Plastic Push-Pull Lock Connectors
RP13 Series
Features
1. Superior mating operability
• A secure mating condition is achieved by simply pushing the plug on to the
receptacle; Pull back on the locking sleeve to easily un-mate the connector.
• Index marks are provided on the plug for easy mating alignment.
• Our proprietary guide keys aid with making a correct mating
orientation in blind or low light conditions.
Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
2. Light weight and robust design
The strong outer shell is made of glass-reinforced polycarbonate
resin, producing light but durable connectors.
3. Available in an anti-static version
The anti-static version connects the plug and receptacle housing
together in such a way that the surrounding shield guards against
the effects of static electricity.
4. Variation
Items
Number of contacts
Connector type
Plug termination type
Receptacle termination type
Receptacle mounting style
13, 15, 20
Plug and jack: Straight, Receptacle: Straight, right angle
Crimp
Crimp, PCB dip
Flange, jam nut
Product Specifications
Rated
current
Ratings
Standard type : 2A (when using a wire of at least 24 AWG)
Anti-static type : 2A (when using a wire of at least 22 AWG)
Rated For 13 and 15 contact positions : AC 30V, DC 42V
voltage 20 contacts : AC 100V, DC 140V
Items
Operating
temperature range
−10 to +60ç
Storage
temperature range
−10 to +60ç
Specifications
1. Contact
resistance
2. Insulation
resistance
3. Withstanding
voltage
4. Vibration
resistance
5. Shock
resistance
Conditions
For 13 and 15 contact positions : 15mø max.
20 contacts : 30mø max.
Measured at DC 1A
1,000Mø min.
Measured at DC 250V
No flashover or dielectric breakdown.
AC 300V for 1 minute
No electrical discontinuity for 10µs or greater.
10 to 55Hz/cycle, amplitude : 0.75mm, 3 axis
directions, 2 hours each
Acceleration : 490m/s2, duration : 11ms,
3 axis directions, 3 cycles each
6. Mating cycles
Contact resistance :
For 13 and 15 contact positions : 20mø max.
For 20 contact positions : 45mø max.
1,000 times
7. Temperature
cycle
Insulation resistance : 100Mø min.
-55ç : 30 minutes ➝ Normal temperature : 10 to
15 minutes ➝ 85ç : 30 minutes ➝ Normal
temperature : 10 to 15 minutes, leave total 5 cycles
8. Moisture
resistance
Insulation resistance : 10Mø min. (at high humidity)
100Mø min. (when dry)
Temperature : 40ç, relative humidity : 90 to 95%,
leave 96 hours
Materials / Finish
Items
Plug
Exterior, insulator
Clamp
Bushing
Exterior, insulator
Receptacle
Crimp contact
Crimp contact
Female contact
Male contact
Female contact
Male contact
Material
Polycarbonate resin
Brass
Vinyl chloride resin
Polycarbonate resin
Steel
Phosphor bronze
Brass
Finish
----------------------------------------------------Nickel plating
Remarks
UL94V-0
--------------------------UL94V-0
Phosphor bronze
Silver plating, gold plating
Silver plating
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2018.7w
1
RP13 Series●Plastic Push-Pull Lock Connectors
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
Plug
RP13A - 12 P A - 13 S C (01)
qModel name : RP13A Series
wShell size : The shell size is the outer diameter of the mating
end of the plug.
yContact form
S : Female contact
P : Male contact
eShell type
P : Straight plug
R : Receptacle
J : Jack
uContact termination type:
A : Straight, PCB dip
B : Right-angle, PCB dip
C : Contact termination by crimping
rShell variation : Connectors are distinguished by A, B, or C
iOther specifications : A two-digit character is added to
if a variation is made within the series.
indicate other specifications as needed.
tNumber of contacts
Crimp contact
RP13A - SC - 2 1 1
qModel name : Indicates the series name.
RP13, RP13A, RP19
oContact type :
SC : Socket type crimp contact (female)
PC : Pin type crimp contact (male)
!0Contact form :
1 : Loose piece contacts
2 : Reel contacts
2
!1Barrel form :
RP13, RP13A
1 : For 18 to 22 AWG
2 : For 24 to 28 AWG
RP19 1 : For 18 to 22 AWG
2 : For 24 to 30 AWG
!2Identification of plating :
1 : Gold plating
2 : Silver plating
Standard type
Standard plug
(Minimum dimension)
A
(Representative example.)
