HR25-9TJ-16SC
HR25-9TJ-16SC
    HRS(广濑)
    16 Position Circular Connector Jack for Female Contacts Free Hanging (In-Line)
HR25-9TJ-16SC 数据手册
High Performance, Microminiature Circular Connectors HR25 Series Mated dimensions Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 43.8 35.8 Diagrams of Connectors in Combination Solder type plug (HR25-*TP-**) Crimp type plug (HR25-9TP-**C) Solder type receptacle (HR25-*TR-**) Crimp type receptacle (HR25-9TR-**C) Direct PCB mounting type receptacle (HR25-*TR-**A) Solder type jack (HR25-*TJ-**) Crimp type jack (HR25-9TJ-**C) Features 1. Small, high density design Maximum plug outer diameter : 4, 6, 8 contacts : Ø10.5 12, 16, 20 contacts : Ø12.5 Designed with Hirose technology to be small, compact connectors with a low profile. 2. Wide range of product variations Number of contacts : 4, 6, 8, 12, 16, 20 Connector styles : Plug, jack, receptacle Termination style : Solder, crimp (Additionally, a direct PCB mounting style is also available for receptacles.) Contact gender : Plug, receptacle, and jack connectors are available configured either way with male or female contacts. 3. Shielded design The connector’s metal shell design is an optimal choice for devices that require EMI shielding. 4. RoHS compliant All materials and substances used to produce this product comply with RoHS standards. In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2015.1w 1 HR25 Series●High Performance, Microminiature Circular Connectors Product Specifications Rated current 1A Rated voltage 30V AC, 42V DC Operating temperature range Storage temperature range Ratings Items -10ç to +60ç Specifications 1.Contact resistance 2.Insulation resistance 3.Withstanding Voltage Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. -25ç to +85ç Conditions 30 mø min. Measured at DC 1A 1,000 Mø min. Measured at DC 100 V No flashover or dielectric breakdown. AC 100 V for one minute 4.Vibration resistance No electrical discontinuity for 10 µs or greater. 10 to 55 Hz/cycle, amplitude: 0.75 mm, 3 axis directions, 2 hours each direction 5.Shock resistance No electrical discontinuity for 10 µs or greater. Acceleration: 490 ms2, duration: 11 ms, 3 axis directions, 3 cycles each direction. 6.Mating Cycles Contact resistance: 50 mø max. 7.Temperature cycle Insulation resistance: 1,000 Mø min. 1,000 times -55ç: 30 minutes ➝ Normal temperature: 10 to 15 minutes ➝ 85ç: 30 minutes ➝ Normal temperature: 10 to 15minutes, left for 5 cycles 8.Moisture resistance Insulation resistance: 5 Mø min. (at high humidity) 50 Mø min (when dry) Temperature: 40ç, relative humidity: 90 to 95%, left for 96 hours Material Item Plug/jack Material Finish Remarks Plated shell Zinc alloy Nickel plated ―――― Insulator ―――― UL94V-0 ―――― ―――― Contact PPS resin Ethylene-propylene rubber Phosphor bronze Gold plated ―――― Plated shell Zinc ally Nickel plated ―――― Insulator PPS resin ―――― UL94V-0 Contact Phosphor bronze Gold plated ―――― Gasket Ethylene-propylene rubber ―――― ―――― Gasket, boot Receptacle Product Number Structure HR25 - 9 T P - 20 P C (**) ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❽ ❶Model name:HR25 Series ❷Shell size:The shell size is the outer diameter of the mating end of the plug. ❸Locking mechanism T:Screw-lock ❹Connector type P:Plug R:Receptacle J :Jack ❺Number of contacts ❻Contact type: S:Female contact P:Male contact ❼Contact termination method: None:Solder termination C:Crimp termination A:PCB dip termination ❽Other specifications: A two-digit number is added to indicate other specifications than ❶ to ❼ shown above. 