60 Amp Board-to-Board Power Pin Connectors
IT-P Series
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
■Temperature Rise Curve
Note : These graphs are for the below combination.
Interposer : IT-P-2P-35H(11)
Receptacle : IT-PD-2S-DIR, IT-PM-2S-DIR
■Features
1. Up to 60 Amp/pin current rating
2. Unique 3-piece structure for flexibility
3. Multiple mating capability (Floating amount ±0.3mm)
4. Paste in hole reflow assembly
5. Stacking heights from 10 to 66mm
6. Designed to be used/assembled alongside IT3, IT5, and IT7
■Stacking Height Variations
※All products are designed for +1mm height use, for example IT-P-2P-65H(11) is applicable to 65∼
66mm height application.
IT-PB
Series
Stacking
Height
IT-PA
Series
IT-P
Series
10 11 12 14 15 16 17 21 22 23 24 25 26 27 28 29 30 35 36 37 38 39 40 41 42 43 44 65 66
mm mm mm mm mm mm mm mm mm mm mm mm mm mm mm mm mm mm mm mm mm mm mm mm mm mm mm mm mm
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
*Under development / planned
2019.1⑤
1
IT-P Series●60 Amp Board-to-Board Power Pin Connectors
■Product Specification
Current
Rating
Voltage
Rating
Ratings
Item
1. Insulation resistance
2. Withstanding voltage
3. Contact resistance
Specification
Condition
Measured at DC 500V
1000 Mø min.
No flashover or insulation breakdown
2mø max (Note 5)
No electrical discontinuity of 1µs or more
No damage, cracks or loose parts
Contact resistance : 2mø max. (Note 5)
4. Vibration resistance
5. Cyclic temperature
and humidity
6. Durability
(Mating / Unmating)
-55ç to +85°C (Note 1,2)
RH 90% max (Note 2,4)
-10ç to +60ç (Note 3)
RH 70% max (Note 3,4)
60A / pin (Note 6)
Operating temperature range
(Temperature rise 30ç max) Operating humidity range
Storage temperature range
300 V DC/AC
Storage humidity range
AC 1000V for 1 minute
100mA
Frequency : 50 to 2000Hz, Power Spectral Density :
0.1g2/Hz for 90 minutes in three directions
25ç, 80% RH : 60 min dwell time, 30 min ramp time
65ç, 50% RH : 60 min dwell time for 24 cycles
100 cycles
Note 1 : Include temperature rise caused by current-carrying.
Note 2 : Operating temperature should be -55 to 55ç when humidity exceeds 80% RH.
Note 3 : “Storage” means a long-term storage state for the unused product in sealed packages before assembly to PCB.
Note 4 : No dew condensation is permitted.
Note 5 : The value of contact resistance includes 2 contact points and the bulk resistance.
Note 6 : Current rating of IT-PA and IT-PB series is 40A. (See the details on page 3.)
■Materials / Finish
Series
Product
Receptacle
IT-P
Interposer
IT-PA
IT-PB
Receptacle
Interposer
Part
Material
Finish
Remarks
Housing (Mounting)
Housing (Mating)
Contact
Shell
Housing
Contact
Housing
Contact
Shell
Contact
LCP
LCP
Copper Alloy
Brass
PBT
Copper Alloy
LCP
Copper Alloy
Brass
Copper Alloy
Black color
Gray color
Gold plated
Silver plated
Black color
Silver plated
Black color
Gold plated
Silver plated
Silver plated
UL94V-0
UL94V-0
------------------UL94V-0
---------UL94V-0
Note 1 : The IT-PA and IT-PB series use the same receptacle housing for the mounting and mating sides.
Note 2 : There is no interposer housing for the IT-PA and IT-PB series.
■Nomenclature
Please select a product based on the ordering information described on page 3 of this catalog when ordering.