RP13A-12PA-13SC(71)
Part No.
HRS No.
RP13A-12PA-13SC(71)
RP13A-12PB-13SC(31)
RP13A-12PD-13SC(71)
RP13A-12PE-13SC(71)
RP13A-12PK-13SC(71)
RP13A-12PS-13SC(71)
RP13A-12PD-15SC(71)
RP13A-12PK-15SC(71)
RP13A-12PP-15SC(71)
113-0182-4 71
113-0184-0 31
113-0186-5 71
113-0201-7 71
113-1006-7 71
113-1026-4 71
113-0206-0 71
113-0219-2 71
113-1010-4 71
No. of contacts A
B ØC Weight
47.2 32
13
52.2 37
47.2 32
52.2 37
15
6.1
5.7
6.1
6.4
7.1 6.0g
8.1
6.1
7.1
7.5
Part No.
HRS No.
RP13A-12PD-20SC(71)
RP13A-12PG-20SC(71)
RP13A-12PH-20SC(71)
RP13A-12PK-20SC(71)
RP13A-12PS-20SC(71)
113-0214-9 71
113-0210-8 71
113-0217-7 71
113-1012-0 71
113-1022-3 71
No. of contacts A
B ØC Weight
6.1
7.5
47.2 32 6.4 6.0g
7.1
52.2 37
8.1
52.2 37
(Note) Cable clamping, cable rotation, and other forces may vary
with the cable construction. Please make sure that your cable
is suitable for use with these connectors before usage and
production.
Receptacle (Flange type)
(Crimp type)
A
25
3.2 10
3
Ø 14.3
13
Press-fitted
metal flange
12
2-B
(Hole is threaded on metal
flange portion)
9
Ø1
45
RP13A-12RA-13PC(71)
Part No.
RP13A-12RA-13PC(71)
RP13A-12RA-15PC(71)
RP13A-12RA-20PC(71)
HRS No.
113-0183-7 71
113-0207-3 71
113-0215-1 71
No. of contacts
13
15
A
18.1
B
Weight
M2.6×0.45
4.0g
16
(Remarks) See page 5 for details on mounting hole dimensions.
(Dip type )
A
18.1
3.2 10
25
B
1
13
3
0.5×0.3
(Dip post diameter)
12
Ø 14.3
Ø16.9
ØC
B
9
Ø1
Press-fitted metal flange
RP13A-12RA-13PA(71)
Part No.
RP13A-12RA-13PA(71)
RP13A-12RA-15PA(71)
45
2-M2.6×0.45
metal flange portion)
HRS No.
113-0202-0 71
113-1002-6 71
No. of contacts
A
B
Weight
13
15
21.5
3
5.0g
(Remarks) See page 5 for details on mounting dimensions and page 7 for details on dip post arrangement sizes.
3
Receptacle (Jam nut to be fastened)
A
(Dip type)
18.1
1
9
1
12
Ø 14.3
B
3
13
0.5×0.3
(Dip post diameter)
M12×1
RP13A-12RB-13PA(71)
Part No.
A
B
No. of
contacts
Weight
21.5
3
13
3.5g
HRS No.
RP13A-12RB-13PA(71)
113-0203-2 71
(Remarks) See page 5 for details on mounting hole dimensions and page 7 for details on dip post arrangement sizes.
Right-angle, dip type
E
1
1
(Note) Panel thickness:
1.5mm max.
4×
R
17
B
C
F
Ø14.3
1
A
4
(Note)
Ø15 mm or more
18
3.5
(Center of the screw hole
for mounting the connector)
Dip post diameter
RP13A-12RC-20PB
(Note) The mounting panel thickness should be 1.5mm or less. Mounting
hole should be Ø15 mm or more.
Part No.
HRS No.
No. of
contacts
A
B
C
ØD
E
F
Weight
RP13A-12RC-13PB
113-1020-8
13
17.5
8.5
3.5
0.64
23.5
13
4.0g
RP13A-12RC-20PB
113-0211-0
10.5
3
0.6
31.5
15
5.0g
(Remarks) See page 7 for details on dip post arrangement sizes.
