MDF7C-26DP-2.54DSA(55)
    HRS(广濑)
    CONN HDR 26POS 2.54MM
MDF7C-26DP-2.54DSA(55) 数据手册
2.54mm Pitch Bottom Entry Type Connector MDF7 Series Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Board to Board size Freely settable Fig.1 Features 1. Board to Board Size Freely Settable The board to board size can be set at infinite stages, according to the header pin through type structure and the diverse header variation. The board to board size can be set at infinite stages. 2. Integrity of Parts Mounted Surface The parts mounted surface on two boards aren't face each other, and can be oriented in the same direction. 3. Wide Variation Single-row product, double-row product, tin plated and gold plated products are lined up. In addition, the header to correspond to the board to board size are prepared. Concerning board to board size, other products can be provided, in addition to products in this catalog. Please contact HRS company as required. In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2018.3③ 1 MDF7 Series●2.54mm Pitch Bottom Entry Type Connector Product Specifications Operating Temperature Range : -35ç to +85ç (Note 1) Storage Temperature Range : -10ç to +60ç (Note 2) Current rating : 3A Rating Voltage rating : 250V AC Operating Humidity Range : 40% to 80% Storage Humidity Range : 40% to 70% (Note 2) Item 1. Insulation Resistance Specification Condition 1000Mø min. 500V DC 2. Withstanding voltage No flashover or insulation breakdown. 650V AC/1 minute Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3. Contact Resistance 30mø max. 4. Single Insertion/Extraction MIN 0.4N (40gf), MAX 4.4N (450gf) Force 100mA 5. Vibration No electrical discontinuity of 10µs or more 6. Humidity (Steady state) Contact resistance : 30mø max. 7. Temperature Cycle Contact resistance : 30mø max. Insulation resistance : 1000Mø min. 8. Durability (Mating/un-mating) 9. Resistance to Soldering heat Measured by the square steel pin with 0.635±0.002mm Frequency : 10 to 55Hz, single amplitude of 0.75mm, 2 hours in each of the 3 directions. 96 hours at temperature of (-55ç : 30 minutes, 5 to 35ç : 10 minutes 85ç : 30 minutes, 5 to 35ç : 10 minutes) 5cycles Tin plating : 30 cycles Gold plating : 50 cycles Flow : 260ç for 10 seconds Manual soldering : 350ç for 3 seconds Contact resistance : 30mø max. No deformation of components affecting performance. Note 1 : Includes temperature rise caused by current flow. Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Material / Finish Product Receptacle Pin Header Part Insulator Material Polyamide Contact Phosphor bronze Insulator PBT Contact Brass Finish Black Remarks Tin plated or gold plated ––––––– Main unit : Black/Locator : Gray UL94V-0 Tin plated or gold plated ––––––– ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. MDF7 q - * S - 2.54 DSA (**) w e q Series Name : MDF7 w Number of contacts: 3 to 46 e Connector Type S : Single row receptacle D : Double row receptacle P : Single row pin header DP: Double row pin header r Contact Pitch : 2.54mm t Contact type DSA : Straight through hole DS : Right Angle through hole 2 r t y y Receptacle (95) : Tin plated (100 pcs/pack) (96) : Gold plated (100 pcs/pack) Pin Header P (55) : Tin plated (100 pcs/pack) (01) : Gold plated (100 pcs/pack) DP (55) : Tin plated (100 pcs/pack) Blank : Gold plated (100 pcs/pack) UL94V-0 MDF7 Series●2.54mm Pitch Bottom Entry Type Connector Single Row Receptacle [Specific No.] (* *), * * (95) : Tin plated (96) : Gold plated A±0.5 1.5±0.2 B±0.3 3±0.3 5±0.3 3±0.2 7.5±0.3 P=2.54±0.15 0.76±0.1 0.2±0.1 Part No. HRS No. MDF7-3S-2.54DSA(**) MDF7-5S-2.54DSA(**) MDF7-6S-2.54DSA(**) MDF7-7S-2.54DSA(**) MDF7-8S-2.54DSA(**) MDF7-9S-2.54DSA(**) MDF7-10S-2.54DSA(**) MDF7-11S-2.54DSA(**) MDF7-12S-2.54DSA(**) MDF7-13S-2.54DSA(**) MDF7-14S-2.54DSA(**) 547-0355-0 ** 547-0112-9 ** 547-0129-1 ** 547-0135-4 ** 547-0136-7 ** 547-0137-0 ** 547-0038-8 ** 547-0138-2 ** 547-0040-0 ** 547-0139-5 ** 547-0140-4 ** A B 7.62 12.70 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 RoHS 5.08 10.16 12.70 15.24 17.78 20.32 Yes 22.86 25.40 27.94 30.48 33.02 Part No. HRS No. MDF7-15S-2.54DSA(**) MDF7-16S-2.54DSA(**) MDF7-17S-2.54DSA(**) MDF7-18S-2.54DSA(**) MDF7-19S-2.54DSA(**) MDF7-20S-2.54DSA(**) MDF7-21S-2.54DSA(**) MDF7-22S-2.54DSA(**) MDF7-23S-2.54DSA(**) MDF7-24S-2.54DSA(**) MDF7-25S-2.54DSA(**) 547-0012-4 ** 547-0141-7 ** 547-0142-0 ** 547-0013-7 ** 547-0143-2 ** 547-0051-6 ** 547-0144-5 ** 547-0145-8 ** 547-0146-0 ** 547-0147-3 ** 547-0014-0 ** No. of Contacts 15 16 17 18 19 20 21 22 23 24 25 A 38.10 40.64 43.18 45.72 48.26 50.80 53.34 55.88 58.42 60.96 63.50 B RoHS 35.56 38.10 40.64 43.18 45.72 48.26 Yes 50.80 53.34 55.88 58.42 60.96 Note : The quantity for delivery is determined 100 pcs/pack. Please order the products per pack. A±0.5 B±0.3 P=2.54±0.15 5±0.3 10±0.3 2.54±0.15 Double Row Receptacle 3±0.3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit : mm No. of Contacts 3 5 6 7 8 9 10 11 12 13 14 0.76±0.1 0.2±0.1 8.54±0.4 Unit : mm No. of [Specific No.] (* *), * * A B RoHS Part No. HRS No. Contacts (95) : Tin plated MDF7-12D-2.54DSA(**) 547-0032-1 ** 12 15.24 12.70 (96) : Gold plated MDF7-14D-2.54DSA(**) 547-0354-8 ** 14 17.78 15.24 MDF7-16D-2.54DSA(**) 547-0363-9 ** 16 20.32 17.78 MDF7-20D-2.54DSA(**) 547-0033-4 ** 20 25.40 22.86 MDF7-22D-2.54DSA(**) 547-0246-5 ** 22 27.94 25.40 Yes MDF7-24D-2.54DSA(**) 547-0244-0 ** 24 30.48 27.94 MDF7-26D-2.54DSA(**) 547-0247-8 ** 26 33.02 30.48 MDF7-30D-2.54DSA(**) 547-0016-5 ** 30 38.10 35.56 MDF7-34D-2.54DSA(**) 547-0227-0 ** 34 43.18 40.64 Note 1 : A quantity for delivery is determined 