RWT2AJB56R0
RWT2AJB56R0
    SEI
    插件电阻 - 56Ω ±5% 2W ±200ppm/℃
RWT2AJB56R0 数据手册
RWT Series Stackpole Electronics, Inc. Thermal Fusing Vertical Mount Resistor Resistive Product Solutions Features: • • • • • Good anti-surge capability Wirewound on ceramic element 100% RoHS compliant and lead free without exemption Halogen free REACH compliant Electrical Specifications Type/Code Element Power Rating (W) @ 70ºC Element + Fuse Power Rating (W) @ 70ºC Rated Functioning Temperature (°C) Fusing Current (A) TCR (ppm/ºC) 1.5 1.6 2 142 2 ± 200 RWT2 2 RWT5 5 RWT7 7 Max Voltage Rating = √ P*R Ohmic Range (Ω) and Tolerance 5% 1 - 100 1 - 470 Mechanical Specifications No. 1 2 3 4 5 6 7 Type/Code RWT2 RWT5 RWT7 W 0.433 11.00 0.512 13.00 0.512 13.00 ± ± ± ± ± ± H 0.020 0.50 0.039 1.00 0.039 1.00 0.807 20.50 0.984 25.00 1.535 39.00 ± ± ± ± ± ± S 0.059 1.50 0.059 1.50 0.059 1.50 0.276 7.00 0.374 9.50 0.374 9.50 ± ± ± ± ± ± Part Name Cap Element core Resistive Wire Thermal fuse Enclosed cement Ceramic case Lead wire L 0.039 1.00 0.039 1.00 0.039 1.00 0.197 5.00 0.197 5.00 0.197 5.00 ± ± ± ± ± ± P 0.020 0.50 0.020 0.50 0.020 0.50 0.197 5.00 0.197 5.00 0.197 5.00 ± ± ± ± ± ± d1 0.039 1.00 0.039 1.00 0.039 1.00 0.024 0.60 0.024 0.60 0.024 0.60 ± ± ± ± ± ± d2 0.002 0.05 0.002 0.05 0.002 0.05 0.031 0.80 0.031 0.80 0.031 0.80 ± ± ± ± ± ± Unit 0.002 0.05 0.002 0.05 0.002 0.05 inches mm inches mm inches mm Performance Characteristics Test Short Time Overload Load Life Humidity Test (no load) Humidity Test (rated load) Resistance to Soldering Heat Test Method Apply DV voltage of 2.5 times the rated voltage for 5 seconds. Apply rated DC voltage for 1.5 hour ON and 0.5 hour OFF. Total time of 1000 hours. Temperature of 40ºC. Humidity of 90 - 95% RH. Total time of 1000 hours. Temperature of 40ºC. Humidity of 90 - 95% RH. Apply 1/10 rated power for 1.5 hour ON and 0.5 hour OFF. Total time of 1000 hours. Dip lead into solder bath at temperature of 260ºC x 10ºC up to 1.5 mm from the body of the resistor. Leave in solder bath for 10 seconds. Test after 24 hours in room temperature. Solderability Insulation Resistance Operating Temperature Range : -25ºC to +100ºC Rev Date: 11/30/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. Test Results ± 2% ± 3% ± 2% ± 2% ± 1% > 95% coverage R 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec * 60 seconds * 10 seconds * Rev Date: 11/30/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com RWT Series Stackpole Electronics, Inc. Thermal Fusing Vertical Mount Resistor Resistive Product Solutions Recommended Lead Free Resistor Reflow Profile RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series RWT Description Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Thermal Fusing Vertical Mount Wirewound Leaded Resistor Radial YES 100% Matte Sn Lead-Free Lead-Free Effective Date Mfg. Effective Date Code (Std Product Series) (YY/WW) Always Always “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the Eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Rev Date: 11/30/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com RWT Series Stackpole Electronics, Inc. Thermal Fusing Vertical Mount Resistor Resistive Product Solutions Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 11 R W T 2 A J B 1 0 0 R Packaging Description Size 2 Bulk 5 7 Quantity 1500 1000 800 Product Series Code Description RWT Thermal Fuse Power Rating Size W 2 2 5 5 7 7 Code A Fuse Type Description 250V 2A 142ºC Tolerance Code Tol J 5% Code B Resistance Value Four characters with the multiplier used as the decimal holder. 1 ohm = 1R00 10 ohm = 10R0 100 ohm = 100R Rev Date: 11/30/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com
RWT2AJB56R0 价格&库存
很抱歉,暂时无法提供与“RWT2AJB56R0”相匹配的价格&库存,您可以联系我们找货
