DATASHEET
IEC Inlet Filters FN 9244 E
Excellent Performance EMC/EMI Filter with Earth Line Choke
Rated currents up to 15 A
Approvals & Compliances
Superior attenuation performance
Integrated earth line choke
Complies with IEC/EN 60601-1
Snap-in versions (S and S1 type)
Hot inlet versions (HI type)
(CQC except HI-types)
Performance indicators
Technical specifications
The FN 9244 E IEC inlet filter combines an IEC inlet
and mains filter with superior filter attenuation in a
small form factor. The FN 9244 E high performance
power entry module offers additional EMI
suppression on the earth line. Choosing the FN 9244
E product line brings you the rapid availability of a
standard filter associated with the necessary safety
acceptances. Standard IEC connector filters are a
practical solution helping you to pass EMI system
approval in a short time. A wide selection on
amperage ratings, output connections, mounting
possibilities and filters for medical applications are
designed to offer you the desired solution. For types
without additional earth line choke please consult
the FN 9244 data sheet.
Features and benefits
Maximum continuous operating voltage
Operating frequency
Rated currents
Approvals by rated current
250 VAC, 50/60 Hz
High potential test voltage
P –> PE 2000 VAC for 2 sec (standard types)
P –> PE 2500 VAC for 2 sec (B types)
P –> N 1000 VAC for 2 sec
Protection category
Temperature range (operation and storage)
Design corresponding to
Flammability corresponding to
MTBF @ 40°C/230 V (Mil-HB-217F)
IP 40 according to IEC 60529
DC to 400 Hz
1 to 15 A @ 50°C
1 to 10 A (ENEC, CQC)
1 to 15 A (UL, CSA)
-25°C to +85°C (25/85/21)
Superior conducted attenuation performance,
based on chokes with high saturation resistance
and excellent thermal behavior
Rear/front or snap-in mounting
Without earth line choke see FN 9244 data sheet
FN 9244 B versions comply with the requirements of
1MOP acc. to IEC/EN 60601-1 for creepage and
clearance, leakage current and high potential
testing
UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939
Wide mounting flanges available
UL 94 V-2 or better
Custom-specific versions are available on request
2,230,000 hours
Typical applications
Electrical and electronic equipment
Small to medium-sized machines and household
equipment
Single-phase power supplies, switch-mode power
supplies
Test and measurement equipment
Medical devices (MDD)
In-vitro diagnostic medical devices (IVDD)
Rack mounting equipment
Typical electrical schematic
2
Schaffner Group
EMC/EMI Products
Datasheets
09 Feb 2021
Filter selection table
Filter
Rated current
Leakage current*
Inductance
Capacitance
@ 50°C (25°C)
@ 250 VAC/50 Hz
L1
L2
Cx
Cy
Resistance
R
[kΩ]
Output connections
Weight
(@ 120 VAC/60 Hz)
FN9244Ex-1-06
[A]
[mA]
[mH]
[mH]
[μF]
[nF]
1 (1.2)
0.31 (0.18)
59.53
0.4
0.1
2.2
[g]
-06
46
FN9244Ex-3-06
3 (3.5)
0.31 (0.18)
13.45
0.4
0.1
2.2
-06
46
FN9244Ex-6-06
6 (7.2)
0.31 (0.18)
4.1
0.4
0.1
2.2
-06
46
FN9244Ex-8-06
8 (10.6)
0.31 (0.18)
2.3
0.4
0.1
2.2
-06
46
FN9244Ex-10-06
10 (11.6)
0.31 (0.18)
1.02
0.4
0.1
2.2
-06
46
FN9244Ex-12-06