2 HR25 Series●High Performance, Microminiature Circular Connectors Plug ØD ØC ØB 5 1 20 2 A Part No. HR25-7TP-4P(72) HR25-7TP-4S(72) HR25-7TP-6P(72) HR25-7TP-6S(72) HR25-7TP-8P(72) HR25-7TP-8S(72) HR25-9TP-12P(72) HR25-9TP-12S(72) HR25-9TP-16P(74) HR25-9TP-16S(73) HR25-9TP-20P(72) HR25-9TP-20S(73) Unit: mm HRS No. 125-0001-8 72 125-0002-0 72 125-0003-3 72 125-0004-6 72 125-0005-9 72 125-0006-1 72 125-0101-2 72 125-0102-5 72 125-0103-8 74 125-0104-0 73 125-0105-3 72 125-0106-6 73 No. of contacts A ØB ØC ØD Weight 35 10.5 6.7 5 8g 43 12.5 8.7 7 13g 4 6 8 12 16 20 ● Crimp type Part No. HR25-9TP-12PC(72) HR25-9TP-12SC(72) HR25-9TP-16PC(72) HR25-9TP-16SC(72) HR25-9TP-20PC(72) HR25-9TP-20SC(72) Unit: mm HRS No. 125-0401-6 72 125-0402-9 72 125-0403-1 72 125-0404-4 72 125-0405-7 72 125-0406-0 72 No. of contacts A ØB ØC ØD Weight 43 12.5 8.7 7 12g 12 16 20 Receptacle 20 ØA 1 5 5.8 13.5 11.5 2 C B D(HEX) ● Solder type Part No. HR25-7TR-4S(73) HR25-7TR-4P(73) HR25-7TR-6S(73) HR25-7TR-6P(73) HR25-7TR-8S(73) HR25-7TR-8P(73) HR25-9TR-12S(71) HR25-9TR-12P(71) HR25-9TR-16S(71) HR25-9TR-16P(71) HR25-9TR-20S(71) HR25-9TR-20P(71) Unit: mm HRS No. 125-0007-4 73 125-0008-7 73 125-0009-0 73 125-0010-9 73 125-0011-1 73 125-0012-4 73 125-0107-9 71 125-0108-1 71 125-0109-4 71 125-0110-3 71 125-0111-6 71 125-0112-9 71 No. of contacts B C D Weight 10.6 M8.5×0.5 M8×0.5 10 3g 12.6 M10.5×0.5 M10×0.75 12 4g 4 6 8 12 16 20 ● Crimp type Part No. HR25-9TR-12SC(71) HR25-9TR-12PC(71) HR25-9TR-16SC(71) HR25-9TR-16PC(71) HR25-9TR-20SC(71) HR25-9TR-20PC(71) ØA Unit: mm HRS No. 125-0407-2 71 125-0408-5 71 125-0409-8 71 125-0410-7 71 125-0411-0 71 125-0412-2 71 No. of contacts 12 16 20 A 11.5 13 11.5 13 11.5 13 Weight 3g A 5.8 φ12.6 Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● Solder type M10×0.5 M10×0.75 12(HEX) 3 HR25 Series●High Performance, Microminiature Circular Connectors Receptacle 14.1 11.5 2(Dip length) 5 1 20 2 ØA 5.8 C B D (HEX) ● Direct PCB mounting type Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HR25-7TR-4SA(73) HR25-7TR-4PA(73) HR25-7TR-6SA(73) HR25-7TR-6PA(73) HR25-7TR-8SA(73) HR25-7TR-8PA(73) HR25-9TR-12SA(71) HR25-9TR-12PA(71) HR25-9TR-16SA(71) HR25-9TR-16PA(71) HR25-9TR-20SA(71) HR25-9TR-20PA(71) HRS No. 125-0019-3 73 125-0020-2 73 125-0021-5 73 125-0022-8 73 125-0023-0 73 125-0024-3 73 125-0119-8 71 125-0120-7 71 125-0121-0 71 125-0122-2 71 125-0123-5 71 125-0124-8 71 Unit: mm No. of contacts ØA B C D Weight 10.6 M8.5×0.5 M8×0.5 10 3g 12.6 M10.5×0.5 M10×0.75 12 4g 4 6 8 12 16 20 Jack 2 20 15 ØA ØC B D ● Solder type Part No. HR25-7TJ-4S(72) HR25-7TJ-4P(72) HR25-7TJ-6S(72) HR25-7TJ-6P(72) HR25-7TJ-8S(72) HR25-7TJ-8P(72) HR25-9TJ-12S(72) HR25-9TJ-12P(72) HR25-9TJ-16S(72) HR25-9TJ-16P(72) HR25-9TJ-20S(73) HR25-9TJ-20P(72) HRS No. 125-0013-7 72 125-0014-0 72 125-0015-2 72 125-0016-5 72 125-0017-8 72 125-0018-0 72 125-0113-1 72 125-0114-4 72 125-0115-7 72 125-0116-0 72 125-0117-2 73 125-0118-5 72 No. of contacts B ØC D 10.6 35 5 M8.5×0.5 8g 12.6 43 7 M10.5×0.5 12g 4 6 8 12 16 20 ● Crimp type Part No. HR25-9TJ-12SC(72) HR25-9TJ-12PC(72) HR25-9TJ-16SC(72) HR25-9TJ-16PC(72) HR25-9TJ-20SC(72) HR25-9TJ-20PC(72) 4 Unit: mm Weight ØA Unit: mm HRS No. 125-0413-5 72 125-0414-8 72 125-0415-0 72 125-0416-3 72 125-0417-6 72 125-0418-9 72 No. of contacts ØA B ØC D Weight 12.6 43 7 M10.5×0.5 12g 12 16 20 HR25 Series●High Performance, Microminiature Circular Connectors Crimp-style contacts ● Female Contacts 0.88 0.88 ● Male Contacts Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Type Loose contacts Reel contacts 13.4 9.4 4 Part No. HRS No. HR25-PC-111 125-0419-1 0.7 0.7 13.4 Suitable Wire AWG#30 HR25-PC-211 125-0420-0 Note: 1. Please use wire with a outer jacket diameter