffner EMV Ltd.
U-Town
20 Floor-2, No 97, Section 1, XinTai 5th Road,
XiZhi District
22175
New Taipei City
+886 226975500
taiwansales@schaffner.com
Thailand
Schaffner EMC Co. Ltd.
Sathorn Square Tower
Room 3780, 37FL, 98 North-Sathorn Rd,
Silom, Bangrak
10500
Bangkok
+66 621056397
thailandsales@schaffner.com
United Kingdom
Schaffner Ltd.
1, Oakmede Place
Terrace Road
RG42 4JF
Binfield
+44 118 9770070
uksales@schaffner.com
United States
Schaffner EMC Inc.
52 Mayfield Avenue
Edison, New Jersey
+1 732 225 9533
usasales@schaffner.com
很抱歉,暂时无法提供与“FN379-4-22”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+382.600801+49.07625
- 10+325.1914610+41.71234
- 40+294.8998340+37.82683
- 80+280.8357980+36.02284
- 120+272.92491120+35.00811
- 280+257.10838280+32.97932
