FN9233R-10-06
FN9233R-10-06
    SCHAFFNER(夏弗纳)
    PWR ENT RCPT IEC320-C14 PANEL QC
FN9233R-10-06 数据手册
DATA SHEET IEC Inlet Filters FN9233 High Performance EMC/EMI Filter Rated currents up to 15 A Approvals & Compliances Excellent attenuation performance Complies with IEC/EN 60601-1 Snap-in versions (S and S1 type) Hot inlet versions (HI type) (CQC except HI-types) Performance indicators The FN 9233 IEC inlet filter combines an excellent IEC inlet and mains filter with excellent filter attenuation in a small form factor. Choosing the FN 9233 product line brings you the rapid availability of a standard filter associated with the necessary safety acceptances. Standard IEC connector filters are a practical solution helping you to pass EMI system approval in a short time. A wide selection on amperage ratings, output connections, mounting possibilities and filters for medical applications are designed to offer you the desired solution. For types with additional earth line choke please consult the FN 9233 E data sheet. Features and Benefits Exceptional conducted attenuation performance, based on chokes with high saturation resistance and excellent thermal behavior Technical Specifications Maximum continuous operating voltage 250 VAC, 50/60 Hz Rear/front or snap-in mounting Operating frequency DC to 400 Hz Rated currents 1 to 15 A @ 50°C Optional earth line choke see FN 9233 E data sheet Approvals by rated current 1 to 10 A (ENEC, CQC) 1 to 15 A (UL, CSA) High potential test voltage P –> PE 2000 VAC for 2 sec (standard types) P –> PE 2500 VAC for 2 sec (B types) P –> N 1000 VAC for 2 sec Protection category IP 40 according to IEC 60529 Temperature range (operation and storage) -25°C to +85°C (25/85/21) Different output connections offering maximum flexibility for assembly Design corresponding to UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 Custom-specific versions are available on request Flammability corresponding to UL 94 V-2 or better MTBF @ 40°C/230 V (Mil-HB-217F) 2,540,000 hours FN 9233 B versions comply with the requirements of 1MOP acc. to IEC/EN 60601-1 for creepage and clearance, leakage current and high potential testing Wide mounting flanges available Typical Applications Portable electrical and electronic equipment Small to medium-sized machines and household equipment Single-phase power supplies, switch-mode power supplies Test and measurement equipment Medical equipment Rack mounting equipment 2 IEC Inlet Filters Schaffner Group DATA SHEET 21. Jun 2022 Filter Selection Table Filter Rated current @ 50°C (25°C) Leakage current* Inductance Capacitance Resistance @ 250 VAC/50 Hz L Cx1 Cx2 Cy R [μF] [nF] [kΩ] Output connections Weight (@ 120 VAC/60 Hz) [A] [mA] [mH] [μF] FN9233 x-1-06 1 (1.2) 0.31 (0.18) 22.5 0.1 2.2 -06 37 FN9233 x-3-06 3 (3.5) 0.31 (0.18) 4.6 0.1 2.2 -06 37 FN9233 x-6-06 6 (7.2) 0.31 (0.18) 1.6 0.1 2.2 -06 37 FN9233 x-8-06 8 (10.6) 0.31 (0.18) 0.9 0.1 2.2 -06 37 FN9233 x-10-06 10 (11.6) 0.31 (0.18) 0.45 0.1 2.2 -06 37 FN9233 x-12-06 12 (12) 0.31 (0.18) 0.27 0.1 2.2 -06 37 FN9233 x-15-06 15 (15) 0.31 (0.18) 0.2 0.1 2.2 -06 37 FN9233 x-12-06HI 12 (12) 0.31 (0.18) 0.27 0.1 2.2 -06 37 FN9233 x-15-06HI 15 (15) 0.31 (0.18) 0.2 0.1 2.2 -06 37 FN9233 xR-1-06 1 (1.2) 0.31 (0.18) 22.5 0.1 2.2 1000 -06 37 FN9233 xR-3-06 3 (3.5) 0.31 (0.18) 4.6 0.1 2.2 1000 -06 37 FN9233 xR-6-06 6 (7.2) 0.31 (0.18) 1.6 0.1 2.2 1000 -06 37 FN9233 xR-8-06 8 (10.6) 0.31 (0.18) 0.9 0.1 2.2 1000 -06 37 FN9233 xR-10-06 10 (11.6) 0.31 (0.18) 0.45 0.1 2.2 1000 -06 37 FN9233 xR-12-06 12 (12) 0.31 (0.18) 0.27 0.1 2.2 1000 -06 37 FN9233 xR-15-06 15 (15) 0.31 (0.18) 0.2 0.1 2.2 1000 -06 37 FN9233 xR-12-06HI 12 (12) 