100 pcs/pack. Please order the products per pack. 3 MDF7 Series●2.54mm Pitch Bottom Entry Type Connector Single Row Straight Pin Header [Specific No.] (* *), * * (55) : Tin plated (01) : Gold plated 2.54±0.3 0.5±0.2 2.54±0.2 C±0.3 □0.64±0.1 [without locator] MDF7 (PCB distance : 2.54 to 5.5mm) A±0.5 B±0.3 P=2.54±0.15 3±0.3 0.5±0.2 C±0.3 3±0.3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Board Through-hole Diameter : Ø1.0++0.1 0 2.54±0.2 2.54±0.3 A±0.5 B±0.3 P=2.54±0.15 □0.64±0.1 [with locator] MDF7B (PCB distance : 2.54 to 12mm) Unit : mm Unit : mm HRS No. No. of Contacts MDF7-3P-2.54DSA(**) 547-0220-1 ** 3 7.62 5.08 MDF7B-3P-2.54DSA(**) 547-0304-0 ** 3 7.62 5.08 MDF7-5P-2.54DSA(**) 547-0113-1 ** 5 12.70 10.16 MDF7B-5P-2.54DSA(**) 547-0133-9 ** 5 12.70 10.16 MDF7-6P-2.54DSA(**) 547-0130-0 ** 6 15.24 12.70 MDF7B-6P-2.54DSA(**) 547-0131-3 ** 6 15.24 12.70 MDF7-7P-2.54DSA(**) 547-0148-6 ** 7 17.78 15.24 MDF7B-7P-2.54DSA(**) 547-0177-4 ** 7 17.78 15.24 MDF7-8P-2.54DSA(**) 547-0149-9 ** 8 20.32 17.78 MDF7B-8P-2.54DSA(**) 547-0178-7 ** 8 20.32 17.78 MDF7-9P-2.54DSA(**) 547-0150-8 ** 9 22.86 20.32 MDF7B-9P-2.54DSA(**) 547-0179-0 ** 9 22.86 20.32 MDF7-10P-2.54DSA(**) 547-0039-0 ** 10 25.40 22.86 MDF7B-10P-2.54DSA(**) 547-0048-1 ** 10 25.40 22.86 MDF7-11P-2.54DSA(**) 547-0151-0 ** 11 27.94 25.40 MDF7B-11P-2.54DSA(**) 547-0047-9 ** 11 27.94 25.40 MDF7-12P-2.54DSA(**) 547-0043-8 ** 12 30.48 27.94 MDF7B-12P-2.54DSA(**) 547-0041-2 ** 12 30.48 27.94 MDF7-13P-2.54DSA(**) 547-0152-3 ** 13 33.02 30.48 MDF7B-13P-2.54DSA(55) 547-0180-9 55 13 33.02 30.48 MDF7-14P-2.54DSA(**) 547-0153-6 ** 14 35.56 33.02 MDF7B-14P-2.54DSA(55) 547-0181-1 55 14 35.56 33.02 MDF7-15P-2.54DSA(**) 547-0018-0 ** 15 38.10 35.56 MDF7B-15P-2.54DSA(**) 547-0024-3 ** 15 38.10 35.56 MDF7-16P-2.54DSA(**) 547-0111-6 ** 16 40.64 38.10 MDF7B-16P-2.54DSA(**) 547-0182-4 ** 16 40.64 38.10 MDF7-17P-2.54DSA(**) 547-0154-9 ** 17 43.18 40.64 MDF7B-17P-2.54DSA(55) 547-0183-7 55 17 43.18 40.64 MDF7-18P-2.54DSA(**) 547-0022-8 ** 18 45.72 43.18 MDF7B-18P-2.54DSA(55) 547-0025-6 55 18 45.72 43.18 MDF7-19P-2.54DSA(**) 547-0155-1 ** 19 48.26 45.72 MDF7B-19P-2.54DSA(55) 547-0184-0 55 19 48.26 45.72 MDF7-20P-2.54DSA(**) 547-0123-5 ** 20 50.80 48.26 MDF7B-20P-2.54DSA(**) 547-0052-9 ** 20 50.80 48.26 MDF7-21P-2.54DSA(**) 547-0156-4 ** 21 53.34 50.80 MDF7B-21P-2.54DSA(55) 547-0185-2 55 21 53.34 50.80 MDF7-22P-2.54DSA(**) 547-0157-7 ** 22 55.88 53.34 MDF7B-22P-2.54DSA(55) 547-0186-5 55 22 55.88 53.34 MDF7-23P-2.54DSA(**) 547-0158-0 ** 23 58.42 55.88 MDF7B-23P-2.54DSA(55) 547-0066-3 55 23 58.42 55.88 MDF7-24P-2.54DSA(**) 547-0159-2 ** 24 60.96 58.42 MDF7B-24P-2.54DSA(55) 547-0067-6 55 24 60.96 58.42 MDF7-25P-2.54DSA(**) 547-0023-0 ** 25 63.50 60.96 MDF7B-25P-2.54DSA(55) 547-0026-9 55 25 63.50 60.96 Part No. A B C RoHS 10 