PLC19RD
PLC19RD
    TRIPPLITE
    POWER CORD TO OUTLET RED 100PK
PLC19RD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Plug-Lock Inserts (C20 power cord to C19 outlet), Red, 100 pack MODEL NUMBER: PLC19RD Highlights ● PLC19RD Plug-lock inserts keep C20 power cords connected to C19 outlets ● Prevents accidental disconnection of network hardware during routine rack maintenance ● Universal compatibility, no special cables, outlets or special PDU hardware required ● RED color inserts ship in packages of 100, more colors available Package Includes ● Description Tripp Lite PLC19RD RED color Plug-lock inserts prevent accidental disconnection of C20 plug-in power cords from C19 output receptacles. IEC 60320 plug-in electrical cords are frequently loose-fitting and are often subject to accidental disconnection during routine network maintenance. To prevent critical equipment plugs from getting knocked loose, place a Plug-lock insert over any C20 input cord and connect it to any C19 outlet. The insert strengthens the connection of the plug to the outlet, keeping critical equipment plugged-in and running during routine rack access and maintenance. Plug-lock inserts provide a no-clutter alternative to common zip-tie cord retention schemes and a low cost answer to expensive proprietary locking plug and outlet hardware. PLC19RD Plug-lock inserts ship in packages of 100. Features ● Tripp Lite PLC19RD Plug-lock inserts prevent accidental disconnection of C20 plug-in power cords from C19 outlets ● RED color PLC19RD inserts ship in packages of 100 pieces ● Corrects loose-fitting IEC60320 power connections that could lead to accidental disconnection of power cables ● Plug-lock inserts strengthen the connection of your C20 plug-in device to any C19 outlet, keeping vital network equipment plugged in and running during routine rack access and maintenance ● Universal compatibility ensures proper fit and enhanced plug retention when used with any standard C20 plug and C19 outlet combination; no proprietary cables or outlets required ● Simple installation, just place a Plug-lock insert over any C20 equipment power cord and plug it in ● Pull tabs enable safe retraction of the insert from powered C19 outlets ● Plug-lock inserts provide a no-clutter alternative to common zip-tie cord retention schemes and prevents reliance on lesser elegant remedies involving duct tape, electrical tape or super glue ● High strength PA66 nylon UL94 material with V2 flame rating Specifications 1/2 100 RED color C20 plug / C19 outlet compatible Plug-lock inserts 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332179753 Accessory Type Plug-Lock Insert Accessory Class PDU Accessories PHYSICAL Color Red Shipping Dimensions (hwd / in.) 3.55 x 12.80 x 8.58 Shipping Dimensions (hwd / cm) 9.02 x 32.51 x 21.79 Shipping Weight (lbs.) 0.95 Shipping Weight (kg) 0.43 Unit Dimensions (hwd / in.) 1.290 x 1.420 x 1.060 Unit Dimensions (hwd / cm) 3.18 x 3.05 x 2.29 WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
PLC19RD 价格&库存
很抱歉,暂时无法提供与“PLC19RD”相匹配的价格&库存,您可以联系我们找货
PLC19RD
  • 1+838.490421+104.13341
  • 10+712.7699510+88.52000
  • 25+668.1887625+82.98339
  • 50+637.7580350+79.20415
库存:9
