無法顯示連結的圖像。檔案可能已移動、重新命名或刪除。請驗證連結指向正確的檔案及位置。
DATA SHEET
WIREWOUND RESISTORS
High Power
PNP V Series
±1%, ±2%, ±5%
1W to 7W
Product specification – August 16, 2021 V.0
RoHS compliant & Halogen Free
Through Hole Resistors
WireWound Resistors
Product Specification
ORDERING INFORMATION
Part number of the power wire wound resistor is identified by the series,
power rating, tolerance, packing, temperature coefficient, forming and
resistance value.
PART NUMBER
APPLICATIONS
Power applications
PNP
3WV
J
T
73-
(1)
(2)
(3)
(4)
(5)
(6)
100R
(7)
(1) SERIES
PNP Series
Home appliance
Industry
(2) POWER RATING
FEATURES
Wide resistance range
High stable performance and
high reliability
1WV = 1W
5WV = 5W
3WV = 3W
5SV = 5W
4WV = 4W
7WV = 7W
(3) TOLERANCE
F = ±1%
J = ±5%
G = ±2%
Flameproof coating equivalent
to UL-94V-0
RoHS compliant & halogen
free
(4) PACKAGING
R = Reel Pack
B = Bulk
T = Box Pack
(5) TEMPERATURE COEFFICIENT OF RESISTANCE
F=±100ppm/°C
- = Based on spec.
(6) FORMING
52- = 52.4mm
91- = 91mm
73- = 73mm
(7) RESISTANCE VALUE
E24 & E96 Series
Example:
0R1= 0.1Ω, 100R= 100Ω, 1K = 1,000Ω
www.yageo.com
Aug. 16, 2021
V.0
2
12
PNP V
WireWound Resistors
PNP V
DIMENSIONS
Unit: mm
Normal
L
ψD
H
ψd
PNP1WV
10.0± 1.0
4.3 ± 0.5
26 ± 2.0
0.8 ± 0.05
PNP3WV
13.0± 1.0
5.5 ± 0.5
34 ± 2.0
0.8 ± 0.05
PNP4WV
17.5± 1.0
6.2 ± 0.5
32 ± 2.0
0.8 ± 0.05
PNP5SV
17.5± 1.0
6.2 ± 0.5
32 ± 2.0
0.8 ± 0.05
PNP5WV
17.0± 1.0
7.5 ± 0.5
32 ± 2.0
0.8 ± 0.05
PNP7WV
25.0± 1.0
7.5 ± 0.5
38 ± 2.0
0.8 ± 0.05
DERATING CURVE
PNP1WV ~ PNP3WV
Rated Power (%)
100
80
60
40
36
200
275
200
275
Ambient Temperature (°C)
PNP4WV ~ PNP7WV
Rated Power (%)
100
80
60
40
31
www.yageo.com
Aug. 16, 2021
V.0
3
12
WireWound Resistors
PNP V
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS
PNP1WV
PNP3WV
Power Rating at 40 °C
PNP4WV
PNP5SV
PNP5WV
PNP7WV
4W
5W
5W
7W
Power Rating at 70 °C
1W
3W
Resistance Range(±1%)
0.1Ω 1KΩ
0.1Ω 2.8KΩ
0.1Ω 4.3KΩ
0.1Ω 5.1KΩ
0.1Ω 8.2KΩ
0.1Ω 10KΩ
Resistance Range(±2% & ±5%)
0.047Ω 1KΩ
0.047Ω 2.8KΩ
0.047Ω 4.3KΩ
0.047Ω 4.3KΩ
0.047Ω 6.8KΩ
0.1Ω 6KΩ
Voltage Proof on
Insulation
300V
300V
300V
300V
300V
300V
Maximum working voltage
√(P X R)
Operating Temp. Range
- 40°C to +200°C
Temperature Coefficient
±100ppm/°C, ±300ppm/°C
Note: For resistance value out of above range is by request.
