PGM4WSJB-220R
PGM4WSJB-220R
    YAGEO(国巨)
    AXIAL-D5X23.3MM
    插件电阻 - 220Ω ±5% 4W -80~+500ppm/℃
PGM4WSJB-220R 数据手册
Approval Sheet for Power Wirewound Resistors Fibre Glass Core & Coated & Radial Type PGM Series ±5% & ±10% YAGEO CORPORATION Headquarters: 3F, No.233-1, Pao Chiao Rd., Xindian, Taipei, Taiwan, R.O.C. Tel: 886-2-6629-9999 Fax: 886-2-6628-8885 URL: www.yageo.com Page-1 Rev. Description Issue Date Drawn Approved 00 issue new spec. May 25, 2012 Feng Ye Ken Hsu 01 Revised the letters on the maps May 19, 2015 Feng Ye Flora Shen 02 Marking is included May 26, 2015 Feng Ye Flora Shen Description Power Wirewound Resistors, Fibre Glass Core & Coated & Radial Type Series PGM Rev. Page-2 02 1. PRODUCT: Power wirewound resistors, wound on fibre glass core, have a special internal direct contact to virtually eliminate resistance changes caused by varying , often high temperatures. RADIAL TYPE (PGM SERIES) 2. PART NUMBER: Part number of the power wirewound resistor is identified by the name, power, tolerance, packing, temperature coefficient and resistance value. Example: PGM 400 J B - 0R47 (1) (2) (3) (4) (5) (6) Series Power Resistance Packing Temperature Resistance Name Rating Tolerance Style Coefficient Value of Resistance (1) Style:PGM SERIES: Radial Type (2) Power Rating: 200=2W、400=4W、500=5W、650=6.5W、800W=8W、2WS=2W、 4WS=4W、5WS=5W、65S=6.5W、8WS=8W (3) Tolerance: J = ±5% K = ±10% (4) Packaging Type: B = Bulk Packing (5) Temperature Coefficient : “-“=base on spec. (6) Resistance Value:±5% for E24 Series ±10% for E12 Series Example:0R1, 0R47, 10R,10K …… Page-3 3. ELECTRICAL CHARACTERISTICS STYLE Power Rating at 70 ℃ PGM200 PGM2WS 2W PGM400 PGM4WS 4W PGM500 PGM5WS 5W PGM650 PGM65S 6.5W PGM800 PGM8WS 8W P70  R Max. Cont. Work. Voltage Thermal resistancev (℃/W) 110 70 60 50 40 Resistance Range (Ω ) 0R1~7K5 0R15~11K 0R27~20K 0R39~27K 0R47~36K Tolerances ±10% ±10% ±10% ±10% ±10% ±5%≧0R2 ±5%≧0R3 ±5%≧0R47 ±5%≧0R68 ±5%≧0R91 Insulation Voltage (1min.) Temperature Coefficient Max. 75V -80~+500PPM/℃ Operating Temp. Range - 55 ℃ to + 350 ℃ 4. DERATING CURVE 5. DIMENSIONS Dimensions in mm Type PGM200/400/500/650/800 5W 10K J Marking Page-4 Type PGM2WS/4WS/5WS/65S/8WS Unit:mm TYPE L RM PGM200/2WS 18.2 10 PGM400/4WS 23.3 15 PGM500/5WS 33.4 25 PGM650/65S 43.5 35 PGM800/8WS 53.7 45 Unit:mm 6. TYPE RM Tolerance X max. PGM200/400/500/650/800 +1.0 3.0 PGM2WS/4WS/5WS/65S/8WS +0.8 1.7 Temperature Rise Solder Joints: Temperature Rise Curves: Type PGM200/2WS Type PGM400/4WS Page-5 Type PGM500/5WS Type PGM650/65S Type PGM800/8WS Page-6 7. ENVIRONMENTAL CHARACTERISTICS (1) Short Time Over Load Test At 2.5 times of the rated voltage applied for 5 seconds, the resistor should be free from defects after the resistor is released from load for about 30 minutes Short Time Overload Voltage = 2.5 * Power Rating  Resistance Value The change of the resistance value should be within ± 2.0 % (2) Voltage Proof on Insulation The resistor shall be clamped in the trough of a 90° metal V Block. Apply the insulation voltage of 75V between the terminals connected together with the block for about 60 seconds. The resistor shall be able to withstand without breakdown or flashover. (3) Temperature Coefficient Test Test of resistors above room temperature 100°C ± 2°C ( Testing Temperature 115°C to 130°C ) at the constant temperature silicon plate for over 5 minutes. Then