HR22-12WTLP-20PC
HR22-12WTLP-20PC
    HRS(广濑)
    CONN HSG PLUG 20POS CBL R/A PIN
HR22-12WTLP-20PC 数据手册
High Performance, Miniature Circular Connectors HR22 Series Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Features ·Both waterproof and non-waterproof types are available. (Waterproof and nonwaterproof connectors can be mated with each other if needed, but will no longer result in a waterproof connection) ·Waterproof performance The HR22 waterproof type is IP67 and IP68 rated when mated. IP67 : Left at a water depth of 1 m for 30 minutes IP68 : Left at a water depth of 2 m for 14 days ·Both crimp and solder type termination are available. Termination style can be chosen as required by your specific application. ·The receptacle features a jam nut configuration at the front, which allows for easy panel mounting. ·The jack connector can also be used as a panel jack. Product specifications Ratings Rated current 2A  Operating temperature range -25ç to +85℃ Rated voltage 100V AC, 140V DC Storage temperature range -10ç to +60℃ Item Specifications Conditions 1. Contact resistance 20mø max. Measured at DC 1A 2. Insulation resistance 1,000Mø min. Measured at DC 100V 3. Withstanding voltage No flashover or dielectric breakdown. Measured at AC 300V for 1 minute 4. Vibration resistance There shall be no electrical No electrical 10 to 500Hz/cycle, amplitude : 0.75mm, acceleration- 98m/s2 discontinuity for 10µs or greater. 3 axis directions, 2 hours each 5. Shock resistance No electrical discontinuity for 10µs or greater. Acceleration : 490m/s2,duration : 11ms, 3 axis directions, 3 times each 6. Mating cycles Contact resistance : 20mø max. 100 times 7. Resistance to water pressure Mated connectors left in Water at a depth of 1.8m for 48 No water penetration into the connector. hours. Materials / Finish Items Plated shell Insulator Male contact Female contact Hood and bushing Material Brass Zinc alloy PBT resin Finish Nickel plating Black Beryllium copper (Soldering) Silver plating UL94V-0 ―――― ―――― ―――― Phosphor bronze (Crimping) Acrylonitrile-butadiene rubber ―――― ―――― Brass (Soldering) Phosphor bronze (Crimping) Remarks Black In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2018.7③ 1 HR22 Series●High Performance, Miniature Circular Connectors Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. HR22 - 12 W T P A - 20 SC (**) 1 2 3 4 5 6 7 8 9 1 Model name : HR22 2 Shell size : The shell size is the outer diameter of the mating end of the plug. 3 W : Waterproof Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Blank : Non-waterproof 4 Locking mechanism T : Threaded coupling type 5 Shell type P : Plug J : Jack R : Receptacle 6 Shell variation : Variation of the same connector configuration is shown by A, B, C, D.... 7 Number of contacts 8 Contact form P : Male pin S : Female pin PC : Crimp type male pin SC : Crimp type female pin 9 Other specifications : A two-digit character is added to indicate other specifications as needed. 2 HR22 Series●High Performance, Miniature Circular Connectors Plug Ø10 Ø11.9 1 4 5 10 1117 2016 Ø21 62 (Applicable cable dia.) Waterproof type (Representative example) HR22-12WTPA-20SC(73) Crimp type Solder type Part No. HRS No. HR22-12WTPA-20SC(73) 122-0004-7 73 HR22-12WTPA-20PC(73) 122-0024-4 73 Part No. HRS No. HR22-12WTPA-20S(73) 122-0015-3 73 HR22-12WTPA-20P(73) 122-0027-2 73 RoHS Yes RoHS Yes Cable clamping force, rotation force, waterproof performance, and other types of performance may differ depending on the cable type used. Please make sure to verify the suitability of the cable assembly before use or production. Ø8.5 Ø11.9 Ø21 53.5 M15×0.75 (Applicable cable dia.) Non-waterproof type 1 4 5 10 1117 2016 Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. M15×0.75 (Representative example) HR22-12TPD-20SC(73) Crimp type Solder type Part No. HRS No. HR22-12TPD-20SC(73) 122-0010-0 73 HR22-12TPD-20PC(73) 122-0018-1 73 Part No. HRS No. HR22-12TPD-20S(73) 122-0011-2 73 HR22-12TPD-20P(73) 122-0012-5 73 RoHS Yes RoHS Yes Cable clamping force, rotation force, waterproof performance, and other types of performance may differ depending on the cable type used. Please make sure to verify the suitability of the cable assembly before use or production. 