68-BSF-020-5-02
68-BSF-020-5-02
    APITECHNOLOGIES
    PWRENTMODRCPTIEC320-C14PNL
68-BSF-020-5-02 数据手册
Switched and Fused Filtered Power Entry Modules Switched and Fused Filtered Power Entry Modules Dual Fuse for European Applications 68-BSF Series Features Dual fuse for European applications Fuse holder and double pole power ON/OFF switch provides a convenient/compact package ■ Suitable for products that must conform to FCC and FTZ requirements ■ Meets over voltage category II of IEC 664 and complies with IEC 950 ■ Metal case provides effective EMI shielding ■ IEC connector meets the safety standards of most certifying agencies ■ Easy access fuse drawer ■ Flange-mounted ■ UL, CSA, and SEMKO approved ■ Designed to be in accordance with VDE 0565, part 3 ■ Operating temperature: -25°C to +85°C (including temperature rise, see graph on page 51) ■ ■ Circuit Diagram FUSE L L L1 E CY1 CX2 CX1 E R1 L2 CY2 N N SW Applications Computers and peripheral equipment Electronic equipment ■ Digital equipment ■ Measuring and testing instruments ■ Telecommunications equipment ■ ■ Specifications Model Rated Voltage (@ 50/60Hz) 68-BSF-020-3-01 Rated Current Leakage Current (Max.) CY1 Capacitance CY2 CX1 2A 68-BSF-020-3-04 68-BSF-040-3-01 250VAC 4A 68-BSF-040-3-04 68-BSF-060-3-01 6A 68-BSF-060-3-04 0.35mA 2200pF 2200pF CX2 0.1uF 0.1uF 0.22uF 0.22uF 0.1uF 0.1uF 0.22uF 0.22uF 0.1uF 0.1uF 0.22uF 0.22uF Inductance (L1) Temperature Rise (Max.) 10.5mH 4.2mH 45°C 1.6mH Note: Test Voltage 1500VAC one minute, line to ground Insulation Resistance: 300 MΩ min. at 500VDC Voltage Drop: 1V max. at rated current Weight: 130g Inlet: Compatible with IEC-320 B(S) = Bolt-in terminals or (Snap-in terminals) 50 SPECTRUM CONTROL INC. • 8031 Avonia Rd. • Fairview, PA 16415 • Phone: 814-474-2207 • Fax: 814-474-2208 • Web site: www.spectrumcontrol.com SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 Switched and Fused Filtered Power Entry Modules Dual Fuse for European Applications Temperature Characteristics 1.947 (49.5) 1.101 (28) .248 (6.3) 1.526 (38.8) 120 2.556 (65) Current (%) 100 80 2.348 (59.7) 60 2 - .142 (3.6) Hole 20 30 40 50 60 70 Ambient Temperature (°C) 80 90 Dimensions in inches (mm) Normal Mode 1 3 Filter 2 4 1 3 Filter 2 4 50Ω Level Meter 50Ω Oscillator 50Ω 90 50Ω 50Ω Level Meter 50Ω 100 90 70 80 Insertion Loss (dB) 80 60 50 40 4 Amp 30 2 Amp 6 Amp 20 70 4 Amp 60 50 2 Amp 40 30 10 0 0.1 t= .031 (0.8) 2.399 (61) Common Mode Oscillator 50Ω R .059 (1.5) Panel cutout dimension mount from back side 1.573 1.16 +.02 -0 (40.±0.2) (29.5 +0.5) -0 0 1.133 (28.8) Fast-on Tab #250 2.273 (57.8) 1.573 (40±0.2) 40 20 Insertion Loss (dB) 2.340 (59.5) Ø.142 (3.6) Switched and Fused Filtered Power Entry Modules 68-BSF Series 6 Amp 20 0.2 0.5 1 2 5 Frequency (MHz) 10 20 50 0 0.1 0.2 0.5 1 2 5 Frequency (MHz) 10 20 50 SPECTRUM CONTROL INC. • 8031 Avonia Rd. • Fairview, PA 16415 • Phone: 814-474-2207 • Fax: 814-474-2208 • Web site: www.spectrumcontrol.com SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 51 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: API Technologies: 68-BSF-040-3-04 68-BSF-040-3-01 68-BSF-060-3-01 68-BSF-020-0-02 68-BSF-020-0-04 68-BSF-020-0-11 68BSF-020-0-12 68-BSF-020-1-02 68-BSF-020-1-04 68-BSF-020-1-11 68-BSF-020-1-12 68-BSF-020-3-01 68-BSF020-3-02 68-BSF-020-3-03 68-BSF-020-3-04 68-BSF-020-3-11 68-BSF-020-3-12 68-BSF-020-4-02 68-BSF-020-404 68-BSF-020-4-11 68-BSF-020-4-12 68-BSF-020-5-01 68-BSF-020-5-02 68-BSF-020-5-03 68-BSF-020-5-04 68BSF-020-5-11 68-BSF-020-5-12 68-BSF-040-0-02 68-BSF-040-0-04 68-BSF-040-0-11 68-BSF-040-0-12 68-BSF040-1-02 68-BSF-040-1-04 68-BSF-040-1-11 68-BSF-040-1-12 68-BSF-040-3-02 68-BSF-040-3-03 68-BSF-040-311 68-BSF-040-3-12 68-BSF-040-4-02 68-BSF-040-4-04 68-BSF-040-4-11 68-BSF-040-4-12 68-BSF-040-5-01 68BSF-040-5-02 68-BSF-040-5-03 68-BSF-040-5-04 68-BSF-040-5-11 68-BSF-040-5-12 68-BSF-060-0-02 68-BSF060-0-04 68-BSF-060-0-11 68-BSF-060-0-12 68-BSF-060-1-02 68-BSF-060-1-04 68-BSF-060-1-11 68-BSF-060-112 68-BSF-060-3-02 68-BSF-060-3-03 68-BSF-060-3-04 68-BSF-060-3-11 68-BSF-060-3-12 68-BSF-060-4-02 68BSF-060-4-04 68-BSF-060-4-11 68-BSF-060-4-12 68-BSF-060-5-01 68-BSF-060-5-02 68-BSF-060-5-03 68-BSF060-5-04 68-BSF-060-5-11
68-BSF-020-5-02 价格&库存
很抱歉,暂时无法提供与“68-BSF-020-5-02”相匹配的价格&库存,您可以联系我们找货