●Receptacle
●Interposer
IT-P ** - 2 S - DIR ** (**)
IT-P ** - 2 P - ** H ** (**)
❶
❷
❸ ❹
❺
❻
❼
❶
❷
❸ ❹
❽
❻
❼
❻ Packaging or Other Specification
·Receptacle
❷ Extra name
Blank : Standard
Receptacle Type
L
: Low height receptacle
A
: Narrow type Receptacle
** : Customized
B
: Narrow and Low height Receptacle
·Interposer
D
: Mating Receptacle
Blank : Standard
D* : Mating Receptacle (Customized)
** : Customized
M
: Mounting Receptacle
Material and Plating Specification
M* : Mounting Receptacle (Customized)
❼
·Receptacle
Interposer Type
Blank : Standard
A
: Interposer for Narrow type receptacle
: Customized
B
: Interposer for Narrow and Low height Receptacle
·Interposer
Blank : Standard
Blank : Brass, Contact plating (silver 5.1um + Ni 1.5um)
** : Customized
(11) : ETP Copper, Contact plating (silver 5.1um + Ni 1.5um)
❸ Contact Positions : 2
: Customized
❹ Connector type
❽ Stacking Height (mm)
S : Receptacle
10, 11, 14, 16, 21, 23, 25, 27, 29, 35, 37, 39, 41, 43, 65
P : Interposer
*All products are designed for +1mm height use, for example
❶ Series Name : IT-P
❺ DIR : Paste in hole (PIH) reflow
2
IT-P-2P-65H(11) is applicable to 65∼66mm height application.
■Product Series
C
B
A
IT-P Series
*16H is without housing case,
like IT-PA, IT-PB
No Latch
Latch
IT-PA Series
IT-PM-2S-DIR, IT-P-2S-DIRL (16H only)
Mounting Side,
includes a positive latch.
Mated Condition
C
IT-PA-2S-DIRL
A
Stacking
Height
IT-PA-2P-14H(11)
Mated Condition
B
IT-PB Series
C
IT-PB-2S-DIRL
IT-PB-2P-11H(11)
A
IT-P-2P-**H(11)
Stacking Height
Mating Side IT-PD-2S-DIR, IT-P-2S-DIRL (16H only)
B
Mated Condition
Unit : mm
Interposer
Receptacles
Dimension
Stacking
Current
Height Range
Rating
Part No.
HRS No.
Part No.
HRS No.
A
B
C
10∼11
IT-PB-2P-10H(11) 636-0632-0 11
IT-PB-2S-DIRL
636-0631-0
4.65 10.8 20.5
11∼12
40A
IT-PB-2P-11H(11) 636-0633-0 11
14∼15
IT-PA-2P-14H(11) 636-0613-9 11 IT-PA-2S-DIRL
636-0614-1
6.4 10.8 20.5
IT-P-2P-16H(11)
636-0644-0 11 IT-P-2S-DIRL
636-0611-3
6.6
12
22
16∼17
21∼22
IT-P-2P-21H(11)
636-0618-2 11
23∼24
IT-P-2P-23H(11)
636-0610-0 11
25∼26
IT-P-2P-25H(11)
636-0607-6 11
27∼28
IT-P-2P-27H(11)
636-0624-5 11
29∼30
IT-P-2P-29H(11)
636-0615-4 11
IT-PM-2S-DIR
636-0600-7
60A
35∼36
IT-P-2P-35H(11)
636-0602-2 11
7.2
12
22
IT-PD-2S-DIR
636-0601-0
37∼38
IT-P-2P-37H(11)
636-0620-4 11
39∼40
IT-P-2P-39H(11)
636-0606-3 11
41∼42
IT-P-2P-41H(11)
636-0619-5 11
43∼44
IT-P-2P-43H(11)
636-0621-7 11
65∼66
IT-P-2P-65H(11)
636-0643-0 11
Note 1 : IT-PB-2P-10H(**), IT-PB-2P-11H(**), IT-PA-2P-14H(**) and IT-P-2P-16H(**) do not come with a housing.
Note 2 : IT-PA-2P-14H (**) is designed to mate with IT-PA-2S-DIRL only.
Note 3 : IT-PB-2P-10H(**) and IT-PB-2P-11H (**) are designed to mate with IT-PB-2S-DIRL only.
Note 4 : IT-P-2P-16H(**) is designed to mate with IT-P-2S-DIRL only.
3
IT-P Series
(7.2) (Note 1)
(7)(Note 1)
■Receptacle (Paste in hole)
A
Lot No.
7.4±0.3
(1.2)
(3.2)
10.6±0.3
22±0.3
2∞Ø6.58±0.15
13±0.3
12±0.15
IT-PD-2S-DIR (**)
Mating side Gray IT-PD-2S-DIR
Mounting side Black IT-PM-2S-DIR
Mating side
Black IT-P-2S-DIRL
Mounting side
HRS No.