3 HR22 Series●High Performance, Miniature Circular Connectors Right angle plug Waterproof type 1 Ø21 4 10 5 16 11 20 17 Ø11.9 17.95 M16×0.75 M15×0.75 41.7 Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HR22-12WTLP-20P(31) (Representative example) Crimp type Part No. HR22-12WTLP-20PC(31) HRS No. 122-0064-9 31 RoHS Yes Solder type Part No. HR22-12WTLP-20P(31) HRS No. 122-0054-5 31 RoHS Yes Cord clamp for use on right-angled plugs φ20 φA M16×0.75 17 JR13WCC-10(72) Part No. JR13WCC-4(72) JR13WCC-5(72) JR13WCC-6(72) HRS No. 114-2045-0 72 114-2046-3 72 114-2047-6 72 (Representative example) A 4 5 6 RoHS Part No. JR13WCC-7(72) JR13WCC-8(72) JR13WCC-9(72) JR13WCC-10(72) Yes HRS No. 114-2048-9 72 114-2049-1 72 114-2050-0 72 114-2051-3 72 A 7 8 9 10 RoHS Yes Cable clamping force, rotation force, waterproof performance, and other types of performance may differ depending on the cable type used. Please make sure to verify the suitability of the cable assembly before use or production. Receptacle Waterproof / Non-waterproof combined use type A 21.5 13.5 4 20 φ20.6 10 16 1 17 5 11 M15×0.75 HR22-12WTRA-20P(73) Crimp type Solder type 4 15.8 20(HEX) M17×0.75 (Representative example) Part No. HR22-12WTRA-20SC(73) HR22-12WTRA-20PC(73) HRS No. 122-0021-6 73 122-0005-0 73 Part No. HR22-12WTRA-20S(73) HR22-12WTRA-20P(73) HRS No. 122-0014-0 73 122-0013-8 73 RoHS Yes A 24 25.5 RoHS Yes HR22 Series●High Performance, Miniature Circular Connectors Jack Waterproof type 20 4 17 1 5 11 Ø10 10 16 15.8 M17×0.75 M15×0.75 HR22-12WTJA-20PC(73) Crimp type (Representative example) Part No. HRS No. HR22-12WTJA-20SC(73) 122-0025-7 73 RoHS HR22-12WTJA-20PC(73) 122-0006-2 73 Yes Cable clamping force, rotation force, waterproof performance, and other types of performance may differ depending on the cable type used. Please make sure to verify the suitability of the cable assembly before use or production. 55.5 15.8 20(HEX) (Applicable cable dia.) Non-waterproof type Ø8.5 Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 20(HEX) (Applicable cable dia.) 64 M17×0.75 M15×0.75 HR22-12TJD-20P(73) Solder type Part No. (Representative example) HRS No. HR22-12TJD-20S(73) 122-0023-1 73 HR22-12TJD-20P(73) 122-0022-9 73 RoHS Yes Cable clamping force, rotation force, waterproof performance, and other types of performance may differ depending on the cable type used. Please make sure to verify the suitability of the cable assembly before use or production. 5 HR22 Series●High Performance, Miniature Circular Connectors Contact Male contact Female contact 1.35 1.2 1.18 1.35 1.18 A 1.2 A A 13 A 14.8 Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Male contact Item Part No. HRS No. Applicable cable Packaging RoHS Loose contact HR22-PC-122 122-0017-9 100 pcs/pack Reel contact HR22-PC-222 122-0009-0 24 to 28 AWG Insulation diameter Ø1.15MAX 10,000 pcs/reel Item Part No. HRS No. Applicable cable Packaging Loose contact HR22-SC-122 122-0016-6 100 pcs/pack Reel contact HR22-SC-222 122-0008-8 24 to 28 AWG Insulation diameter Ø1.15MAX Yes Female contact RoHS Yes 10,000 pcs/reel Applicable tools Item Part No. HRS No. Applicable terminal Applicable wire Manual crimping tool HR22-TA2428HC 150-0200-4 HR22-PC-122 HR22-SC-122 24 to 28 AWG Insulation diameter Ø1.15MAX CM-105C 901-0001-0 ―――― ―――― AP105-HR22-2 901-2023-7 HR22-PC-222 HR22-SC-222 24 to 28 AWG Insulation diameter Ø1.15MAX HR10A-TC-04 150-0058-5 ―――― Ø8.5 RP6-SC-TP 150-0039-0 ―――― ―――― HR22-12P-T01 150-0075-4 ―――― Plug connector use Machine body Automatic crimping tool Applicator Cable crimping tool Extractor Cable termination tool Extractor Manual crimping tool Cable crimping tool HR22-12P-T01 Automatic crimping machine CM-105C 6 HR22 Series●High Performance, Miniature Circular Connectors Panel mounting dimensions 15.85 +0.05  0 4 3 2 1 10 9 8 7 6 5 Pin allocation 16 15 14 13 12 11 +   0.0 0 5 20 19 18 17 Ø0.8 Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Ø1 7. 05 Solder pot inner dia. Panel thickness t: 1 to 3mm Notes: The above figure shows the pin allocation viewed from the engagement side. Precautions 1. Switch off the power of the circuit before disconnecting or plugging-in the connectors. 