PSP400KR-220R
PSP400KR-220R
    YAGEO(国巨)
    插件,20x6.4mm
    插件电阻 220Ω ±10% 4W ±100ppm/℃
PSP400KR-220R 数据手册
Through-hole resistors Fiberglass Cement Resistors Power Wirewound & Axial Lead Type Normal & Miniature Style [ PSP Series ] FEATURES Power Rating 4W, 5W, 7W, 9W, 11W, 17W Resistance Tolerance ±5%, ±10% T.C.R 400±50ppm/°C DERATING CURVE For resistors operated in ambient temperatures above 70°C, power rating must be derated in accordance with the curve below. INTRODUCTION The PSP Series Resistors are wound on Fiberglass core. The materials used and the construction techniques ensure excellent flame resistance, arc resistance and moisture resistance as well as self-extinguishing capabilities. They will withstand the most rigorous loading test. 70 Rated Load (%) 350 °C 100 80 60 40 20 0 -50 As resistors in radio and television receivers, hazardous conditions such as smoking and redheat can be completely prevented by the proper choice of power resistors. 0 50 Ambient Temperature (°C) 100 150 200 250 300 350 DIMENSIONS Unit: mm STYLE 36±3 L 36±3 W H * * ød * 6mm, reduced solderability in this area DIMENSION Normal Miniature L W H ød PSP400 - 20±1.0 6.4±0.3 6.4±0.3 0.8±0.02 PSP500 - 25±1.0 6.4±0.3 6.4±0.3 0.8±0.02 - PSP7WS 25±1.0 9.0±0.3 9.0±0.3 0.8±0.02 PSP700 - 38±1.0 6.4±0.3 6.4±0.3 0.8±0.02 PSP900 - 38±1.0 9.0±0.3 9.0±0.3 0.8±0.02 PSP11A - 50±1.5 9.0±0.3 9.0±0.3 0.8±0.02 PSP17A - 75±2.0 9.0±0.3 9.0±0.3 0.8±0.02 61 Note: ELECTRICAL CHARACTERISTICS STYLE PSP400 PSP500 PSP7WS Power Rating at 70°C 4W 5W 7W Maximum working voltage PxR Voltage Proof on Insulation 2000V Resistance Range 0.1 Ω - 9.1K Ω Operating Temp. Range -55°C to +350°C Temperature Coefficient 400±50ppm/°C 0.15 Ω - 15K Ω PSP700 PSP900 PSP11A PSP17A 9W 11W 17W 0.51 Ω - 47K Ω 0.91 Ω - 82K Ω 0.33 Ω - 33K Ω Note: Special value is available on request ENVIRONMENTAL CHARACTERISTICS PERFORMANCE TEST TEST METHOD APPRAISE Short Time Overload IEC 60115-1 4.13 10 times rated power for 5 Sec. ±2.0%+0.05Ω Voltage Proof on Insulation IEC 60115-1 4.7 In V-Block for 60 sec., test voltage as above table No Breakdown Temperature Coefficient IEC 60115-1 4.8 Between -40°C to +155°C By type Insulation Resistance IEC 60115-1 4.6 in V-block for 60 Sec. >10,000MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of Marking IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of coatings and markings Robustness of Terminations IEC 60115-1 4.16 Direct load for 10 Sec. in the direction of the terminal leads ≥50N Periodic-pulse Overload IEC 60115-1 4.39 4 times RCWV 10,000 cycles (1 Sec. on, 25 Sec. off) ±2.0%+0.05Ω Damp Heat Steady State IEC 60115-1 4.24 40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV ±2.0%+0.05Ω Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV (or Umax., Whichever less) for 1,000 Hr. (1.5Hr.on, 0.5Hr. Off) ±3.0%+0.05Ω Temperature Cycling IEC 60115-1 4.19 -55°C  Room Temp.  +155°C  Room Temp. (5 cycles) ±2.0%+0.05Ω Resistance to Soldering Heat IEC 60115-1 4.18 260±3°C for 10±1 Sec., immersed to a point 3±0.5mm from the body ±0.2%+0.05Ω Note: RCWV(Rated Continuous Working Voltage) = Power Rating x Resistance Value or Max. working voltage listed above, whichever less. Revision: 2020
PSP400KR-220R
- 物料型号:PSP系列电阻器,包括PSP400、PSP500、PSP7WS、PSP700、PSP900、PSPIIA和PSPI7A。 - 器件简介:这些电阻器以玻璃纤维为核心缠绕制成,具有出色的防火、抗弧和防潮性能,以及自熄能力。 - 引脚分配:文档中未明确提供引脚分配信息,但提到了轴向引脚类型。 - 参数特性:包括功率等级(4W、5W、7W、9W、11W、17W)、电阻公差(±5%、±10%)、温度系数(400±50ppm/°C)。 - 功能详解:电阻器适用于无线电和电视接收器,可防止吸烟和红热等危险条件。 - 应用信息:文档中未明确提供应用信息,但提到了电阻器在无线电和电视接收器中的应用。 - 封装信息:提供了不同型号的尺寸信息,包括宽度(W)、高度(H)和外径(od)。
PSP400KR-220R 价格&库存
很抱歉,暂时无法提供与“PSP400KR-220R”相匹配的价格&库存,您可以联系我们找货
