Approval Sheet
for
Power Wirewound Resistors
Fibre Glass Core & Coated & Radial
Type
PGM Series
±5% & ±10%
YAGEO CORPORATION
Headquarters: 3F, No.233-1, Pao Chiao Rd., Xindian, Taipei, Taiwan, R.O.C.
Tel: 886-2-6629-9999 Fax: 886-2-6628-8885
URL: www.yageo.com
Page-1
Rev.
Description
Issue Date
Drawn
Approved
00
issue new spec.
May 25, 2012
Feng Ye
Ken Hsu
01
Revised the letters on the maps
May 19, 2015
Feng Ye
Flora Shen
02
Marking is included
May 26, 2015
Feng Ye
Flora Shen
Description
Power Wirewound Resistors, Fibre Glass Core & Coated & Radial Type
Series
PGM
Rev.
Page-2
02
1.
PRODUCT:
Power wirewound resistors, wound on fibre glass core, have a special internal direct contact to virtually
eliminate resistance changes caused by varying , often high temperatures.
RADIAL TYPE
(PGM SERIES)
2.
PART NUMBER:
Part number of the power wirewound resistor is identified by the name, power,
tolerance, packing, temperature coefficient and resistance value.
Example:
PGM
400
J
B
0R47
(1)
(2)
(3)
(4)
(5)
(6)
Series Power Resistance Packing Temperature Resistance
Name Rating Tolerance Style
Coefficient
Value
of Resistance
(1) Style:PGM SERIES: Radial Type
(2) Power Rating: 200=2W、400=4W、500=5W、650=6.5W、800W=8W、2WS=2W、
4WS=4W、5WS=5W、65S=6.5W、8WS=8W
(3) Tolerance: J = ±5% K = ±10%
(4) Packaging Type: B = Bulk Packing
(5) Temperature Coefficient : “-“=base on spec.
(6) Resistance Value:±5% for E24 Series
±10% for E12 Series
Example:0R1, 0R47, 10R,10K ……
Page-3
3.
ELECTRICAL CHARACTERISTICS
STYLE
Power Rating at 70 ℃
PGM200
PGM2WS
2W
PGM400
PGM4WS
4W
PGM500
PGM5WS
5W
PGM650
PGM65S
6.5W
PGM800
PGM8WS
8W
P70 R
Max. Cont. Work. Voltage
Thermal resistancev (℃/W)
110
70
60
50
40
Resistance Range (Ω )
0R1~7K5
0R15~11K
0R27~20K
0R39~27K
0R47~36K
Tolerances
±10%
±10%
±10%
±10%
±10%
±5%≧0R2
±5%≧0R3
±5%≧0R47
±5%≧0R68
±5%≧0R91
Insulation Voltage (1min.)
Max. 75V
-80~+500PPM/℃
Operating Temp. Range
- 55 ℃ to + 350 ℃
4.
DERATING CURVE
5.
DIMENSIONS
Dimensions in mm
Type PGM200/400/500/650/800
5W 10K J
Marking
Page-4
Type PGM2WS/4WS/5WS/65S/8WS
Unit:mm
TYPE
L
RM
PGM200/2WS
18.2
10
PGM400/4WS
23.3
15
PGM500/5WS
33.4
25
PGM650/65S
43.5
35
PGM800/8WS
53.7
45
Unit:mm
6.
TYPE
RM Tolerance
X max.
+1.0
3.0
+0.8
1.7
Temperature Rise
Solder Joints:
Temperature Rise Curves:
Type PGM200/2WS
Type PGM400/4WS
Page-5
Type PGM500/5WS
Type PGM650/65S
Type PGM800/8WS
Page-6
7.
ENVIRONMENTAL CHARACTERISTICS
(1) Short Time Over Load Test
At 2.5 times of the rated voltage applied for 5 seconds, the resistor should be free from defects after the
resistor is released from load for about 30 minutes
Short Time Overload Voltage =
2.5 * Power Rating Resistance Value
The change of the resistance value should be within ± 2.0 %
(2) Voltage Proof on Insulation
The resistor shall be clamped in the trough of a 90° metal V Block. Apply the insulation voltage of 75V
between the terminals connected together with the block for about 60 seconds.
