FN9244ES-15-06
FN9244ES-15-06
    SCHAFFNER(夏弗纳)
    PWR ENT RCPT IEC320-C14 PANEL QC
FN9244ES-15-06 数据手册
DATASHEET IEC Inlet Filters FN 9244 E Excellent Performance EMC/EMI Filter with Earth Line Choke Rated currents up to 15 A Approvals & Compliances Superior attenuation performance Integrated earth line choke Complies with IEC/EN 60601-1 Snap-in versions (S and S1 type) Hot inlet versions (HI type) (CQC except HI-types) Performance indicators Technical specifications The FN 9244 E IEC inlet filter combines an IEC inlet and mains filter with superior filter attenuation in a small form factor. The FN 9244 E high performance power entry module offers additional EMI suppression on the earth line. Choosing the FN 9244 E product line brings you the rapid availability of a standard filter associated with the necessary safety acceptances. Standard IEC connector filters are a practical solution helping you to pass EMI system approval in a short time. A wide selection on amperage ratings, output connections, mounting possibilities and filters for medical applications are designed to offer you the desired solution. For types without additional earth line choke please consult the FN 9244 data sheet. Features and benefits Maximum continuous operating voltage Operating frequency Rated currents Approvals by rated current 250 VAC, 50/60 Hz High potential test voltage P –> PE 2000 VAC for 2 sec (standard types) P –> PE 2500 VAC for 2 sec (B types) P –> N 1000 VAC for 2 sec Protection category Temperature range (operation and storage) Design corresponding to Flammability corresponding to MTBF @ 40°C/230 V (Mil-HB-217F) IP 40 according to IEC 60529 DC to 400 Hz 1 to 15 A @ 50°C 1 to 10 A (ENEC, CQC) 1 to 15 A (UL, CSA) -25°C to +85°C (25/85/21) Superior conducted attenuation performance, based on chokes with high saturation resistance and excellent thermal behavior Rear/front or snap-in mounting Without earth line choke see FN 9244 data sheet FN 9244 B versions comply with the requirements of 1MOP acc. to IEC/EN 60601-1 for creepage and clearance, leakage current and high potential testing UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 Wide mounting flanges available UL 94 V-2 or better Custom-specific versions are available on request 2,230,000 hours Typical applications Electrical and electronic equipment Small to medium-sized machines and household equipment Single-phase power supplies, switch-mode power supplies Test and measurement equipment Medical devices (MDD) In-vitro diagnostic medical devices (IVDD) Rack mounting equipment Typical electrical schematic 2 Schaffner Group EMC/EMI Products Datasheets 09 Feb 2021 Filter selection table Filter Rated current Leakage current* Inductance Capacitance @ 50°C (25°C) @ 250 VAC/50 Hz L1 L2 Cx Cy Resistance R [kΩ] Output connections Weight (@ 120 VAC/60 Hz) FN9244Ex-1-06 [A] [mA] [mH] [mH] [μF] [nF] 1 (1.2) 0.31 (0.18) 59.53 0.4 0.1 2.2 [g] -06 46 FN9244Ex-3-06 3 (3.5) 0.31 (0.18) 13.45 0.4 0.1 2.2 -06 46 FN9244Ex-6-06 6 (7.2) 0.31 (0.18) 4.1 0.4 0.1 2.2 -06 46 FN9244Ex-8-06 8 (10.6) 0.31 (0.18) 2.3 0.4 0.1 2.2 -06 46 FN9244Ex-10-06 10 (11.6) 0.31 (0.18) 1.02 0.4 0.1 2.2 -06 46 FN9244Ex-12-06 12 (12) 0.31 (0.18) 0.58 0.1 0.1 2.2 -06 46 FN9244Ex-15-06 15 (15) 0.31 (0.18) 0.4 0.1 0.1 2.2 -06 46 FN9244Ex-12-06HI 12 (12) 0.31 (0.18) 0.58 0.1 0.1 2.2 -06 46 FN9244Ex-15-06HI 15 (15) 0.31 (0.18) 0.4 0.1 0.1 2.2 -06 46 FN9244ExR-1-06 1 (1.2) 0.31 (0.18) 59.53 0.4 0.1 2.2 -06 46 FN9244ExR-3-06 3 (3.5) 0.31 (0.18) 13.45 0.4 0.1 2.2 1000 -06 46 FN9244ExR-6-06 6 (7.2) 0.31 (0.18) 