12 (12)
0.31 (0.18)
0.58
0.1
0.1
2.2
-06
46
FN9244Ex-15-06
15 (15)
0.31 (0.18)
0.4
0.1
0.1
2.2
-06
46
FN9244Ex-12-06HI
12 (12)
0.31 (0.18)
0.58
0.1
0.1
2.2
-06
46
FN9244Ex-15-06HI
15 (15)
0.31 (0.18)
0.4
0.1
0.1
2.2
-06
46
FN9244ExR-1-06
1 (1.2)
0.31 (0.18)
59.53
0.4
0.1
2.2
-06
46
FN9244ExR-3-06
3 (3.5)
0.31 (0.18)
13.45
0.4
0.1
2.2
1000
-06
46
FN9244ExR-6-06
6 (7.2)
0.31 (0.18)
4.1
0.4
0.1
2.2
1000
-06
46
FN9244ExR-8-06
8 (10.6)
0.31 (0.18)
2.3
0.4
0.1
2.2
1000
-06
46
FN9244ExR-10-06
10 (11.6)
0.31 (0.18)
1.02
0.4
0.1
2.2
1000
-06
46
FN9244ExR-12-06
12 (12)
0.31 (0.18)
0.58
0.1
0.1
2.2
1000
-06
46
FN9244ExR-15-06
15 (15)
0.31 (0.18)
0.4
0.1
0.1
2.2
1000
-06
46
FN9244ExR-12-06HI
12 (12)
0.31 (0.18)
0.58
0.1
0.1
2.2
1000
-06
46
FN9244ExR-15-06HI
15 (15)
0.31 (0.18)
0.4
0.1
0.1
2.2
1000
-06
46
FN9244ExB-1-06
1 (1.2)
0.00
59.53
0.4
0.1
1000
-06
46
FN9244ExB-3-06
3 (3.5)
0.00
13.45
0.4
0.1
1000
-06
46
FN9244ExB-6-06
6 (7.2)
0.00
4.1
0.4
0.1
1000
-06
46
FN9244ExB-8-06
8 (10.6)
0.00
2.3
0.4
0.1
1000
-06
46
FN9244ExB-10-06
10 (11.6)
0.00
1.02
0.4
0.1
1000
-06
46
FN9244ExB-12-06
12 (12)
0.00
0.58
0.1
0.1
1000
-06
46
FN9244ExB-15-06
15 (15)
0.00
0.4
0.1
0.1
1000
-06
46
FN9244ExB-12-06HI
12 (12)
0.00
0.58
0.1
0.1
1000
-06
46
FN9244ExB-15-06HI
15 (15)
0.00
0.4
0.1
0.1
1000
-06
46
1000
* Maximum leakage under normal operating conditions (acc. to IEC60939-3). Note: if the neutral line is interrupted, worst case leakage could reach twice this level.
Distributor inventory
Check stock levels at global distributors at
https://products.schaffner.com/stock
(Also available via the QR code)
Stock level per types 1 - 15 A
Standard housing types
Housing with wider mounting flanges (U)
Snap-in housing types (S&S1)
Medical versions (B)
Bleed resistor types (R)
Link
3
Schaffner Group
EMC/EMI Products
Product selector
For example: FN 9244 E-15-06, FN 9244 ES1B-10-06-20, FN 9244 ER-12-06HI, FN 9244 EUB-8-06
Typical filter attenuation
Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym; C=0.1 Ω/100 Ω sym; D=100 Ω/0.1 Ω sym
1 and 3 A types
6 to 10 A types
12 and 15 A types
Datasheets
09 Feb 2021
4
Schaffner Group
EMC/EMI Products
Mechanical data
FN 9244 E
FN 9244 E-HI
FN 9244 ES
FN 9244 ES1
FN 9244EU
Panel cut out
Installation
Datasheets
09 Feb 2021
5
Schaffner Group
EMC/EMI Products
Datasheets
09 Feb 2021
Dimensions
FN 9244 E
FN 9244 EU
FN 9244 ES
FN 9244 ES1
FN 9244 E-HI
A
48
48
29.9
29.9
48
B
22.4
25
22.4
22.4
C
40
40
D
46.8
46.7
E
27.8
27.7
27.8
27.8
27.8
F
5.7
5.7
5.7
5.7
5.7
G
20.1
20.1
20.1
20.1
H
Ø3.3
Ø3.3
I
14
14
14
14
J
13.3
13.3
13.3
13.3
13.3
M
R ≤3
R ≤3
R ≤1.5
R ≤1.5
R ≤3
N
21.5
21.5
20.8
21.9
21.5
P
28.5
28.5
29.4
28.5
R*
M3
M3
S
90°
90°
22.4
40
46.8
46.8
20.1
14
28.5
M3
90°
0.7 - 1.5
0.7 - 1.5
T**
1.5 - 2.2
1.5 - 2.2
**Recommended torque for M3 (90° countersunk flat head) is 0.5 Nm
** For selecting the panel thickness, please refer to the filter selector table.
All dimensions in mm; 1 inch = 25.4 mm
Tolerances according: ISO 2768-m/EN 22768-m
Please visit www.schaffner.com to find more details on filter connectors.
±0.2
46.8
Ø3.3
T**
Tol.
