PE800103
PE800103
    CURTISINDUSTRIES
    PE800103
PE800103 数据手册
PE7/PE8 Series Specifications: POWER ENTRY MODULES Combination Rated Voltage: 250VAC Maximum - 50/60 Hz Rated Current: 115VAC 250VAC 3A 3A 6A 6A Current Overload: 6X for 8 Seconds Hi-Pot Test (1 min): Line to Ground 1500VAC Line to Line 1768VDC Insulation Resistance: 9 x 109 Ω at 100VDC Ambient Temperature: 40°C Max. at Rated Current Humidity Range: 0% to 95% R.H. Termination: • IEC Receptacle • Wire Wrap/Solder Maximum Leakage Current: Each Line to Ground PE7, PE 8 115VAC, 60Hz: 0.25mA 250VAC, 50Hz: 0.40mA Voltage Select Card: Installed in 120VAC position unless otherwise specified Agency Approvals: Refer to Page 55 for Ordering Instructions Features: • RFI Filter Module Combines IEC Connector, Fusing, and Voltage Select Features in One Unit • PE7 Series Filters Provide 20% More Differential Mode Attenuation Than Comparable Units • Accepts Either U.S. or European Standard Fuse Sizes PE7 Series Simplified Schematic FUSING LINE G L SERIES-SERIES 110-220240 V VOLTAGE SELECTOR 1-POLE B A a b G FOR TRANSFORMERS WITH TAP LOAD C A C 240V 220V c D D N Voltage Contacts 110V b,e 220V b,c 240V a d H F E e 2-POLE E F 2a 110V G 52 MINIMUM INSERTION LOSS - dB (50 ohm Circuit) Nominal Current Rating Part Number 3A PE7XXX03 PE8XXX03 IEC/Solder Tabs 6A PE7XXX06 PE8XXX06 IEC/Solder Tabs www.curtisind.com Termination Line/Load MODE Frequency - MHz 1.0 5.0 .15 .50 Common Differential 18 8 24 18 30 24 Common Differential 10 8 19 18 24 24 Curtis Industries A Division of Powers Holdings, Inc. 10 30 45 46 45 50 50 40 39 39 44 40 50 40 Specifications subject to change. Dimensions are shown for reference purposes only. PE7 Series Simplified Schematic FUSING LINE 1-POLE G L SERIES-PARALLEL 100-120220-240 V VOLTAGE SELECTOR B A a b G FOR TRANSFORMERS WITH TWO SEPARATE WINDINGS LOAD 120V A C C 100V c D D d H N e F Voltage Contacts 100V a,c,e 120V b,c,e 220V a,d 240V b,d 120V E E F 2-POLE G B a b G B A C A C 115V c D D d H N F e Voltage Contacts 115V a,b d,e 230V c 115V E E F 2-POLE Combination G L G LINE ROCKER SWITCH FUSING 1-POLE G L 1-POLE 1 1a LOAD L G H N 2-POLE 2 2a POWER ENTRY MODULES PE8 Series Simplified Schematic N 2-POLE G Dimensions are in inches and millimeters unless otherwise specified. Values in parentheses are metric equivalents. Curtis Industries A Division of Powers Holdings, Inc. 1-800-657-0853 53 PE7/PE8 Series (continued) PE7/PE8 Snap-Mount Series (3 and 6Amp) Dimensions Refer to Page 55 for Standard Mounting Cutouts 2.266 (57,55) 1.260 (32,0) 1.051 (26,70) .22 (5,5) POWER ENTRY MODULES Combination 2.283 (58,0) .100 (2,7) Q.C. Terminals All Locations LINE LOAD 1.091 (27,71) PE7/PE8 Screw-Mount Series (3 and 6Amp) Dimensions Refer to Page 55 for Standard Mounting Cutouts 1.969 (50,0) 2.266 (57,55) 1.575 (40,0) .22 (5,5) 1.051 (26,70) 1.142 (29,0) 2.283 (58,0) LINE 54 www.curtisind.com .126 (3,20) Dia. Holes LOAD .100 (2,7) Terminals Except Switch Curtis Industries A Division of Powers Holdings, Inc. 1.091 (27,71) Specifications subject to change. Dimensions are shown for reference purposes only. How to Order PE7 PE8 X X X X X SERIES PE = Power Entry CURRENT RATING 3 = 3 AMP 6 = 6 AMP OPTIONS (Consult Factory) 0 = Standard Units SWITCH 0 = No Switch 1 = SPST Rocker Switch w/Q.C. 2 = DPST Rocker Switch w/Q.C. VOLTAGE SELECTOR 0 = No Selector (PE80 Series) 1 = 110-220-240 VAC 2 = 100-120-220-240 VAC 3 = 115-230 VAC 1.10 (27,9) 2.20 (55,9) 1.575 (40,0) 1.122 (28,50) Cutout .031" - .079" use 2.20" .080" - .125" use 2.22" Dimensions are in inches and millimeters unless otherwise specified. Values in parentheses are metric equivalents. POWER ENTRY MODULES .08 R (2,0) *See Below 1.122 (28,50) *Panel Thickness PE7/PE8 To change fuse, remove power cord and open the front cover on the module. Remove fuse holder and replace fuse. Reinsert fuse holder and close cover. To change the operating voltage on the PE7 Series, remove the power cord and open front cover. Rotate voltage select wheel until desired voltage appears in window of cover. • Filter shipped without fuse. Always use caution when selecting and changing fuses and voltage requirements. Curtis Industries is not responsible for malfunction due to improper installation/selection of fuse and/or voltage select. PE7/PE8 Screw Mount Series PE7/PE8 Snap-Mount Series 2.20 (55,9) INSTALLATION INSTRUCTION IMPORTANT – CHANGING FUSE/VOLTAGE Combination MOUNTING METHOD & FUSING 0 = Snap Mount Metric Fuse 1 = Snap Mount U.S. Fuse 2 = Snap Mount 2 Metric Fuse 3 = Snap Mount 2 U.S. Fuses 6 = Screw Mount Metric Fuse 7 = Screw Mount U.S. Fuse 8 = Screw Mount 2 Metric Fuses 9 = Screw Mount 2 U.S. Fuses 4-40 (M3) .08 R (2,0) Curtis Industries A Division of Powers Holdings, Inc. 1-800-657-0853 55
PE800103
1. 物料型号:PE7/PE8系列。 2. 器件简介:这些模块结合了IEC连接器、熔断器和电压选择功能于一体,具有RFI滤波器模块。 3. 引脚分配:文档中提供了简化的电路图,展示了不同电压选择器的引脚配置。 4. 参数特性: - 额定电压:250VAC最大 - 50/60 Hz。 - 额定电流:115VAC和250VAC均为3A或6A。 - 过载电流:6倍额定电流持续8秒。 - 耐压测试:1分钟,线对地1500VAC,线对线1768VDC。 - 绝缘电阻:9 x 10^9 Ω在100VDC。 - 环境温度:最高40°C。 - 湿度范围:0%至95% R.H. - 端接方式:IEC插座、线绕/焊接。 - 最大漏电流:115VAC,60Hz时PE7,PE8为0.25mA;250VAC,50Hz时为0.40mA。 5. 功能详解:文档详细描述了模块的工作原理,包括熔断器选择、电压选择器的使用和安装说明。 6. 应用信息:适用于需要电源输入和RFI滤波的应用。 7. 封装信息:提供了不同安装方式的尺寸,包括快装和螺丝安装系列。
PE800103 价格&库存
很抱歉,暂时无法提供与“PE800103”相匹配的价格&库存,您可以联系我们找货