The resistor shall be able to withstand without breakdown or flashover.
(3) Temperature Coefficient Test
Test of resistors above room temperature 100°C ± 2°C ( Testing Temperature 115°C to 130°C ) at the
constant temperature silicon plate for over 5 minutes. Then measure the resistance value.
The Temperature Coefficient is calculated by the following equation and its value should be within the
range of requested.
Re sistor Temperature Coefficient
R
R0
t
to
R R0
1
10 6
R0
t t0
= Resistance value under the testing temperature
= Resistance value at the room temperature
= The testing temperature
= Room temperature
(4) Solderability
Immerse the specimen into the solder pot at 235 ± 5 °C for 3 ± 0.5 seconds.
At least 90% solder coverage on the termination.
(5) Solvent Resistance of Marking
The specimen into the appropriate solvent of IPA condition of ultrasonic machine for 5± 0.5 minutes.
The specimen is no deterioration of coatings and color code.
(6) Robustness of Terminations
Direct Load – Resistors shall be held by one terminal and the load shall be gradually applied in the
direction of the longitudinal axis of the resistor unit the applied load reached the requirement.
The load shall be held for 10 seconds. The load of weight shall be 4 kg (40N ).
(7) Damp Heat Steady State
Place the specimen in a test chamber at 40 °C and 93 % relative humidity. Apply the rated voltage to
the specimen at the 1.5 hours on and 0.5 hour off cycle. The total length of test is 56 days
The change of the resistance value shall be within ±2%
(8) Endurance at 70 °C
Placed in the constant temperature chamber of 70 ± 3 °C the resistor shall be connected to the lead wire
at the point of 25mm. Length with each terminal, the resistors shall be arranged not much effected
Page-7
mutually by the temperature of the resistors and the excessive ventilation shall not be performed, for 90
minutes on and 30 minutes off under this condition the rated D.C. voltage is applied continuously for
1000+48/-0 hours then left at no-load for 1hour, measured at this time the resistance value。
The change of the resistance value shall be within ± 3.0 %.
There shall be no remarkable change in the appearance and the color code shall be legible after the test.
(9) Temperature Cycling Test
The temperature cycle shown in the following table shall be repeated 5 times consecutively. The
measurement of the resistance value is done before the first cycle and after ending the fifth cycle,
leaving in the room temperature for about 1 hour。
Temperature Cycling Conditions:
Step
Temperature(°C)
Time (minute)
1
-55 ± 3
30
2
25 ± 3
10 ~ 15
3
155 ± 3
30
4
25 ± 3
10 ~ 15
The change of the resistance value shall be within ± 2 %
After the test the resistor shall be free from the electrical or mechanical damage.
(10) Resistance to Soldering Heat
The terminal lead shall be dipped into the solder pot at 260 ± 3 °C for 10 ± 1.0 seconds up to 2.5 ~ 3.5
mm.
The change of the resistance value shall be within ± 0.2 %
8.
PACKAGING
Type
Packaging
PGM200/2WS
Bulk
PGM400/4WS
Bulk
PGM500/5WS
Bulk
PGM650/65S
Bulk
PGM800/8WS
Bulk
Pieces
Pack.-Code
500
1000
500
1000
250
500
250
500
250
250
B
R
Page-8
B
B
B
B
9.
Plant Address
A.
China Dongguan Plant
7-1, Gaoli Road, Gaoli Industrial Zone
Tangxia Zhen, Dongguan, Guangdong, China
(廣東省東莞市塘廈鎮高麗工業區高麗路 7-1 號)
Tel. 86-769-8772 0275
Fax. 86-769-8772 0275 #4333
B.
China Suzhou Plant
No.158, Jinchang Road, No.1 Building of Nan Bang IND. Zone,
Mu Du New District, Suzhou, China
(江蘇省蘇州市木瀆新區金長路 158 號南濱工業區 1 號)
Tel. 86-512-66518889
Fax. 86-512-66519889
Page-9
很抱歉,暂时无法提供与“PGM400KB-3R3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+1.699391000+0.21156
