DATASHEET
IEC Inlet Filters FN370
Versatile Filtered Power Entry Module
Rated currents up to 6 A
Approvals & Compliances
Single or dual-fuse holder
Fuses Ø6.3 x 32 mm or Ø5 x 20 mm
Voltage selector 100/120/230/240 V
General purpose application
Optional medical versions (B type)
Performance indicators
The FN 370 power entry module combines an IEC
inlet, a mains filter with a single or dual- fuse holder
and a voltage selector. Choosing FN 370 product line
brings you the rapid availability of a standard filter
associated with the necessary safety acceptances.
Standard IEC connector filters are a practical solution
helping you to pass EMI system approval in a short
time. A wide selection on amperage ratings, fuse
options, mounting possibilities and filters for medical
applications are designed to offer you the desired
solution.
Features and benefits
Good conducted attenuation performance, based
on chokes with high saturation resistance and
excellent thermal behavior
Technical specifications
Maximum continuous operating voltage
Operating frequency
Rated currents
High potential test voltage
Rear/front or snap-in mounting
250 V, 50/60 Hz
DC to 400 Hz
USA Ø6.3 x 32 mm or EU Ø5 x 20 mm fuses
2 to 6 A @ 40°C max.
Two attenuation performance ranges
P –> PE 2000 VAC for 2 sec (standard types)
P –> N 760 VAC for 2 sec
P –> PE 2500 VAC for 2 sec (B types)
Protection category
Temperature range (operation and storage)
Design corresponding to
Flammability corresponding to
MTBF @ 40°C/230 V (Mil-HB-217F)
Voltage selector description
Function
Voltage marking
IP 40 according to IEC 60529
-25°C to +85°C (25/85/21)
UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939
UL 94 V-2 or better
550,000 hours
Custom-specific versions are available on request
Typical applications
Portable electrical and electronic equipment
Consumer goods
VOL-SE 4SP-4
EDP and office equipment
Series/parallel
Single-phase power supplies, switch-mode power
supplies
1st
2nd
3rd
4th
Closed internal contact corresponding to
100
Test and measurement equipment
120
Medical equipment
1st
3st
4st
2st
a, c, e
* Other selected voltage marking on request.
230
240
a, d
b, d
b, c, e
Typical electrical schematic
2
Schaffner Group
EMC/EMI Products
Datasheets
05 Jan 2022
Filter selection table
Filter*
Rated current
Leakage current**
Inductance
Resistance
Output
@ 40°C (25°C)
@ 230 VAC/50 Hz
L
Capacitance
Cx
Cy
R
connections
[kΩ]
Fuses***
Weight
[A]
[μA]
[mH]
[nF]
[nF]
[Qty]
[g]
FN 370-2-2 z
2 (2.4)
373
0.70
47
2.2
13
1
55
FN 370-4-2 z
4 (4.8)
373
0.30
47
2.2
13
1
55
FN 370-6-2 z
6 (7.2)
373
0.18
47
2.2
13
1
55
FN 372-2-2 z
2 (2.4)
373
0.70
47
2.2
13
2
55
FN 372-4-2 z
4 (4.8)
373
0.30
47
2.2
13
2
55
FN 372-6-2 z
6 (7.2)
373
0.18
47
2.2
13
2
55
FN 378-2-2 z
2 (2.4)
373
0.70
47
2.2
13
2
60
FN 378-4-2 z
4 (4.8)
373
0.30
47
2.2
13
2
60
FN 378-6-2 z
6 (7.2)
373
0.18
47
2.2
13
2
60
FN 379-2-2 z
2 (2.4)
373
2.00
47
2.2
13
2
70
FN 379-4-2 z
4 (4.8)
373
0.80
47
2.2
13
2
70
FN 379-6-2 z
6 (7.2)
373
0.50
47
2.2
13
2
70
FN 379 B-2-2 z
2 (2.4)
2
2.00
47
1000
13
2
70
FN 379 B-4-2 z
4 (4.8)
2
0.80
47
1000
13
2
70
FN 379 B-6-2 z
6 (7.2)
2
0.50
47
1000
13
2
70
Select the requested fuse holder for fuse EUR-1 or USA-1 (z).
** Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level.
*** Filters are delivered without fuse.
Product selector
For example: FN 370-6-21, FN 378-4-22, FN 379 B-2-22
3
Schaffner Group
EMC/EMI Products
Typical filter attenuation
Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym; C=0.1 Ω/100 Ω sym; D=100 Ω/0.1 Ω sym
FN 370/FN 372/FN 378
FN 379
Mechanical data
FN 370/FN 372
Connection designation
FN 378/FN 379
Panel cut out
Datasheets
05 Jan 2022
4
Schaffner Group
EMC/EMI Products
Datasheets
Dimensions
FN 370
FN 372
FN 378
FN 379
Tolerances
A
32
32
50
50
±0.3
B
58
58
58
58
±0.3
40
40
±0.1
64.5
C
D
54
54
54
F
5.5
5.5
5.5
5.5
Ø3.3
Ø3.3
H
J
12.5
12.5
12.5
12.5
M
R ≤2
R ≤2
R ≤2
R ≤2
±0.1
N
55.9*/56.2**
55.9*/56.2**
55.9*/56.2**
55.9*/56.2**
+0.2/-0
P
28.5
28.5
+0.2/-0
R
S
U
9
9
For a panel thickness between 0.8 and 3 mm
For a back panel thickness between 2.1 and 3.2 mm
All dimensions in mm; 1 inch = 25.4 mm
Tolerances according: ISO 2768-m/EN 22768-m
Please visit www.schaffner.com to find more details on filter connectors.