+0.6/-0
+0.6/-0
6
Schaffner Group
EMC/EMI Products
Accessories
Power Cor
Cord
d with angled LLock
ocking
ing Syst
System
em C13
Locking system for standardized IEC C14 inlet filter
No accidental disconnection
Rated current up to 15 A
Fits any Schaffner IEC C14 inlet filter
Retrofit for any IEC C14 inlet
Various power line plucs for international usage
Datasheet PDF >
IL 13P IEC C13 R
Re
ewir
wireable
eable Angled Connec
Connecttors with LLock
ocking
ing Syst
System
em
Various power line plugs for international usage
Datasheet PDF >
IL 13P IEC C13 R
Re
ewir
wireable
eable Connec
ocking
ing Syst
System
em
Guards against accidental disconnection
Requires no other equipment or special inlets to
secure it
Rewireable - offering total flexibility when
assembling cables
Fits any Schaffner IEC C14 inlet Filter
Can be retrofitted
LSZH - Low smoke zero halogen
Datasheet PDF >
Datasheets
09 Feb 2021
7
Schaffner Group
EMC/EMI Products
Datasheets
09 Feb 2021
Headquarters, global
innovation and development
Sales and application centers
Switzerland
Schaffner Group
Industrie Nord
Nordstrasse 11e
4542 Luterbach
T +41 32 681 66 26
info@schaffner.com
China
Schaffner EMC Ltd. Shanghai
T20-3 C, No 565 Chuangye Road,
Pudong district
201201 Shanghai
T +86 21 3813 9500
cschina@schaffner.com
www.schaffner.com.cn
Spain
Schaffner EMC España
Calle Caléndula 93, Miniparc III, Edificio E
El Soto de Moraleja, Alcobendas
28109 Madrid
T +34 917 912 900
F +34 917 912 901
spainsales@schaffner.com
Finland
Schaffner Oy
Sauvonrinne 19 H
08500 Lohja
T +358 50 468 7284
finlandsales@schaffner.com
Sweden
Schaffner EMC AB
Östermalmstorg 1
114 42 Stockholm
T +46 8 5050 2425
swedensales@schaffner.com
www.schaffner.com
France
Schaffner EMC S.A.S.
16-20 Rue Louis Rameau
95875 Bezons
T +33 1 34 34 30 60
F +33 1 39 47 02 28
francesales@schaffner.com
Germany
Schaffner Deutschland GmbH
Schoemperlenstrasse 12B
76185 Karlsruhe
T +49 721 56910
F +49 721 569110
germanysales@schaffner.com
India
Schaffner India Pvt. Ltd
REGUS WORLD TRADE CENTRE
WTC, 22nd Floor Unit No 2238, Brigade
Gateway Campus, 26/1, Dr. Rajkumar Road
Malleshwaram (W)
560055 Bangalore
T +91 80 67935355
indiasales@schaffner.com
To find your local partner within Schaffner‘s
global network: www.schaffner.com
© 2020 Schaffner Group
The content of this document has been
carefully checked and understood. However,
neither Schaffner nor its subsidiaries assume
any liability whatsoever for any errors or
inaccuracies of this document and the
consequences thereof. Published specifications are subject to change without notice.
Product suitability for any area of application
must ultimately be determined by the
customer. In all cases, products must never
be operated outside their published
specifications. Schaffner does not guarantee
the availability of all published products. This
disclaimer shall be governed by substantive
Swiss law and resulting disputes shall be
settled by the courts at the place of business
of Schaffner Holding AG. Latest publications
and a complete disclaimer can be downloaded from the Schaffner website. All
trademarks recognized.
Italy
Schaffner EMC S.r.l.
Via Ticino, 30
20900 Monza (MB)
T +39 039 21 41 070
italysales@schaffner.com
Japan
Schaffner EMC K.K.
Taiju-Seimei Sangenjaya Bldg.
1-32-12, Kamiuma, Setagaya-ku
154-0011 Tokyo
T +81 3 5712 3650
F +81 3 5712 3651
japansales@schaffner.com
www.schaffner.jp
Singapore
Schaffner EMC Pte Ltd.
#05-09, Kg Ubi Ind. Estate
408705 Singapore
T +65 6377 3283
F +65 6377 3281
singaporesales@schaffner.com
Switzerland
Schaffner EMV AG
Industrie Nord
Nordstrasse 11e
4542 Luterbach
T +41 32 681 66 88
T +41 32 681 66 26
switzerlandsales@schaffner.com
Taiwan
Schaffner EMV Ltd.
20 Floor-2, No 97, Section 1, XinTai 5th Road
22175 XiZhi District New Taipei City 22175
T +886 2 2697 5500
F +886 2 2697 5533
taiwansales@schaffner.com
www.schaffner.com.tw
Thailand
Schaffner EMC Co. Ltd.
Northern Region Industrial Estate
67 Moo 4 Tambon Ban Klang
Amphur Muangg P.O. Box 14
51000 Lamphun
T +66 53 58 11 04
F +66 53 58 10 19
thailandsales@schaffner.com
United Kingdom
Schaffner Ltd.
1, Oakmede Place
Binfield
RG42 4JF Berkshire
T +44 118 9770070
F +44 118 9792969
uksales@schaffner.com
USA
Schaffner EMC Inc.
52 Mayfield Avenue
Edison, New Jersey
T +1 732 225 9533
F +1 732 225 4789
usasales@schaffner.com
www.schaffnerusa.com
很抱歉,暂时无法提供与“FN9244ESB-12-06”相匹配的价格&库存,您可以联系我们找货
