FN9233EU-15-06HI
FN9233EU-15-06HI
    SCHAFFNER(夏弗纳)
    PWR ENT RCPT IEC320-C16 PANEL QC
FN9233EU-15-06HI 数据手册
DATA SHEET IEC Inlet Filters FN9233E High Performance EMC/EMI Filter with Earth Line Choke Rated currents up to 15 A Approvals & Compliances Excellent attenuation performance Integrated earth line choke Complies with IEC/EN 60601-1 Snap-in versions (S and S1 type) Hot inlet versions (HI type) (CQC except HI-types) Technical Specifications The FN 9233 E IEC inlet filter combines an IEC inlet and mains filter with excellent filter attenuation in a small form factor. The FN 9233 E high performance power entry module offers additional EMI suppression on the earth line. Choosing the FN 9233 E product line brings you the rapid availability of a standard filter associated with the necessary safety acceptances. Standard IEC connector filters are a practical solution helping you to pass EMI system approval in a short time. A wide selection on amperage ratings, output connections, mounting possibilities and filters for medical applications are designed to offer you the desired solution. For types without additional earth line choke please consult the FN 9233 data sheet. Maximum continuous operating voltage 250 VAC, 50/60 Hz Operating frequency DC to 400 Hz Rated currents 1 to 15 A @ 50°C Approvals by rated current 1 to 10 A (ENEC, CQC) 1 to 15 A (UL, CSA) High potential test voltage P –> PE 2000 VAC for 2 sec (standard types) P –> PE 2500 VAC for 2 sec (B types) P –> N 1000 VAC for 2 sec Protection category IP 40 according to IEC 60529 Temperature range (operation and storage) -25°C to +85°C (25/85/21) Design corresponding to UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 Exceptional conducted attenuation performance, based on chokes with high saturation resistance and excellent thermal behavior Flammability corresponding to UL 94 V-2 or better Rear/front or snap-in mounting MTBF @ 40°C/230 V (Mil-HB-217F) 1,710,000 hours Without earth line choke see FN 9233 data sheet Features and Benefits FN 9233 B versions comply with the requirements of 1MOP acc. to IEC/EN 60601-1 for creepage and clearance, leakage current and high potential testing Wide mounting flanges available Different output connections offering maximum flexibility for assembly Custom-specific versions are available on request Typical Applications Portable electrical and electronic equipment Small to medium-sized machines and household equipment Single-phase power supplies, switch-mode power supplies Test and measurement equipment Medical equipment Rack mounting equipment Typical electrical schematic 2 IEC Inlet Filters Schaffner Group DATA SHEET 21. Jun 2022 Filter Selection Table Filter Rated current @ 50°C(25 °C) Leakage current* Inductance Capacitance Resistance @ 250 VAC/50 Hz L1 L2 Cx Cy R [kΩ] Output connections Weight (@ 120 VAC/60 Hz) [A] [mA] [mH] [mH] [μF] [nF] [g] FN 9233 Ex-1-06 1 (1.2) 0.31 (0.18) 22.5 0.4 0.1 2.2 -06 46 FN 9233 Ex-3-06 3 (3.5) 0.31 (0.18) 4.6 0.4 0.1 2.2 -06 46 FN 9233 Ex-6-06 6 (7.2) 0.31 (0.18) 1.6 0.4 0.1 2.2 -06 46 FN 9233 Ex-8-06 8 (10.6) 0.31 (0.18) 0.9 0.4 0.1 2.2 -06 46 FN 9233 Ex-10-06 10 (11.6) 0.31 (0.18) 0.45 0.4 0.1 2.2 -06 46 FN 9233 Ex-12-06 12 (12) 0.31 (0.18) 0.27 