PSP400KB-2R2
PSP400KB-2R2
    YAGEO(国巨)
    插件电阻 - 2.2Ω ±10% 4W -
PSP400KB-2R2 数据手册
無法顯示連結的圖像。檔案可能已移動、重新命名或刪除。請驗證連結指向正確的檔案及位置。 DATA SHEET FIBERGLASS CEMENT RESISTORS Power, Wirewound, Axial Lead PSP Series ±5%, ±10% 4W to 17W Product specification – August 12, 2021 V.0 RoHS compliant & Halogen Free Through Hole Resistors Fiberglass Cement Resistors Product Specification ORDERING INFORMATION Part number of the fiberglass cement resistor is identified by the series, power rating, tolerance, packing, temperature coefficient and resistance value. PART NUMBER APPLICATIONS  All general purpose applications PSP 400 J B - (1) (2) (3) (4) (5) 100R (6) (1) SERIES PSP Series FEATURES  Fiberglass core, high ohmic  Miniaturization (2) POWER RATING 400 = 4W 700 = 7W 500 = 5W 900 = 9W 7WS = 7W 11A = 11W 17A = 17W  Vertical terminal  Flameproof ceramic case  RoHS compliant and halogen free (3) TOLERANCE J = ±5% K = ±10% (4) PACKAGING B = Bulk (5) TEMPERATURE COEFFICIENT OF RESISTANCE - = Based on spec. (6) RESISTANCE VALUE E24 Series Example: 0R1 = 0.1Ω, 100R = 100Ω, 1K = 1,000Ω www.yageo.com Aug. 12, 2021 V.0 2 7 PSP Through Hole Resistors Fiberglass Cement Resistors Product Specification 7 PSP DIMENSIONS Unit: mm Normal Miniature L W H ψd PSP400 - 20±1.0 6.4±0.3 6.4±0.3 0.8±0.02 PSP500 - 25±1.0 6.4±0.3 6.4±0.3 0.8±0.02 - PSP7WS 25±1.0 9.0±0.3 9.0±0.3 0.8±0.02 PSP700 - 38±1.0 6.4±0.3 6.4±0.3 0.8±0.02 PSP900 - 38±1.0 9.0±0.3 9.0±0.3 0.8±0.02 PSP11A - 50±1.0 9.0±0.3 9.0±0.3 0.8±0.02 PSP17A - 75±1.0 9.0±0.3 9.0±0.3 0.8±0.02 DERATING CURVE Rated Power (%) 100 80 60 40 20 70 275 Ambient Temperature (°C) ELECTRICAL CHARACTERISTICS CHARACTERISTICS PSP400 PSP500 PSP7WS PSP700 PSP900 PSP11A PSP17A Power Rating at 70 °C 4W 5W 7W 7W 9W 11W 17W Voltage Proof on Insulation 2000V 2000V 2000V 2000V 2000V 2000V 2000V Maximum Working Voltage √(P X R) Resistance Range 0.1Ω ~ 2.2KΩ 0.1Ω ~ 2.2KΩ 0.1Ω ~ 2.5KΩ 0.1Ω ~ 3.9KΩ 0.1Ω ~ 3.9KΩ 1Ω ~ 10KΩ 1Ω ~ 10KΩ Operating Temp. Range - 55°C to +275°C Temperature Coefficient see table I Note: For resistance value out of above range is by request. www.yageo.com Aug. 12, 2021 V.0 3 Through Hole Resistors Fiberglass Cement Resistors Product Specification 7 PSP TABLE I TEMPERATURE COEFFICIENT TYPE TEMP. COEFFICIENT ±400 PPM/ °C TEMP. COEFFICIENT ±100 PPM/ °C PSP400 ≤0.2Ω ≥0.22Ω PSP500 ≤0.3Ω ≥0.33Ω PSP700 ≤0.68Ω ≥0.75Ω PSP7WS ≤0.3Ω ≥0.33Ω PSP900 ≤0.68Ω ≥0.75Ω PSP11A ≤1Ω ≥1.1Ω PSP17A ≤1.6Ω ≥1.8Ω TEST AND REQUIRMENTS TEST TEST METHOD Short Time Overload IEC 60115-1 4.13 10 times rated power for 5 sec. ±2.0%+0.05Ω Voltage Proof on IEC 60115-1 4.7 In V-Block for 60 sec. test voltage as No Breakdown Insulation PROCEDURE APPRAISE above table Temperature Coefficient IEC 60115-1 4.8 Between -55°C to +155°C By Type Insulation Resistance IEC 60115-1 4.6 In V-Block for 60 sec. >10,000MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of Marking coatings and markings Robustness of IEC 60115-1 4.16 Terminations Periodic-pulse Overload Direct load for 10 Sec. in the direction of ≥50N the terminal leads IEC 60115-1 4.39 4 times RCWV 10,000 cycles (1 Sec. on, ±2.0%+0.05Ω 25 Sec.off) Damp Heat Steady State IEC 60115-1 4.24 40±2°C,90-95% RH for 56 days, loaded ±2.0%+0.05Ω with 0.1 times RCWV Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV(or Umax., whichever ±3.0%+0.05Ω less) for 1,000 Hr.