PLC13BL
PLC13BL
    TRIPPLITE
    POWERCORDTOOUTLETBLUE100PK
PLC13BL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Plug-Lock Inserts (C14 power cord to C13 outlet), Blue, 100 pack MODEL NUMBER: PLC13BL Highlights ● PLC13BL Plug-lock inserts keep C14 power cords connected to C13 outlets ● Prevents accidental disconnection of network hardware during routine rack maintenance ● Universal compatibility, no special cables, outlets or special PDU hardware required ● BLUE color inserts ship in packages of 100, more colors available Package Includes ● Description Tripp Lite PLC13BL BLUE color Plug-lock inserts prevent accidental disconnection of C14 plug-in power cords from C13 output receptacles. IEC 60320 plug-in electrical cords are frequently loose-fitting and are often subject to accidental disconnection during routine network maintenance. To prevent critical equipment plugs from getting knocked loose, place a Plug-lock insert over any C14 input cord and connect it to any C13 outlet. The insert strengthens the connection of the plug to the outlet, keeping critical equipment plugged-in and running during routine rack access and maintenance. Plug-lock inserts provide a no-clutter alternative to common zip-tie cord retention schemes and a low cost answer to expensive proprietary locking plug and outlet hardware. PLC13BL Plug-lock inserts ship in packages of 100. Features ● Tripp Lite PLC13BL Plug-lock inserts prevent accidental disconnection of C14 plug-in power cords from C13 outlets ● BLUE color PLC13BL inserts ship in packages of 100 pieces ● Corrects loose-fitting IEC60320 power connections that could lead to accidental disconnection of power cables ● Plug-lock inserts strengthen the connection of any C14 plug-in device to any C13 outlet, keeping vital network equipment plugged in and running during routine rack access and maintenance ● Universal compatibility ensures proper fit and enhanced plug retention when used with any standard C14 plug and C13 outlet combination; no proprietary cables or outlets required ● Simple installation, just place a Plug-lock insert over any C14 equipment power cord and plug it in ● Pull tabs enable safe retraction of the insert from powered C13 outlets ● Plug-lock inserts provide a no-clutter alternative to common zip-tie cord retention schemes and prevents reliance on lesser elegant remedies involving duct tape, electrical tape or super glue ● High strength PA66 nylon UL94 material with V2 flame rating Specifications 1/2 100 Blue color C14 plug / C13 outlet compatible Plug-lock inserts 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332179685 Accessory Type Plug-Lock Insert Accessory Class PDU Accessories PHYSICAL Color Blue Shipping Dimensions (hwd / in.) 3.60 x 12.30 x 8.60 Shipping Dimensions (hwd / cm) 9.14 x 31.24 x 21.84 Shipping Weight (lbs.) 1.10 Shipping Weight (kg) 0.50 Unit Dimensions (hwd / in.) 1.250 x 1.200 x 0.900 Unit Dimensions (hwd / cm) 3.18 x 3.05 x 2.29 FEATURES & SPECIFICATIONS IP68 Rated No IP20 Rated No WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
PLC13BL 价格&库存
很抱歉,暂时无法提供与“PLC13BL”相匹配的价格&库存,您可以联系我们找货
PLC13BL
  • 1+812.144311+101.58065
  • 10+690.3740910+86.34998
  • 25+647.1936825+80.94910
  • 50+617.7191050+77.26251
库存:13