Yes Part No. HRS No. No. of Contacts Note 1 : PCB distance in the above table represents the case where the 1.6mm thickness board is used. Note 2 : The quantity for delivery is determined 100 pcs/pack. Please order the products per pack. 4 A B C RoHS 16.46 Yes MDF7 Series●2.54mm Pitch Bottom Entry Type Connector MDF7P (PCB distance : 2.54 to 8mm) MDF7C (PCB distance : 5.08 to 15mm, with Locator) Unit : mm Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HRS No. No. of A B Contacts 3 7.62 5.08 C RoHS Unit : mm Part No. HRS No. MDF7C-3P-2.54DSA(**) 547-0489-7 ** No. of A B Contacts 3 7.62 5.08 MDF7P-3P-2.54DSA(01) 547-0462-0 01 MDF7P-5P-2.54DSA(**) 547-0511-4 ** 5 12.70 10.16 MDF7C-5P-2.54DSA(**) 547-0344-4 ** 5 12.70 10.16 MDF7P-6P-2.54DSA(**) 547-0513-0 ** 6 15.24 12.70 MDF7C-6P-2.54DSA(55) 547-0268-8 55 6 15.24 12.70 MDF7P-7P-2.54DSA(**) ––––––– 7 17.78 15.24 MDF7C-7P-2.54DSA(**) 547-0378-6 ** 7 17.78 15.24 MDF7P-8P-2.54DSA(55) 547-0514-2 55 8 20.32 17.78 MDF7C-8P-2.54DSA(55) 547-0375-8 55 8 20.32 17.78 MDF7P-9P-2.54DSA(**) ––––––– 9 22.86 20.32 MDF7C-9P-2.54DSA(55) 547-0506-4 55 9 22.86 20.32 MDF7P-10P-2.54DSA(55) 547-0360-0 55 10 25.40 22.86 MDF7C-10P-2.54DSA(55) 547-0191-5 55 10 25.40 22.86 MDF7P-11P-2.54DSA(**) 11 27.94 25.40 MDF7C-11P-2.54DSA(55) 547-0376-0 55 11 27.97 25.40 MDF7P-12P-2.54DSA(55) 547-0345-7 55 ––––––– 12 30.48 27.94 MDF7C-12P-2.54DSA(**) 547-0475-2 ** 12 30.48 27.94 MDF7P-13P-2.54DSA(**) 13 33.02 30.48 MDF7C-13P-2.54DSA(55) 547-0401-6 55 13 33.02 30.48 MDF7P-14P-2.54DSA(55) 547-0385-1 55 ––––––– 14 35.56 33.02 MDF7C-14P-2.54DSA(55) 547-0380-8 55 14 35.56 33.02 MDF7P-15P-2.54DSA(55) 547-0230-5 55 15 38.10 35.56 MDF7C-15P-2.54DSA(55) 547-0187-8 55 15 38.10 35.56 MDF7P-16P-2.54DSA(55) 547-0346-0 55 16 40.64 38.10 MDF7C-16P-2.54DSA(**) ––––––– 16 40.64 38.10 MDF7P-17P-2.54DSA(**) ––––––– 17 43.18 40.46 MDF7C-17P-2.54DSA(**) ––––––– 17 43.18 40.64 MDF7P-18P-2.54DSA(**) ––––––– 12.5 Yes 18 45.72 43.18 MDF7C-18P-2.54DSA(55) 547-0029-7 55 18 45.72 43.18 MDF7P-19P-2.54DSA(55) 547-0347-2 55 19 48.26 45.72 MDF7C-19P-2.54DSA(55) 547-0361-3 55 19 48.26 45.72 MDF7P-20P-2.54DSA(**) ––––––– 20 50.80 48.26 MDF7C-20P-2.54DSA(**) 547-0198-4 ** 20 50.80 48.26 MDF7P-21P-2.54DSA(**) ––––––– 21 53.34 50.80 MDF7C-21P-2.54DSA(**) ––––––– 21 53.34 50.80 MDF7P-22P-2.54DSA(**) ––––––– 22 55.88 53.34 MDF7C-22P-2.54DSA(**) ––––––– 22 55.88 53.34 MDF7P-23P-2.54DSA(**) ––––––– 23 58.42 55.88 MDF7C-23P-2.54DSA(55) 547-0909-0 55 23 58.42 55.88 MDF7P-24P-2.54DSA(**) ––––––– 24 60.96 58.42 MDF7C-24P-2.54DSA(**) 24 60.96 58.42 25 63.50 60.96 MDF7C-25P-2.54DSA(55) 547-0305-2 55 25 63.50 60.96 MDF7P-25P-2.54DSA(55) 547-0348-5 55 ––––––– C RoHS 19.46 Yes Note 1 : PCB distance in the above table represents the case where the 1.6mm thickness board is used. Note 2 : A quantity for delivery is determined 100 pcs/pack. Please order the products per pack. Note 3 : As for the products, which HRS No. is not indicated in the above table, we will correspond to samples, and massproduction according to your demand. Please contact our account executive, as required. 