MPR Series
Stackpole Electronics, Inc.
Flameproof Metal Plate Resistor
Resistive Product Solutions
Features:
Small size with high power ratio
Low resistance values and low inductance
Crimped leads keep circuit board temperatures cooler
100% RoHS compliant and lead free without exemption
Halogen free
REACH compliant
Electrical Specifications
Type / Code
Power Rating (W)
@ 70ºC
Maximum
Working
Voltage (V)
MPR3
MPR5
3
5
350
Maximum
Overload
Voltage (V)
TCR (ppm/ºC)
700
± 350
Ohmic Range (Ω) and Tolerance
5%, 10%
0.01 - 0.47
Mechanical Specifications
L
Type / Code
MPR3
MPR5
0.551
14.00
0.551
14.00
W
0.059
1.50
0.059
1.50
0.197
5.00
0.197
5.00
H
0.039
1.00
0.039
1.00
0.394
10.00
0.709
18.00
d
0.039
1.00
0.039
1.00
0.031
0.80
0.031
0.80
P
0.004
0.10
0.004
0.10
0.394
10.00
0.394
10.00
Unit
0.039
1.00
0.039
1.00
inches
mm
inches
mm
Performance Characteristics
Test
Short Time Overload
Dielectric Withstanding Voltage
Thermal Shock
Temperature Coefficient
Load Life
Load Life with Humidity
Operating temperature range is -55°C to 275°C
Test Limit
ΔR ≤ (2% Ro + 0.05Ω)
500V
± 350 ppm/ºC
ΔR ≤ (3% Ro + 0.05Ω)
Test Method (JIS C 5201-1)
2.5X, 5 seconds
5.7
4.19
4.8
4.25
4.23
Power Derating Curve:
Rev Date: 12/03/2020
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
1
www.seielect.com
marketing@seielect.com
MPR Series
Load Factor:
Recommended Solder Profile
This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should
be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board
density, geometry, packages used, etc., especially those cells labeled with “*”.
100% Matte Tin / RoHS Compliant Terminations
Soldering iron recommended temperatures: 330°C to 350°C with minimum duration.
Maximum number of reflow cycles: 3.
Wave Soldering
Description
Maximum
Recommended
Preheat Time
80 seconds
70 seconds
Temperature Diff.
140°C
120°C
Solder Temp.
260°C
250°C
Dwell Time at Max.
10 seconds
5 seconds
Ramp DN (°C/sec)
N/A
N/A
Temperature Diff. = Defference between final preheat stage and soldering stage.
Minimum
60 seconds
100°C
240°C
N/A
Convection IR Reflow
Description
Maximum
Recommended
Minimum
Ramp Up (°C/sec)
Dwell Time > 217°C
Solder Temp.
Dwell Time at Max.
Ramp DN (°C/sec)
3°C/sec
150 seconds
260°C
30 seconds
6°C/sec
2°C/sec
90 seconds
245°C
15 seconds
3°C/sec
60 seconds
10 seconds
2
www.seielect.com
MPR Series
Recommended Lead Free Resistor Reflow Profile
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
MPR
Description
Package /
Termination
Type
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
Flameproof Rectangular Type
Radial
Special
YES
100% Matte Sn
Always
Always
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
3
www.seielect.com
MPR Series
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
M
Product Series
Flameproof
MPR
Metal Plate
P
R
Power Rating
Size
W
3
3
5
5
3
Tolerance
Code
Tol
J
5%
K
10%
J
B
Code
B
4
1
Packaging
Description
Size
Bulk
All Sizes
L
Quantity
2000
Resistance Value
Four characters with the
multiplier used as the
decimal holder.
"L" used as multiplier of
10-3 for any value
under 0.1 ohm.
0.01 ohm = 10L0
0.1 ohm = R100
0.47 ohm = R470
www.seielect.com
很抱歉,暂时无法提供与“MPR5JB25L0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2000+3.818852000+0.49233
