NJU7222L2-30
NJU7222L2-30
    JRC(⽇本无线)
    TO-92-3
    IC REG LDO 3V 0.1A TO92-3
NJU7222L2-30 数据手册
NJU7222 Series HIGH PRECISION AND HIGH OUTPUT CURRENT C-MOS 3-TERMINAL VOLTAGE REGULATOR PRELIMINARY ■ GENERAL DESCRIPTION The NJU7222 series is a high precision output voltage (±2%) and high output current C-MOS 3-terminal positive voltage regulator which contains internal accurate voltage reference, error amplifier, control transistor, output voltage setting resistor and short current protection circuit. The regulation voltage is fixed by internal circuits and the following line-up of different output voltage versions are available. The short current protection circuit prevents destruction of a element by careless great current output in short circuit. The NJU7222 series is suitable for battery operated items and battery back-up systems because of low operating current and low dropout voltage. ■ PACKAGE OUTLINE ■ FEATURES • High Precision Output Voltage ±2% • High Output Current IO = 100mA • Low Operating Current 20µA typ • Low Dropout Voltage ∆VIO < 0.6V @IO = 100mA • Wide Operating Voltage Range • Small Temperature Coefficient of Output Voltage • Short Current Protection Circuit • Package Outline TO-92/SOT-89 • C-MOS Technology ■ TERMINAL DESCRIPTION No. Description 1 GND 2 Input 3 Output NJU7222L NJU7222U ■ OUTPUT VOLTAGE LINE-UP Output Voltage TO-92 Type SOT-89 Type +3.0V NJU7222L30 NJU7222U30 +3.3V NJU7222L33 NJU7222U33 +5.0V NJU7222L50 NJU7222U50 Note1) The SOT-89 type name is different from the marking, so it refer to attached paper correspondence table. ■ EQUIVALENT CIRCUIT Ver.2003-07-18 -1- NJU7222 Series ■ ABSOLUTE MAXIMUM RATINGS PARAMETER Input Voltage (Ta = 25ºC) SYMBOL RATINGS UNIT VIN 15 V Output Voltage VOUT GND-0.3 to VIN+0.3 V Output Current IOUT 200 mA Power Dissipation PD Operating Temperature Range Topr -25 to + 75 ºC Storage Temperature Range Tstg -40 to +125 ºC 500 (TO-92) 300 (SOT-89) mW ■ ELECTRICAL CHARACTERISTICS +3.0V Version PARAMETER Output Voltage Dropout Voltage Input Voltage Operating Current Load Regulation Line Regulation (CIN = CO = 0.1µF, Ta = 25°C) SYMBOL VOUT ∆VIO VIN IDD1 ∆VOUT ∆IOUT CONDITION VIN = 5.0V, IOUT = 70mA IOUT = 50mA VIN = 5.0V VIN = 5.0V, IOUT = 1 to 100mA ∆VOUT VIN = 4.0 to 12.0V ∆VIN ⋅ VOUT MIN. TYP. MAX. UNIT 2.85 - 3.00 0.4 20 3.15 0.6 14 30 V V V µA - 120 160 mV - 0.1 - %/V +3.3V Version PARAMETER Output Voltage Dropout Voltage Input Voltage Operating Current Load Regulation Line Regulation (CIN = CO = 0.1µF, Ta = 25°C) SYMBOL VOUT ∆VIO VIN IDD1 ∆VOUT ∆IOUT CONDITION VIN = 5.3V, IOUT = 70mA IOUT = 50mA VIN = 5.3V VIN = 5.3V, IOUT = 1 to 100mA ∆VOUT VIN = 4.3 to 12.0V ∆VIN ⋅ VOUT MIN. TYP. MAX. UNIT 3.135 - 3.300 0.4 20 3.465 0.6 14 30 V V V µA - 120 160 mV - 0.1 - %/V +5.0V Version PARAMETER Output Voltage Dropout Voltage Input Voltage Operating Current Load Regulation Line Regulation (CIN = CO = 0.1µF, Ta = 25°C) SYMBOL VOUT ∆VIO VIN IDD1 ∆VOUT ∆IOUT CONDITION VIN = 7.0V, IOUT = 70mA IOUT = 100mA VIN = 7.0V VIN = 7.0V, IOUT = 1 to 100mA ∆VOUT VIN = 6.0 to 12.0V ∆VIN ⋅ VOUT MIN. TYP. MAX. UNIT 4.75 - 5.00 0.3 20 5.25 0.6 14 30 V V V µA - 120 160 mV - 0.1 - %/V ■ MEASUREMENT CIRCUIT [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. -2- Ver.2003-07-18
NJU7222L2-30 价格&库存
很抱歉,暂时无法提供与“NJU7222L2-30”相匹配的价格&库存,您可以联系我们找货