2. Use connectors with socket contacts at the power side of the circuit. 3. Make sure that the coupling is in completely cocked position. 4. The cable pull and twisting strength and other characteristics may differ, depending on the cable structure. Please confirm before the use. 5. This product uses silver plated contacts. Please be aware that silver easily reacts to sulfur gases, causing discoloration or degradation when exposed to certain environmental conditions as shown below. These conditions include areas with: • Dusty site • Area or location with a high density of sulfur dioxide gas, hydrogen sulfide gas, nitrogen dioxide gas, or other gas (Emission gases from vehicles and factories, etc.) • Highly fluctuating temperatures, such as close to a heating apparatus. In addition, it is recommended to store the products in their original packaging or similar state in order to prevent discoloration. • Temperature : -10 to +60ç, relative humidity : 80% or lower (An environment where temperature and relative humidity are constant and there is little temperature variation.) Please use the products within six months after delivery. (lf the storage period has expired, please examine the connectors and solder cups for corrosion and/or tarnish.) 7 Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HR22 Series●High Performance, Miniature Circular Connectors Powered by TCPDF (www.tcpdf.org) USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE 2300 Warrenville Road, Suite 150, Downers Grove, IL 60515 Phone : +1-630-282-6700 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 2841 Junction Ave, Suite 200 San Jose, CA. 95134 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 17197 N. Laurel Park Drive, Suite 253, Livonia, MI 48152 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE 300 Brickstone Square Suite 201, Andover, MA 01810 Phone : +1-978-662-5255 THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Schoenbergstr. 20, 73760 ostfildern Phone : +49-711-456002-1 Fax : +49-711-456002-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE Neumeyerstrasse 22-26, 90411 Nurnberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE Bayernstr. 3, Haus C 30855 Langenhagen, Germany Phone : +49-511 97 82 61 30 Fax : +49-511 97 82 61 35 http://www.hirose.com/eu/ FRANCE: HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE 130 Avenue Joseph Kessel, Bat E, 78960 Voisins le Bretonneux, France Phone : +33-1-85764886 Fax : +33-1-85764823 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. (SHANGHAI, HEADQUARTERS) 18, Enterprise Center Tower 2, 209# Gong He Road, Jing’an District, Shanghai, CHINA 200070 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. SHENZHEN BRANCH Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7355 http://www.hirose.com/tw/ KOREA: HIROSE KOREA CO.,LTD. 143, Gongdan 1-daero, Siheung-si, Gyeonggi-do, 15084, Korea Phone : +82-31-496-7000 Fax : +82-31-496-7100 http://www.hirose.co.kr/ SINGAPORE: INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE HIROSE ELECTRIC SINGAPORE PTE. LTD. 03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C, Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India Singapore 079909 Phone : +91-12-660-8018 Phone : +65-6324-6113 Fax : +91-120-4804949 Fax : +65-6324-6123 http://www.hirose.com/sg/ http://www.hirose.com/sg/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma Gandhi (MG) Road, Bangalore 560 001, Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ MALAYSIA: THAILAND: PENANG REPRESENTATIVE OFFICE BANGKOK OFFICE (REPRESENTATIVE OFFICE) 73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn Road, Yannawa, Sathorn, Bangkok 10120 Thailand Lepas Penang, 11950, Malaysia Phone : +66-2-686-1255 Phone : +604-648-5536 Fax : +66-2-686-3433 http://www.hirose.com/sg/ http://www.hirose.com/sg/ ® 8 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 07/2018. Contents are subject to change without notice for the purpose of improvements.
HR22-12WTLP-20PC 价格&库存
很抱歉,暂时无法提供与“HR22-12WTLP-20PC”相匹配的价格&库存,您可以联系我们找货