636-0601-0
636-0600-7
636-0611-3
4
(1.2)
12±0.15
No. of
Packing Pitch
contacts
2
2
250pcs/
12mm
reel
2
Note 1 : This area is a vacuum pickup area.
Note 2 : Minimum clearance area.
Note 3 : Recommended clearance area for insertion / extraction.
Note 4 : Please see page 3 (Ordering Information) for applicable Interposers.
Note 5 : IT-P-2S-DIRL is designed to mate with IT-P-2P-16H(**) only.
Note 6 : There is no latch for IT-P-2S-DIRL.
13±0.3
2ר6.58±0.15
(24)
1 min
(Note 2)
(23)
Part No.
22±0.3
1 min
(Note 2)
Connector size
2∞Ø6.98±0.07
Plated
Through-hole
Diameter
(Note 3) 5 min
(Note 2) 1 min
Color
(6.8)(Note 1)
Lot No.
(Note 3) 5 min
(Note 2) 1 min
Type
(3.2)
IT-PM-2S-DIR (**)
6.6±0.3
9.8±0.3
(7)(Note 1)
IT-PM-2S-DIR & IT-PD-2S-DIR
2∞Ø8.4±0.05
LAND-pattern
Diameter
12±0.05
Footprint
Keep-out area
IT-PA Series
(Narrow type)
(7)(Note 1)
(6.2)(Note 1)
6.4±0.3
Lot No.
9.5±0.3
(3.2)
9.6±0.3
20.5±0.3
2ר5.2±0.15
10.8±0.05
IT-PA-2S-DIRL
HRS No.
636-0614-1
(22.5)
1min (Note 2)
1min (Note 2)
1min
(Note 2)
Part No.
No. of
Packing Pitch
contacts
250pcs/
2
10.8mm
reel
2ר5.6±0.07
Plated
Through-hole
Diameter
(11.5)
Note 3 : This product is designed to mate with
IT-PA-2P-14H (**) Only.
Note 4 : IT-PA series are Narrow type of IT-P.
Note 5 : There is no latch for this receptacle.
1min
(Note 2)
2ר7±0.05
LAND-pattern
Diameter
Connector size
Keep-out area
Footprint
IT-PB Series
(Narrow and Low height type)
(5.1)(Note 1)
(7)(Note 1)
4.65±0.3
Lot No.
20.5±0.3
9.5±0.3
(3.95)
8.6±0.3
2ר5.2±0.15
10.8±0.15
10.8±0.05
636-0631-0
IT-PB-2P-10H (**) and IT-PB-2P-11H (**) only.
Note 4 : IT-PB series are Narrow and Low height type of IT-P.
(22.5)
1min(Note 2)
1min(Note 2)
1min
(Note 2)
IT-PB-2S-DIRL
HRS No.
2ר5.6±0.07
Plated
Through-hole
Diameter
(11.5)
Part No.
No. of
Packing Pitch
contacts
250pcs/
2
10.8mm
reel
1min
(Note 2)
10.8±0.15
2ר7±0.05
LAND-pattern
Diameter
Connector size
Keep-out area
Footprint
5
IT-P Series
■Interposer with Housing
13±0.3
(3.45)
22±0.3
(12)
Ø3.7±0.15
(1.2)
H±0.3
(1.2)
(2.95)
IT-P-2P-35H (**)
4.5±0.2
Lot No.
4.4±0.2
Ø3.7±0.15
Unit : mm
Part No.
HRS No.
IT-P-2P-21H(11)
IT-P-2P-23H(11)
IT-P-2P-25H(11)
IT-P-2P-27H(11)
IT-P-2P-29H(11)
IT-P-2P-35H(11)
IT-P-2P-37H(11)
IT-P-2P-39H(11)
IT-P-2P-41H(11)
IT-P-2P-43H(11)
IT-P-2P-65H(11)
636-0618-2 11
636-0610-0 11
636-0607-6 11
636-0624-5 11
636-0615-4 11
636-0602-2 11
636-0620-4 11
636-0606-3 11
636-0619-5 11
636-0621-7 11
636-0643-0 11
Stacking
Height
21∼22
23∼24
25∼26
27∼28
29∼30
35∼36
37∼38
39∼40
41∼42
43∼44
65∼66
H
16
18
24
30
32
34
36
38
60
Packing
Pitch
50pcs/tray
56pcs/tray
25pcs/tray
12
40pcs/tray
28pcs/tray
IT-P, IT-PA, IT-PB Series
■Interposer without Housing
IT-PA, IT-PB Series
IT-P Series (16H only)
Ø3±0.15
(H)
(H)
Ø3.7±0.04
Ø3.79±0.04
Ø3.14±0.15
IT-PA-2P-14H (**)
Unit : mm
Part No.