0.31 (0.18) 0.27 0.1 2.2 1000 -06 37 FN9233 xR-15-06HI 15 (15) 0.31 (0.18) 0.2 0.1 2.2 1000 -06 37 FN9233 xB-1-06 1 (1.2) 0.00 22.5 0.1 1000 -06 37 FN9233 xB-3-06 3 (3.5) 0.00 4.6 0.1 1000 -06 37 FN9233 xB-6-06 6 (7.2) 0.00 1.6 0.1 1000 -06 37 FN9233 xB-8-06 8 (10.6) 0.00 0.9 0.1 1000 -06 37 FN9233 xB-10-06 10 (11.6) 0.00 0.45 0.1 1000 -06 37 FN9233 xB-12-06 12 (12) 0.00 0.27 0.1 1000 -06 37 FN9233 xB-15-06 15 (15) 0.00 0.2 0.1 1000 -06 37 FN9233 xB-12-06HI 12 (12) 0.00 0.27 0.1 1000 -06 37 FN9233 xB-15-06HI 15 (15) 0.00 0.2 0.1 1000 -06 37 FN9233 UF2-1-06 1 (1.2) 0.47 (0.27) 22.5 0.047 0.047 3.3 -06 46 FN9233 UF2-3-06 3 (3.5) 4.6 0.047 0.047 3.3 -06 46 FN9233 UF2-6-06 6 (7.2) 1.6 0.047 0.047 3.3 -06 46 FN9233 UF2-8-06 8 (10.6) 0.9 0.047 0.047 3.3 -06 46 FN9233 UF2-10-06 10 (11.6) 0.45 0.047 0.047 3.3 -06 46 FN9233 UF2-12-06 12 (12) 0.27 0.047 0.047 3.3 -06 46 FN9233 UF2-15-06 15 (15) 0.2 0.047 0.047 3.3 -06 46 0.47 (0.27) 0.47 (0.27) 0.47 (0.27) 0.47 (0.27) 0.47 (0.27) 0.47 (0.27) [g] * Maximum leakage under normal operating conditions (acc. to IEC60939-3). Note: if the neutral line is interrupted, worst case leakage could reach twice this level. 3 IEC Inlet Filters Schaffner Group Product selector DATA SHEET Typical electrical schematic For example: FN 9233-15-06, FN 9233 S1B-10-06-20, FN 9233 R-12-06HI Typical Filter Attenuation Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym; C=0.1 Ω/100 Ω sym; D=100 Ω/0.1 Ω sym FFN 9233: 1 and 3 A types FN 9233: 6 to 10 A types FN 9233: 1 and 3 A types FN 9233 UF2: 1 and 3 A types FN 9233 UF2: 6 to 10 A types FN 9233 UF2: 12 and 15 A types 21. Jun 2022 4 IEC Inlet Filters Schaffner Group Mechanical Data FN 9233 FN 9233-HI FN 9233 S FN 9233vS1 FN 9233 U FN 9233 UF2: 1 and 3 A types FN 9233 UF2: 6 to 10 A types DATA SHEET 21. Jun 2022 5 IEC Inlet Filters Schaffner Group DATA SHEET 21. Jun 2022 Dimensions FN 9233 FN 9233 U FN 9233 UF2 FN 9233 S FN 9233 S1 FN 9233-HI A 48 48 48 29.9 29.9 48 B 22.4 25 25 22.4 22.4 22.4 C 40 40 40 D 38.25 38.25 47.1 38.25 38.25 38.25 E 27.8 27.7 27.7 27.8 27.8 27.8 40 F 5.7 5.7 5.7 5.7 5.7 5.7 G 20.1 20.1 20.1 20.1 20.1 20.1 H Ø3.3 Ø3.3 Ø3.3 Ø 3.3 I 14 14 14 14 14 14 J 13.3 13.3 13.3 13.3 13.3 13.3 M R ≤3 R ≤3 R ≤3 R ≤1.5 R ≤1.5 R ≤3 N 21.5 21.5 21.5 20.8 21.9 21.5 P 28.5 28.5 28.5 29.4 28.5 28.5 R* M3 M3 M3 S 90° 90° 90° M3 90° T** 0.7 - 1.5 0.7 - 1.5 T** 1.5 - 2.2 1.5 - 2.2 **Recommended torque for M3 (90° countersunk flat head) is 0.5 Nm ** For selecting the panel thickness, please refer to the filter selector table. All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m/EN 22768-m Please visit www.schaffner.com to find more details on connectors. Tol. ±0.2 +0.6/-0 +0.6/-0 6 IEC Inlet Filters Schaffner Group Accessories Power Cor Cord d with angled LLock ocking ing Syst System em C13 Protects appliances that are vulnerable to vibration Connector cannot be accidentally pulled or vibrated out of the inlet Space availability/constraints Different angles for ease of access Space saving Release locking mechanism Prevents accidental disconnection Technical Data Sheet > IL 13P IEC C13 R Re ewir wireable eable Angled Connec Connecttors with LLock ocking ing Syst System em Protects appliances that are vulnerable to vibration Connector cannot be accidentally pulled or vibrated out of the inlet Space availability/constraints Different angles for ease of access Space saving Release locking mechanism Prevents accidental disconnection Technical Data Sheet > IL 13P IEC C13 R Re ewir wireable eable Connec Connecttors with LLock ocking ing Syst System em The locking system has a tensile force of typical 300N. It is recommended to use it with