PE1 Series
Rated Voltage: 250VAC Maximum - 50/60 Hz
Rated Current:
115VAC
250VAC
10A
10A
Current Overload: 6X for 8 seconds
Hi-Pot Test (1 min):
Line to Ground
1500VAC
Line to Line
2250VDC
Insulation Resistance: 9 x 109 Ω at 100VDC
Ambient Temperature: 40°C Max at rated current
Humidity Range: 0% to 95% R.H.
Termination:
• QC – Quick Connect
• IEC Receptacle
Maximum Leakage Current:
Each Line to Ground
PE1
PE1-PO
115VAC, 60Hz:
0.25mA
0.4mA
250VAC, 50Hz:
0.40mA
.75mA
Voltage Select Card: Installed in 120VAC position
unless otherwise specified
Agency Approvals:
• RFI Filter Module Combines IEC Connector, Fusing,
Optional Voltage Select and On/Off Switch into a
Single, Space-Efficient Assembly
• Enhanced Low Frequency Response with No
Resonant Peaks
• Fully Shielded for Radiative Noise Control
• Accepts Either U.S. or European Standard Fuse
Sizes. Dual or Single Power Line Fusing
FUSING
1 POLE
1
L
2
LINE
PE1 Series Simplified
Schematic without Voltage Selector
L
LOAD
Features:
3
4
N
N
2 POLE
G
G
PE1 Series Simplified Schematic with Voltage Selector
FUSING
1 POLE L
L
1
110V
4
2 POLE
G
G
LOAD
3
N
N
Nominal
Current
Rating
110V
2
LINE
POWER ENTRY MODULES
Combination
Specifications:
MINIMUM INSERTION LOSS - dB (50 ohm Circuit)
Part
Number
Termination
Line/Load
MODE
.05
.15
Frequency - MHz
.50
.10
5.0
10
30
PE1XXX10
IEC/QC
Common
Differential
10
10
30
38
35
45
55
50
60
50
55
PE1XXXP0
IEC/QC
Common
Differential
13
10
24
30
38
35
48
65
54
65
54
55
10A
NOTE: Other combinations of terminals may be specified on special order.
56
www.curtisind.com
Curtis Industries
A Division of Powers Holdings, Inc.
Specifications subject to change.
Dimensions are shown for
reference purposes only.
PE1
1.99
(50,5)
(10Amp)
Dimensions
L
I
N
E
Refer to Standard
Mounting Cutouts on
Page 58
L
O
A
D
2.41
(61,2)
Max.
3.00
(76,2)
1.12
(28,4)
2.58
(65,5)
Max.
1
3
2
How to Order
PE1
X
MOUNTING
METHOD & FUSING
6 = Screw Mount Metric or U.S. Fuse*
8 = Screw Mount 2 Metric or U.S. Fuses
* U.S. Fuse not available without
voltage selector
VOLTAGE SELECTOR
0 = No Selector
3 = 115-230 VAC
Dimensions are in inches and millimeters
unless otherwise specified.
Values in parentheses are metric equivalents.
X
X
OPTIONS
(Consult Factory)
1 = Standard Units
P = High Performance
Insertion Loss
CURRENT RATING
0 = 10 AMP
SWITCH
0 = No Switch
1 = SPST Rocker Switch
2 = DPST Rocker Switch
Curtis Industries
INSTALLATION INSTRUCTION
IMPORTANT – CHANGING
FUSE/VOLTAGE
PE1
To change fuse, remove power cord.
Remove voltage selector and replace
fuse. Reinsert fuse holder. To change
the operating voltage on the PE1
Series, remove the power cord and
rotate fuse holder block until desired
voltage aligns with the mark on the
module housing.
• Filter shipped without fuse.
Always use caution when selecting
and changing fuses and voltage
requirements. Curtis Industries is
not responsible for malfunction due
to improper installation/selection of
fuse and/or voltage select.
1-800-657-0853
POWER ENTRY MODULES
SERIES
PE = Power Entry
PM = Medical
Power Entry
X
WITH
VOLTAGE
SELECTOR
Combination
3.20
(81,3)
H
1.575
(40,01)
1.15
(29,2)
Max.
4
57
很抱歉,暂时无法提供与“PE180110”相匹配的价格&库存,您可以联系我们找货
