FN9263S1-10-06
FN9263S1-10-06
    SCHAFFNER(夏弗纳)
    PWR ENT MOD RCPT IEC320-C14 PNL
FN9263S1-10-06 数据手册
IEC Inlet Filters FN 9263 General Purpose Power Entry Module with Mains Switch Rated currents up to 10A 1-pole rocker switch Snap-in versions (S and S1 type) Compact to fit 1U rack size Flammability corresponding to: Function: High potential test voltage for capacitors: Maximum continuous operating voltage: MTBF @ 40°C/230V (Mil-HB-217F): Operating frequency: Protection category: Rated currents: Rocker switch description: Switch ratings: Europe (ENEC): Temperature range (operation and storage): USA (UL): (CQC except HI-types) Typical electrical schematic Technical specifications Canada (CSA): Design corresponding to: Electrical specifications: Approvals 10A, 250VAC; 1/4HP UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 Inrush current 78A 10,000 on-off operations according to UL 1054, TV 5 UL 94V-2 or better 1-pole, dark not illuminated Marking I - 0 P –> PE 2000VAC for 2 sec P –> N 760VAC for 2 sec 250VAC, 50/60Hz 6,500,000 hours 50 to 400Hz IP40 according to IEC 60529 1 to 10 A @ 40°C max. 10A (4A), 250VAC* -25°C to +85°C (25/85/21) 10A, 125VAC; 8A, 250VAC; 1/4HP Features and benefits The FN9263 power entry module combines an IEC inlet, mains filter with excellent filter attenuation and a mains switch in a small form factor. Choosing the FN9263 product line brings you the rapid availability of a standard filter associated with the necessary safety acceptances. Standard IEC connector filters are a practical solution helping you to pass EMI system approval in a short time. A wide selection on amperage ratings and mounting possibilities are designed to offer you the desired solution. Exceptional conducted attenuation performance, based on chokes with high saturation resistance and excellent thermal behavior. Rear/front or snap-in mounting. Small compact housing fitting 1U rack applications. Versions up to 10A are available with 1 pole rocker switch. Custom-specific versions are available on request. Typical applications Electrical and electronic equipment Consumer goods Household equipment Medical equipment Electronic data processing equipment Office automation and datacom equipment Various noisy applications requiring high filter performance IEC Inlet Filters > FN 9263 Filter selection table Filter Rated current @ 40°C (25°C) Leakage current** @ 230VAC/50Hz Inductance L [A] 1 (1.2) 2 (2.3) 3 (3.5) 4 (4.6) 6 (6.9) 8 (9.2) 10 (11.5) [µA] 373 373 373 373 373 373 373 [mH] 5.3 2.7 2 1 0.3 0.25 0.2 FN9263x-1-06-y FN9263x-2-06-y FN9263x-3-06-y FN9263x-4-06-y FN9263x-6-06-y FN9263x-8-06-y FN9263x-10-06-y Capacitance Cx Cy [µF] 0.1 0.1 0.1 0.1 0.1 0.1 0.1 Resistance R [nF] 2.2 2.2 2.2 2.2 2.2 2.2 2.2 * Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level. Product selector For example: FN9263-1, FN9263S-10-06-20, FN9263S1-6-06-30 Typical filter attenuation Per CISPR 17; A = 50Ω/50Ω sym; B = 50Ω/50Ω asym; C = 0.1Ω/100Ω sym; D = 100Ω/0.1Ω sym 1 to 4A types 6 to 10A types [kΩ] 1000 1000 1000 1000 1000 1000 1000 Output connections Weight -06 -06 -06 -06 -06 -06 -06 [g] 55 55 55 55 55 55 55 IEC Inlet Filters > FN 9263 Mechanical data FN9263 FN9263S FN9263S1 Panel cut out Installation Dimensions A B C D E F G H I J M N P R S T* T* T* FN9263 FN9263S FN9263S1 Tolerances 46 35 36 41 27.9 5.5 32.2 Ø3.3 13.8 12.5 R ≤ 3.5 33.2 29.2 M3 90° 34 35 34 35 ±0.3 41 27.9 5.5 32.2 