0.1 0.1 2.2 -06 46 FN 9233 Ex-15-06 15 (15) 0.31 (0.18) 0.2 0.1 0.1 2.2 -06 46 FN 9233 Ex-12-06HI 12 (12) 0.31 (0.18) 0.27 0.1 0.1 2.2 -06 46 FN 9233 Ex-15-06HI 15 (15) 0.31 (0.18) 0.2 0.1 0.1 2.2 -06 46 FN 9233 ExR-1-06 1 (1.2) 0.31 (0.18) 22.5 0.4 0.1 2.2 1000 -06 46 FN 9233 ExR-3-06 3 (3.5) 0.31 (0.18) 4.6 0.4 0.1 2.2 1000 -06 46 FN 9233 ExR-6-06 6 (7.2) 0.31 (0.18) 1.6 0.4 0.1 2.2 1000 -06 46 FN 9233 ExR-8-06 8 (10.6) 0.31 (0.18) 0.9 0.4 0.1 2.2 1000 -06 46 FN 9233 ExR-10-06 10 (11.6) 0.31 (0.18) 0.45 0.4 0.1 2.2 1000 -06 46 FN 9233 ExR-12-06 12 (12) 0.31 (0.18) 0.27 0.1 0.1 2.2 1000 -06 46 FN 9233 ExR-15-06 15 (15) 0.31 (0.18) 0.2 0.1 0.1 2.2 1000 -06 46 FN 9233 ExR-12-06HI 12 (12) 0.31 (0.18) 0.27 0.1 0.1 2.2 1000 -06 46 FN 9233 ExR-15-06HI 15 (15) 0.31 (0.18) 0.2 0.1 0.1 2.2 1000 -06 46 FN 9233 ExB-1-06 1 (1.2) 0.00 22.5 0.4 0.1 1000 -06 46 FN 9233 ExB-3-06 3 (3.5) 0.00 4.6 0.4 0.1 1000 -06 46 FN 9233 ExB-6-06 6 (7.2) 0.00 1.6 0.4 0.1 1000 -06 46 FN 9233 ExB-8-06 8 (10.6) 0.00 0.9 0.4 0.1 1000 -06 46 FN 9233 ExB-10-06 10 (11.6) 0.00 0.45 0.4 0.1 1000 -06 46 FN 9233 ExB-12-06 12 (12) 0.00 0.27 0.1 0.1 1000 -06 46 FN 9233 ExB-15-06 15 (15) 0.00 0.2 0.1 0.1 1000 -06 46 FN 9233 ExB-12-06HI 12 (12) 0.00 0.27 0.1 0.1 1000 -06 46 FN 9233 ExB-15-06HI 15 (15) 0.00 0.2 0.1 0.1 1000 -06 46 * Maximum leakage under normal operating conditions (acc. to IEC60939-3). Note: if the neutral line is interrupted, worst case leakage could reach twice this level. 3 IEC Inlet Filters Schaffner Group Product selector For example: FN 9233 E-15-06, FN 9233 ES1B-10-06-20, FN 9233 ER-12-06HI, FN 9233 EUB-8-06-20 Typical Filter Attenuation Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym; C=0.1 Ω/100 Ω sym; D=100 Ω/0.1 Ω sym 1 and 3 A types 6 to 10 A types 12 and 15 A types DATA SHEET 21. Jun 2022 4 IEC Inlet Filters Schaffner Group Mechanical Data FN 9233 E FN 9233 E-HI A FN 9233 ES FN 9233 ES1 FN 9233 EU Panel cut out Installation DATA SHEET 21. Jun 2022 5 IEC Inlet Filters Schaffner Group DATA SHEET 21. Jun 2022 Dimensions FN 9233 E FN 9233 EU FN 9233 ES FN 9233 ES1 FN 9233 E-HI A 48 48 29.9 29.9 48 B 22.4 25 22.4 22.4 22.4 C 40 40 D 47.1 47.1 47.1 47.1 47.1 E 27.8 27.7 27.8 27.8 27.8 40 F 5.7 5.7 5.7 5.7 5.7 G 20.1 20.1 20.1 20.1 20.1 H Ø3.3 Ø3.3 Ø3.3 I 14 14 14 14 14 J 13.3 13.3 13.3 13.3 13.3 M R ≤3 R ≤3 R ≤1.5 R ≤1.5 R ≤3 N 21.5 21.5 20.8 21.9 21.5 P 28.5 28.5 29.4 28.5 28.5 R* M3 M3 S 90° 90° M3 90° T** 0.7 - 1.5 0.7 - 1.5 T** 1.5 - 2.2 1.5 - 2.2 **Recommended torque for M3 (90° countersunk flat head) is 0.5 Nm ** For selecting the panel thickness, please refer to the filter selector table. All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m/EN 22768-m Please visit www.schaffner.com to find more details on connectors. Tol. 0.2 +0.6/-0 +0.6/-0 6 IEC Inlet Filters Schaffner Group Accessories Power Cor Cord d with angled LLock ocking ing Syst System em C13 Protects appliances that are vulnerable to vibration Connector cannot be accidentally pulled or vibrated out of the inlet Space availability/constraints Different angles for ease of access Space saving Release locking mechanism Prevents accidental disconnection Technical Data Sheet > IL 13P IEC C13 R Re ewir wireable eable Angled