flange mount filters. For details refer to our Application Note "Using IEC Lock Power Cords with IEC Inlets and Filters". Schaffner power connector with IEC lock guard against accidental disconnection of all electrical appliances with an IEC inlet. No exchange or modification of the IEC inlet or IEC inlet filter system is needed. Easy retrofit .for all electronic equipments and devices Technical Data Sheet > DATA SHEET 21. Jun 2022 7 IEC Inlet Filters Headquarters, Global Innovation and Development Switzerland Schaffner Holding AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 info@schaffner.com Schaffner Group China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road,Pudong district 201201 Shanghai +86 2138139500 cschina@schaffner.com Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid +34 917 912 900 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 8500 Lohja +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstrorg 1 114 42 Stockholm +46 8 5050 2425 swedensales@schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons +33 1 34 34 30 60 francesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 switzerlandsales@schaffner.com India Schaffner India Pvt. Ltd Regus World Trade Centre WTC, 22nd Floor Unit No 2238, Brigade Gateway Campus, 26/1, Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore +91 8067935355 indiasales@schaffner.com © 2022 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifica-tions are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloa-ded from the Schaffner website. All trademarks recognized. 21. Jun 2022 Sales and Application Centers Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe +49 721 56910 germanysales@schaffner.com To find your local partner within Schaffner‘s global network schaffner.com DATA SHEET Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. ISM Sangenjaya 7F 1-32-12 Kamiuma, Setagaya-ku 154-0011 Tokyo +81 3 5712 3650 japansales@schaffner.com Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1, #05-09, Kampong Ubi Industrial Estate 408705 Singapore +65 63773283 singaporesales@schaffner.com Taiwan Schaffner EMV Ltd. U-Town 20 Floor-2, No 97, Section 1, XinTai 5th Road, XiZhi District 22175 New Taipei City +886 226975500 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Sathorn Square Tower Room 3780, 37FL, 98 North-Sathorn Rd, Silom, Bangrak 10500 Bangkok +66 621056397 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 1, Oakmede Place Terrace Road RG42 4JF Binfield +44 118 9770070 uksales@schaffner.com United States Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey +1 732 225 9533 usasales@schaffner.com
FN9233R-10-06
物料型号:FN9233系列
器件简介:FN9233 IEC入口滤波器是一种高性能的EMC/EMI滤波器,额定电流高达15A,具有出色的衰减性能,并符合IEC/EN 60601-1标准。
引脚分配:文档中未明确列出引脚分配,但提供了电气原理图和典型应用图。
参数特性: - 最大连续工作电压:250VAC, 50/60Hz - 工作频率:DC至400Hz - 额定电流:1至15A@50°C - 认证:1至10A (ENEC, CQC),1至15A (UL, CSA) - 高电位测试电压:标准类型P->PE 2000 VAC 2秒,B类型P->PE 2500 VAC 2秒,P->N1000VAC 2秒 - 保护类别:IP40 (IEC60529) - 温度范围:-25°C至+85°C - 设计符合:UL1283, CSA 22.2No.8 1986, IEC/EN 60939 - 可燃性:UL 94V-2或更好 - MTBF@40°C/230V:2,540,000小时
功能详解: - 提供卓越的传导衰减性能,基于具有高饱和电阻和出色热性能的电感 - 后部/前部或快插式安装 - 可选的地线电感,详见FN9233 E数据表 - FN9233 B版本符合IEC/EN 60601-1的1MOP要求,包括爬电距离和间隙、漏电流和高电位测试 - 提供宽安装法兰 - 不同的输出连接提供最大的组装灵活性 - 可应要求提供定制特定版本
应用信息: - 便携式电子和电气设备 - 中小型机器和家用电器 - 单相电源、开关电源 - 测试和测量设备 - 医疗设备 - 机架安装设备
封装信息:提供了详细的尺寸数据和公差,以及推荐的扭矩值。
FN9233R-10-06 价格&库存
很抱歉,暂时无法提供与“FN9233R-10-06”相匹配的价格&库存,您可以联系我们找货
FN9233R-10-06
  • 1+105.746151+12.63600
  • 10+81.2126310+9.70440
  • 25+73.3886625+8.76948
  • 40+69.7444240+8.33402
  • 120+62.10768120+7.42148
  • 240+57.86663240+6.91470
  • 480+54.02678480+6.45586
  • 960+50.55299960+6.04076
库存:120