41 27.9 5.5 32.2 13.8 12.5 R ≤ 3.5 32.6 29.0 13.8 12.5 R ≤ 3.5 33.3 28.3 ±0.3 +0.2/-0 ±0.3 +0/-0.2 ±0.1 0.6 - 1.5 1.6 - 2.5 2.6 - 3.5 0.6 - 1.5 1.6 - 2.5 2.6 - 3.5 * For selecting the panel thickness, please refer to the filter selector table. All dimensions in mm; 1 inch = 25.4mm Tolerances according: ISO 2768-m / EN 22768-m Your local partner: To find your local partner within Schaffner's global network, please go to www.schaffner.com ±0.3 ±0.1 ±0.1 Headquarters, global innovation Sales and application centers Schaffner Group Nordstrasse 11 4542 Luterbach Switzerland T +41 32 681 66 26 F +41 32 681 66 30 info@schaffner.com www.schaffner.com China Schaffner EMC Ltd. Shanghai T20-3, No 565 Chuangye Road Pudong New Area 201201 Shanghai T +86 21 3813 9500 F F +86 21 3813 9501 / 02 cschina@schaffner.com http://www.schaffner.com.cn/ and development center Finland Schaffner Oy Sauvonrinne 19 H 08500 Lohja T +358 19 35 72 71 finlandsales@schaffner.com France Schaffner EMC S.A.S. 112, Quai de Bezons Boîte postale 133 95103 Argenteuil T +33 1 34 34 30 60 F +33 1 39 47 02 28 francesales@schaffner.com Germany Schaffner Deutschland GmbH Westring 18 33142 Büren T +49 2951 60 01 0 F +49 2951 60 01 23 buerensales@schaffner.com Italy Schaffner EMC S.r.l. Via Galileo Galilei 47 20092 Cinisello Balsamo (MI) T +39 02 66 04 30 45/47 F +39 02 61 23 943 italysales@schaffner.com To find your local partner within Schaffner‘s global network, please go to www.schaffner.com © 2012 Schaffner Group Specifications are subject to change without notice. The latest version of the data sheets can be obtained from the website. All trademarks recognized. Schaffner is an ISO-registered company. Its products are designed and manufactured under the strict quality and environnmental requirements o the ISO 9001 and ISO 14001 10/2013 EN standards. This document has been carefully checked. However, Schaffner does not assume any liability for errors or inaccuracies. Japan Schaffner EMC K.K. 1-32-12, Kamiuma, Setagaya-ku 7F Mitsui-seimei Sangenjaya Bldg. 154-0011 Tokyo T +81 3 5712 3650 F +81 3 5712 3651 japansales@schaffner.com http://www.schaffner.jp Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1 05-09 Kampong Ubi Industrial Estate 408705 Singapore T +65 6377 3283 F +65 6377 3281 singaporesales@schaffner.com Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de la Moraleja Alcobendas 28109 Madrid T +34 618 176 133 spainsales@schaffner.com Sweden Schaffner EMC AB Turebergstorg 1, 6 19147 Sollentuna T +46 8 5792 1121 / 22 F +46 8 92 96 90 swedensales@schaffner.com Switzerland Schaffner EMV AG Nordstrasse 11 4542 Luterbach T +41 32 6816 626 F +41 32 6816 641 sales@schaffner.ch Taiwan R.O.C. Schaffner EMV Ltd. 6 Floor, No. 413 Rui Guang Road 114 Neihu District Taipei City T +886 2 87525050 F +886 2 87518086 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Northern Region Industrial Estate 67 Moo 4 Tambon Ban Klang Amphur Muangg P.O. Box 14 51000 Lamphun T +66 53 58 11 04 F +66 53 58 10 19 thailandsales@schaffner.com UK Schaffner Ltd. 5 Ashville Way Molly Millars Lane Wokingham RG41 2PL Berkshire T +44 118 9770070 F +44 118 9792969 uksales@schaffner.com http://www.schaffner.uk.com USA Schaffner EMC Inc. 52 Mayfield Avenue 08837 Edison T 1-800-367-5566 T 732-225-9533 F 732-225-4789 usasales@schaffner.com http://www.schaffner.com/us
FN9263S1-10-06 价格&库存
很抱歉,暂时无法提供与“FN9263S1-10-06”相匹配的价格&库存,您可以联系我们找货