Connec Connecttors with LLock ocking ing Syst System em Protects appliances that are vulnerable to vibration Connector cannot be accidentally pulled or vibrated out of the inlet Space availability/constraints Different angles for ease of access Space saving Release locking mechanism Prevents accidental disconnection Technical Data Sheet > IL 13P IEC C13 R Re ewir wireable eable Connec Connecttors with LLock ocking ing Syst System em The locking system has a tensile force of typical 300N. It is recommended to use it with flange mount filters. For details refer to our Application Note "Using IEC Lock Power Cords with IEC Inlets and Filters". Schaffner power connector with IEC lock guard against accidental disconnection of all electrical appliances with an IEC inlet. No exchange or modification of the IEC inlet or IEC inlet filter system is needed. Easy retrofit .for all electronic equipments and devices Technical Data Sheet > DATA SHEET 21. Jun 2022 7 IEC Inlet Filters Headquarters, Global Innovation and Development Switzerland Schaffner Holding AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 info@schaffner.com Schaffner Group China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road,Pudong district 201201 Shanghai +86 2138139500 cschina@schaffner.com Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid +34 917 912 900 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 8500 Lohja +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstrorg 1 114 42 Stockholm +46 8 5050 2425 swedensales@schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons +33 1 34 34 30 60 francesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 switzerlandsales@schaffner.com India Schaffner India Pvt. Ltd Regus World Trade Centre WTC, 22nd Floor Unit No 2238, Brigade Gateway Campus, 26/1, Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore +91 8067935355 indiasales@schaffner.com © 2022 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifica-tions are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloa-ded from the Schaffner website. All trademarks recognized. 21. Jun 2022 Sales and Application Centers Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe +49 721 56910 germanysales@schaffner.com To find your local partner within Schaffner‘s global network schaffner.com DATA SHEET Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. ISM Sangenjaya 7F 1-32-12 Kamiuma, Setagaya-ku 154-0011 Tokyo +81 3 5712 3650 japansales@schaffner.com Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1, #05-09, Kampong Ubi Industrial Estate 408705 Singapore +65 63773283 singaporesales@schaffner.com Taiwan Schaffner EMV Ltd. U-Town 20 Floor-2, No 97, Section 1, XinTai 5th Road, XiZhi District 22175 New Taipei City +886 226975500 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Sathorn Square Tower Room 3780, 37FL, 98 North-Sathorn Rd, Silom, Bangrak 10500 Bangkok +66 621056397 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 1, Oakmede Place Terrace Road RG42 4JF Binfield +44 118 9770070 uksales@schaffner.com United States Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey +1 732 225 9533 usasales@schaffner.com
FN9233EU-15-06HI 价格&库存
很抱歉,暂时无法提供与“FN9233EU-15-06HI”相匹配的价格&库存,您可以联系我们找货