measure the resistance value. The Temperature Coefficient is calculated by the following equation and its value should be within the range of requested. Re sistor Temperature Coefficient  R R0 t to R  R0 1   10 6 R0 t  t0 = Resistance value under the testing temperature = Resistance value at the room temperature = The testing temperature = Room temperature (4) Solderability Immerse the specimen into the solder pot at 235 ± 5 °C for 3 ± 0.5 seconds. At least 90% solder coverage on the termination. (5) Solvent Resistance of Marking The specimen into the appropriate solvent of IPA condition of ultrasonic machine for 5± 0.5 minutes. The specimen is no deterioration of coatings and color code. (6) Robustness of Terminations Direct Load – Resistors shall be held by one terminal and the load shall be gradually applied in the direction of the longitudinal axis of the resistor unit the applied load reached the requirement. The load shall be held for 10 seconds. The load of weight shall be 4 kg (40N ). (7) Damp Heat Steady State Place the specimen in a test chamber at 40 °C and 93 % relative humidity. Apply the rated voltage to the specimen at the 1.5 hours on and 0.5 hour off cycle. The total length of test is 56 days The change of the resistance value shall be within ±2% (8) Endurance at 70 °C Placed in the constant temperature chamber of 70 ± 3 °C the resistor shall be connected to the lead wire at the point of 25mm. Length with each terminal, the resistors shall be arranged not much effected Page-7 mutually by the temperature of the resistors and the excessive ventilation shall not be performed, for 90 minutes on and 30 minutes off under this condition the rated D.C. voltage is applied continuously for 1000+48/-0 hours then left at no-load for 1hour, measured at this time the resistance value。 The change of the resistance value shall be within ± 3.0 %. There shall be no remarkable change in the appearance and the color code shall be legible after the test. (9) Temperature Cycling Test The temperature cycle shown in the following table shall be repeated 5 times consecutively. The measurement of the resistance value is done before the first cycle and after ending the fifth cycle, leaving in the room temperature for about 1 hour。 Temperature Cycling Conditions: Step Temperature(°C) Time (minute) 1 -55 ± 3 30 2 25 ± 3 10 ~ 15 3 155 ± 3 30 4 25 ± 3 10 ~ 15 The change of the resistance value shall be within ± 2 % After the test the resistor shall be free from the electrical or mechanical damage. (10) Resistance to Soldering Heat The terminal lead shall be dipped into the solder pot at 260 ± 3 °C for 10 ± 1.0 seconds up to 2.5 ~ 3.5 mm. The change of the resistance value shall be within ± 0.2 % 8. PACKAGING Type Packaging PGM200/2WS Bulk PGM400/4WS Bulk PGM500/5WS Bulk PGM650/65S Bulk PGM800/8WS Bulk Pieces Pack.-Code 500 1000 500 1000 250 500 250 500 250 250 B R Page-8 B B B B 9. Plant Address A. China Dongguan Plant 7-1, Gaoli Road, Gaoli Industrial Zone Tangxia Zhen, Dongguan, Guangdong, China (廣東省東莞市塘廈鎮高麗工業區高麗路 7-1 號) Tel. 86-769-8772 0275 Fax. 86-769-8772 0275 #4333 B. China Suzhou Plant No.158, Jinchang Road, No.1 Building of Nan Bang IND. Zone, Mu Du New District, Suzhou, China (江蘇省蘇州市木瀆新區金長路 158 號南濱工業區 1 號) Tel. 86-512-66518889 Fax. 86-512-66519889 Page-9
PGM4WSJB-220R 价格&库存
很抱歉,暂时无法提供与“PGM4WSJB-220R”相匹配的价格&库存,您可以联系我们找货
