1000 Eaton Boulevard
Cleveland, OH 44122
United States
Plug-Lock Inserts (C20 power cord to C19 outlet),
Blue, 100 pack
MODEL NUMBER: PLC19BL
Highlights
PLC19BL Plug-lock inserts keep
C20 power cords connected to
C19 outlets
Prevents accidental
disconnection of network
hardware during routine rack
maintenance
Universal compatibility, no
special cables, outlets or special
PDU hardware required
BLUE color inserts ship in
packages of 100, more colors
available
Package Includes
Description
Tripp Lite PLC19BL BLUE color Plug-lock inserts prevent accidental disconnection of C20 plug-in power
cords from C19 output receptacles. IEC 60320 plug-in electrical cords are frequently loose-fitting and are
often subject to accidental disconnection during routine network maintenance. To prevent critical
equipment plugs from getting knocked loose, place a Plug-lock insert over any C20 input cord and
connect it to any C19 outlet. The insert strengthens the connection of the plug to the outlet, keeping
critical equipment plugged-in and running during routine rack access and maintenance. Plug-lock inserts
provide a no-clutter alternative to common zip-tie cord retention schemes and a low cost answer to
expensive proprietary locking plug and outlet hardware. PLC19BL Plug-lock inserts ship in packages of
100.
Features
Tripp Lite PLC19BL Plug-lock inserts prevent accidental disconnection of C20 plug-in power cords from
C19 outlets
BLUE color PLC19BL inserts ship in packages of 100 pieces
Corrects loose-fitting IEC60320 power connections that could lead to accidental disconnection of power
cables
Plug-lock inserts strengthen the connection of your C20 plug-in device to any C19 outlet, keeping vital
network equipment plugged in and running during routine rack access and maintenance
Universal compatibility ensures proper fit and enhanced plug retention when used with any standard
C20 plug and C19 outlet combination; no proprietary cables or outlets required
Simple installation, just place a Plug-lock insert over any C20 equipment power cord and plug it in
Pull tabs enable safe retraction of the insert from powered C19 outlets
Plug-lock inserts provide a no-clutter alternative to common zip-tie cord retention schemes and prevents
reliance on lesser elegant remedies involving duct tape, electrical tape or super glue
High strength PA66 nylon UL94 material with V2 flame rating
Specifications
1/2
100 BLUE color C20 plug / C19
outlet compatible Plug-lock
inserts
Cleveland, OH 44122
United States
OVERVIEW
UPC Code
037332179746
Accessory Type
Plug-Lock Insert
Accessory Class
PDU Accessories
PHYSICAL
Color
Blue
Shipping Dimensions (hwd / in.)
3.60 x 12.40 x 8.50
Shipping Dimensions (hwd / cm)
9.14 x 31.50 x 21.59
Shipping Weight (lbs.)
1.00
Shipping Weight (kg)
0.45
Unit Dimensions (hwd / in.)
1.290 x 1.420 x 1.060
Unit Dimensions (hwd / cm)
3.18 x 3.05 x 2.29
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“PLC19BL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+832.553851+104.13341
- 10+707.7234910+88.52000
- 25+663.4579325+82.98339
- 50+633.2426550+79.20415