(1.5 Hr.on,0.5 Hr. off) Temperature Cycling IEC 60115-1 4.19  -55°C  Room Temp.  ±2.0%+0.05Ω +155°C Room Temp.(5 cycles) Resistance to Soldering Heat IEC 60115-1 4.18 260±3°C for 10±1 Sec., immersed to a ±1.0%+0.05Ω point 3±0.5mm from the body www.yageo.com Aug. 12, 2021 V.0 4 Through Hole Resistors Fiberglass Cement Resistors Product Specification 7 PSP Note: RCWV (Rated Continuous Working Voltage ): The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V=√(P X R) or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (V) P=Rated power (W) R=Resistance value (Ω) BULK PACKING Unit: Piece Normal Miniature PACKAGE Quantity PSP400 - Bulk 1,700 PSP500 - Bulk 1,800 PSP700 - Bulk 1,200 - PSP7WS Bulk 600 PSP900 - Bulk 600 PSP11A - Bulk 600 PSP17A - Bulk 400 MARKING Example: YAGEO = Brand 1801 = Date code 7WS = Power rating 100R = Resistance J = Tolerance www.yageo.com Aug. 12, 2021 V.0 5 Through Hole Resistors Fiberglass Cement Resistors Product Specification 7 PSP REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 0 Aug.2, 2021 - - First issue of this specification “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itse lf are unchanged. Any product change will be announced by PCN.” www.yageo.com Aug. 12, 2021 V.0 6 Through Hole Resistors Fiberglass Cement Resistors Product Specification 7 PSP LEGAL DISCLAIMER Yageo, its distributors and agents (collectively, “Yageo”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. Yageo may make changes, modifications and/or improvements to product related information at any time and without notice. Yageo makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum extent permitted by law, Yageo disclaims (i) any and all liability arising out of the application or use of any Yageo product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non-infringement and merchantability. Yageo statements regarding the suitability of products for certain types of applications are based on Yageo’s knowledge of typical operating conditions for such types of applications in a generic nature. Such statements are neither binding statements of Yageo nor intended to constitute any warranty concerning the suitability for a specific customer application or use. They are intended for use only by customers with requisite knowledge and experience for determining whether Yageo products are the correct products for their application or use. In addition, unpredicatable and isolated cases of product failure may still occur, therefore, customer application or use of Yageo products which requires higher degree of reliability or safety, shall employ additional protective safeguard measures to ensure that product failure would not result in personal injury or property damage. Yageo products are not designed for application or use in medical, life-saving, or life-sustaining devices or for any other application or use in which the failure of Yageo products could result in personal injury or death. Customers using or selling Yageo products not expressly indicated for above-mentioned purposes shall do so at their own risk and agree to fully indemnify Yageo and hold Yageo harmless. Information provided here is intended to indicate product specifications only. Yageo reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com Aug. 12, 2021 V.0 7
PSP400KB-2R2 价格&库存
很抱歉,暂时无法提供与“PSP400KB-2R2”相匹配的价格&库存,您可以联系我们找货
