MDF14A-10P-2.5DS(05)
    HRS(广濑)
    CONNHDR10POS2.5MMT/HR/A
MDF14A-10P-2.5DS(05) 数据手册
2.5mm Pitch Board to Board Vertical Post Header Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MDF14A Series B166 ■Features 1. Service Efficiency Up contact and contact. The post header is developed in the special design capable of vertically connecting the board unnecessary for insertion or extraction. The post header can be connected in combination of the receptacle with the plug at low cost. 2. Current Capacity [5A] By adopting the 0.8mm round pin as the post pin, the pin strength can be enhanced as well as the current capacity can be maintained at 5A approximately. 3. Board Pre-fixed Mechanism The kink process is provided for the board pre-fix process. 4. Pin Extraction Specification The post header corresponds to individual pin extraction specifications. ■Applications Various power supply units, and secondary power unit for the set Kink process MDF14A Series●2.5mm Pitch Board to Board Vertical Post Header ■Product Specifications Rating Current rating : 5A Operating Temperature Range: -30 to +85ç (Note 1) Storage Temperature Range: -10 to +60ç(Note 2) Voltage rating : 250V AC Operating Moisture Range: 40 to 80% Item Specification (Note 2) Condition 1. Insulation Resistance 1000M ohms min. 500V DC 2. Withstanding voltage No flashover or insulation breakdown. 1500V AC/1 minute 3. Vibration No damage, cracks, or parts looseness. Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. 4. Humidity (Steady state) Insulation resistance: 1000M ohms min. 5. Temperature Cycle Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Storage Moisture Range: 40 to 70% 96 hours at temperature of 40 ± 2ç and humidity of 90% to 95% (-55ç: 30 minutes→5 to 35ç: 10 minutes max.→ No damage, cracks, or parts looseness. (-85ç: 30 minutes→5 to 35ç: 10 minutes max.) 5 cycles 6. Resistance to Soldering heat No deformation of components affecting performance. Flow: 260ç for 10 seconds Manual soldering: 350ç for 3 seconds Note 1: Includes temperature rise caused by current flow. Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Note 3: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Material Product Pin Header Part Material Finish Remarks Insulator Contact Polyamide Beige Brass Tin plated UL94V-0 ________ Note: Hirose's tin plating process takes measures against whisker. ■Ordering Information ●Connector MDF14A - * P - 2.5 DS (05) q q Series Name w : MDF 14A w Number of contacts: 4 to 10 e Connector Type P : Pin Header e r t r Contact pitch: 2.5mm t Connection Type DS : Right Angle y Contact Surface Finish / Packaging Type (05) : Tin plated, 100 pcs. per bag B167 MDF14A Series●2.5mm Pitch Board to Board Vertical Post Header ■Pin Header Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Applicable Through-hole Diameter : Ø1.0 +0.1 +0 BApplication Pattern Note:The kink process is alternately performed in optional directions. Unit: mm Part Number CL No. Number of Contacts A B MDF14A- 4P-2.5DS(05) 547-0242-4-05 4 10.0 7.5 MDF14A- 5P-2.5DS(05) 547-0241-1-05 5 12.5 10.0 MDF14A- 6P-2.5DS(05) 547-0240-9-05 6 15.0 12.5 MDF14A- 7P-2.5DS(05) 547-0239-0-05 7 17.5 15.0 MDF14A- 8P-2.5DS(05) 547-0238-7-05 8 20.0 17.5 MDF14A- 9P-2.5DS(05) 547-0237-4-05 9 22.5 20.0 MDF14A-10P-2.5DS(05) 547-0236-1-05 10 25.0 22.5 Note: A packaging quantity is delivered by the bag unit (100 pcs.). If needed, please order the products per bag. BPrecautions 1. Recommended Soldering Condition Flow: 255±5ç for 10 seconds max. Manual soldering: 340±10ç for 3 seconds B168 RoHS YES [Specific No.] –* *, (* *) (05) :Tin plated, 100 pcs. per bag
MDF14A-10P-2.5DS(05) 价格&库存
很抱歉,暂时无法提供与“MDF14A-10P-2.5DS(05)”相匹配的价格&库存,您可以联系我们找货