5 MDF7 Series●2.54mm Pitch Bottom Entry Type Connector A±0.5 B±0.5 P=2.54±0.25 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4±0.3 ●Board Through-hole Diameter : Ø1.0++0.1 0 0.5±0.2 0.5±0.2 12.2±0.5 7.43±0.5 3.3±0.3 (7.3) 4±0.2 Single-Row Right Angle Pin Header [Specific No.] (* *), * * (55) : Tin plated (56) : Gold plated □0.64±0.1 Unit : mm Part No. HRS No. MDF7-5P-2.54DS(**) MDF7-6P-2.54DS(**) MDF7-7P-2.54DS(**) MDF7-8P-2.54DS(**) MDF7-9P-2.54DS(**) MDF7-10P-2.54DS(**) MDF7-11P-2.54DS(**) MDF7-12P-2.54DS(**) MDF7-13P-2.54DS(**) MDF7-14P-2.54DS(**) MDF7-15P-2.54DS(**) 547-0160-1 ** 547-0161-4 ** 547-0162-7 ** 547-0163-0 ** 547-0164-2 ** 547-0165-5 ** 547-0166-8 ** 547-0116-0 ** 547-0167-0 ** 547-0168-3 ** 547-0027-1 ** No. of Contacts 5 6 7 8 9 10 11 12 13 14 15 A 12.70 15.24 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 B RoHS Part No. HRS No. 10.16 MDF7-16P-2.54DS(**) 547-0169-6 ** 12.70 MDF7-17P-2.54DS(**) 547-0170-5 ** 15.24 MDF7-18P-2.54DS(**) 547-0019-3 ** 17.78 MDF7-19P-2.54DS(**) 547-0171-8 ** 20.32 MD7F-20P-2.54DS(**) 547-0172-0 ** 22.86 Yes MDF7-21P-2.54DS(**) 547-0173-3 ** MDF7-22P-2.54DS(**) 547-0174-6 ** 25.40 27.94 MDF7-23P-2.54DS(**) 547-0175-9 ** 30.48 MDF7-24P-2.54DS(**) 547-0176-1 ** 33.02 MDF7-25P-2.54DS(**) 547-0028-4 ** 35.56 No. of Contacts 16 17 18 19 20 21 22 23 24 25 A 40.64 43.18 45.72 48.26 50.80 53.34 55.88 58.42 60.96 63.50 B RoHS 38.10 40.64 43.18 45.72 48.26 Yes 50.80 53.34 55.88 58.42 60.96 Note : A quantity for delivery is determined 100 pcs/pack. Please order the products per pack. Application Pattern and PCB mounting pattern When the single-row straight pin header is used When the header with locator is used The locator moves as the connector is inserted. When the PCB distance is set to MAX To separate clearance between the boards, the operation limit t is defined as the state where the male pin has passed through the receptacle. 6 When the right angle pin header is used MDF7 Series●2.54mm Pitch Bottom Entry Type Connector A±0.5 B±0.3 P=2.54±0.15 3±0.3 0.5±0.2 C±0.3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Board Through-hole Diameter : Ø1.0++0.1 0 2.54±0.2 5.08±0.3 2.54±0.15 Double-Row Straight Pin Header MDF7 (PCB distance : 2.54 to 5.5mm) [Specific No.] (* *), * * (55) : Tin plated Blank : Gold plated □0.64±0.1 MDF7P (PCB distance : 2.54 to 8mm) Unit : mm Part No. HRS No. MDF7-12DP-2.54DSA(**) MDF7-14DP-2.54DSA(**) MDF7-16DP-2.54DSA(**) MDF7-20DP-2.54DSA(**) MDF7-22DP-2.54DSA(**) MDF7-24DP-2.54DSA(**) MDF7-26DP-2.54DSA(**) MDF7-30DP-2.54DSA(**) MDF7-34DP-2.54DSA(**) 