FN9260SB-2-06-10
FN9260SB-2-06-10
    SCHAFFNER(夏弗纳)
    PWR ENT MOD RCPT IEC320-C14 PNL
FN9260SB-2-06-10 数据手册
DATA SHEET Power Entry Module with EMC- Filter FN9260/ FN261 General Purpose Power Entry Module with Fuses Rated currents up to 10 A Approvals & Compliances Integrated single/dual fuse holder Optional reduced leakage current versions (A/B type) Complies with IEC/EN 60601-1 Snap-in versions (S type) Good attenuation performance NEW: Wire leads option Performance indicators The FN9260 power entry module combines an IEC inlet, mains filter with excellent filter attenuation and fuses in a small form factor. Choosing FN9260 product line brings you rapid availability of a standard filter associated with the necessary safety acceptances. Standard IEC connector filters are a practical solution helping you to pass EMI system approval in a short time. A wide selection on amperage ratings, output connections, mounting possibilities and filters for medical applications are designed to offer you the desired solution. Features and Benefits Exceptional conducted attenuation performance, based on chokes with high saturation resistance and excellent thermal behavior FN9260 B versions comply with the requirements of 1MOP acc. to IEC/EN 60601-1 for creepage and clearance, leakage current and high potential testing Versions up to 10 A are available with fuse holder for one or two fuses Technical Specifications Custom-specific versions are available on request Maximum continuous operating voltage 250 VAC, 50/60 Hz Operating frequency DC to 400 Hz Rated currents 1 to 10 A @ 40°C max Portable electrical and electronic equipment High potential test voltage P –> PE 2000 VAC for 2 sec (standard types) P –> PE 2500 VAC for 2 sec (B types) P –> N 760 VAC for 2 sec Medical equipment Protection category IP 40 according to IEC 60529 Temperature range (operation and storage) -25°C to +85°C (25/85/21) Single-phase power supplies, switch-mode power supplies Design corresponding to UL 60939-3, CSA Std C22.2 No. 8-13, IEC/EN 60939-3, GB/T15287, GB/T15288 Test and measurement equipment Flammability corresponding to Inlet plastic: UL 94 V-0 Fuseholder plastic: UL 94 V-0 Typical electrical schematic MTBF @ 40°C/230 V (Mil-HB-217F) 2,200,000 hours Fuse holder 1 or 2 fuses (Ø5 x 20 mm) (certified to IEC 60127-6), power acceptance 1.6W @ Ta 23°C per pole for 2 fuses. 2.5W, if only 1 pole is used. Typical Applications Small to medium-sized machines and household equipment 2 Power Entry Module with EMC- Filter Schaffner Group DATA SHEET 24. Nov 2022 Filter Selection Table Filter Buy Rated current Leakage current* Inductance** Capacitance** Resistance** @ 40°C (25°C) @ 250 VAC/50 Hz L Cx Cy R Output connections Fuses*** Weight [Qty] [g] (@ 120 VAC/60 Hz) [A] [mA] [mH] [μF] [nF] [kΩ] FN9260v-1-yy-zz 1 (1.2) 0.31 (0.18) 5.3 0.1 2.2 1000 -06 -07 2 55 FN9260v-2-yy-zz 2 (2.3) 0.31 (0.18) 2.7 0.1 2.2 1000 -06 -07 2 55 FN9260v-4-yy-zz 4 (4.6) 0.31 (0.18) 1.0 0.1 2.2 1000 -06 -07 2 55 FN9260v-6-yy-zz 6 (6.9) 0.31 (0.18) 0.3 0.1 2.2 1000 -06 -07 2 55 10 (11.5) 0.31 (0.18) 0.2 0.1 2.2 1000 -06 -07 2 55 FN9260vA1-1-yy-zz 1 (1.2) 0.03 (0.02) 5.3 0.1 0.22 1000 -06 -07 2 55 FN9260vA-2-yy-zz 2 (2.3) 0.07 (0.04) 2.7 0.1 0.47 1000 -06 -07 2 55 FN9260vA-4-yy-zz 4 (4.6) 0.07 (0.04) 1.0 0.1 0.47 1000 -06 -07 2 55 FN9260v-10-yy-zz FN9260vA-6-yy-zz 6 (6.9) 0.07 (0.04) 0.3 0.1 0.47 1000 -06 -07 2 55 10 (11.5) 0.07 (0.04) 0.2 0.1 0.47 1000 -06 -07 2 55 FN9260vB-1-yy-zz 1 (1.2) 0.00 5.3 0.1 1000 -06 -07 2 55 FN9260vB-2-yy-zz 2 (2.3) 0.00 2.7 0.1 1000 -06 -07 2 55 FN9260vB-4-yy-zz 4 (4.6) 0.00 1.0 0.1 1000 -06 -07 2 55 FN9260vB-6-yy-zz 6 (6.9) 0.00 0.3 0.1 1000 -06 -07 2 55 10 (11.5) 0.00 0.2 0.1 1000 -06 -07 2 55 FN261v-1-06-zz 1 (1.2) 0.31 (0.18) 5.3 0.1 2.2 1000 -06 1 55 FN261v-2-06-zz 2 (2.3) 0.31 (0.18) 2.7 0.1 2.2 1000 -06 1 55 FN261v-4-06-zz 4 (4.6) 0.31 (0.18) 1.0 0.1 2.2 1000 -06 1 55 FN261v-6-06-zz 6 (6.9) 0.31 (0.18) 0.3 0.1 2.2 1000 -06 1 55 10 (11.5) 0.31 (0.18) 0.2 0.1 2.2 1000 -06 1 55 FN9260vA-10-yy-zz FN9260vB-10-yy-zz FN261v-10-06-zz * Leakage current under normal operating conditions (acc. to IEC60939-3). Note: if the neutral line is interrupted, worst case leakage could reach twice this level. ** Tolerances apply: Inductance: -30/+50%, Capacitance: ±20%, Resistance: ±10% *** Fuses are not included in the filter and need to be selected according to application Product selector FN9260vw- xx-yy-zz Snap -in range for S version only 10: Snap -in range 0.6 to 1.5mm 20: Snap -in range 1.6 to 2.5mm 30: Snap -in range 2.6 to 3.5mm 06: 07: Fast-on 6.3 x 0.8mm (spade/soldering) Wire leads 1 to 10: Rated current Blank: A: B: Standard version Safety version Medical version (without Y-capacitor) Blank: S: Standard housing with mounting flanges Snap -in version, snapper on vertical side For example: FN9260-1-06-10, FN9260SB-10-06-20, FN261S-6-06-30 3 Power Entry Module with EMC- Filter Schaffner Group DATA SHEET 24. Nov 2022 Typical Filter Attenuation Per CISPR 17; DM (differential mode)=50 Ω/50 Ω sym; CM (common mode)=50 Ω/50 Ω asym FN261/ FN9260: 1 A type FN261/ FN9260: 2 A type FN261/ FN9260: 4 A type FN261/ FN9260: 6 and 10 A types Mechanical Data FN9260w-xx-06-zz / FN261 FN9260Sw-xx-06-zz / FN261S FN9260w-xx-07-zz FN9260Sw-xx-07-zz B B IEC PLUG TYPE C14 IEC PLUG TYPE C14 H S BU BU J AC J GNYE E Z G Panel cut out F D A J J E GNYE BN Z BN G I F D I Installation For selecting the panel thickness, please refer to the filter selector table 4 Power Entry Module with EMC- Filter Schaffner Group DATA SHEET 24. Nov 2022 Dimensions FN9260vw-xx-06-zz FN261 Fast-On FN9260vw-xx-07-zz FN9260Sw-xx-07-zz Wire leads** FN9260Sw-xx-06-zz FN261 Fast-On A 46 Wire leads** Tolerances 46 34 34 B ±0.3 35 35 35 35 ±0.3 C 36 36 D 41 50 41 50 E 27.8 27.8 27.8 27.8 F 5.5 5.5 5.5 5.5 ±0.3 G 32 32 32 32 +0.3/-0 H ±0.3 Ø3.2 Ø3.2 I 14±0.5 160±5** 14±0.5 160±5** J 12.5 7.8 12.5 7.8 ±0.1 M R ≤3.5 R ≤3.5 R ≤3.5 R ≤3.5 N 33 +0.3/-0 33 +0.3/-0 33 +0.2/-0 33 +0.2/-0 P 29 ±0.3 29 ±0.3 29.5 ±0.2 29.5 ±0.2 R* M3 M3 S 90° 90° Z 6 *Recommended torque for M3 (90° countersunk flat head) is 0.5 Nm ** 1 A - 6 A - AWG18; 10 A - AWG16 All dimensions in mm; 1 inch = 25.4 mm / Tolerances according: ISO 2768-m/EN 22768-m Please visit www.schaffner.com to find more details on filter connections. +0.3/-0 6 5 Power Entry Module with EMC- Filter Schaffner Group DATA SHEET 24. Nov 2022 Accessories IL 13P IEC C13 R Re ewir wireable eable Connec Connecttors with LLock ocking ing Syst System em The locking system has a tensile force of typical 300N. It is recommended to use it with flange mount filters. For details refer to our Application Note "Using IEC Lock Power Cords with IEC Inlets and Filters". Schaffner power connector with IEC lock guard against accidental disconnection of all electrical appliances with an IEC