A
Ø16.9
ØC
B
(Minimum dimension)
Jack
RP13A-12J-13PC(71)
Part No.
HRS No.
RP13A-12J-13PC(71)
113-0166-8 71
RP13A-12JD-15PC(71)
113-1005-4 71
RP13A-12JK-15PC(71)
113-0218-0 71
RP13A-12JG-20PC(71)
113-1004-1 71
No. of
contacts
A
B
13
49.1
34.6
15
54.1
39.6
37.4
ØC
Weight
6.1
7.1
4.5g
7.4
(Note) Cable clamping, cable rotation, and other forces may vary with the cable construction. Please make sure that your cable
is suitable for use with these connectors before usage and production.
4
Contact
(Male contact)
Panel mounting hole
dimensions
A-A
45°
B
E
A
±30
A
D
C
Plating
+0.05
Ø 14.4
B C D E Applicable
wire size
HRS No.
13 contact position for super-thick wires (available for contact position numbers 12 and 13 only)
Type
Part No.
HRS No.
Plating
B C D E Applicable
wire size
Loose piece
RP13-PC-112 113-0178-7
contacts
Silver plating 1.6 2.1 13.9 1.4 18 to 22 AWG
Reel contacts RP13-PC-212 113-0140-4
Type
Part No.
HRS No.
Plating
Loose piece
contacts RP13-PC-122 113-0179-0 Silver plating
Partial gold 1.2 1.35 13.9 1.4 24 to 28 AWG
RP13-PC-221 113-0360-0
plating
Reel contacts
RP13-PC-222 113-0141-7 Silver plating
(Flange type)
Applicable connector
Part No.
HRS No.
RP13A-12RA-13PC(71)
113-0183-7 71
RP13A-12RA-13PA(71)
113-0202-0 71
RP13A-12RA-15PC(71)
113-0207-3 71
RP13A-12RA-15PA(71)
113-1002-6 71
RP13A-12RA-20PC(71)
113-0215-1 71
B C D E Applicable
wire size
7.1 0
+0.1
Loose piece
contacts RP19-PC-122 113-0268-8 Silver plating 1.2 1.35 12 1.18 24 to 30 AWG
Reel contacts RP19-PC-222 113-0264-7
(Female contact)
A-A
A
+0.1
E
B
Ø12.1
Ø1
A
0.1
+ 0
D
3.8
Part No.
2
+0.
2ר
+0.05
7.5 0
Type
+0.05
3.1 0
C
(The form shown above represents an example.)
Type
Part No.
HRS No.
Plating
Loose piece RP13A-SC-121 113-0363-9 Partial gold plating
contacts RP13A-SC-122 113-0181-1 Silver plating
Reel contacts
RP13A-SC-221 113-0362-6 Partial gold plating
(Jam nut to be tightened)
B C D E Applicable
wire size
Part No.
RP13A-SC-222 113-0151-0 Silver plating
Type
Part No.
HRS No.
Plating
B C D E
Applicable
wire size
Loose piece
contacts RP13A-SC-112 113-0180-9 Silver plating 1.6 2.1 13.9 1.4 18 to 22 AWG
Reel contacts RP13A-SC-212 113-0150-8
Type
Part No.
HRS No.
Plating
RP13A-12RB-13PA(71)
HRS No.
113-0203-2 71
(Note 1) Above figures show the arrangement
viewed from the panel surface. The
mating guide of flange type is located
on the top position.
(Note 2) The applicable panel thickness for the
flange type receptacle is 2.7mm max.,
since this type is mounted from the back
surface of the panel.
(Note 3) The applicable panel thickness for a hex
nut fastening type is 5mm max. and
1mm min.
B C D E Applicable
wire size
Loose piece
contacts RP19-SC-122 113-0270-0 Silver plating 1.2 1.35 11 1.18 24 to 30 AWG
Reel contacts RP19-SC-222 113-0266-2
(Note 1) Use connectors with gold-plated contacts if the connectors will be
subjected to constant vibration.
(Note 2) Loose piece contacts are available in 100 piece packs. Reel
contacts are available as 10,000 piece reels.