547-0034-7 ** 547-0365-4 ** 547-0364-1 ** 547-0114-4 ** 547-0093-6 ** 547-0250-2 ** 547-0251-5 ** 547-0037-5 ** 547-0252-8 ** No. of Contacts 12 14 16 20 22 24 26 30 34 A 15.24 17.78 20.32 25.40 27.94 30.48 33.02 38.10 43.18 B C RoHS 12.70 15.24 17.78 22.86 25.40 10 Yes 27.94 30.48 35.56 40.64 Unit : mm Part No. MDF7P-12DP-2.54DSA(**) MDF7P-14DP-2.54DSA(**) MDF7P-16DP-2.54DSA(55) MDF7P-20DP-2.54DSA(55) MDF7P-22DP-2.54DSA(55) MDF7P-24DP-2.54DSA(**) MDF7P-26DP-2.54DSA(**) MDF7P-30DP-2.54DSA(55) MDF7P-34DP-2.54DSA(**) No. of HRS No. Contacts 547-0407-2 ** 12 ––––––– 14 547-0367-0 55 16 547-0260-6 55 20 547-0261-9 55 22 547-0262-1 ** 24 547-0263-4 ** 26 547-0264-7 55 30 ––––––– 34 A B C RoHS 15.24 12.70 17.78 15.24 20.32 17.78 25.40 22.86 27.94 25.40 12.5 Yes 30.48 27.94 33.02 30.48 38.10 35.56 43.18 40.64 Note 1 : PCB distance in the above table represents the state where the 1.6mm thickness board is used. Note 2 : A quantity for delivery is determined 100 pcs/pack. Please order the products per pack. Note 3 : As for the products, which HRS No. is not indicated in the above table, we will correspond to samples, and massproduction according to your demand. Please contact our account executive, as required. Application Pattern and PCB mounting pattern When the double-row straight pin header is used Precautions 1. Recommended Soldering Condition 2. Board Masking 3. Cleaning Condition 4. Cautions ■Flow Condition by Automatic Soldering Unit Soldering temperature : 255±5ç, Soldering time: within 10 seconds ■Manual Soldering Condition Soldering iron temperature : 340±10ç, Soldering time : within 3 seconds If the automatic soldering unit is used, block the pin header through-hole on the receptacle mounted board with the masking tape, etc., and prevent the flux pervasion. In addition, if much flux is adhered so as to affect the contact, please be sure to clean the board. Refer to Wire-to-Board Connector Use Hand book. ■It is impossible to fix the board to the board by the connector only. Please take actions to fix the board without using the connector. ■If the board deformation could occur due to vibration, please use the gold plating. ■Don't use the connector as the top entry. 7 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MDF7 Series●2.54mm Pitch Bottom Entry Type Connector USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE 2300 Warrenville Road, Suite 150, Downers Grove, IL 60515 Phone : +1-630-282-6700 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 2841 Junction Ave, Suite 200 San Jose, CA. 95134 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 17197 N. Laurel Park Drive, Suite 253, Livonia, MI 48152 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE 300 Brickstone Square Suite 201, Andover, MA 01810 Phone : +1-978-662-5255 THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Schoenbergstr. 