TEST AND REQUIRMENTS
TEST
TEST METHOD
Short Time Overload
IEC 60115-1 4.13
10 times rated power for 5 sec.
±2%+0.05Ω
Voltage Proof on
IEC 60115-1 4.7
In V-Block for 60 sec. test voltage as
No Breakdown
Insulation
PROCEDURE
APPRAISE
above table
IEC 60115-1 4.8
Between -40°C to +155°C
By Type
Insulation Resistance
IEC 60115-1 4.6
>100MΩ
Solderability
IEC 60115-1 4.17
245±5°C for 3±0.5 Sec.
95% Min. coverage
Solvent Resistance of
IEC 60115-1 4.30
IPA for 5±0.5 Min. with ultrasonic
No deterioration of
Marking
coatings and markings
Robustness of
IEC 60115-1 4.16
Terminations
Damp Heat Steady State
Direct load for 10 Sec. in the direction of
≥2.5Kg(24.5N)
the terminal leads
IEC 60115-1 4.24
40±2°C,90-95% RH for 56 days, loaded
±5.0%+0.05Ω
with 0.1 times RCWV
Endurance at 70°C
IEC 60115-1 4.25
70±2°C at RCWV(or Umax., whichever
±5.0%+0.05Ω
less) for 1,000 Hr.(1.5 Hr.on,0.5 Hr. off)
Temperature Cycling
IEC 60115-1 4.19
-55°C
Room Temp.
±1.0%+0.05Ω
+155°C Room Temp.(5 cycles)
Resistance to Soldering
IEC 60115-1 4.18
Heat
260±3°C for 10±1 Sec., immersed to a
±1.0 %+0.05Ω
point 3±0.5mm from the body
Accidental Overload
Test
IEC 60115-1 4.26
4 times RCWV for 1 Min.
No evidence of flaming
or arcing
www.yageo.com
Aug. 16, 2021
V.0
4
12
WireWound Resistors
PNP V
Note:
RCWV (Rated Continuous Working Voltage ):
The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following
formula:
V=√(P X R)
or max. working voltage whichever is less
Where
V=Continuous rated DC or
AC (rms) working voltage (V)
P=Rated power (W)
R=Resistance value (Ω)
PULSE DIAGRAMS
PNP3WV Series: Pmax.: Maximum permissible peak pulse power
ti: Pulse duration
tp: Pulse repetition time
www.yageo.com
Aug. 16, 2021
V.0
5
12
WireWound Resistors
PNP V
PNP5WV Series: Pmax.: Maximum permissible peak pulse power
ti: Pulse duration
PNP7WV Series: Pmax.: Maximum permissible peak pulse power
ti: Pulse duration
www.yageo.com
Aug. 16, 2021
V.0
6
12
WireWound Resistors
PNP V
AXIAL / REEL TAPE SPECIFICATION
Unit: mm
Normal
a
A
B1-B2 (Max.)