4.1 0.4 0.1 2.2 1000 -06 46 FN9244ExR-8-06 8 (10.6) 0.31 (0.18) 2.3 0.4 0.1 2.2 1000 -06 46 FN9244ExR-10-06 10 (11.6) 0.31 (0.18) 1.02 0.4 0.1 2.2 1000 -06 46 FN9244ExR-12-06 12 (12) 0.31 (0.18) 0.58 0.1 0.1 2.2 1000 -06 46 FN9244ExR-15-06 15 (15) 0.31 (0.18) 0.4 0.1 0.1 2.2 1000 -06 46 FN9244ExR-12-06HI 12 (12) 0.31 (0.18) 0.58 0.1 0.1 2.2 1000 -06 46 FN9244ExR-15-06HI 15 (15) 0.31 (0.18) 0.4 0.1 0.1 2.2 1000 -06 46 FN9244ExB-1-06 1 (1.2) 0.00 59.53 0.4 0.1 1000 -06 46 FN9244ExB-3-06 3 (3.5) 0.00 13.45 0.4 0.1 1000 -06 46 FN9244ExB-6-06 6 (7.2) 0.00 4.1 0.4 0.1 1000 -06 46 FN9244ExB-8-06 8 (10.6) 0.00 2.3 0.4 0.1 1000 -06 46 FN9244ExB-10-06 10 (11.6) 0.00 1.02 0.4 0.1 1000 -06 46 FN9244ExB-12-06 12 (12) 0.00 0.58 0.1 0.1 1000 -06 46 FN9244ExB-15-06 15 (15) 0.00 0.4 0.1 0.1 1000 -06 46 FN9244ExB-12-06HI 12 (12) 0.00 0.58 0.1 0.1 1000 -06 46 FN9244ExB-15-06HI 15 (15) 0.00 0.4 0.1 0.1 1000 -06 46 1000 * Maximum leakage under normal operating conditions (acc. to IEC60939-3). Note: if the neutral line is interrupted, worst case leakage could reach twice this level. Distributor inventory Check stock levels at global distributors at https://products.schaffner.com/stock (Also available via the QR code) Stock level per types 1 - 15 A Standard housing types Housing with wider mounting flanges (U) Snap-in housing types (S&S1) Medical versions (B) Bleed resistor types (R) Link 3 Schaffner Group EMC/EMI Products Product selector For example: FN 9244 E-15-06, FN 9244 ES1B-10-06-20, FN 9244 ER-12-06HI, FN 9244 EUB-8-06 Typical filter attenuation Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym; C=0.1 Ω/100 Ω sym; D=100 Ω/0.1 Ω sym 1 and 3 A types 6 to 10 A types 12 and 15 A types Datasheets 09 Feb 2021 4 Schaffner Group EMC/EMI Products Mechanical data FN 9244 E FN 9244 E-HI FN 9244 ES FN 9244 ES1 FN 9244EU Panel cut out Installation Datasheets 09 Feb 2021 5 Schaffner Group EMC/EMI Products Datasheets 09 Feb 2021 Dimensions FN 9244 E FN 9244 EU FN 9244 ES FN 9244 ES1 FN 9244 E-HI A 48 48 29.9 29.9 48 B 22.4 25 22.4 22.4 C 40 40 D 46.8 46.7 E 27.8 27.7 27.8 27.8 27.8 F 5.7 5.7 5.7 5.7 5.7 G 20.1 20.1 20.1 20.1 H Ø3.3 Ø3.3 I 14 14 14 14 J 13.3 13.3 13.3 13.3 13.3 M R ≤3 R ≤3 R ≤1.5 R ≤1.5 R ≤3 N 21.5 21.5 20.8 21.9 21.5 P 28.5 28.5 29.4 28.5 R* M3 M3 S 90° 90° 22.4 40 46.8 46.8 20.1 14 28.5 M3 90° 0.7 - 1.5 0.7 - 1.5 T** 1.5 - 2.2 1.5 - 2.2 **Recommended torque for M3 (90° countersunk flat head) is 0.5 Nm ** For selecting the panel thickness, please refer to the filter selector table. All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m/EN 22768-m Please visit www.schaffner.com to find more details on filter connectors. ±0.2 46.8 Ø3.3 T** Tol. +0.6/-0 +0.6/-0 6 Schaffner Group EMC/EMI Products Accessories Power Cor Cord d with angled LLock ocking ing Syst System em C13 Locking system for standardized IEC C14 inlet filter No accidental disconnection Rated current up to 15 A Fits any Schaffner IEC C14 inlet filter Retrofit for any IEC C14 inlet Various power line plucs for international usage Datasheet PDF > IL 13P IEC C13 R Re ewir wireable eable Angled Connec Connecttors with LLock ocking ing Syst System em Locking system for standardized IEC C14 inlet filter No accidental disconnection Rated current up to 15 A Fits any Schaffner IEC C14 inlet filter Retrofit for any IEC C14 inlet Various power line plugs for international usage Datasheet PDF > IL 13P IEC C13 R Re ewir wireable eable Connec Connecttors with LLock ocking ing Syst System em Guards against accidental disconnection Requires no other equipment or special