20, 73760 ostfildern Phone : +49-711-456002-1 Fax : +49-711-456002-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE Neumeyerstrasse 22-26, 90411 Nurnberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE Bayernstr. 3, Haus C 30855 Langenhagen, Germany Phone : +49-511 97 82 61 30 Fax : +49-511 97 82 61 35 http://www.hirose.com/eu/ FRANCE: HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE 130 Avenue Joseph Kessel, Bat E, 78960 Voisins le Bretonneux, France Phone : +33-1-85764886 Fax : +33-1-85764823 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. (SHANGHAI, HEADQUARTERS) 18, Enterprise Center Tower 2, 209# Gong He Road, Jing’an District, Shanghai, CHINA 200070 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. SHENZHEN BRANCH Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7355 http://www.hirose.com/tw/ KOREA: HIROSE KOREA CO.,LTD. 143, Gongdan 1-daero, Siheung-si, Gyeonggi-do, 15084, Korea Phone : +82-31-496-7000 Fax : +82-31-496-7100 http://www.hirose.co.kr/ SINGAPORE: INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE HIROSE ELECTRIC SINGAPORE PTE. LTD. 03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C, Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India Singapore 079909 Phone : +91-12-660-8018 Phone : +65-6324-6113 Fax : +91-120-4804949 Fax : +65-6324-6123 http://www.hirose.com/sg/ http://www.hirose.com/sg/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma Gandhi (MG) Road, Bangalore 560 001, Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ MALAYSIA: THAILAND: PENANG REPRESENTATIVE OFFICE BANGKOK OFFICE (REPRESENTATIVE OFFICE) 73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn Road, Yannawa, Sathorn, Bangkok 10120 Thailand Lepas Penang, 11950, Malaysia Phone : +66-2-686-1255 Phone : +604-648-5536 Fax : +66-2-686-3433 http://www.hirose.com/sg/ http://www.hirose.com/sg/ ® 8 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 03/2018. Contents are subject to change without notice for the purpose of improvements.
MDF7C-26DP-2.54DSA(55) AI解析
物料型号:HIROSE ELECTRIC CO., LTD. 的 MDF7 系列,2.54mm 间距底部进线型连接器。
器件简介: - 提供了板对板尺寸可自由设置的特性。 - 两个板上的元件安装面不相对,可以同向排列。 - 产品线丰富,包括单排、双排产品,以及镀锡和镀金产品。
引脚分配:根据产品类型(如单排插座、双排插座、单排针头、双排针头),提供了不同的引脚分配和间距。
参数特性: - 电流额定值:3A - 工作温度范围:-35℃ 至 +85℃ - 存储温度范围:-10℃ 至 +60℃ - 电压额定值:250V AC - 操作湿度范围:40% 至 80% - 存储湿度范围:40% 至 70%
功能详解: - 提供了详细的电气特性和机械耐久性测试结果,如绝缘电阻、接触电阻、单次插拔力、振动测试、稳态湿热测试、温度循环测试和耐焊接热测试。
应用信息: - 适用于需要高可靠性的应用,如汽车行业。如需更多信息,请联系公司代表。
封装信息: - 提供了详细的封装尺寸和材料信息,包括插座和针头的绝缘体、接触材料以及镀层(镀锡或镀金)。
产品编号结构:提供了如何根据产品编号确定产品规格的图表,并指导用户在订购时参考目录中列出的产品编号。
注意事项: - 推荐焊接条件、板级屏蔽、清洁条件和使用时的注意事项。
*介绍内容由AI识别生成
MDF7C-26DP-2.54DSA(55) 价格&库存
很抱歉,暂时无法提供与“MDF7C-26DP-2.54DSA(55)”相匹配的价格&库存,您可以联系我们找货
