Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/05/2022
page 1 of 3
SERIES: HSS-B20-01 | DESCRIPTION: HEAT SINK
FEATURES
• TO-220 package
• available with and without solder pin
• slide in style for easy component attachment
• black anodized finish
MODEL
solder pin
orientation
thermal resistance1
length
(mm)
power
dissipation1
@ 75°C ΔT, nat
conv (°C/W)
@ 1 W,
nat conv
(°C/W)
@ 1 W,
200 LFM
(°C/W)
@ 1 W,
400 LFM
(°C/W)
@ 75°C ΔT, nat
conv
(W)
HSS-B20-061H
horizontal
6.1
18.63
23.05
5.01
4.01
4.02
HSS-B20-0953H
horizontal
9.53
18.63
23.05
5.01
4.01
4.02
HSS-B20-065V
vertical
6.5
18.63
23.05
5.01
4.01
4.02
HSS-B20-NP
no pin
18.63
23.05
5.01
4.01
4.02
Note:
1. See performance curves for full thermal resistance details.
PERFORMANCE CURVES
100
Power
(W)
Natural
Conv.
200 LFM
23.05
5.01
4.01
2
42.19
9.68
7.89
3
57.90
14.39
11.64
400 LFM
4
74.85
18.96
15.57
5
88.08
23.63
19.26
Ths: “hot spot” temperature measured on the heatsink
Ta: ambient temperature
Mounting Surface Temperature
Rise Above Ambient (°C)
Heatsink Temperature Rise Above
Ambient (ΔT = Ths - Ta) (°C)
Without Airflow
90
200 LFM
80
400 LFM
70
60
50
40
30
2
3
Heat Dissipated (W)
cuidevices.com
4
5
Product Page
3D Model
PCB Footprint
CUI DEVICES | SERIES: HSS-B20-01 | DESCRIPTION: HEAT SINK
date 08/05/2022 | page 2 of 3
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
MATERIAL
AL5052
FINISH
black anodized
THICKNESS
0.8 mm
PIN MATERIAL
brass
PIN PLATING
tin
WEIGHT
HSS-B20-061H: 3.1 g
HSS-B20-0953H: 3.1 g
HSS-B20-065V: 3.1 g
HSS-B20-NP: 3.0 g
HSS-B20-061H
HSS-B20-0953H
HSS-B20-065V
HSS-B20-NP
cuidevices.com
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
03/29/2017
1.01
brand update
02/11/2020
logo, datasheet style update
08/05/2022
1.02
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“HSS-B20-NP”相匹配的价格&库存,您可以联系我们找货
