RWT Series
Stackpole Electronics, Inc.
Thermal Fusing Vertical Mount Resistor
Resistive Product Solutions
Features:
Good anti-surge capability
Wirewound on ceramic element
100% RoHS compliant and lead free without exemption
Halogen free
REACH compliant
Electrical Specifications
Type/Code
Element
Power Rating (W)
@ 70ºC
Element + Fuse
Power Rating (W)
@ 70ºC
Rated Functioning
Temperature
(°C)
Fusing
Current
(A)
TCR (ppm/ºC)
1.5
1.6
2
142
2
± 200
RWT2
2
RWT5
5
RWT7
7
Max Voltage Rating = √ P*R
Ohmic Range (Ω)
and Tolerance
5%
1 - 100
1 - 470
Mechanical Specifications
No.
1
2
3
4
5
6
7
Type/Code
RWT2
RWT5
RWT7
W
0.433
11.00
0.512
13.00
0.512
13.00
H
0.020
0.50
0.039
1.00
0.039
1.00
0.807
20.50
0.984
25.00
1.535
39.00
S
0.059
1.50
0.059
1.50
0.059
1.50
0.276
7.00
0.374
9.50
0.374
9.50
Part Name
Cap
Element core
Resistive Wire
Thermal fuse
Enclosed cement
Ceramic case
Lead wire
L
0.039
1.00
0.039
1.00
0.039
1.00
0.197
5.00
0.197
5.00
0.197
5.00
P
0.020
0.50
0.020
0.50
0.020
0.50
0.197
5.00
0.197
5.00
0.197
5.00
d1
0.039
1.00
0.039
1.00
0.039
1.00
0.024
0.60
0.024
0.60
0.024
0.60
d2
0.002
0.05
0.002
0.05
0.002
0.05
0.031
0.80
0.031
0.80
0.031
0.80
Unit
0.002
0.05
0.002
0.05
0.002
0.05
inches
mm
inches
mm
inches
mm
Performance Characteristics
Test
Short Time Overload
Load Life
Humidity Test (no load)
Humidity Test (rated load)
Resistance to Soldering Heat
Test Method
Apply DV voltage of 2.5 times the rated voltage for 5 seconds.
Apply rated DC voltage for 1.5 hour ON and 0.5 hour OFF. Total time of 1000 hours.
Temperature of 40ºC. Humidity of 90 - 95% RH. Total time of 1000 hours.
Temperature of 40ºC. Humidity of 90 - 95% RH. Apply 1/10 rated power for 1.5 hour ON
Dip lead into solder bath at temperature of 260ºC x 10ºC up to 1.5 mm from the body of the
resistor. Leave in solder bath for 10 seconds. Test after 24 hours in room temperature.
Solderability
Insulation Resistance
Operating Temperature Range : -25ºC to +100ºC
Rev Date: 11/30/2020
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
Test Results
± 2%
± 3%
± 2%
± 2%
± 1%
> 95% coverage
R 217°C
Solder Temp.
Dwell Time at Max.
Ramp DN (°C/sec)
3°C/sec
150 seconds
260°C
30 seconds
6°C/sec
2°C/sec
90 seconds
245°C
15 seconds
3°C/sec
60 seconds
10 seconds
2
www.seielect.com
marketing@seielect.com
RWT Series
Recommended Lead Free Resistor Reflow Profile
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
RWT
Description
Package /
Termination
Type
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Wirewound Leaded Resistor
Radial
YES
100% Matte Sn
Lead-Free
Lead-Free
Effective Date
Mfg. Effective Date
Code
(Std Product Series)
(YY/WW)
Always
Always
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the Eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
3
www.seielect.com
RWT Series
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
1
2
3
4
5
6
7
8
9
10
11
R
W
T
2
A
J
B
1
R
Packaging
Description Size
2
Bulk
5
7
Quantity
1500
1000
800
Product Series
Code Description
RWT Thermal Fuse
Power Rating
Size
W
2
2
5
5
7
7
Code
A
Fuse Type
Description
250V 2A 142ºC
Tolerance
Code Tol
J
5%
Code
B
Resistance Value
Four characters with the
multiplier used as the
decimal holder.
1 ohm = 1R00
10 ohm = 10R0
100 ohm = 100R
4
www.seielect.com
很抱歉,暂时无法提供与“RWT2AJB1R00”相匹配的价格&库存,您可以联系我们找货