5
RP13A anti-static type
47.2
Ø 16.9
Ø6.1
32
(Minimum dimension)
Plug
RP13A-12PA-13PC(71)
Part No.
HRS No.
RP13A-12PA-13PC(71)
No. of contacts
Weight
13
6.0g
113-4003-5 71
Receptacle (flange type)
(Crimp type)
15
25
12
φ14.3
φ1
9
2ר2.8 (hole)
(metal flange)
Press-fitted
metal flange
45
RP13A-12R-13SC(71)
Part No.
HRS No.
RP13A-12R-13SC(71)
No. of contacts
Weight
13
4.0g
113-4002-2 71
(Remarks) See page 7 for details on mounting hole dimensions.
Contact
(Female contact)
(Male contact)
A-A
A-A
B
E
B
A
E
A
A
A
D
Type
Part No.
HRS No.
Loose
piece RP19-PC-122 113-0268-8
contacts
Reel
D
C
B
C
D
E Applicable
wire size
Type
Part No.
HRS No.
Loose
piece RP19-SC-122 113-0270-0
contacts
Reel RP19-SC-212 113-0265-0
C
B
C
D
E Applicable
wire size
1.2 1.35
1.6
2.1
24 to 30 AWG
11 1.18
1.2 1.35
(Note 1) Loose piece contacts are available in 100 piece packs. Reel contacts are available as 10,000 piece reels.
Only contact positions 12 and 13 can be used with 18 to 20 AWG wire.
Other contact positions numbers cannot be used with this wire gauge.
(Note 2) When crimping wires gauge 18 to 22 AWG, make sure that the outer insulation diameter is Ø1.79mm or less.
For wires gauges 24 to 30 AWG, use an outer insulation diameter of Ø1.15 or less.
6
18 to 22 AWG
24 to 30 AWG
Panel mounting hole dimensions (for anti-static type)
45 °
±30
+0.1
3.1 0
+0.2
+0.1
2× φ 2.8
.1
+0
(Flange type)
(Note 1) Above figures show the arrangement viewed from the panel surface. The mating guide of flange type is located on top
the position.
(Note 2) The applicable panel thickness for a flange type receptacle is maximum 4.7mm, as this type is mounted from the back
Dip post arrangement sizes for receptacles
Straight dip type
13 contacts
7
8
11
12
2
1
8
1.35
14
13
Ø0.6
(15 positions)
1.15
1.4
3.35
9
15
Ø0.6
(13 positions)
2.9
5
12
13
1.15
1.4
3
4
0.9
3
2.75
2
3.75
1
4
1.25
0.95
3
2.3
1.05
2.3
3.15
2.55
3.45
0.6
3.45
15 contacts
1.15
1.15
2.3
2.3
3.45
3.45
(Remarks) 1. The figures shown above for 13 and 15 contact positions are viewed from the receptacle mating end.
2. A machining tolerance of ±0.05 is recommended for the PCB layout dimensions.
13 contacts
20 contacts
C.L
C.L
11
Use a tapping screw for JIS B 1122 M3.
(Screw hole for mounting the connector)
13
11
12
11
8
7
Ø0.9
(13 positions)
4
3
5
5
5
1.4
2.3
3.45
1.15
1.4
13
12
7
6
(20 positions)
16
15
14
1
Ø0.85
1.15
18
17
10
9
8
2
1
4
3
2 2 2 2 2 2 2
11
2 2 2
1
4
Ø 14
2.3
0.8
3.45
0.8
2.4
2.4
4
4
(Remarks) 1. The figures shown above are viewed from the contact insertion end.
2. A machining tolerance of ±0.05mm is recommended for the PCB layout dimensions.
7
Applicable tools
Type
Manual
Items
Manual crimping
tool
Part No.
HRS No.