IT-PB-2P-10H(11)
IT-PB-2P-11H(11)
IT-PA-2P-14H(11)
IT-P-2P-16H(11)
HRS No.
636-0632-0 11
636-0633-0 11
636-0613-9 11
636-0644-0 11
Stacking Height
10∼11
11∼12
14∼15
16∼17
H
16.5
17.5
18
Packing
50pairs/tray
Note 1 : The lager side (Ø3.14) or (Ø3.79) of the pin should be inserted to mother board side since it has a locking mechanism.
You can remove the pin if you pull strongly.
Note 2 : The thinner side (Ø3) or (Ø3.7) does not have any locking mechanism.
6
■Precautions For Use
Parameters
Preheat Ramp
Rate
1. Recommended Temperature Profile
Soak Time
Soak Temperature
Peak Reflow
Temperature
Time Above
Liquidus (TAL)
Cooling Rate
Maximum Delta
between Body and
PWB at Liquidus
Package Body
Exposure Limit at
Maximum Temperature
2 - 3ç/sec
0-120 sec
140 - 180ç
205 - 225ç
30-90 sec
>6ç/sec
240ç
10ç
5 sec
Pb-Free
Comment
Other components may limit
ramp rate to 2ç/sec.
Soak requirements
determined by board design,
0-120 sec
oven capability, and paste
activation requirements
Caution-"oversoaking" may
160 - 215ç e x h a u s t f l u x a n d a f f e c t
soldering
Cooler peak temperatures
230 - 250ç
may require longer TAL's
45 - 120 Shorter TAL's may require
sec
higher peak temperatures
Faster cooling rates produce
>6ç/sec finer grain structures and
smoother joint appearances
Open body design allows for
260ç
low delta T between package
and solder joint
Standard practice is easy
10ç
to achieve with open body
design.
Adjust profile if maximum
5 sec
exposure limit is approached
or exceeded
2 - 3ç/sec
Note 1 : Values in this temperature profile are suggested values only.
Note 2 : IT-P receptacles are not compatible with the double-sided and inverted reflow.
2-1. Recommended Net Solder Paste Volume for IT-P series.
Dimensions For Recommended Solder Preform Placement
Dimensions For Recommended Net Solder Paste Volume
(12)
(5)
(5)
(5)
(5)
(4)
(4)
(3.7)
Solder Preform
8∞(0.72)
(6)
(8)
(10)
1.45mm3
(3.7)
(3.7)
1.63mm3
Note1. The following solder preform volume shows 2.4mm
board thickness.
2∞
(Ø
1.63mm3
(3.7)
7.
1.45mm3
3)
Connector contact area
(2) Solder preform volume : 32.768mm3
・Recommended Preform Solder : SMIC Chip Solder S M705
・Size : 3.2×1.6×0.8 = 4.096mm3
・Quantity : 8 pcs
(1) Net solder paste volume : 10.9mm3
=12.32mm3 ∞ (100-11.5)%
・Stencil thickness of 0.12mm
・Flux content of 11.5%
2-2. Recommended Net Solder Paste Volume for IT-PA and IT-PB series.
(19.6)
(2 × Ø5.6)
1.67mm3
(10.8)
(2.8)
1.45mm3
(2.8)
(1.7)
(2.8)
Solder Preform
(9.45)
4×
C
6
1.
