PLC13RD
PLC13RD
    TRIPPLITE
    POWERCORDTOOUTLETRED100PK
PLC13RD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Plug-Lock Inserts (C14 power cord to C13 outlet), Red, 100 pack MODEL NUMBER: PLC13RD Highlights ● PLC13RD Plug-lock inserts keep C14 power cords connected to C13 outlets ● Prevents accidental disconnection of network hardware during routine rack maintenance ● Universal compatibility, no special cables, outlets or special PDU hardware required ● RED color inserts ship in packages of 100, more colors available Package Includes ● Description Tripp Lite PLC13RD RED color Plug-lock inserts prevent accidental disconnection of C14 plug-in power cords from C13 output receptacles. IEC 60320 plug-in electrical cords are frequently loose-fitting and are often subject to accidental disconnection during routine network maintenance. To prevent critical equipment plugs from getting knocked loose, place a Plug-lock insert over any C14 input cord and connect it to any C13 outlet. The insert strengthens the connection of the plug to the outlet, keeping critical equipment plugged-in and running during routine rack access and maintenance. Plug-lock inserts provide a no-clutter alternative to common zip-tie cord retention schemes and a low cost answer to expensive proprietary locking plug and outlet hardware. PLC13RD Plug-lock inserts ship in packages of 100. Features ● Tripp Lite PLC13RD Plug-lock inserts prevent accidental disconnection of C14 plug-in power cords from C13 outlets ● RED color PLC13RD inserts ship in packages of 100 pieces ● Corrects loose-fitting IEC60320 power connections that could lead to accidental disconnection of power cables ● Plug-lock inserts strengthen the connection of any C14 plug-in device to any C13 outlet, keeping vital network equipment plugged in and running during routine rack access and maintenance ● Universal compatibility ensures proper fit and enhanced plug retention when used with any standard C14 plug and C13 outlet combination; no proprietary cables or outlets required ● Simple installation, just place a Plug-lock insert over any C14 equipment power cord and plug it in ● Pull tabs enable safe retraction of the insert from powered C13 outlets ● Plug-lock inserts provide a no-clutter alternative to common zip-tie cord retention schemes and prevents reliance on lesser elegant remedies involving duct tape, electrical tape or super glue ● High strength PA66 nylon UL94 material with V2 flame rating Specifications 1/2 100 RED color C14 plug / C13 outlet compatible Plug-lock inserts 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332179692 Accessory Type Plug-Lock Insert Accessory Class PDU Accessories DISPLAY Accessories (Included) N/A PHYSICAL Color Red Shipping Dimensions (hwd / in.) 3.55 x 12.80 x 8.58 Shipping Dimensions (hwd / cm) 9.02 x 32.51 x 21.79 Shipping Weight (lbs.) 0.87 Shipping Weight (kg) 0.39 Unit Dimensions (hwd / in.) 1.250 x 1.200 x 0.900 Unit Dimensions (hwd / cm) 3.18 x 3.05 x 2.29 FEATURES & SPECIFICATIONS IP68 Rated No IP20 Rated No WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
PLC13RD 价格&库存
很抱歉,暂时无法提供与“PLC13RD”相匹配的价格&库存,您可以联系我们找货