150-0024-3
RP13-PC-112
RP13-TC-12
150-0025-6
RP13-PC-121, 122
24 to 28 AWG
RP13A-TC-11
150-0026-9
RP13A-SC-112
18 to 22 AWG
RP13A-TC-12
150-0027-1
RP13A-SC-121, 122
24 to 28 AWG
RP19-TC-11
150-0048-1
RP19-PC-112
RP19-SC-112
18 to 22 AWG
RP19-PC-122
RP19-SC-122
24 to 28 AWG
Cable crimping tool
Extraction tool
18 to 22 AWG
CM-105C
901-0001-0
AP105-RP13-2
901-2024-0
RP13-PC-221, 222
RP13A-SC-221, 222
24 to 28 AWG
AP105-RP19-1
901-2013-3
RP19-SC-212
18 to 22 AWG
AP105-RP19-2
901-2014-6
RP19-PC-222
RP19-SC-222
24 to 28 AWG
RP13A-TC-01
150-0070-0
Ø4.6~Ø5.8
Ø7~Ø7.5
RP13A-TC-02
150-0071-3
Ø6.3, Ø7.8
Auto
Applicator
Applicable wire size and
applicable cable diameter
RP13-TC-11
RP19-TC-12
Automatic crimping
press
Applicable contact
RP13-PC-TP
150-0021-5
Male contact
RP13A-SC-TP
150-0022-8
RP6-SC-TP
150-0039-0
Female contact
Male/female contact for
RP19
RP13A-TC-02
Cable crimping tool
(handle shape is shown as an example.)
RP13-TC-11
Manual crimping tool
RP6-SC-TP
RP13-PC-TP
RP13A-SC-TP
Extraction tools
8
Automatic crimping press
(Type CM-105C)
Termination/assembly procedure
Plug
Assembly procedure
Cable
Cord tube
1. First, pass the terminated cable through the cord tube in
the following order: spring, connection sleeve, and cord
bushing, and then crimp and terminate the contacts.
2. Assemble the crimped and terminated contacts to the
contact holes of the P-insulation P case. At this time,
please make sure that the crimped contacts are
securely engaged onto the contact holes of the
P-insulation P case by lightly pulling the cable.
3. Attach the metal fitting by clamping to it the cord
bushing and assemble these into the P-insulation P
case. Then crimp the metal fitting by clamping it with
the applicable tool.
4. Next, attach in the following order to the P-insulation P
case: connection sleeve, spring, and cord. Then align
the screw hole of the cord tube and that of the metal
fitting for clamping, and tighten the round flat screw to
the specified torque of 0.2 N•m (2 kg•cm).
5. After the assembly procedure described above has
been completed, test the parts to make sure that the
locking collar moves correctly.
Round, flat head screw
Spring
Arrow view A
A
+3
Metal fitting for
clamping
P-insulation
P case
3.3±0.2
2 or more
Cord bushing
27.3
Locking collar
Contact Arrangement
(Standard type)
2
1
Contact
arrangement
4
3
7
4
11
8
12
No. of contacts
13
2
7
6
1
8
12
11
15
13
3
10
14
15
13
4
1
5
10
5
9
16
11
(Anti-static type)
2
3
1
Contact
arrangement
7
4
11
8
12
No. of contacts
13
13
(Remarks) 1. The figures shown above are viewed from the receptacle and jack mating end (plug connection end).
9
Precautions
This product series uses silver plated contacts. Silver reacts easily to exposure to sulfur gas so the below conditions may
cause tarnishing.
・Dusty environments
・Area with a high concentration area of gases such as sulfur dioxide gas, hydrogen sulfide gas, nitrogen dioxide gas and so on.
Example; In close proximity to factory exhaust, automotive emissions, etc.
・Close to heaters, or in other areas marked by extreme temperature differences or high humidity.
・Close to rubber products includes rubber adhesives.
The Electrical connection is not affected by tarnishing on a silver surface due to the wiping effect of the contact pins.
Storage
Packing state; Packed in original packing or equivalent container
Temperature -10 to +60ç
Humidity
85% Max
(It is recommended that the product be stored in an area of normal level of temperature and humidity, and free of any
temperature fluctuation)
Please use this products within 6 months of delivery.
(After 6 month, please check the solderbility before use)
“Storage” means long-term storage of the unused products in sealed packaging, prior to assembly to PCB.