inlets to secure it Rewireable - offering total flexibility when assembling cables Fits any Schaffner IEC C14 inlet Filter Can be retrofitted Various power line plugs for international usage LSZH - Low smoke zero halogen Datasheet PDF > Datasheets 09 Feb 2021 7 Schaffner Group EMC/EMI Products Datasheets 09 Feb 2021 Headquarters, global innovation and development Sales and application centers Switzerland Schaffner Group Industrie Nord Nordstrasse 11e 4542 Luterbach T +41 32 681 66 26 info@schaffner.com China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road, Pudong district 201201 Shanghai T +86 21 3813 9500 cschina@schaffner.com www.schaffner.com.cn Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid T +34 917 912 900 F +34 917 912 901 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 08500 Lohja T +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstorg 1 114 42 Stockholm T +46 8 5050 2425 swedensales@schaffner.com www.schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons T +33 1 34 34 30 60 F +33 1 39 47 02 28 francesales@schaffner.com Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe T +49 721 56910 F +49 721 569110 germanysales@schaffner.com India Schaffner India Pvt. Ltd REGUS WORLD TRADE CENTRE WTC, 22nd Floor Unit No 2238, Brigade Gateway Campus, 26/1, Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore T +91 80 67935355 indiasales@schaffner.com To find your local partner within Schaffner‘s global network: www.schaffner.com © 2020 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifications are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloaded from the Schaffner website. All trademarks recognized. Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) T +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. Taiju-Seimei Sangenjaya Bldg. 1-32-12, Kamiuma, Setagaya-ku 154-0011 Tokyo T +81 3 5712 3650 F +81 3 5712 3651 japansales@schaffner.com www.schaffner.jp Singapore Schaffner EMC Pte Ltd. #05-09, Kg Ubi Ind. Estate 408705 Singapore T +65 6377 3283 F +65 6377 3281 singaporesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach T +41 32 681 66 88 T +41 32 681 66 26 switzerlandsales@schaffner.com Taiwan Schaffner EMV Ltd. 20 Floor-2, No 97, Section 1, XinTai 5th Road 22175 XiZhi District New Taipei City 22175 T +886 2 2697 5500 F +886 2 2697 5533 taiwansales@schaffner.com www.schaffner.com.tw Thailand Schaffner EMC Co. Ltd. Northern Region Industrial Estate 67 Moo 4 Tambon Ban Klang Amphur Muangg P.O. Box 14 51000 Lamphun T +66 53 58 11 04 F +66 53 58 10 19 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 1, Oakmede Place Binfield RG42 4JF Berkshire T +44 118 9770070 F +44 118 9792969 uksales@schaffner.com USA Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey T +1 732 225 9533 F +1 732 225 4789 usasales@schaffner.com www.schaffnerusa.com
FN9244ES-15-06
物料型号:FN 9244 E
器件简介:该产品是一个IEC入口滤波器,集成了优越的EMC/EMI滤波性能和接地线扼流圈,符合IEC/EN 60601-1标准,有快插式(S和S1型)和热入口(HI型)版本。
引脚分配:文档中未明确提供引脚分配信息,但提到了多种输出连接选项。
参数特性: - 最大连续工作电压:250 VAC, 50/60Hz - 工作频率:DC至400Hz - 额定电流:1至15A@50°C - 认证:1至10A(ENEC,CQC),1至15A(UL/CSA) - 高电位测试电压:标准型和B型有不同标准 - 防护等级:IP40 - 工作和存储温度范围:-25°C至+85°C - 设计符合:UL1283, CSA 222 No.8 1986, IEC/EN60939 - 可燃性:UL 94V-2或更好 - MTBF @40°C/230 V(Mil-HB-217F):2,230,000小时
功能详解:FN 9244 E IEC入口滤波器结合了IEC入口和主滤波器,具有优越的滤波衰减性能。高功率输入模块在地线上提供了额外的EMI抑制。
应用信息:适用于电子电气设备、中小型机械和家用电器、单相电源、开关电源、测试和测量设备、医疗设备(MDD)、体外诊断医疗设备(IVDD)、机架安装设备等。
封装信息:提供了多种额定电流、输出连接、安装方式和医疗应用的滤波器选择。
FN9244ES-15-06 价格&库存
很抱歉,暂时无法提供与“FN9244ES-15-06”相匹配的价格&库存,您可以联系我们找货
FN9244ES-15-06
  • 120+79.41703120+10.26973