(2.8)
Maximum Package
Body Terminal (T)
Eutectic(SnPb)
2×(0.72)
1.67mm3
1.45mm3
(1) Net solder paste volume : 11.05mm3
= 12.48mm3 × (100-11.5)%
・Stencil thickness is 0.12mm
・Flux content rate is 11.5%
・Quantity : 8 pcs
7
IT-P Series
BEmbossed Carrier Tape Dimensions
Drawing For Packing (Not to scale)
A
A
A
A
Ø2
1
+2
Ø80 +20
(0.5)
(12.3)
Ø380±2
1.7 +0.15
44.4
(13.5)
.2
±0
Ø13
+0.1
5 Empty Pockets minimum
Reel Dimensions (Not to scale)
43.9~47.4
1.5
Top Cover Tape
8 Empty Pockets minimum
.8
P=20±0.1
2±0.15
P=4±0.1
±0
Direction of Feed
+0
0 .1
Leader(400mm Min)
1.75±0.1
.5
(22.5)
20.2±0.1
40.4±0.1
44±0.3
Ø1
Filled Pockets (250 Connectors)
Trailer
Note : This embossed carrier tape is for IT-PD-2S-DIR, IT-PM-2S-DIR, IT-P-2S-DIRL.
IT-PA and IT-PB Series
Ø1
.5 +0.
Direction of Feed
P=20±0.1
P=4±0.1 2±0.15
Trailer
+0.1
1.5 0
Top Cover Tape
5 Empty Pockets Minimum
8 Empty Pockets Minimum
(10.5)
(0.5)
(11.3)
44.4+20
0.2
3±
43.9∼47.4
8
0.
21
Ø
(10.8)
(0.5)
(2.15)
Ø380±2
+2
Ø80 0
IT-PA Series
IT-PB Series
Note : This embossed carrier tape is for IT-PA-2S-DIRL and IT-PB-2S-DIRL.
8
Leader (400mm Min)
Ø1
+0.15
1.7 0
(21.5)
20.2±0.1
40.4±0.1
44±0.3
0 1
1.75±0.1
BDimensions of Interposer Tray
IT-P (16H only), IT-PA, IT-PB SERIES
IT-P SERIES
(A)
(B)
(28.6)
10.8
(15.25)
16.7
A
10.8
(B)
IT-P SERIES
(28.6)
B
(B)
QTY.50 PAIRS
6
Pick up tool
Tray A
Stacked Tray Dimensions
(66.5)
(28.6)
(52.2)
Tray B
Note 1 : These diagrams show typical trays.
The size of the pocket and stacked height differs depending on the size of the product.
Note 2 : The Pick up tool has been provided to avoid touching the contacts with your bare hands.
Note 3 : The Pick up tool with the red housing should be discarded after use.
Note 4 : The interposer of IT-P-2P-16H (**) , IT-PA and IT-PB series are placed into the tray with the larger side down.
(10.25)
(A)
(A)
6
BProduct List
Part No.
IT-PB-2P-10H(11)
IT-PB-2P-11H(11)
IT-PA-2P-14H(11)
IT-P-2P-16H(11)
IT-P-2P-21H(11)
IT-P-2P-23H(11)
IT-P-2P-25H(11)
IT-P-2P-27H(11)
IT-P-2P-29H(11)
IT-P-2P-35H(11)
IT-P-2P-37H(11)
IT-P-2P-39H(11)
IT-P-2P-41H(11)
IT-P-2P-43H(11)
IT-P-2P-65H(11)
HRS No.
636-0632-0 11
636-0633-0 11
636-0613-9 11
636-0644-0 11
636-0618-2 11
636-0610-0 11
636-0607-6 11
636-0624-5 11
636-0615-4 11
636-0602-2 11
636-0620-4 11
636-0606-3 11
636-0619-5 11
636-0621-7 11
636-0643-0 11
Unit : mm
Parts per Tray
50 pairs
Qty per Box
500
A
B
250
175
355
255
265
175
355
255
300
50 pcs
150
56 pcs
25 pcs
112
150
40 pcs
28 pcs
120
80
56
*16H is without housing case.
*1 pair = 2 contact pins
9
BInstallation
<IT-P Series>
① Solder the Receptacle
Mother Board.
④ Install Daughter Card
② Install Interposer
③ Interposer Installed
Push down until the latch locked.
⑤ Mated
<IT-PA, IT-PB Series>
② Pick up the Interposer and install into the receptacle ③ Interposer Installed
Pick up tool
Larger side
Mother Board.
Push Interposer down until they hit the bottom.
⑤ Mated
Note 1 : To prevent silver tarnish, do not touch the contacts with your bare hands.
Use the mating receptacle that has been provided as a pick up tool.
Note 2 : The pick up tool is intended to be used to pick up the contacts in tray and then be discarded.
10
Remove
pick-up tool.