of 0.71mm or less. 2. Loose contacts come in packages of 100 pcs. Reel contacts come in reels of 10,000 pcs. Type Loose contacts Reel contacts 9.4 4 Part No. HRS No. Suitable Wire HR25-SC-111 125-0421-3 HR25-SC-211 125-0422-6 AWG#30 Note: 1. Please use wire with a outer jacket diameter of 0.71mm or less. 2. Loose contacts come in packages of 100 pcs. Reel contacts come in reels of 10,000 pcs. Applicable Tools Type Item Part No. HRS No. Applicable Contacts Applicable Wire and Applicable Cable Diameter Manual Manual crimping tool HR25-TA3032HC 150-0207-3 HR25-PC-111 HR25-SC-111 AWG#30 Auto crimping machine body CM-105 901-0005-4 − − Applicator AP105-HR25-1 901-2040-6 HR25-PC-211 HR25-SC-211 AWG#30 Cable crimping tool HR10A-TC-02 150-0041-2 − Ø5、Ø7 Extractor HR25-TP 150-0091-0 − − Auto Assembly Tools Use of the following assembly tools will simplify the process of disassembling and assembling the connectors for the cable assembly. Part No. HRS No. Suitable Connectors and Uses HR25-7TP-T01 150-0082-0 For HR25-7TP wiring and P shell unit tightening HR25-9TP-T01 150-0080-4 For HR25-9TP wiring and P shell unit tightening HR25-7TJ-T01 150-0089-9 For HR25-7TJ wiring and J shell unit tightening HR25-9TJ-T01 150-0090-8 For HR25-9TJ wiring and J shell unit tightening 5 HR25 Series●High Performance, Microminiature Circular Connectors Cable Assembly Procedures The outline of wiring work for this diagram uses the soldered type as an example. The jack side is also based on the work outline of the plug: however, the receptacle side does not require a special work outline and has been omitted because of this. ● Construction Diagram P shell unit Spanner position Cable Clamp body Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Clamp fitting Solder type approx. 1.5 Crimp type 1.7±0.2 2 or less Boss Cable bushing A Set screw (Opposite sides 1.27) Table 1 7 Soldered type A dimensions 10mm Crimp type A dimensions − 9 19mm 15mm Shell size Spanner spacing Tightening torque 8mm 1N・m 10mm 1N・m Work Operation Procedures 1. With regard to cables, the wire to be used should have a conductor with a nominal cross-sectional area of 0.08 mm2 (AWG#28) or less in a finished form suited to each size. 2. First pass the cable bushing and the plug body in order over the cable, then cut the end at the dimensions indicated in the above diagram. 3. Mount the P shell unit in the wiring jig and perform the solder wiring. 4. Use the cable crimping jig (HR10A-TC-02) to fix the clamp fitting to the cable. 5. After performing the wiring, tighten the plug body to the screw portion of the P shell unit using the specified torque (in the above table). 6. Tighten the set screw so that the tip of the set screw falls into one of the two bosses of the clamp fitting. Note that the tightening torque of the set screw is from 0.3 to 0.4 Nm. 7. Put the cable bushing over the plug body and complete the work. Note that the use of paint lock (e.g., Locktight 263 manufactured by HENKEL JAPAN LTD.) is recommended on the screw portion to prevent loosening of the P shell unit. The aforementioned work procedure is for the soldered type. In the case of the crimp-style type, Steps 1 and 3 are changed as follows: 1. With regard to cables, the wire to be used should have a conductor with a nominal cross-sectional area of 0.05 mm2 (AWG#30) in a finished form suited to each size. 3. Crimp a suitable crimp terminal to the conductor portion of the cable, then fit into the housing of the P shell unit. 6 HR25 Series●High Performance, Microminiature Circular Connectors Mounting Hole Dimensions Diagram Mounting hole dimensions are indicated as viewed from the