inlet. No exchange or modification of the IEC inlet or IEC inlet filter system is needed. Easy retrofit .for all electronic equipments and devices Technical Data Sheet > IL 13P IEC C13 R Re ewir wireable eable Angled Connec Connecttors with LLock ocking ing Syst System em Protects appliances that are vulnerable to vibration Connector cannot be accidentally pulled or vibrated out of the inlet Space availability/constraints Different angles for ease of access Space saving Release locking mechanism Prevents accidental disconnection Technical Data Sheet > Power Cor Cord d with angled LLock ocking ing Syst System em C13 Protects appliances that are vulnerable to vibration Connector cannot be accidentally pulled or vibrated out of the inlet Space availability/constraints Different angles for ease of access Space saving Release locking mechanism Prevents accidental disconnection Technical Data Sheet > 6 Power Entry Module with EMC- Filter Schaffner Group DATA SHEET 24. Nov 2022 Headquarters, Global Innovation and Development Switzerland Schaffner Group Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 info@schaffner.com Sales and Application Centers China Schaffner EMC Ltd. Shanghai T20-3 C No 565 Chuangye Road Pudong district 201201 Shanghai +86 2138139500 cschina@schaffner.com Spain Schaffner EMC España Calle Caléndula 93 Miniparc III Edificio E El Soto de Moraleja Alcobendas 28109 Madrid +34 917 912 900 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 8500 Lohja +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstrorg 1 114 42 Stockholm +46 8 5050 2425 swedensales@schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons +33 1 34 34 30 60 francesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 switzerlandsales@schaffner.com Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe +49 721 56910 germanysales@schaffner.com India Schaffner India Pvt. Ltd Regus World Trade Centre WTC 22nd Floor Unit No 2238 Brigade Gateway Campus 26/1 Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore +91 8067935355 indiasales@schaffner.com To find your local partner within Schaffner‘s global network schaffner.com © 2022 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifica-tionsw are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloa-ded from the Schaffner website. All trademarks recognized. Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. ISM Sangenjaya 7F 1-32-12 Kamiuma Setagaya-ku 154-0011 Tokyo +81 3 5712 3650 japansales@schaffner.com Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1 #05-09 Kampong Ubi Industrial Estate 408705 Singapore +65 63773283 singaporesales@schaffner.com Taiwan Schaffner EMV Ltd. U-Town 20 Floor-2 No 97 Section 1 XinTai 5th Road XiZhi District 22175 New Taipei City +886 226975500 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Sathorn Square Tower Room 3780 37FL 98 North-Sathorn Rd Silom Bangrak 10500 Bangkok +66 621056397 thailandsales@schaffner.com United Kingdom Schaffner Ltd. Suite 1 Oakmede Place Terrace Road RG42 4JF Binfield +44 118 9770070 uksales@schaffner.com United States Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey +1 732 225 9533 usasales@schaffner.com
FN9260SB-2-06-10 价格&库存
很抱歉,暂时无法提供与“FN9260SB-2-06-10”相匹配的价格&库存,您可以联系我们找货
FN9260SB-2-06-10
  • 1+169.017401+21.67830
  • 10+143.6717510+18.42745
  • 25+134.6710325+17.27301
  • 60+126.6044160+16.23838
  • 120+122.21890120+15.67589
库存:118