S (spacing)
PNP1WV
6 ± 0.5
52.4 ± 1.5
1.2
10
73.0 ± 1.5
1.5
PNP3WV
6 ± 0.5
52.4 ± 1.5
1.2
73.0 ± 1.5
1.5
52.4 ± 1.5
1.2
73.0 ± 1.5
1.5
52.4 ± 1.5
1.2
73.0 ± 1.5
1.5
52.4 ± 1.5
1.2
91.0 ± 1.5
1.5
PNP4WV
10
6 ± 0.5
PNP5WV
6 ± 0.5
1 mm per 10 spacing,
0.5 mm per 5 spacing
10
6 ± 0.5
PNP7WV
T (max. deviation of
spacing)
10
6 ± 0.5
PNP5SV
10
10
www.yageo.com
Aug. 16, 2021
V.0
7
12
WireWound Resistors
PNP V
TAPE ON REEL PACKING
TYPE
Unit: mm/piece
Normal
Across Flange(A)
B
Quantity Per Reel
PNP1WV
66.5
75.5
2,500
PNP3WV
66.5
75.5
1,000
PNP4WV
87
96
1,000
PNP5SV
87
96
1,000
PNP5WV
87
96
500
www.yageo.com
Aug. 16, 2021
V.0
8
12
WireWound Resistors
PNP V
TAPE ON BOX PACKING
TYPE
DIMENTIONS
Normal
A
B
C
Quantity Per Box
PNP1WV
73
45
258
1,000
PNP3WV
103
94
260
1,000
PNP4WV
103
94
260
1,000
PNP5SV
103
78
260
500
PNP5WV
103
94
260
250
PNP7WV
115
70
263
250
Unit: mm/piece
BULK PACKING
Normal
Piece/Per Inner Box
Bag/Per Inner Box
Piece Per Bag
PNP1WV
5,000
5
1,000
PNP3WV
1,000
2
500
PNP4WV
1,000
2
500
PNP5SV
1,000
2
500
PNP5WV
500
10
50
PNP7WV
500
10
50
www.yageo.com
Aug. 16, 2021
V.0
9
12
WireWound Resistors
12
PNP V
MARKING
5-BAND-CODE
±2%, ±5%
COLOR
BLACK
BROWN
RED
ORANGE
YELLOW
GREEN
BLUE
VIOLET
GREY
WHITE
GOLD
SILVER
1st BAND
2nd BAND
3rd BAND
MULTIPLIER
2
3
4
5
6
7
8
9
2
3
4
5
6
7
8
9
2
3
4
5
6
7
8
9
1Ω
10Ω
100Ω
1KΩ
10KΩ
100K
1MΩ
10MΩ
0.001Ω
0.0001Ω
0.1Ω
0.01Ω
TOLERANCE
SPECIAL CODE
± 1%(F)
± 2%(G)
PNP V Series
± 5%(J)
±1%
6-BAND-CODE
www.yageo.com
Aug. 16, 2021
V.0
10
WireWound Resistors
12
PNP V
REVISION HISTORY
REVISION
DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 0
Aug.2, 2021
- First issue of this specification
“ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as
the products itse lf are unchanged. Any product change will be announced by PCN.”
www.yageo.com
Aug. 16, 2021
V.0
11
WireWound Resistors
12
PNP V
LEGAL DISCLAIMER
Yageo, its distributors and agents (collectively, “Yageo”), hereby disclaims any and all liabilities for any errors,
inaccuracies or incompleteness contained in any product related information, including but not limited to product
specifications, datasheets, pictures and/or graphics. Yageo may make changes, modifications and/or
improvements to product related information at any time and without notice.
Yageo makes no representation, warranty, and/or guarantee about the fitness of its products for any particular
purpose or the continuing production of any of its products. To the maximum extent permitted by law, Yageo
disclaims (i) any and all liability arising out of the application or use of any Yageo product, (ii) any and all liability,
including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties,
including warranties of fitness for a particular purpose, non-infringement and merchantability.
Yageo statements regarding the suitability of products for certain types of applications are based on Yageo’s
knowledge of typical operating conditions for such types of applications in a generic nature. Such statements are
neither binding statements of Yageo nor intended to constitute any warranty concerning the suitability for a
specific customer application or use. They are intended for use only by customers with requisite knowledge and
experience for determining whether Yageo products are the correct products for their application or use. In
addition, unpredicatable and isolated cases of product failure may still occur, therefore, customer application or
use of Yageo products which requires higher degree of reliability or safety, shall employ additional protective
safeguard measures to ensure that product failure would not result in personal injury or property damage.
Yageo products are not designed for application or use in medical, life-saving, or life-sustaining devices or for
any other application or use in which the failure of Yageo products could result in personal injury or death.
Customers using or selling Yageo products not expressly indicated for above-mentioned purposes shall do so at
their own risk and agree to fully indemnify Yageo and hold Yageo harmless.
Information provided here is intended to indicate product specifications only. Yageo reserves all the rights for revising this
content without further notification, as long as products are unchanged. Any product change will be announced by PCN.
www.yageo.com
Aug. 16, 2021
V.0
12