engagement side. Lock System Screw Lock Type Shell Size Size 7 Size 9 A 1.55 +0.05 0 1.55 +0.05 0 B +0.03 7.25 − 0.02 +0.03 9.25 − 0.02 C B Diagram Symbol φD 5.4 +0.1 0 C 4.4 D 8 +0.05 0 10 +0.05 0 Mounting Panel Thickness 0.7 ∼ 2 0.7 ∼ 2 A Note: The ▽ mark indicates the engagement guide key position. Receptacle Dip Post Configuration Dimensions 1.5 0.9 3 Size 7, 4 conductors 2.1 8 6×φ0.5 +0.1 0 Size 7, 6 conductors 2.8 12×φ0.5 Size 9, 12 conductors +0.1 0 0.7 1.9 3.1 9 1 2 5 6 8 13 14 0.7 3 10 11 15 16 16 19 20 16×φ0.5 Size 9, 16 conductors +0.1 0 0.7 12 2.1 0.7 1.9 9 0.7 8 1 4 2.1 5 1.4 0.7 2.1 1.4 4 2.1 2.8 1.4 8×φ0.5 +0.1 0 Size 7, 8 conductors 3.1 0.7 7 6 2.1 0.7 4 0.7 4 2 4 4×φ0.5 +0.1 0 1 1 2 5 0.9 3 1 2 0.9 1 1.5 0.7 1.5 2 1.5 1 0.9 1 1.4 Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. +0.1 0 20×φ0.5 +0.1 0 1.4 1.4 2.8 2.8 Size 9, 20 conductors Note: 1. The above diagrams are viewed from the engagement side of the socket insert (i.e., the wiring side of the pin insert). 2. The ▽ mark of the above diagrams indicates the engagement guide key position. 3. A tolerance of ±0.05 is recommended for dimensions without indication. 7 HR25 Series●High Performance, Microminiature Circular Connectors Contact Configuration and Basic Specifications Shell size Size 7 1 Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Contact configuration Powered by TCPDF (www.tcpdf.org) Number of contacts 1 2 1 2 3 2 3 4 3 4 4 5 6 5 6 7 8 4 Withstand voltage 6 8 100V AC for 1 minute Current capacity 1A Insulation resistance 1,000 Mø or greater Contact resistance Solder pot inside diameter 30 mø 0.5 mm dia. Shell size Size 9 1 2 3 4 Contact configuration 5 6 7 8 9 10 11 12 Number of contacts 12 Withstand voltage 1 2 3 4 5 6 7 8 1 2 3 4 5 6 7 8 9 10 14 15 16 11 12 13 14 15 16 17 18 19 20 16 20 9 10 11 12 13 100V AC for 1 minute Current capacity 1A Insulation resistance 1,000 Mø or greater Contact resistance Solder pot inside diameter 30 mø 0.5 mm dia. Note: 1. The above diagrams are viewed from the engagement side of the socket insert (i.e., the wiring side of the pin insert). 2. The ▽ mark of the above diagrams indicates the engagement guide key position. 3. The withstand voltage indicates the test voltage value. For regular use the voltage used should be less than 30 V AC or 42 V DC. 4. The current capacity of the crimp terminals indicates the value when using wire of AWG#30. 5. The insulation resistance indicates a value when measured at 100 V DC. Precautions 1. Switch off the power of the circuit before disconnecting or plugging-in the connectors. 2. Use connectors with socket contacts at the power side of the circuit. 3. Make sure that the coupling is in completely cocked position. 4. Cable clamping, cable rotation, and other forces may vary with the cable construction. Please make sure that your cable is suitable for use with these connectors before usage and production. ® 8 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 1/2015. Contents are subject to change without notice for the purpose of improvements.
HR25-9TJ-16SC
物料型号:HR25系列,包括不同型号的插头(TP)、插座(TR)、插孔(TJ)等。
器件简介:HR25系列连接器具有小型化、高密度设计,多种产品变体,屏蔽设计,符合RoHS标准。
引脚分配:提供4、6、8、12、16、20等不同接触点数量的连接器。
参数特性: - 额定电流:1A - 额定电压:30V AC, 42V DC - 工作温度范围:-25°C至+85°C - 接触电阻:最小30 mΩ - 绝缘电阻:最小1,000 MΩ - 耐电压:AC100V下1分钟无闪络或击穿 - 振动抵抗:10至55 Hz/周期,幅度0.75mm,3轴方向,每方向2小时 - 冲击抵抗:加速度490 m/s²,持续时间11ms,3轴方向,每方向3次循环 - 插拔周期:1000次,接触电阻最大50 mΩ - 温度循环:-55°C至85°C,5个周期 - 湿度抵抗:在高湿度下绝缘电阻5 MΩ,干燥后50 MΩ
功能详解:文档提供了连接器的详细物理尺寸、材料信息、产品编号结构、安装孔尺寸图、接触配置和基本规格。
应用信息:适用于需要EMI屏蔽的设备,如汽车领域。
封装信息:包括材料、镀层、绝缘体、密封圈、接触材料等详细描述。
HR25-9TJ-16SC 价格&库存
很抱歉,暂时无法提供与“HR25-9TJ-16SC”相匹配的价格&库存,您可以联系我们找货