MEMO :
11
USA:
HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE
2300 Warrenville Road, Suite 150,
Downers Grove, IL 60515
Phone : +1-630-282-6700
http://www.hirose.com/us/
USA:
HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE
2841 Junction Ave, Suite 200
San Jose, CA. 95134
Phone : +1-408-253-9640
Fax : +1-408-253-9641
USA:
HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE)
17197 N. Laurel Park Drive, Suite 253,
Livonia, MI 48152
Phone : +1-734-542-9963
Fax : +1-734-542-9964
USA:
HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE
300 Brickstone Square Suite 201,
Andover, MA 01810
Phone : +1-978-662-5255
THE NETHERLANDS:
HIROSE ELECTRIC EUROPE B.V.
Hogehillweg #8 1101 CC Amsterdam Z-O
Phone : +31-20-6557460
Fax : +31-20-6557469
http://www.hirose.com/eu/
GERMANY:
HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH
Schoenbergstr. 20, 73760 ostfildern
Phone : +49-711-456002-1
Fax : +49-711-456002-299
GERMANY:
HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE
Neumeyerstrasse 22-26, 90411 Nurnberg
Phone : +49-911 32 68 89 63
Fax : +49-911 32 68 89 69
GERMANY:
HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE
Bayernstr. 3, Haus C 30855 Langenhagen, Germany
Phone : +49-511 97 82 61 30
Fax : +49-511 97 82 61 35
FRANCE:
HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE
130 Avenue Joseph Kessel, Bat E, 78960
Voisins le Bretonneux, France
Phone : +33-1-85764886
Fax : +33-1-85764823
UNITED KINGDOM:
HIROSE ELECTRIC EUROPE BV (UK BRANCH)
4 Newton Court, Kelvin Drive, Knowlhill,
Milton Keynes, MK5 8NH
Phone : +44-1908 202050
Fax : +44-1908 202058
CHINA:
HIROSE ELECTRIC (CHINA) CO., LTD. (SHANGHAI, HEADQUARTERS)
18, Enterprise Center Tower 2, 209# Gong He
Road, Jing’an District, Shanghai, CHINA 200070
Phone : +86-21-6391-3355
Fax : +86-21-6391-3335
http://www.hirose.com/cn/
CHINA:
HIROSE ELECTRIC (CHINA) CO.,LTD. BEIJING BRANCH
A1001, Ocean International Center, Building 56# East 4th
Ring Middle Road, ChaoYang District, Beijing, 100025
Phone : +86-10-5165-9332
Fax : +86-10-5908-1381
CHINA:
HIROSE ELECTRIC (CHINA) CO., LTD. SHENZHEN BRANCH
Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre,
5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008
Phone : +86-755-8207-0851
Fax : +86-755-8207-0873
HONG KONG:
HIROSE ELECTRIC HONGKONG TRADING CO., LTD.
Room 1001, West Wing, Tsim Sha Tsui Centre, 66
Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong
Phone : +852-2803-5338
Fax : +852-2591-6560
http://www.hirose.com/hk/
TAIWAN:
HIROSE ELECTRIC TAIWAN CO., LTD.
103 8F, No.87, Zhengzhou Rd., Taipei
Phone : +886-2-2555-7377
Fax : +886-2-2555-7355
http://www.hirose.com/tw/
KOREA:
HIROSE KOREA CO.,LTD.
143, Gongdan 1-daero, Siheung-si,
Gyeonggi-do, 15084, Korea
Phone : +82-31-496-7000
Fax : +82-31-496-7100
http://www.hirose.co.kr/
SINGAPORE:
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE
03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C,
Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India
Singapore 079909
Phone : +91-12-660-8018
Phone : +65-6324-6113
Fax : +91-120-4804949
Fax : +65-6324-6123
http://www.hirose.com/sg/
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE
Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma
Gandhi (MG) Road, Bangalore 560 001, Karnataka, India
Phone : +91-80-4120 1907
Fax : +91-80-4120 9908
MALAYSIA:
THAILAND:
PENANG REPRESENTATIVE OFFICE
BANGKOK OFFICE (REPRESENTATIVE OFFICE)
73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn
Road, Yannawa, Sathorn, Bangkok 10120 Thailand
Lepas Penang, 11950, Malaysia
Phone : +66-2-686-1255
Phone : +604-648-5536
Fax : +66-2-686-3433
12
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 01/2019. Contents are subject to change without notice for the purpose of improvements.