10
MEMO :
11
Powered by TCPDF (www.tcpdf.org)
USA:
HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE
2300 Warrenville Road, Suite 150,
Downers Grove, IL 60515
Phone : +1-630-282-6700
http://www.hirose.com/us/
USA:
HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE
2841 Junction Ave, Suite 200
San Jose, CA. 95134
Phone : +1-408-253-9640
Fax : +1-408-253-9641
USA:
HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE)
17197 N. Laurel Park Drive, Suite 253,
Livonia, MI 48152
Phone : +1-734-542-9963
Fax : +1-734-542-9964
USA:
HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE
300 Brickstone Square Suite 201,
Andover, MA 01810
Phone : +1-978-662-5255
THE NETHERLANDS:
HIROSE ELECTRIC EUROPE B.V.
Hogehillweg #8 1101 CC Amsterdam Z-O
Phone : +31-20-6557460
Fax : +31-20-6557469
http://www.hirose.com/eu/
GERMANY:
HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH
Schoenbergstr. 20, 73760 ostfildern
Phone : +49-711-456002-1
Fax : +49-711-456002-299
GERMANY:
HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE
Neumeyerstrasse 22-26, 90411 Nurnberg
Phone : +49-911 32 68 89 63
Fax : +49-911 32 68 89 69
GERMANY:
HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE
Bayernstr. 3, Haus C 30855 Langenhagen, Germany
Phone : +49-511 97 82 61 30
Fax : +49-511 97 82 61 35
FRANCE:
HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE
130 Avenue Joseph Kessel, Bat E, 78960
Voisins le Bretonneux, France
Phone : +33-1-85764886
Fax : +33-1-85764823
UNITED KINGDOM:
HIROSE ELECTRIC EUROPE BV (UK BRANCH)
4 Newton Court, Kelvin Drive, Knowlhill,
Milton Keynes, MK5 8NH
Phone : +44-1908 202050
Fax : +44-1908 202058
CHINA:
HIROSE ELECTRIC (CHINA) CO., LTD. (SHANGHAI, HEADQUARTERS)
18, Enterprise Center Tower 2, 209# Gong He
Road, Jing’an District, Shanghai, CHINA 200070
Phone : +86-21-6391-3355
Fax : +86-21-6391-3335
http://www.hirose.com/cn/
CHINA:
HIROSE ELECTRIC (CHINA) CO.,LTD. BEIJING BRANCH
A1001, Ocean International Center, Building 56# East 4th
Ring Middle Road, ChaoYang District, Beijing, 100025
Phone : +86-10-5165-9332
Fax : +86-10-5908-1381
CHINA:
HIROSE ELECTRIC (CHINA) CO., LTD. SHENZHEN BRANCH
Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre,
5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008
Phone : +86-755-8207-0851
Fax : +86-755-8207-0873
HONG KONG:
HIROSE ELECTRIC HONGKONG TRADING CO., LTD.
Room 1001, West Wing, Tsim Sha Tsui Centre, 66
Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong
Phone : +852-2803-5338
Fax : +852-2591-6560
http://www.hirose.com/hk/
TAIWAN:
HIROSE ELECTRIC TAIWAN CO., LTD.
103 8F, No.87, Zhengzhou Rd., Taipei
Phone : +886-2-2555-7377
Fax : +886-2-2555-7355
http://www.hirose.com/tw/
KOREA:
HIROSE KOREA CO.,LTD.
143, Gongdan 1-daero, Siheung-si,
Gyeonggi-do, 15084, Korea
Phone : +82-31-496-7000
Fax : +82-31-496-7100
http://www.hirose.co.kr/
SINGAPORE:
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE
03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C,
Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India
Singapore 079909
Phone : +91-12-660-8018
Phone : +65-6324-6113
Fax : +91-120-4804949
Fax : +65-6324-6123
http://www.hirose.com/sg/
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE
Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma
Gandhi (MG) Road, Bangalore 560 001, Karnataka, India
Phone : +91-80-4120 1907
Fax : +91-80-4120 9908
MALAYSIA:
THAILAND:
PENANG REPRESENTATIVE OFFICE
BANGKOK OFFICE (REPRESENTATIVE OFFICE)
73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn
Road, Yannawa, Sathorn, Bangkok 10120 Thailand
Lepas Penang, 11950, Malaysia
Phone : +66-2-686-1255
Phone : +604-648-5536
Fax : +66-2-686-3433
12
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 07/2018. Contents are subject to change without notice for the purpose of improvements.