28.5
28.5
M3
M3
90°
90°
9
9
05 Jan 2022
5
Schaffner Group
EMC/EMI Products
Datasheets
05 Jan 2022
Headquarters, global
innovation and development
Sales and application centers
Switzerland
Schaffner Group
Industrie Nord
Nordstrasse 11e
4542 Luterbach
T +41 32 681 66 26
info@schaffner.com
China
Schaffner EMC Ltd. Shanghai
T20-3 C, No 565 Chuangye Road,
Pudong district
201201 Shanghai
T +86 21 3813 9500
cschina@schaffner.com
www.schaffner.com.cn
Spain
Schaffner EMC España
Calle Caléndula 93, Miniparc III, Edificio E
El Soto de Moraleja, Alcobendas
28109 Madrid
T +34 917 912 900
F +34 917 912 901
spainsales@schaffner.com
Finland
Schaffner Oy
Sauvonrinne 19 H
08500 Lohja
T +358 50 468 7284
finlandsales@schaffner.com
Sweden
Schaffner EMC AB
Östermalmstorg 1
114 42 Stockholm
T +46 8 5050 2425
swedensales@schaffner.com
www.schaffner.com
France
Schaffner EMC S.A.S.
16-20 Rue Louis Rameau
95875 Bezons
T +33 1 34 34 30 60
F +33 1 39 47 02 28
francesales@schaffner.com
Germany
Schaffner Deutschland GmbH
Schoemperlenstrasse 12B
76185 Karlsruhe
T +49 721 56910
germanysales@schaffner.com
India
Schaffner India Pvt. Ltd
REGUS WORLD TRADE CENTRE
WTC, 22nd Floor Unit No 2238, Brigade
Gateway Campus, 26/1, Dr. Rajkumar Road
Malleshwaram (W)
560055 Bangalore
T +91 80 67935355
indiasales@schaffner.com
To find your local partner within Schaffner‘s
global network: www.schaffner.com
© 2021 Schaffner Group
The content of this document has been
carefully checked and understood. However,
neither Schaffner nor its subsidiaries assume
any liability whatsoever for any errors or
inaccuracies of this document and the
consequences thereof. Published specifications are subject to change without notice.
Product suitability for any area of application
must ultimately be determined by the
customer. In all cases, products must never
be operated outside their published
specifications. Schaffner does not guarantee
the availability of all published products. This
disclaimer shall be governed by substantive
Swiss law and resulting disputes shall be
settled by the courts at the place of business
of Schaffner Holding AG. Latest publications
and a complete disclaimer can be downloaded from the Schaffner website. All
trademarks recognized.
Italy
Schaffner EMC S.r.l.
Via Ticino, 30
20900 Monza (MB)
T +39 039 21 41 070
italysales@schaffner.com
Japan
Schaffner EMC K.K.
Taiju-Seimei Sangenjaya Bldg.
1-32-12, Kamiuma, Setagaya-ku
154-0011 Tokyo
T +81 3 5712 3650
F +81 3 5712 3651
japansales@schaffner.com
www.schaffner.jp
Singapore
Schaffner EMC Pte Ltd.
#05-09, Kg Ubi Ind. Estate
408705 Singapore
T +65 6377 3283
F +65 6377 3281
singaporesales@schaffner.com
Switzerland
Schaffner EMV AG
Industrie Nord
Nordstrasse 11e
4542 Luterbach
T +41 32 681 66 88
T +41 32 681 66 26
switzerlandsales@schaffner.com
Taiwan
Schaffner EMV Ltd.
20 Floor-2, No 97, Section 1, XinTai 5th Road
22175 XiZhi District New Taipei City 22175
T +886 2 2697 5500
F +886 2 2697 5533
taiwansales@schaffner.com
www.schaffner.com.tw
Thailand
Schaffner EMC Co. Ltd.
Northern Region Industrial Estate
67 Moo 4 Tambon Ban Klang
Amphur Muangg P.O. Box 14
51000 Lamphun
T +66 53 58 11 04
F +66 53 58 10 19
thailandsales@schaffner.com
United Kingdom
Schaffner Ltd.
1, Oakmede Place
Binfield
RG42 4JF Berkshire
T +44 118 9770070
F +44 118 9792969
uksales@schaffner.com
USA
Schaffner EMC Inc.
52 Mayfield Avenue
Edison, New Jersey
T +1 732 225 9533
F +1 732 225 4789
usasales@schaffner.com
www.schaffnerusa.com
很抱歉,暂时无法提供与“FN378-6-21”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+346.377811+41.39840
- 10+282.3645910+33.74766
- 25+260.3354525+31.11478
- 40+249.7156340+29.84552
- 80+234.8457880+28.06831
- 240+231.56816240+27.67657
